CONFIG_64BIT is not set
CONFIG_X86_32=y
CONFIG_X86_64 is not set
CONFIG_X86=y
CONFIG_OUTPUT_FORMAT="elf32-i386"
CONFIG_ARCH_DEFCONFIG="arch/x86/configs/i386_defconfig"
CONFIG_GENERIC_TIME=y
CONFIG_GENERIC_CMOS_UPDATE=y
CONFIG_CLOCKSOURCE_WATCHDOG=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_HAVE_LATENCYTOP_SUPPORT=y
CONFIG_FAST_CMPXCHG_LOCAL=y
CONFIG_MMU=y
CONFIG_ZONE_DMA=y
CONFIG_GENERIC_ISA_DMA=y
CONFIG_GENERIC_IOMAP=y
CONFIG_GENERIC_BUG=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_ARCH_MAY_HAVE_PC_FDC=y
CONFIG_RWSEM_GENERIC_SPINLOCK is not set
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_ARCH_HAS_CPU_IDLE_WAIT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_GENERIC_TIME_VSYSCALL is not set
CONFIG_ARCH_HAS_CPU_RELAX=y
CONFIG_ARCH_HAS_DEFAULT_IDLE=y
CONFIG_ARCH_HAS_CACHE_LINE_SIZE=y
CONFIG_HAVE_SETUP_PER_CPU_AREA=y
CONFIG_HAVE_DYNAMIC_PER_CPU_AREA=y
CONFIG_HAVE_CPUMASK_OF_CPU_MAP is not set
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_ZONE_DMA32 is not set
CONFIG_ARCH_POPULATES_NODE_MAP=y
CONFIG_AUDIT_ARCH is not set
CONFIG_ARCH_SUPPORTS_OPTIMIZED_INLINING=y
CONFIG_ARCH_SUPPORTS_DEBUG_PAGEALLOC=y
CONFIG_GENERIC_HARDIRQS=y
CONFIG_GENERIC_HARDIRQS_NO__DO_IRQ=y
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_GENERIC_PENDING_IRQ=y
CONFIG_USE_GENERIC_SMP_HELPERS=y
CONFIG_X86_32_SMP=y
CONFIG_X86_HT=y
CONFIG_X86_TRAMPOLINE=y
CONFIG_X86_32_LAZY_GS=y
CONFIG_KTIME_SCALAR=y
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
CONFIG_CONSTRUCTORS=y
General setup
CONFIG_EXPERIMENTAL is not set
CONFIG_LOCK_KERNEL=y
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO=y
CONFIG_HAVE_KERNEL_GZIP=y
CONFIG_HAVE_KERNEL_BZIP2=y
CONFIG_HAVE_KERNEL_LZMA=y
CONFIG_KERNEL_GZIP=y
CONFIG_KERNEL_BZIP2 is not set
CONFIG_KERNEL_LZMA is not set
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
CONFIG_BSD_PROCESS_ACCT=y
CONFIG_BSD_PROCESS_ACCT_V3=y
CONFIG_TASKSTATS=y
CONFIG_TASK_DELAY_ACCT=y
CONFIG_TASK_XACCT=y
CONFIG_TASK_IO_ACCOUNTING=y
CONFIG_AUDIT=y
CONFIG_AUDITSYSCALL=y
CONFIG_AUDIT_TREE=y
RCU Subsystem
CONFIG_CLASSIC_RCU is not set
CONFIG_TREE_RCU is not set
CONFIG_PREEMPT_RCU=y
CONFIG_RCU_TRACE is not set
CONFIG_TREE_RCU_TRACE is not set
CONFIG_PREEMPT_RCU_TRACE is not set
CONFIG_IKCONFIG=y
CONFIG_IKCONFIG_PROC=y
CONFIG_LOG_BUF_SHIFT=16
CONFIG_HAVE_UNSTABLE_SCHED_CLOCK=y
CONFIG_CGROUPS=y
CONFIG_CGROUP_DEBUG is not set
CONFIG_CGROUP_NS=y
CONFIG_CGROUP_FREEZER=y
CONFIG_CPUSETS=y
CONFIG_PROC_PID_CPUSET=y
CONFIG_CGROUP_CPUACCT=y
CONFIG_RESOURCE_COUNTERS is not set
CONFIG_SYSFS_DEPRECATED=y
CONFIG_SYSFS_DEPRECATED_V2=y
CONFIG_RELAY=y
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
CONFIG_IPC_NS=y
CONFIG_BLK_DEV_INITRD is not set
CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
CONFIG_EMBEDDED is not set
CONFIG_UID16=y
CONFIG_SYSCTL_SYSCALL=y
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_EXTRA_PASS is not set
CONFIG_HOTPLUG=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_PCSPKR_PLATFORM=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_HAVE_PERF_COUNTERS=y
Performance Counters
CONFIG_PERF_COUNTERS is not set
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_PCI_QUIRKS=y
CONFIG_SLUB_DEBUG=y
CONFIG_STRIP_ASM_SYMS=y
CONFIG_COMPAT_BRK is not set
CONFIG_SLAB is not set
CONFIG_SLUB=y
CONFIG_SLOB is not set
CONFIG_PROFILING=y
CONFIG_TRACEPOINTS=y
CONFIG_MARKERS=y
CONFIG_OPROFILE=m
CONFIG_OPROFILE_IBS=y
CONFIG_HAVE_OPROFILE=y
CONFIG_KPROBES is not set
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
CONFIG_HAVE_IOREMAP_PROT=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_ATTRS=y
CONFIG_HAVE_DMA_API_DEBUG=y
GCOV-based kernel profiling
CONFIG_GCOV_KERNEL is not set
CONFIG_SLOW_WORK is not set
CONFIG_HAVE_GENERIC_DMA_COHERENT=y
CONFIG_SLABINFO=y
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
CONFIG_MODVERSIONS=y
CONFIG_MODULE_SRCVERSION_ALL=y
CONFIG_STOP_MACHINE=y
CONFIG_BLOCK=y
CONFIG_LBDAF=y
CONFIG_BLK_DEV_BSG=y
CONFIG_BLK_DEV_INTEGRITY is not set
IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_AS=m
CONFIG_IOSCHED_DEADLINE=m
CONFIG_IOSCHED_CFQ=y
CONFIG_DEFAULT_AS is not set
CONFIG_DEFAULT_DEADLINE is not set
CONFIG_DEFAULT_CFQ=y
CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED="cfq"
CONFIG_FREEZER=y
Processor type and features
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
CONFIG_SMP=y
CONFIG_SPARSE_IRQ=y
CONFIG_X86_MPPARSE=y
CONFIG_X86_BIGSMP is not set
CONFIG_X86_EXTENDED_PLATFORM=y
CONFIG_X86_ELAN is not set
CONFIG_X86_RDC321X is not set
CONFIG_X86_32_NON_STANDARD is not set
CONFIG_SCHED_OMIT_FRAME_POINTER=y
CONFIG_PARAVIRT_GUEST=y
CONFIG_VMI=y
CONFIG_KVM_CLOCK=y
CONFIG_KVM_GUEST=y
CONFIG_LGUEST_GUEST=y
CONFIG_PARAVIRT=y
CONFIG_PARAVIRT_CLOCK=y
CONFIG_MEMTEST is not set
CONFIG_M386 is not set
CONFIG_M486 is not set
CONFIG_M586 is not set
CONFIG_M586TSC is not set
CONFIG_M586MMX is not set
CONFIG_M686=y
CONFIG_MPENTIUMII is not set
CONFIG_MPENTIUMIII is not set
CONFIG_MPENTIUMM is not set
CONFIG_MPENTIUM4 is not set
CONFIG_MK6 is not set
CONFIG_MK7 is not set
CONFIG_MK8 is not set
CONFIG_MCRUSOE is not set
CONFIG_MEFFICEON is not set
CONFIG_MWINCHIPC6 is not set
CONFIG_MWINCHIP3D is not set
CONFIG_MGEODEGX1 is not set
CONFIG_MGEODE_LX is not set
CONFIG_MCYRIXIII is not set
CONFIG_MVIAC3_2 is not set
CONFIG_MVIAC7 is not set
CONFIG_MPSC is not set
CONFIG_MCORE2 is not set
CONFIG_GENERIC_CPU is not set
CONFIG_X86_GENERIC=y
CONFIG_X86_CPU=y
CONFIG_X86_L1_CACHE_BYTES=64
CONFIG_X86_INTERNODE_CACHE_BYTES=64
CONFIG_X86_CMPXCHG=y
CONFIG_X86_L1_CACHE_SHIFT=5
CONFIG_X86_XADD=y
CONFIG_X86_PPRO_FENCE=y
CONFIG_X86_WP_WORKS_OK=y
CONFIG_X86_INVLPG=y
CONFIG_X86_BSWAP=y
CONFIG_X86_POPAD_OK=y
CONFIG_X86_INTEL_USERCOPY=y
CONFIG_X86_USE_PPRO_CHECKSUM=y
CONFIG_X86_TSC=y
CONFIG_X86_CMOV=y
CONFIG_X86_MINIMUM_CPU_FAMILY=4
CONFIG_X86_DEBUGCTLMSR=y
CONFIG_CPU_SUP_INTEL=y
CONFIG_CPU_SUP_CYRIX_32=y
CONFIG_CPU_SUP_AMD=y
CONFIG_CPU_SUP_CENTAUR=y
CONFIG_CPU_SUP_TRANSMETA_32=y
CONFIG_CPU_SUP_UMC_32=y
CONFIG_X86_DS is not set
CONFIG_HPET_TIMER=y
CONFIG_HPET_EMULATE_RTC=y
CONFIG_DMI=y
CONFIG_IOMMU_HELPER is not set
CONFIG_IOMMU_API is not set
CONFIG_NR_CPUS=2
CONFIG_SCHED_SMT is not set
CONFIG_SCHED_MC is not set
CONFIG_PREEMPT_NONE is not set
CONFIG_PREEMPT_VOLUNTARY is not set
CONFIG_PREEMPT=y
CONFIG_X86_LOCAL_APIC=y
CONFIG_X86_IO_APIC=y
CONFIG_X86_REROUTE_FOR_BROKEN_BOOT_IRQS=y
CONFIG_X86_MCE=y
CONFIG_X86_OLD_MCE is not set
CONFIG_X86_NEW_MCE=y
CONFIG_X86_MCE_INTEL=y
CONFIG_X86_MCE_AMD is not set
CONFIG_X86_ANCIENT_MCE is not set
CONFIG_X86_MCE_THRESHOLD=y
CONFIG_X86_MCE_INJECT is not set
CONFIG_X86_THERMAL_VECTOR=y
CONFIG_VM86=y
CONFIG_TOSHIBA=y
CONFIG_I8K is not set
CONFIG_X86_REBOOTFIXUPS=y
CONFIG_MICROCODE=y
CONFIG_MICROCODE_INTEL=y
CONFIG_MICROCODE_AMD is not set
CONFIG_MICROCODE_OLD_INTERFACE=y
CONFIG_X86_MSR=m
CONFIG_X86_CPUID=m
CONFIG_X86_CPU_DEBUG=m
CONFIG_NOHIGHMEM is not set
CONFIG_HIGHMEM4G=y
CONFIG_HIGHMEM64G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_HIGHMEM=y
CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_PAGEFLAGS_EXTENDED=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_PHYS_ADDR_T_64BIT is not set
CONFIG_ZONE_DMA_FLAG=1
CONFIG_BOUNCE=y
CONFIG_VIRT_TO_BUS=y
CONFIG_HAVE_MLOCK=y
CONFIG_HAVE_MLOCKED_PAGE_BIT=y
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
CONFIG_HIGHPTE=y
CONFIG_X86_CHECK_BIOS_CORRUPTION is not set
CONFIG_X86_RESERVE_LOW_64K is not set
CONFIG_MATH_EMULATION is not set
CONFIG_MTRR=y
CONFIG_MTRR_SANITIZER=y
CONFIG_MTRR_SANITIZER_ENABLE_DEFAULT=0
CONFIG_MTRR_SANITIZER_SPARE_REG_NR_DEFAULT=1
CONFIG_X86_PAT=y
CONFIG_EFI=y
CONFIG_SECCOMP=y
CONFIG_CC_STACKPROTECTOR is not set
CONFIG_HZ_100 is not set
CONFIG_HZ_250 is not set
CONFIG_HZ_300 is not set
CONFIG_HZ_1000=y
CONFIG_HZ=1000
CONFIG_SCHED_HRTICK=y
CONFIG_KEXEC=y
CONFIG_CRASH_DUMP=y
CONFIG_PHYSICAL_START=0x100000
CONFIG_RELOCATABLE is not set
CONFIG_PHYSICAL_ALIGN=0x100000
CONFIG_HOTPLUG_CPU=y
CONFIG_COMPAT_VDSO is not set
CONFIG_CMDLINE_BOOL is not set
CONFIG_ARCH_ENABLE_MEMORY_HOTPLUG=y
Power management and ACPI options
CONFIG_PM=y
CONFIG_PM_DEBUG is not set
CONFIG_PM_SLEEP_SMP=y
CONFIG_PM_SLEEP=y
CONFIG_SUSPEND=y
CONFIG_SUSPEND_FREEZER=y
CONFIG_HIBERNATION_NVS=y
CONFIG_HIBERNATION=y
CONFIG_PM_STD_PARTITION=""
CONFIG_ACPI=y
CONFIG_ACPI_SLEEP=y
CONFIG_ACPI_PROCFS is not set
CONFIG_ACPI_PROCFS_POWER is not set
CONFIG_ACPI_SYSFS_POWER=y
CONFIG_ACPI_PROC_EVENT is not set
CONFIG_ACPI_AC=y
CONFIG_ACPI_BATTERY=y
CONFIG_ACPI_BUTTON=y
CONFIG_ACPI_VIDEO=m
CONFIG_ACPI_FAN=y
CONFIG_ACPI_DOCK=y
CONFIG_ACPI_PROCESSOR=y
CONFIG_ACPI_HOTPLUG_CPU=y
CONFIG_ACPI_THERMAL=y
CONFIG_ACPI_CUSTOM_DSDT is not set
CONFIG_ACPI_BLACKLIST_YEAR=0
CONFIG_ACPI_DEBUG is not set
CONFIG_ACPI_PCI_SLOT=m
CONFIG_X86_PM_TIMER=y
CONFIG_ACPI_CONTAINER=y
CONFIG_ACPI_SBS=m
CONFIG_X86_APM_BOOT=y
CONFIG_APM=y
CONFIG_APM_IGNORE_USER_SUSPEND is not set
CONFIG_APM_DO_ENABLE=y
CONFIG_APM_CPU_IDLE=y
CONFIG_APM_DISPLAY_BLANK is not set
CONFIG_APM_ALLOW_INTS=y
CPU Frequency scaling
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_TABLE=y
CONFIG_CPU_FREQ_DEBUG is not set
CONFIG_CPU_FREQ_STAT is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE=y
CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
CONFIG_CPU_FREQ_GOV_POWERSAVE=y
CONFIG_CPU_FREQ_GOV_USERSPACE=y
CONFIG_CPU_FREQ_GOV_ONDEMAND=y
CONFIG_CPU_FREQ_GOV_CONSERVATIVE=y
CPUFreq processor drivers
CONFIG_X86_ACPI_CPUFREQ=m
CONFIG_X86_POWERNOW_K6 is not set
CONFIG_X86_POWERNOW_K7 is not set
CONFIG_X86_POWERNOW_K8 is not set
CONFIG_X86_GX_SUSPMOD is not set
CONFIG_X86_SPEEDSTEP_CENTRINO is not set
CONFIG_X86_SPEEDSTEP_ICH=y
CONFIG_X86_P4_CLOCKMOD is not set
CONFIG_X86_LONGRUN is not set
CONFIG_X86_LONGHAUL is not set
shared options
CONFIG_X86_SPEEDSTEP_LIB=y
CONFIG_X86_SPEEDSTEP_RELAXED_CAP_CHECK=y
CONFIG_CPU_IDLE=y
CONFIG_CPU_IDLE_GOV_LADDER=y
CONFIG_CPU_IDLE_GOV_MENU=y
Bus options (PCI etc.)
CONFIG_PCI=y
CONFIG_PCI_GOBIOS is not set
CONFIG_PCI_GOMMCONFIG is not set
CONFIG_PCI_GODIRECT is not set
CONFIG_PCI_GOOLPC is not set
CONFIG_PCI_GOANY=y
CONFIG_PCI_BIOS=y
CONFIG_PCI_DIRECT=y
CONFIG_PCI_MMCONFIG=y
CONFIG_PCI_DOMAINS=y
CONFIG_PCIEPORTBUS=y
CONFIG_HOTPLUG_PCI_PCIE is not set
CONFIG_PCIEAER=y
CONFIG_PCIE_ECRC is not set
CONFIG_PCIEAER_INJECT is not set
CONFIG_ARCH_SUPPORTS_MSI=y
CONFIG_PCI_MSI=y
CONFIG_PCI_LEGACY=y
CONFIG_PCI_STUB=y
CONFIG_HT_IRQ=y
CONFIG_PCI_IOV=y
CONFIG_ISA_DMA_API=y
CONFIG_ISA=y
CONFIG_EISA is not set
CONFIG_MCA is not set
CONFIG_SCx200=y
CONFIG_SCx200HR_TIMER=y
CONFIG_OLPC is not set
CONFIG_K8_NB=y
CONFIG_PCCARD=y
CONFIG_PCMCIA_DEBUG is not set
CONFIG_PCMCIA=m
CONFIG_PCMCIA_IOCTL is not set
CONFIG_CARDBUS=y
PC-card bridges
CONFIG_YENTA=m
CONFIG_YENTA_O2=y
CONFIG_YENTA_RICOH=y
CONFIG_YENTA_TI=y
CONFIG_YENTA_ENE_TUNE=y
CONFIG_YENTA_TOSHIBA=y
CONFIG_PD6729=m
CONFIG_I82092=m
CONFIG_I82365=m
CONFIG_TCIC=m
CONFIG_PCMCIA_PROBE=y
CONFIG_PCCARD_NONSTATIC=m
CONFIG_HOTPLUG_PCI=y
CONFIG_HOTPLUG_PCI_FAKE=m
CONFIG_HOTPLUG_PCI_COMPAQ=m
CONFIG_HOTPLUG_PCI_COMPAQ_NVRAM is not set
CONFIG_HOTPLUG_PCI_IBM=m
CONFIG_HOTPLUG_PCI_ACPI=m
CONFIG_HOTPLUG_PCI_ACPI_IBM=m
CONFIG_HOTPLUG_PCI_CPCI=y
CONFIG_HOTPLUG_PCI_CPCI_ZT5550=m
CONFIG_HOTPLUG_PCI_CPCI_GENERIC=m
CONFIG_HOTPLUG_PCI_SHPC=m
Executable file formats / Emulations
CONFIG_BINFMT_ELF=y
CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
CONFIG_HAVE_AOUT=y
CONFIG_BINFMT_AOUT=y
CONFIG_BINFMT_MISC=y
CONFIG_HAVE_ATOMIC_IOMAP=y
CONFIG_NET=y
Networking options
CONFIG_PACKET=y
CONFIG_PACKET_MMAP=y
CONFIG_UNIX=y
CONFIG_XFRM=y
CONFIG_XFRM_USER=m
CONFIG_XFRM_IPCOMP=m
CONFIG_NET_KEY=m
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_FIB_HASH=y
CONFIG_IP_PNP is not set
CONFIG_NET_IPIP=m
CONFIG_NET_IPGRE=m
CONFIG_NET_IPGRE_BROADCAST=y
CONFIG_IP_MROUTE=y
CONFIG_IP_PIMSM_V1=y
CONFIG_IP_PIMSM_V2=y
CONFIG_ARPD is not set
CONFIG_SYN_COOKIES=y
CONFIG_INET_AH=m
CONFIG_INET_ESP=m
CONFIG_INET_IPCOMP=m
CONFIG_INET_XFRM_TUNNEL=m
CONFIG_INET_TUNNEL=m
CONFIG_INET_XFRM_MODE_TRANSPORT=m
CONFIG_INET_XFRM_MODE_TUNNEL=m
CONFIG_INET_XFRM_MODE_BEET=m
CONFIG_INET_LRO=y
CONFIG_INET_DIAG=m
CONFIG_INET_TCP_DIAG=m
CONFIG_TCP_CONG_ADVANCED=y
CONFIG_TCP_CONG_BIC=m
CONFIG_TCP_CONG_CUBIC=y
CONFIG_TCP_CONG_WESTWOOD=m
CONFIG_TCP_CONG_HTCP=m
CONFIG_DEFAULT_BIC is not set
CONFIG_DEFAULT_CUBIC=y
CONFIG_DEFAULT_HTCP is not set
CONFIG_DEFAULT_VEGAS is not set
CONFIG_DEFAULT_WESTWOOD is not set
CONFIG_DEFAULT_RENO is not set
CONFIG_DEFAULT_TCP_CONG=“cubic”
CONFIG_IPV6 is not set
CONFIG_NETLABEL=y
CONFIG_NETWORK_SECMARK=y
CONFIG_NETFILTER=y
CONFIG_NETFILTER_DEBUG is not set
CONFIG_NETFILTER_ADVANCED=y
CONFIG_BRIDGE_NETFILTER=y
[color=#FF0000]
Core Netfilter Configuration
CONFIG_NETFILTER_NETLINK=m
CONFIG_NETFILTER_NETLINK_QUEUE=m
CONFIG_NETFILTER_NETLINK_LOG=m
CONFIG_NF_CONNTRACK=m
CONFIG_NF_CT_ACCT=y
CONFIG_NF_CONNTRACK_MARK=y
CONFIG_NF_CONNTRACK_SECMARK=y
CONFIG_NF_CONNTRACK_EVENTS=y
CONFIG_NF_CT_PROTO_GRE=m
CONFIG_NF_CT_PROTO_UDPLITE=m
CONFIG_NF_CONNTRACK_AMANDA=m
CONFIG_NF_CONNTRACK_FTP=m
CONFIG_NF_CONNTRACK_H323=m
CONFIG_NF_CONNTRACK_IRC=m
CONFIG_NF_CONNTRACK_NETBIOS_NS=m
CONFIG_NF_CONNTRACK_PPTP=m
CONFIG_NF_CONNTRACK_SIP=m
CONFIG_NF_CONNTRACK_TFTP=m
CONFIG_NF_CT_NETLINK=m
CONFIG_NETFILTER_XTABLES=m
CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
CONFIG_NETFILTER_XT_TARGET_CONNMARK=m
CONFIG_NETFILTER_XT_TARGET_CONNSECMARK=m
CONFIG_NETFILTER_XT_TARGET_DSCP=m
CONFIG_NETFILTER_XT_TARGET_HL=m
CONFIG_NETFILTER_XT_TARGET_LED=m
CONFIG_NETFILTER_XT_TARGET_MARK=m
CONFIG_NETFILTER_XT_TARGET_NFLOG=m
CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
CONFIG_NETFILTER_XT_TARGET_NOTRACK=m
CONFIG_NETFILTER_XT_TARGET_RATEEST=m
CONFIG_NETFILTER_XT_TARGET_TRACE=m
CONFIG_NETFILTER_XT_TARGET_SECMARK=m
CONFIG_NETFILTER_XT_TARGET_TCPMSS=m
CONFIG_NETFILTER_XT_MATCH_CLUSTER=m
CONFIG_NETFILTER_XT_MATCH_COMMENT=m
CONFIG_NETFILTER_XT_MATCH_CONNBYTES=m
CONFIG_NETFILTER_XT_MATCH_CONNLIMIT=m
CONFIG_NETFILTER_XT_MATCH_CONNMARK=m
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=m
CONFIG_NETFILTER_XT_MATCH_DCCP=m
CONFIG_NETFILTER_XT_MATCH_DSCP=m
CONFIG_NETFILTER_XT_MATCH_ESP=m
CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m
CONFIG_NETFILTER_XT_MATCH_HELPER=m
CONFIG_NETFILTER_XT_MATCH_HL=m
CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
CONFIG_NETFILTER_XT_MATCH_LENGTH=m
CONFIG_NETFILTER_XT_MATCH_LIMIT=m
CONFIG_NETFILTER_XT_MATCH_MAC=m
CONFIG_NETFILTER_XT_MATCH_MARK=m
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=m
CONFIG_NETFILTER_XT_MATCH_OWNER=m
CONFIG_NETFILTER_XT_MATCH_POLICY=m
CONFIG_NETFILTER_XT_MATCH_PHYSDEV=m
CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
CONFIG_NETFILTER_XT_MATCH_QUOTA=m
CONFIG_NETFILTER_XT_MATCH_RATEEST=m
CONFIG_NETFILTER_XT_MATCH_REALM=m
CONFIG_NETFILTER_XT_MATCH_RECENT=m
CONFIG_NETFILTER_XT_MATCH_RECENT_PROC_COMPAT is not set
CONFIG_NETFILTER_XT_MATCH_STATE=m
CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
CONFIG_NETFILTER_XT_MATCH_STRING=m
CONFIG_NETFILTER_XT_MATCH_TCPMSS=m
CONFIG_NETFILTER_XT_MATCH_TIME=m
CONFIG_NETFILTER_XT_MATCH_U32=m
CONFIG_NETFILTER_XT_MATCH_OSF is not set
CONFIG_IP_VS=m
CONFIG_IP_VS_DEBUG is not set
CONFIG_IP_VS_TAB_BITS=12
IPVS transport protocol load balancing support
CONFIG_IP_VS_PROTO_TCP=y
CONFIG_IP_VS_PROTO_UDP=y
CONFIG_IP_VS_PROTO_AH_ESP=y
CONFIG_IP_VS_PROTO_ESP=y
CONFIG_IP_VS_PROTO_AH=y
IPVS scheduler
CONFIG_IP_VS_RR=m
CONFIG_IP_VS_WRR=m
CONFIG_IP_VS_LC=m
CONFIG_IP_VS_WLC=m
CONFIG_IP_VS_LBLC=m
CONFIG_IP_VS_LBLCR=m
CONFIG_IP_VS_DH=m
CONFIG_IP_VS_SH=m
CONFIG_IP_VS_SED=m
CONFIG_IP_VS_NQ=m
IPVS application helper
CONFIG_IP_VS_FTP=m
IP: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV4=m
CONFIG_NF_CONNTRACK_IPV4=m
CONFIG_NF_CONNTRACK_PROC_COMPAT=y
CONFIG_IP_NF_QUEUE=m
CONFIG_IP_NF_IPTABLES=m
CONFIG_IP_NF_MATCH_ADDRTYPE=m
CONFIG_IP_NF_MATCH_AH=m
CONFIG_IP_NF_MATCH_ECN=m
CONFIG_IP_NF_MATCH_TTL=m
CONFIG_IP_NF_FILTER=m
CONFIG_IP_NF_TARGET_REJECT=m
CONFIG_IP_NF_TARGET_LOG=m
CONFIG_IP_NF_TARGET_ULOG=m
CONFIG_NF_NAT=m
CONFIG_NF_NAT_NEEDED=y
CONFIG_IP_NF_TARGET_MASQUERADE=m
CONFIG_IP_NF_TARGET_NETMAP=m
CONFIG_IP_NF_TARGET_REDIRECT=m
CONFIG_NF_NAT_SNMP_BASIC=m
CONFIG_NF_NAT_PROTO_GRE=m
CONFIG_NF_NAT_PROTO_UDPLITE=m
CONFIG_NF_NAT_FTP=m
CONFIG_NF_NAT_IRC=m
CONFIG_NF_NAT_TFTP=m
CONFIG_NF_NAT_AMANDA=m
CONFIG_NF_NAT_PPTP=m
CONFIG_NF_NAT_H323=m
CONFIG_NF_NAT_SIP=m
CONFIG_IP_NF_MANGLE=m
CONFIG_IP_NF_TARGET_ECN=m
CONFIG_IP_NF_TARGET_TTL=m
CONFIG_IP_NF_RAW=m
CONFIG_IP_NF_SECURITY=m
CONFIG_IP_NF_ARPTABLES=m
CONFIG_IP_NF_ARPFILTER=m
CONFIG_IP_NF_ARP_MANGLE=m
CONFIG_BRIDGE_NF_EBTABLES=m
CONFIG_BRIDGE_EBT_BROUTE=m
CONFIG_BRIDGE_EBT_T_FILTER=m
CONFIG_BRIDGE_EBT_T_NAT=m
CONFIG_BRIDGE_EBT_802_3=m
CONFIG_BRIDGE_EBT_AMONG=m
CONFIG_BRIDGE_EBT_ARP=m
CONFIG_BRIDGE_EBT_IP=m
CONFIG_BRIDGE_EBT_LIMIT=m
CONFIG_BRIDGE_EBT_MARK=m
CONFIG_BRIDGE_EBT_PKTTYPE=m
CONFIG_BRIDGE_EBT_STP=m
CONFIG_BRIDGE_EBT_VLAN=m
CONFIG_BRIDGE_EBT_ARPREPLY=m
CONFIG_BRIDGE_EBT_DNAT=m
CONFIG_BRIDGE_EBT_MARK_T=m
CONFIG_BRIDGE_EBT_REDIRECT=m
CONFIG_BRIDGE_EBT_SNAT=m
CONFIG_BRIDGE_EBT_LOG=m
CONFIG_BRIDGE_EBT_ULOG=m
CONFIG_BRIDGE_EBT_NFLOG=m
CONFIG_ATM=m
CONFIG_ATM_CLIP=m
CONFIG_ATM_CLIP_NO_ICMP is not set
CONFIG_ATM_LANE is not set
CONFIG_ATM_BR2684=m
CONFIG_ATM_BR2684_IPFILTER is not set
CONFIG_STP=m
CONFIG_BRIDGE=m
CONFIG_VLAN_8021Q is not set
CONFIG_DECNET=m
CONFIG_LLC=m
CONFIG_LLC2=m
CONFIG_IPX=m
CONFIG_IPX_INTERN is not set
CONFIG_ATALK is not set
CONFIG_PHONET is not set
CONFIG_NET_SCHED is not set
CONFIG_NET_CLS_ROUTE=y
CONFIG_DCB=y
Network testing
CONFIG_NET_PKTGEN=y
CONFIG_HAMRADIO is not set
CONFIG_CAN=m
CONFIG_CAN_RAW=m
CONFIG_CAN_BCM=m
CAN Device Drivers
CONFIG_CAN_VCAN=m
CONFIG_CAN_DEV is not set
CONFIG_CAN_DEBUG_DEVICES is not set
CONFIG_IRDA is not set
CONFIG_BT=m
CONFIG_BT_L2CAP=m
CONFIG_BT_SCO=m
CONFIG_BT_RFCOMM=m
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=m
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
CONFIG_BT_HIDP=m[/color]
Bluetooth device drivers
CONFIG_BT_HCIBTUSB=m
CONFIG_BT_HCIBTSDIO=m
CONFIG_BT_HCIUART=m
CONFIG_BT_HCIUART_H4=y
CONFIG_BT_HCIUART_BCSP=y
CONFIG_BT_HCIUART_LL=y
CONFIG_BT_HCIBCM203X=m
CONFIG_BT_HCIBPA10X=m
CONFIG_BT_HCIBFUSB=m
CONFIG_BT_HCIDTL1=m
CONFIG_BT_HCIBT3C=m
CONFIG_BT_HCIBLUECARD=m
CONFIG_BT_HCIBTUART=m
CONFIG_BT_HCIVHCI=m
CONFIG_WIRELESS=y
CONFIG_CFG80211=m
CONFIG_CFG80211_REG_DEBUG is not set
CONFIG_CFG80211_DEBUGFS is not set
CONFIG_WIRELESS_OLD_REGULATORY is not set
CONFIG_WIRELESS_EXT=y
CONFIG_WIRELESS_EXT_SYSFS is not set
CONFIG_LIB80211=y
CONFIG_LIB80211_CRYPT_WEP=y
CONFIG_LIB80211_CRYPT_CCMP=y
CONFIG_LIB80211_CRYPT_TKIP=y
CONFIG_LIB80211_DEBUG is not set
CONFIG_MAC80211=m
CONFIG_MAC80211_DEFAULT_PS=y
CONFIG_MAC80211_DEFAULT_PS_VALUE=1
Rate control algorithm selection
CONFIG_MAC80211_RC_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT_PID is not set
CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT="minstrel"
CONFIG_MAC80211_LEDS=y
CONFIG_MAC80211_DEBUGFS is not set
CONFIG_MAC80211_DEBUG_MENU is not set
CONFIG_WIMAX is not set
CONFIG_RFKILL is not set
Device Drivers
Generic Driver Options
CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug"
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=y
CONFIG_FIRMWARE_IN_KERNEL is not set
CONFIG_SYS_HYPERVISOR is not set
CONFIG_CONNECTOR=m
CONFIG_MTD=m
CONFIG_MTD_DEBUG is not set
CONFIG_MTD_CONCAT=m
CONFIG_MTD_PARTITIONS=y
CONFIG_MTD_TESTS is not set
CONFIG_MTD_REDBOOT_PARTS=m
CONFIG_MTD_REDBOOT_DIRECTORY_BLOCK=-1
CONFIG_MTD_REDBOOT_PARTS_UNALLOCATED is not set
CONFIG_MTD_REDBOOT_PARTS_READONLY is not set
CONFIG_MTD_AR7_PARTS=m
#[color=#FF0000]
User Modules And Translation Layers
CONFIG_MTD_CHAR=m
CONFIG_HAVE_MTD_OTP=y
CONFIG_MTD_BLKDEVS=m
CONFIG_MTD_BLOCK=m
CONFIG_MTD_BLOCK_RO=m
CONFIG_FTL=m
CONFIG_NFTL=m
CONFIG_NFTL_RW=y
CONFIG_INFTL=m
CONFIG_RFD_FTL=m
CONFIG_SSFDC=m
CONFIG_MTD_OOPS=m
RAM/ROM/Flash chip drivers
CONFIG_MTD_CFI=m
CONFIG_MTD_JEDECPROBE=m
CONFIG_MTD_GEN_PROBE=m
CONFIG_MTD_CFI_ADV_OPTIONS is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
CONFIG_MTD_CFI_I4 is not set
CONFIG_MTD_CFI_I8 is not set
CONFIG_MTD_CFI_INTELEXT=m
CONFIG_MTD_CFI_AMDSTD=m
CONFIG_MTD_CFI_STAA=m
CONFIG_MTD_CFI_UTIL=m
CONFIG_MTD_RAM=m
CONFIG_MTD_ROM=m
CONFIG_MTD_ABSENT=m
Mapping drivers for chip access
CONFIG_MTD_COMPLEX_MAPPINGS=y
CONFIG_MTD_PHYSMAP=m
CONFIG_MTD_PHYSMAP_COMPAT is not set
CONFIG_MTD_SC520CDP=m
CONFIG_MTD_NETSC520=m
CONFIG_MTD_TS5500=m
CONFIG_MTD_SBC_GXX=m
CONFIG_MTD_SCx200_DOCFLASH=m
CONFIG_MTD_AMD76XROM=m
CONFIG_MTD_ICHXROM=m
CONFIG_MTD_ESB2ROM=m
CONFIG_MTD_CK804XROM=m
CONFIG_MTD_SCB2_FLASH=m
CONFIG_MTD_NETtel=m
CONFIG_MTD_L440GX=m
CONFIG_MTD_PCI=m
CONFIG_MTD_INTEL_VR_NOR=m
CONFIG_MTD_PLATRAM=m
Self-contained MTD device drivers
CONFIG_MTD_PMC551=m
CONFIG_MTD_PMC551_BUGFIX is not set
CONFIG_MTD_PMC551_DEBUG is not set
CONFIG_MTD_SLRAM=m
CONFIG_MTD_PHRAM=m
CONFIG_MTD_MTDRAM=m
CONFIG_MTDRAM_TOTAL_SIZE=4096
CONFIG_MTDRAM_ERASE_SIZE=128
CONFIG_MTD_BLOCK2MTD=m
Disk-On-Chip Device Drivers
CONFIG_MTD_DOC2000=m
CONFIG_MTD_DOC2001=m
CONFIG_MTD_DOC2001PLUS=m
CONFIG_MTD_DOCPROBE=m
CONFIG_MTD_DOCECC=m
CONFIG_MTD_DOCPROBE_ADVANCED is not set
CONFIG_MTD_DOCPROBE_ADDRESS=0
CONFIG_MTD_NAND=m
CONFIG_MTD_NAND_VERIFY_WRITE is not set
CONFIG_MTD_NAND_ECC_SMC is not set
CONFIG_MTD_NAND_MUSEUM_IDS is not set
CONFIG_MTD_NAND_IDS=m
CONFIG_MTD_NAND_CAFE=m
CONFIG_MTD_NAND_CS553X=m
CONFIG_MTD_NAND_NANDSIM=m
CONFIG_MTD_NAND_PLATFORM=m
CONFIG_MTD_ALAUDA=m
CONFIG_MTD_ONENAND=m
CONFIG_MTD_ONENAND_VERIFY_WRITE=y
CONFIG_MTD_ONENAND_OTP=y
CONFIG_MTD_ONENAND_2X_PROGRAM=y
CONFIG_MTD_ONENAND_SIM=m
LPDDR flash memory drivers
CONFIG_MTD_LPDDR=m
CONFIG_MTD_QINFO_PROBE=m
UBI - Unsorted block images
CONFIG_MTD_UBI=m
CONFIG_MTD_UBI_WL_THRESHOLD=4096
CONFIG_MTD_UBI_BEB_RESERVE=1
CONFIG_MTD_UBI_GLUEBI is not set
UBI debugging options
CONFIG_MTD_UBI_DEBUG is not set
CONFIG_PARPORT is not set
CONFIG_PNP=y
CONFIG_PNP_DEBUG_MESSAGES is not set
[/color]
Protocols
CONFIG_ISAPNP=y
CONFIG_PNPACPI=y
CONFIG_BLK_DEV=y
CONFIG_BLK_DEV_FD=y
CONFIG_BLK_DEV_XD is not set
CONFIG_BLK_CPQ_DA=m
CONFIG_BLK_CPQ_CISS_DA=m
CONFIG_CISS_SCSI_TAPE=y
CONFIG_BLK_DEV_DAC960=m
CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=y
CONFIG_BLK_DEV_CRYPTOLOOP=m
CONFIG_BLK_DEV_NBD=m
CONFIG_BLK_DEV_OSD is not set
CONFIG_BLK_DEV_SX8=y
CONFIG_BLK_DEV_UB=y
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=4096
CONFIG_BLK_DEV_XIP=y
CONFIG_CDROM_PKTCDVD=y
CONFIG_CDROM_PKTCDVD_BUFFERS=8
CONFIG_ATA_OVER_ETH=m
CONFIG_BLK_DEV_HD is not set
CONFIG_MISC_DEVICES=y
CONFIG_PHANTOM=m
CONFIG_SGI_IOC4=m
CONFIG_ENCLOSURE_SERVICES=m
CONFIG_HP_ILO=m
CONFIG_ISL29003=m
[color=#FF0000]
EEPROM support
CONFIG_EEPROM_AT24=m
CONFIG_EEPROM_AT25=m
CONFIG_EEPROM_LEGACY=m
CONFIG_EEPROM_93CX6=m[/color]
CONFIG_CB710_CORE is not set
CONFIG_HAVE_IDE=y
CONFIG_IDE=y
Please see Documentation/ide/ide.txt for help/info on IDE drives
CONFIG_BLK_DEV_IDE_SATA is not set
CONFIG_IDE_GD=y
CONFIG_IDE_GD_ATA=y
CONFIG_IDE_GD_ATAPI is not set
CONFIG_BLK_DEV_IDECS is not set
CONFIG_BLK_DEV_DELKIN is not set
CONFIG_BLK_DEV_IDECD is not set
CONFIG_BLK_DEV_IDETAPE is not set
CONFIG_BLK_DEV_IDEACPI is not set
CONFIG_IDE_TASK_IOCTL is not set
CONFIG_IDE_PROC_FS=y
IDE chipset support/bugfixes
CONFIG_IDE_GENERIC is not set
CONFIG_BLK_DEV_PLATFORM is not set
CONFIG_BLK_DEV_CMD640 is not set
CONFIG_BLK_DEV_IDEPNP is not set
PCI IDE chipsets support
CONFIG_BLK_DEV_GENERIC is not set
CONFIG_BLK_DEV_RZ1000 is not set
CONFIG_BLK_DEV_AEC62XX is not set
CONFIG_BLK_DEV_ALI15X3 is not set
CONFIG_BLK_DEV_AMD74XX is not set
CONFIG_BLK_DEV_ATIIXP is not set
CONFIG_BLK_DEV_CMD64X is not set
CONFIG_BLK_DEV_TRIFLEX is not set
CONFIG_BLK_DEV_CS5530 is not set
CONFIG_BLK_DEV_CS5535 is not set
CONFIG_BLK_DEV_CS5536 is not set
CONFIG_BLK_DEV_HPT366 is not set
CONFIG_BLK_DEV_JMICRON is not set
CONFIG_BLK_DEV_SC1200 is not set
CONFIG_BLK_DEV_PIIX is not set
CONFIG_BLK_DEV_IT8172 is not set
CONFIG_BLK_DEV_IT8213 is not set
CONFIG_BLK_DEV_IT821X is not set
CONFIG_BLK_DEV_NS87415 is not set
CONFIG_BLK_DEV_PDC202XX_OLD is not set
CONFIG_BLK_DEV_PDC202XX_NEW is not set
CONFIG_BLK_DEV_SVWKS is not set
CONFIG_BLK_DEV_SIIMAGE is not set
CONFIG_BLK_DEV_SIS5513 is not set
CONFIG_BLK_DEV_SLC90E66 is not set
CONFIG_BLK_DEV_TRM290 is not set
CONFIG_BLK_DEV_VIA82CXXX is not set
CONFIG_BLK_DEV_TC86C001 is not set
Other IDE chipsets support
Note: most of these also require special kernel boot parameters
CONFIG_BLK_DEV_4DRIVES is not set
CONFIG_BLK_DEV_ALI14XX is not set
CONFIG_BLK_DEV_DTC2278 is not set
CONFIG_BLK_DEV_HT6560B is not set
CONFIG_BLK_DEV_QD65XX is not set
CONFIG_BLK_DEV_UMC8672 is not set
CONFIG_BLK_DEV_IDEDMA is not set
SCSI device support
CONFIG_RAID_ATTRS=y
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
CONFIG_SCSI_TGT=m
CONFIG_SCSI_NETLINK=y
CONFIG_SCSI_PROC_FS=y
SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
CONFIG_CHR_DEV_ST=y
CONFIG_CHR_DEV_OSST=y
CONFIG_BLK_DEV_SR=y
CONFIG_BLK_DEV_SR_VENDOR=y
CONFIG_CHR_DEV_SG=y
CONFIG_CHR_DEV_SCH=y
CONFIG_SCSI_ENCLOSURE=m
CONFIG_SCSI_MULTI_LUN=y
CONFIG_SCSI_CONSTANTS=y
CONFIG_SCSI_LOGGING=y
CONFIG_SCSI_SCAN_ASYNC=y
CONFIG_SCSI_WAIT_SCAN=m
SCSI Transports
CONFIG_SCSI_SPI_ATTRS=y
CONFIG_SCSI_FC_ATTRS=y
CONFIG_SCSI_ISCSI_ATTRS=y
CONFIG_SCSI_SAS_ATTRS=y
CONFIG_SCSI_SAS_LIBSAS=y
CONFIG_SCSI_SAS_ATA=y
CONFIG_SCSI_SAS_HOST_SMP=y
CONFIG_SCSI_SAS_LIBSAS_DEBUG is not set
CONFIG_SCSI_SRP_ATTRS=y
CONFIG_SCSI_LOWLEVEL=y
CONFIG_ISCSI_TCP=m
CONFIG_SCSI_BNX2_ISCSI is not set
CONFIG_BLK_DEV_3W_XXXX_RAID=m
CONFIG_SCSI_3W_9XXX=m
CONFIG_SCSI_7000FASST=m
CONFIG_SCSI_ACARD=m
CONFIG_SCSI_AHA152X=m
CONFIG_SCSI_AHA1542=m
CONFIG_SCSI_AACRAID=m
CONFIG_SCSI_AIC7XXX=m
CONFIG_AIC7XXX_CMDS_PER_DEVICE=8
CONFIG_AIC7XXX_RESET_DELAY_MS=15000
CONFIG_AIC7XXX_DEBUG_ENABLE is not set
CONFIG_AIC7XXX_DEBUG_MASK=0
CONFIG_AIC7XXX_REG_PRETTY_PRINT is not set
CONFIG_SCSI_AIC7XXX_OLD is not set
CONFIG_SCSI_AIC79XX=m
CONFIG_AIC79XX_CMDS_PER_DEVICE=32
CONFIG_AIC79XX_RESET_DELAY_MS=15000
CONFIG_AIC79XX_DEBUG_ENABLE is not set
CONFIG_AIC79XX_DEBUG_MASK=0
CONFIG_AIC79XX_REG_PRETTY_PRINT is not set
CONFIG_SCSI_AIC94XX=m
CONFIG_AIC94XX_DEBUG is not set
CONFIG_SCSI_MVSAS=m
CONFIG_SCSI_MVSAS_DEBUG=y
CONFIG_SCSI_DPT_I2O=m
CONFIG_SCSI_ADVANSYS=m
CONFIG_SCSI_IN2000=m
CONFIG_SCSI_ARCMSR=m
CONFIG_SCSI_ARCMSR_AER is not set
CONFIG_MEGARAID_NEWGEN=y
CONFIG_MEGARAID_MM=m
CONFIG_MEGARAID_MAILBOX=m
CONFIG_MEGARAID_LEGACY=m
CONFIG_MEGARAID_SAS=m
CONFIG_SCSI_MPT2SAS=m
CONFIG_SCSI_MPT2SAS_MAX_SGE=128
CONFIG_SCSI_MPT2SAS_LOGGING is not set
CONFIG_SCSI_HPTIOP=m
CONFIG_SCSI_BUSLOGIC=m
CONFIG_SCSI_FLASHPOINT=y
CONFIG_LIBFC=m
CONFIG_LIBFCOE=m
CONFIG_FCOE=m
CONFIG_FCOE_FNIC=m
CONFIG_SCSI_DMX3191D=m
CONFIG_SCSI_DTC3280=m
CONFIG_SCSI_EATA=m
CONFIG_SCSI_EATA_TAGGED_QUEUE=y
CONFIG_SCSI_EATA_LINKED_COMMANDS=y
CONFIG_SCSI_EATA_MAX_TAGS=16
CONFIG_SCSI_FUTURE_DOMAIN=m
CONFIG_SCSI_GDTH=m
CONFIG_SCSI_GENERIC_NCR5380=m
CONFIG_SCSI_GENERIC_NCR5380_MMIO=m
CONFIG_SCSI_GENERIC_NCR53C400=y
CONFIG_SCSI_IPS=m
CONFIG_SCSI_INITIO=m
CONFIG_SCSI_INIA100=m
CONFIG_SCSI_NCR53C406A=m
CONFIG_SCSI_STEX=m
CONFIG_SCSI_SYM53C8XX_2=m
CONFIG_SCSI_SYM53C8XX_DMA_ADDRESSING_MODE=1
CONFIG_SCSI_SYM53C8XX_DEFAULT_TAGS=16
CONFIG_SCSI_SYM53C8XX_MAX_TAGS=64
CONFIG_SCSI_SYM53C8XX_MMIO=y
CONFIG_SCSI_IPR=m
CONFIG_SCSI_IPR_TRACE is not set
CONFIG_SCSI_IPR_DUMP is not set
CONFIG_SCSI_PAS16=m
CONFIG_SCSI_QLOGIC_FAS=m
CONFIG_SCSI_QLOGIC_1280=m
CONFIG_SCSI_QLA_FC=m
CONFIG_SCSI_QLA_ISCSI=m
CONFIG_SCSI_LPFC=m
CONFIG_SCSI_LPFC_DEBUG_FS is not set
CONFIG_SCSI_SYM53C416=m
CONFIG_SCSI_DC390T=m
CONFIG_SCSI_T128=m
CONFIG_SCSI_U14_34F=m
CONFIG_SCSI_U14_34F_TAGGED_QUEUE=y
CONFIG_SCSI_U14_34F_LINKED_COMMANDS=y
CONFIG_SCSI_U14_34F_MAX_TAGS=8
CONFIG_SCSI_ULTRASTOR=m
CONFIG_SCSI_NSP32=m
CONFIG_SCSI_DEBUG is not set
CONFIG_SCSI_SRP=m
CONFIG_SCSI_LOWLEVEL_PCMCIA=y
CONFIG_PCMCIA_AHA152X=m
CONFIG_PCMCIA_FDOMAIN=m
CONFIG_PCMCIA_NINJA_SCSI=m
CONFIG_PCMCIA_QLOGIC=m
CONFIG_PCMCIA_SYM53C500=m
CONFIG_SCSI_DH=y
CONFIG_SCSI_DH_RDAC=y
CONFIG_SCSI_DH_HP_SW=y
CONFIG_SCSI_DH_EMC=y
CONFIG_SCSI_OSD_INITIATOR=m
CONFIG_SCSI_OSD_ULD=m
CONFIG_SCSI_OSD_DPRINT_SENSE=1
CONFIG_SCSI_OSD_DEBUG is not set
CONFIG_ATA=y
CONFIG_ATA_NONSTANDARD is not set
CONFIG_ATA_ACPI=y
CONFIG_SATA_PMP=y
CONFIG_SATA_AHCI=y
CONFIG_SATA_SIL24=m
CONFIG_ATA_SFF=y
CONFIG_SATA_SVW=m
CONFIG_ATA_PIIX=y
CONFIG_SATA_MV is not set
CONFIG_SATA_NV is not set
CONFIG_PDC_ADMA is not set
CONFIG_SATA_QSTOR is not set
CONFIG_SATA_PROMISE is not set
CONFIG_SATA_SIL is not set
CONFIG_SATA_SIS is not set
CONFIG_SATA_ULI is not set
CONFIG_SATA_VIA is not set
CONFIG_SATA_VITESSE is not set
CONFIG_SATA_INIC162X is not set
CONFIG_PATA_ACPI=y
CONFIG_PATA_ALI is not set
CONFIG_PATA_AMD is not set
CONFIG_PATA_ARTOP is not set
CONFIG_PATA_ATIIXP is not set
CONFIG_PATA_CMD64X is not set
CONFIG_PATA_CS5520 is not set
CONFIG_PATA_CS5530 is not set
CONFIG_PATA_CS5536 is not set
CONFIG_PATA_EFAR is not set
CONFIG_ATA_GENERIC=y
CONFIG_PATA_HPT366 is not set
CONFIG_PATA_HPT3X3 is not set
CONFIG_PATA_ISAPNP is not set
CONFIG_PATA_IT821X is not set
CONFIG_PATA_JMICRON is not set
CONFIG_PATA_TRIFLEX is not set
CONFIG_PATA_MARVELL is not set
CONFIG_PATA_MPIIX is not set
CONFIG_PATA_OLDPIIX is not set
CONFIG_PATA_NETCELL is not set
CONFIG_PATA_NS87410 is not set
CONFIG_PATA_NS87415 is not set
CONFIG_PATA_PCMCIA=m
CONFIG_PATA_PDC_OLD=y
CONFIG_PATA_QDI is not set
CONFIG_PATA_RZ1000 is not set
CONFIG_PATA_SC1200 is not set
CONFIG_PATA_SERVERWORKS is not set
CONFIG_PATA_PDC2027X is not set
CONFIG_PATA_SIL680 is not set
CONFIG_PATA_SIS is not set
CONFIG_PATA_VIA is not set
CONFIG_PATA_WINBOND is not set
CONFIG_PATA_SCH=y
CONFIG_MD=y
CONFIG_BLK_DEV_MD is not set
CONFIG_BLK_DEV_DM=m
CONFIG_DM_DEBUG is not set
CONFIG_DM_CRYPT is not set
CONFIG_DM_SNAPSHOT=m
CONFIG_DM_MIRROR=m
CONFIG_DM_ZERO=m
CONFIG_DM_MULTIPATH=m
CONFIG_DM_MULTIPATH_QL=m
CONFIG_DM_MULTIPATH_ST=m
CONFIG_FUSION=y
CONFIG_FUSION_SPI=y
CONFIG_FUSION_FC=y
CONFIG_FUSION_SAS=y
CONFIG_FUSION_MAX_SGE=40
CONFIG_FUSION_CTL=y
CONFIG_FUSION_LOGGING is not set
IEEE 1394 (FireWire) support
You can enable one or both FireWire driver stacks.
#[color=#FF0000]
See the help texts for more information.
CONFIG_FIREWIRE=m
CONFIG_FIREWIRE_OHCI=m
CONFIG_FIREWIRE_OHCI_DEBUG=y
CONFIG_FIREWIRE_SBP2=m
CONFIG_IEEE1394 is not set
CONFIG_I2O=m
CONFIG_I2O_LCT_NOTIFY_ON_CHANGES=y
CONFIG_I2O_EXT_ADAPTEC=y
CONFIG_I2O_CONFIG=m
CONFIG_I2O_CONFIG_OLD_IOCTL is not set
CONFIG_I2O_BUS=m
CONFIG_I2O_BLOCK=m
CONFIG_I2O_SCSI=m
CONFIG_I2O_PROC=m
CONFIG_MACINTOSH_DRIVERS is not set
CONFIG_NETDEVICES=y
CONFIG_DUMMY=y
CONFIG_BONDING=y
CONFIG_EQUALIZER is not set
CONFIG_TUN=m
CONFIG_VETH=y
CONFIG_NET_SB1000 is not set
CONFIG_ARCNET is not set
CONFIG_PHYLIB=y
[/color]
MII PHY device drivers
CONFIG_MARVELL_PHY is not set
CONFIG_DAVICOM_PHY is not set
CONFIG_QSEMI_PHY is not set
CONFIG_LXT_PHY is not set
CONFIG_CICADA_PHY is not set
CONFIG_VITESSE_PHY is not set
CONFIG_SMSC_PHY is not set
CONFIG_BROADCOM_PHY is not set
CONFIG_ICPLUS_PHY is not set
CONFIG_REALTEK_PHY=y
CONFIG_NATIONAL_PHY is not set
CONFIG_STE10XP is not set
CONFIG_LSI_ET1011C_PHY is not set
CONFIG_FIXED_PHY=y
CONFIG_MDIO_BITBANG=m
CONFIG_NET_ETHERNET=y
CONFIG_MII=y
CONFIG_HAPPYMEAL is not set
CONFIG_SUNGEM is not set
CONFIG_CASSINI is not set
CONFIG_NET_VENDOR_3COM is not set
CONFIG_LANCE is not set
CONFIG_NET_VENDOR_SMC is not set
CONFIG_ETHOC is not set
CONFIG_NET_VENDOR_RACAL is not set
CONFIG_DNET is not set
CONFIG_NET_TULIP is not set
CONFIG_DEPCA is not set
CONFIG_HP100 is not set
CONFIG_NET_ISA is not set
CONFIG_IBM_NEW_EMAC_ZMII is not set
CONFIG_IBM_NEW_EMAC_RGMII is not set
CONFIG_IBM_NEW_EMAC_TAH is not set
CONFIG_IBM_NEW_EMAC_EMAC4 is not set
CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set
CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set
CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set
CONFIG_NET_PCI=y
CONFIG_PCNET32 is not set
CONFIG_AMD8111_ETH is not set
CONFIG_ADAPTEC_STARFIRE is not set
CONFIG_APRICOT is not set
CONFIG_B44 is not set
CONFIG_FORCEDETH is not set
CONFIG_CS89x0 is not set
CONFIG_E100 is not set
CONFIG_FEALNX is not set
CONFIG_NATSEMI is not set
CONFIG_NE2K_PCI is not set
CONFIG_8139TOO=y
CONFIG_8139TOO_PIO is not set
CONFIG_8139TOO_TUNE_TWISTER=y
CONFIG_8139TOO_8129=y
CONFIG_8139_OLD_RX_RESET is not set
CONFIG_R6040 is not set
CONFIG_SIS900 is not set
CONFIG_EPIC100 is not set
CONFIG_SMSC9420 is not set
CONFIG_SUNDANCE is not set
CONFIG_TLAN is not set
CONFIG_KS8842 is not set
CONFIG_KS8851 is not set
CONFIG_VIA_RHINE is not set
CONFIG_ATL2 is not set
CONFIG_NETDEV_1000 is not set
CONFIG_NETDEV_10000 is not set
CONFIG_MLX4_CORE=m
CONFIG_TR is not set
Wireless LAN
CONFIG_WLAN_PRE80211 is not set
CONFIG_WLAN_80211=y
CONFIG_PCMCIA_RAYCS is not set
CONFIG_LIBERTAS is not set
CONFIG_LIBERTAS_THINFIRM is not set
CONFIG_AIRO is not set
CONFIG_ATMEL is not set
CONFIG_AT76C50X_USB is not set
CONFIG_AIRO_CS is not set
CONFIG_USB_ZD1201 is not set
CONFIG_RTL8187 is not set
CONFIG_MAC80211_HWSIM is not set
CONFIG_ATH9K is not set
CONFIG_IPW2100 is not set
CONFIG_IPW2200=y
CONFIG_IPW2200_MONITOR=y
CONFIG_IPW2200_RADIOTAP=y
CONFIG_IPW2200_PROMISCUOUS=y
CONFIG_IPW2200_DEBUG is not set
CONFIG_LIBIPW=y
CONFIG_LIBIPW_DEBUG is not set
CONFIG_HOSTAP is not set
CONFIG_B43 is not set
CONFIG_B43LEGACY is not set
CONFIG_HERMES is not set
[color=#FF0000][color=#FF0000]#
Enable WiMAX (Networking options) to see the WiMAX drivers
USB Network Adapters[/color]
CONFIG_USB_KAWETH is not set
CONFIG_USB_PEGASUS is not set
CONFIG_USB_USBNET is not set
CONFIG_NET_PCMCIA is not set
CONFIG_WAN is not set
CONFIG_ATM_DRIVERS=y
CONFIG_ATM_DUMMY=m
CONFIG_ATM_TCP=m
CONFIG_ATM_LANAI=m
CONFIG_ATM_ENI=m
CONFIG_ATM_ENI_DEBUG is not set
CONFIG_ATM_ENI_TUNE_BURST is not set
CONFIG_ATM_FIRESTREAM=m
CONFIG_ATM_ZATM=m
CONFIG_ATM_ZATM_DEBUG is not set
CONFIG_ATM_NICSTAR=m
CONFIG_ATM_NICSTAR_USE_SUNI is not set
CONFIG_ATM_NICSTAR_USE_IDT77105 is not set
CONFIG_ATM_IDT77252=m
CONFIG_ATM_IDT77252_DEBUG is not set
CONFIG_ATM_IDT77252_RCV_ALL is not set
CONFIG_ATM_IDT77252_USE_SUNI=y
CONFIG_ATM_AMBASSADOR=m
CONFIG_ATM_AMBASSADOR_DEBUG is not set
CONFIG_ATM_HORIZON=m
CONFIG_ATM_HORIZON_DEBUG is not set
CONFIG_ATM_IA=m
CONFIG_ATM_IA_DEBUG is not set
CONFIG_ATM_FORE200E=m
CONFIG_ATM_FORE200E_USE_TASKLET is not set
CONFIG_ATM_FORE200E_TX_RETRY=16
CONFIG_ATM_FORE200E_DEBUG=0
CONFIG_ATM_HE=m
CONFIG_ATM_HE_USE_SUNI=y
CONFIG_ATM_SOLOS=m
CONFIG_FDDI=y
CONFIG_DEFXX=y
CONFIG_DEFXX_MMIO=y
CONFIG_SKFP=m
CONFIG_PPP=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_ASYNC=y
CONFIG_PPP_SYNC_TTY=y
CONFIG_PPP_DEFLATE=y
CONFIG_PPP_BSDCOMP=y
CONFIG_PPPOATM=m
CONFIG_SLIP=y
CONFIG_SLIP_COMPRESSED=y
CONFIG_SLHC=y
CONFIG_SLIP_SMART=y
CONFIG_SLIP_MODE_SLIP6=y
CONFIG_NET_FC is not set
CONFIG_NETPOLL is not set
CONFIG_NET_POLL_CONTROLLER is not set
CONFIG_ISDN is not set
CONFIG_PHONE is not set
[/color]
Input device support
CONFIG_INPUT=y
CONFIG_INPUT_FF_MEMLESS=m
CONFIG_INPUT_POLLDEV=y
Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
CONFIG_INPUT_JOYDEV=y
CONFIG_INPUT_EVDEV=y
CONFIG_INPUT_EVBUG is not set
Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
[color=#FF0000]CONFIG_KEYBOARD_ATKBD=y
CONFIG_KEYBOARD_LKKBD=m
CONFIG_KEYBOARD_LM8323 is not set
CONFIG_KEYBOARD_NEWTON=m
CONFIG_KEYBOARD_STOWAWAY=m
CONFIG_KEYBOARD_SUNKBD=m
CONFIG_KEYBOARD_XTKBD=m[/color]
CONFIG_INPUT_MOUSE=y
CONFIG_MOUSE_PS2=m[color=#FF0000]
CONFIG_MOUSE_PS2_ALPS=y
CONFIG_MOUSE_PS2_LOGIPS2PP=y
CONFIG_MOUSE_PS2_SYNAPTICS=y
CONFIG_MOUSE_PS2_LIFEBOOK=y
CONFIG_MOUSE_PS2_TRACKPOINT=y
CONFIG_MOUSE_PS2_ELANTECH=y
CONFIG_MOUSE_PS2_TOUCHKIT is not set
CONFIG_MOUSE_SERIAL=m
CONFIG_MOUSE_APPLETOUCH=m
CONFIG_MOUSE_BCM5974=m
CONFIG_MOUSE_INPORT=m
CONFIG_MOUSE_ATIXL is not set
CONFIG_MOUSE_LOGIBM=m
CONFIG_MOUSE_PC110PAD=m
CONFIG_MOUSE_VSXXXAA=m
CONFIG_MOUSE_SYNAPTICS_I2C is not set
CONFIG_INPUT_JOYSTICK=y
CONFIG_JOYSTICK_ANALOG=m
CONFIG_JOYSTICK_A3D=m
CONFIG_JOYSTICK_ADI=m
CONFIG_JOYSTICK_COBRA=m
CONFIG_JOYSTICK_GF2K=m
CONFIG_JOYSTICK_GRIP=m
CONFIG_JOYSTICK_GRIP_MP=m
CONFIG_JOYSTICK_GUILLEMOT=m
CONFIG_JOYSTICK_INTERACT=m
CONFIG_JOYSTICK_SIDEWINDER=m
CONFIG_JOYSTICK_TMDC=m
CONFIG_JOYSTICK_IFORCE=m
CONFIG_JOYSTICK_IFORCE_USB=y
CONFIG_JOYSTICK_IFORCE_232=y
CONFIG_JOYSTICK_WARRIOR=m
CONFIG_JOYSTICK_MAGELLAN=m
CONFIG_JOYSTICK_SPACEORB=m
CONFIG_JOYSTICK_SPACEBALL=m
CONFIG_JOYSTICK_STINGER=m
CONFIG_JOYSTICK_TWIDJOY=m
CONFIG_JOYSTICK_ZHENHUA=m
CONFIG_JOYSTICK_JOYDUMP=m
CONFIG_JOYSTICK_XPAD=m
CONFIG_JOYSTICK_XPAD_FF=y
CONFIG_JOYSTICK_XPAD_LEDS=y
CONFIG_INPUT_TABLET=y
CONFIG_TABLET_USB_ACECAD=m
CONFIG_TABLET_USB_AIPTEK=m
CONFIG_TABLET_USB_GTCO=m
CONFIG_TABLET_USB_KBTAB=m
CONFIG_TABLET_USB_WACOM=m
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_ADS7846=m
CONFIG_TOUCHSCREEN_AD7877=m
CONFIG_TOUCHSCREEN_AD7879_I2C=m
CONFIG_TOUCHSCREEN_AD7879=m
CONFIG_TOUCHSCREEN_EETI is not set
CONFIG_TOUCHSCREEN_FUJITSU=m
CONFIG_TOUCHSCREEN_GUNZE=m
CONFIG_TOUCHSCREEN_ELO=m
CONFIG_TOUCHSCREEN_WACOM_W8001=m
CONFIG_TOUCHSCREEN_MTOUCH=m
CONFIG_TOUCHSCREEN_INEXIO=m
CONFIG_TOUCHSCREEN_MK712=m
CONFIG_TOUCHSCREEN_HTCPEN=m
CONFIG_TOUCHSCREEN_PENMOUNT=m
CONFIG_TOUCHSCREEN_TOUCHRIGHT=m
CONFIG_TOUCHSCREEN_TOUCHWIN=m
CONFIG_TOUCHSCREEN_WM97XX=m
CONFIG_TOUCHSCREEN_WM9705=y
CONFIG_TOUCHSCREEN_WM9712=y
CONFIG_TOUCHSCREEN_WM9713=y
CONFIG_TOUCHSCREEN_USB_COMPOSITE=m
CONFIG_TOUCHSCREEN_USB_EGALAX=y
CONFIG_TOUCHSCREEN_USB_PANJIT=y
CONFIG_TOUCHSCREEN_USB_3M=y
CONFIG_TOUCHSCREEN_USB_ITM=y
CONFIG_TOUCHSCREEN_USB_ETURBO=y
CONFIG_TOUCHSCREEN_USB_GUNZE=y
CONFIG_TOUCHSCREEN_USB_DMC_TSC10=y
CONFIG_TOUCHSCREEN_USB_IRTOUCH=y
CONFIG_TOUCHSCREEN_USB_IDEALTEK=y
CONFIG_TOUCHSCREEN_USB_GENERAL_TOUCH=y
CONFIG_TOUCHSCREEN_USB_GOTOP=y
CONFIG_TOUCHSCREEN_TOUCHIT213=m
CONFIG_TOUCHSCREEN_TSC2007=m
CONFIG_TOUCHSCREEN_W90X900 is not set
CONFIG_INPUT_MISC=y
CONFIG_INPUT_PCSPKR=m
CONFIG_INPUT_APANEL=m
CONFIG_INPUT_WISTRON_BTNS=m
CONFIG_INPUT_ATLAS_BTNS=m
CONFIG_INPUT_ATI_REMOTE=m
CONFIG_INPUT_ATI_REMOTE2=m
CONFIG_INPUT_POWERMATE=m
CONFIG_INPUT_UINPUT=m
CONFIG_INPUT_PCF50633_PMU=m
[/color]
PPS support
CONFIG_ARCH_WANT_OPTIONAL_GPIOLIB=y
CONFIG_GPIOLIB is not set
CONFIG_W1=m
CONFIG_W1_CON=y
1-wire Bus Masters
CONFIG_W1_MASTER_MATROX=m
CONFIG_W1_MASTER_DS2490=m
1-wire Slaves
CONFIG_W1_SLAVE_THERM=m
CONFIG_W1_SLAVE_SMEM=m
CONFIG_W1_SLAVE_DS2431=m
CONFIG_W1_SLAVE_DS2433=m
CONFIG_W1_SLAVE_DS2433_CRC is not set
CONFIG_W1_SLAVE_DS2760=m
CONFIG_W1_SLAVE_BQ27000=m
CONFIG_POWER_SUPPLY=y
CONFIG_POWER_SUPPLY_DEBUG is not set
CONFIG_PDA_POWER=m
CONFIG_WM8350_POWER=m
CONFIG_BATTERY_DS2760=m
CONFIG_BATTERY_DS2782 is not set
CONFIG_BATTERY_BQ27x00=m
CONFIG_BATTERY_MAX17040 is not set
CONFIG_CHARGER_PCF50633=m
CONFIG_HWMON=y
CONFIG_HWMON_VID=m
CONFIG_SENSORS_ADM1021=m
CONFIG_SENSORS_ADM1025=m
CONFIG_SENSORS_ADM9240=m
CONFIG_SENSORS_DS1621=m
CONFIG_SENSORS_FSCHER=m
CONFIG_SENSORS_FSCPOS=m
CONFIG_SENSORS_FSCHMD=m
CONFIG_SENSORS_G760A=m
CONFIG_SENSORS_GL518SM=m
CONFIG_SENSORS_GL520SM=m
CONFIG_SENSORS_IBMAEM=m
CONFIG_SENSORS_IBMPEX=m
CONFIG_SENSORS_IT87=m
CONFIG_SENSORS_LM63=m
CONFIG_SENSORS_LM75=m
CONFIG_SENSORS_LM77=m
CONFIG_SENSORS_LM78=m
CONFIG_SENSORS_LM83=m
CONFIG_SENSORS_LM87=m
CONFIG_SENSORS_LM90=m
CONFIG_SENSORS_LM92=m
CONFIG_SENSORS_LM93=m
CONFIG_SENSORS_LM95241=m
CONFIG_SENSORS_MAX1111=m
CONFIG_SENSORS_MAX1619=m
CONFIG_SENSORS_PC87360=m
CONFIG_SENSORS_PCF8591=m
CONFIG_SENSORS_SIS5595=m
CONFIG_SENSORS_SMSC47M1=m
CONFIG_SENSORS_ADS7828=m
CONFIG_SENSORS_VIA686A=m
CONFIG_SENSORS_VT8231=m
CONFIG_SENSORS_W83781D=m
CONFIG_SENSORS_W83627HF=m
CONFIG_SENSORS_W83627EHF=m
CONFIG_SENSORS_HDAPS=m
CONFIG_SENSORS_LIS3LV02D=m
CONFIG_SENSORS_APPLESMC=m
CONFIG_HWMON_DEBUG_CHIP is not set
CONFIG_THERMAL=y
CONFIG_THERMAL_HWMON=y
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_NOWAYOUT is not set
Watchdog Device Drivers
CONFIG_SOFT_WATCHDOG=m
CONFIG_WM8350_WATCHDOG=m
CONFIG_ACQUIRE_WDT=m
CONFIG_ADVANTECH_WDT=m
CONFIG_ALIM1535_WDT=m
CONFIG_ALIM7101_WDT=m
CONFIG_SC520_WDT=m
CONFIG_EUROTECH_WDT=m
CONFIG_IB700_WDT=m
CONFIG_IBMASR=m
CONFIG_WAFER_WDT=m
CONFIG_I6300ESB_WDT=m
CONFIG_ITCO_WDT=m
CONFIG_ITCO_VENDOR_SUPPORT=y
CONFIG_IT8712F_WDT=m
CONFIG_HP_WATCHDOG=m
CONFIG_SC1200_WDT=m
CONFIG_SCx200_WDT=m
CONFIG_PC87413_WDT=m
CONFIG_60XX_WDT=m
CONFIG_SBC8360_WDT=m
CONFIG_SBC7240_WDT=m
CONFIG_CPU5_WDT=m
CONFIG_SMSC_SCH311X_WDT=m
CONFIG_SMSC37B787_WDT=m
CONFIG_W83627HF_WDT=m
CONFIG_W83697HF_WDT=m
CONFIG_W83697UG_WDT=m
CONFIG_W83877F_WDT=m
CONFIG_W83977F_WDT=m
CONFIG_MACHZ_WDT=m
CONFIG_SBC_EPX_C3_WATCHDOG=m
ISA-based Watchdog Cards
CONFIG_PCWATCHDOG=m
CONFIG_MIXCOMWD=m
CONFIG_WDT=m
PCI-based Watchdog Cards
CONFIG_PCIPCWATCHDOG=m
CONFIG_WDTPCI=m
USB-based Watchdog Cards
CONFIG_USBPCWATCHDOG=m
CONFIG_SSB_POSSIBLE=y
Sonics Silicon Backplane
CONFIG_SSB=m
CONFIG_SSB_SPROM=y
CONFIG_SSB_PCIHOST_POSSIBLE=y
CONFIG_SSB_PCIHOST=y
CONFIG_SSB_B43_PCI_BRIDGE is not set
CONFIG_SSB_PCMCIAHOST_POSSIBLE=y
CONFIG_SSB_PCMCIAHOST=y
CONFIG_SSB_DEBUG is not set
CONFIG_SSB_DRIVER_PCICORE_POSSIBLE=y
CONFIG_SSB_DRIVER_PCICORE=y
Multifunction device drivers
CONFIG_MFD_CORE=m
CONFIG_MFD_SM501=m
CONFIG_HTC_PASIC3=m
CONFIG_MFD_TMIO is not set
CONFIG_MFD_WM8400=m
CONFIG_MFD_WM8350=m
CONFIG_MFD_WM8350_I2C=m
CONFIG_MFD_PCF50633=m
CONFIG_PCF50633_ADC=m
CONFIG_PCF50633_GPIO=m
CONFIG_AB3100_CORE is not set
CONFIG_EZX_PCAP is not set
CONFIG_REGULATOR=y
CONFIG_REGULATOR_DEBUG is not set
CONFIG_REGULATOR_FIXED_VOLTAGE is not set
CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
CONFIG_REGULATOR_BQ24022=m
CONFIG_REGULATOR_MAX1586 is not set
CONFIG_REGULATOR_WM8350=m
CONFIG_REGULATOR_WM8400=m
CONFIG_REGULATOR_PCF50633=m
CONFIG_REGULATOR_LP3971 is not set
CONFIG_MEDIA_SUPPORT is not set
Graphics support
CONFIG_AGP=y
CONFIG_AGP_ALI=m
CONFIG_AGP_ATI=m
CONFIG_AGP_AMD=m
CONFIG_AGP_AMD64=y
CONFIG_AGP_INTEL=m
CONFIG_AGP_NVIDIA=m
CONFIG_AGP_SIS=m
CONFIG_AGP_SWORKS=m
CONFIG_AGP_VIA=m
CONFIG_AGP_EFFICEON=m
CONFIG_DRM=m
CONFIG_DRM_TDFX=m
CONFIG_DRM_R128=m
CONFIG_DRM_RADEON=m
CONFIG_DRM_I810=m
CONFIG_DRM_I830=m
CONFIG_DRM_I915=m
CONFIG_DRM_I915_KMS is not set
CONFIG_DRM_MGA=m
CONFIG_DRM_SIS=m
CONFIG_DRM_VIA=m
CONFIG_DRM_SAVAGE=m
CONFIG_VGASTATE=m
CONFIG_VIDEO_OUTPUT_CONTROL=m
CONFIG_FB=y
CONFIG_FIRMWARE_EDID=y
CONFIG_FB_DDC=m
CONFIG_FB_BOOT_VESA_SUPPORT=y
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set
CONFIG_FB_SYS_FILLRECT=m
CONFIG_FB_SYS_COPYAREA=m
CONFIG_FB_SYS_IMAGEBLIT=m
CONFIG_FB_FOREIGN_ENDIAN is not set
CONFIG_FB_SYS_FOPS=m
CONFIG_FB_DEFERRED_IO=y
CONFIG_FB_HECUBA=m
CONFIG_FB_SVGALIB=m
CONFIG_FB_MACMODES is not set
CONFIG_FB_BACKLIGHT=y
CONFIG_FB_MODE_HELPERS=y
CONFIG_FB_TILEBLITTING=y
Frame buffer hardware drivers
CONFIG_FB_CIRRUS=m
CONFIG_FB_PM2=m
CONFIG_FB_PM2_FIFO_DISCONNECT=y
CONFIG_FB_CYBER2000=m
CONFIG_FB_ARC is not set
CONFIG_FB_ASILIANT is not set
CONFIG_FB_IMSTT is not set
CONFIG_FB_VGA16=m
CONFIG_FB_UVESA=m
CONFIG_FB_VESA=y
CONFIG_FB_EFI=y
CONFIG_FB_N411=m
CONFIG_FB_HGA=m
CONFIG_FB_S1D13XXX=m
CONFIG_FB_NVIDIA=m
CONFIG_FB_NVIDIA_I2C=y
CONFIG_FB_NVIDIA_DEBUG is not set
CONFIG_FB_NVIDIA_BACKLIGHT=y
CONFIG_FB_RIVA=m
CONFIG_FB_RIVA_I2C=y
CONFIG_FB_RIVA_DEBUG is not set
CONFIG_FB_RIVA_BACKLIGHT=y
CONFIG_FB_LE80578=m
CONFIG_FB_CARILLO_RANCH=m
CONFIG_FB_MATROX=m
CONFIG_FB_MATROX_MILLENIUM=y
CONFIG_FB_MATROX_MYSTIQUE=y
CONFIG_FB_MATROX_G=y
CONFIG_FB_MATROX_I2C=m
CONFIG_FB_MATROX_MAVEN=m
CONFIG_FB_MATROX_MULTIHEAD=y
CONFIG_FB_RADEON=m
CONFIG_FB_RADEON_I2C=y
CONFIG_FB_RADEON_BACKLIGHT=y
CONFIG_FB_RADEON_DEBUG is not set
CONFIG_FB_ATY128=m
CONFIG_FB_ATY128_BACKLIGHT=y
CONFIG_FB_ATY=m
CONFIG_FB_ATY_CT=y
CONFIG_FB_ATY_GENERIC_LCD=y
CONFIG_FB_ATY_GX=y
CONFIG_FB_ATY_BACKLIGHT=y
CONFIG_FB_S3=m
CONFIG_FB_SIS=m
CONFIG_FB_SIS_300=y
CONFIG_FB_SIS_315=y
CONFIG_FB_VIA=m
CONFIG_FB_NEOMAGIC=m
CONFIG_FB_KYRO=m
CONFIG_FB_3DFX=m
CONFIG_FB_VOODOO1=m
CONFIG_FB_VT8623=m
CONFIG_FB_TRIDENT=m
CONFIG_FB_ARK=m
CONFIG_FB_CARMINE is not set
CONFIG_FB_TMIO=m
CONFIG_FB_TMIO_ACCELL=y
CONFIG_FB_SM501=m
CONFIG_FB_VIRTUAL is not set
CONFIG_FB_METRONOME=m
CONFIG_FB_MB862XX=m
CONFIG_FB_MB862XX_PCI_GDC=y
CONFIG_FB_BROADSHEET=m
CONFIG_BACKLIGHT_LCD_SUPPORT=y
CONFIG_LCD_CLASS_DEVICE=m
CONFIG_LCD_LTV350QV=m
CONFIG_LCD_ILI9320=m
CONFIG_LCD_TDO24M=m
CONFIG_LCD_VGG2432A4=m
CONFIG_LCD_PLATFORM=m
CONFIG_BACKLIGHT_CLASS_DEVICE=y
CONFIG_BACKLIGHT_GENERIC=m
CONFIG_BACKLIGHT_PROGEAR=m
CONFIG_BACKLIGHT_CARILLO_RANCH=m
CONFIG_BACKLIGHT_MBP_NVIDIA=m
CONFIG_BACKLIGHT_SAHARA=m
Display device support
CONFIG_DISPLAY_SUPPORT=m
Display hardware drivers
Console display driver support
CONFIG_VGA_CONSOLE=y
CONFIG_VGACON_SOFT_SCROLLBACK=y
CONFIG_VGACON_SOFT_SCROLLBACK_SIZE=64
CONFIG_MDA_CONSOLE=m
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
CONFIG_FONTS is not set
[color=#FF0000]CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
CONFIG_LOGO=y
CONFIG_LOGO_LINUX_MONO=y
CONFIG_LOGO_LINUX_VGA16=y
CONFIG_LOGO_LINUX_CLUT224=y
CONFIG_SOUND=y
CONFIG_SOUND_OSS_CORE=y
CONFIG_SND=m
CONFIG_SND_TIMER=m
CONFIG_SND_PCM=m
CONFIG_SND_HWDEP=m
CONFIG_SND_RAWMIDI=m
CONFIG_SND_SEQUENCER=m
CONFIG_SND_SEQ_DUMMY=m
CONFIG_SND_OSSEMUL=y
CONFIG_SND_MIXER_OSS=m
CONFIG_SND_PCM_OSS=m
CONFIG_SND_PCM_OSS_PLUGINS=y
CONFIG_SND_SEQUENCER_OSS=y
CONFIG_SND_HRTIMER=m
CONFIG_SND_SEQ_HRTIMER_DEFAULT=y
CONFIG_SND_DYNAMIC_MINORS=y
CONFIG_SND_SUPPORT_OLD_API is not set
CONFIG_SND_VERBOSE_PROCFS=y
CONFIG_SND_VERBOSE_PRINTK is not set
CONFIG_SND_DEBUG is not set
CONFIG_SND_VMASTER=y
CONFIG_SND_RAWMIDI_SEQ=m
CONFIG_SND_OPL3_LIB_SEQ=m
CONFIG_SND_OPL4_LIB_SEQ=m
CONFIG_SND_SBAWE_SEQ=m
CONFIG_SND_EMU10K1_SEQ=m
CONFIG_SND_MPU401_UART=m
CONFIG_SND_OPL3_LIB=m
CONFIG_SND_OPL4_LIB=m
CONFIG_SND_VX_LIB=m
CONFIG_SND_AC97_CODEC=m
CONFIG_SND_DRIVERS=y
CONFIG_SND_DUMMY=m
CONFIG_SND_VIRMIDI=m
CONFIG_SND_MTPAV=m
CONFIG_SND_SERIAL_U16550=m
CONFIG_SND_MPU401=m
CONFIG_SND_AC97_POWER_SAVE=y
CONFIG_SND_AC97_POWER_SAVE_DEFAULT=0
CONFIG_SND_WSS_LIB=m
CONFIG_SND_SB_COMMON=m
CONFIG_SND_SB8_DSP=m
CONFIG_SND_SB16_DSP=m
CONFIG_SND_ISA=y
CONFIG_SND_ADLIB=m
CONFIG_SND_AD1816A=m
CONFIG_SND_AD1848=m
CONFIG_SND_ALS100=m
CONFIG_SND_AZT2320=m
CONFIG_SND_CMI8330=m
CONFIG_SND_CS4231=m
CONFIG_SND_CS4236=m
CONFIG_SND_DT019X=m
CONFIG_SND_ES968=m
CONFIG_SND_ES1688=m
CONFIG_SND_ES18XX=m
CONFIG_SND_SC6000=m
CONFIG_SND_GUSCLASSIC=m
CONFIG_SND_GUSEXTREME=m
CONFIG_SND_GUSMAX=m
CONFIG_SND_INTERWAVE=m
CONFIG_SND_INTERWAVE_STB=m
CONFIG_SND_OPL3SA2=m
CONFIG_SND_OPTI92X_AD1848=m
CONFIG_SND_OPTI92X_CS4231=m
CONFIG_SND_OPTI93X=m
CONFIG_SND_MIRO=m
CONFIG_SND_SB8=m
CONFIG_SND_SB16=m
CONFIG_SND_SBAWE=m
CONFIG_SND_SB16_CSP=y
CONFIG_SND_SGALAXY=m
CONFIG_SND_SSCAPE=m
CONFIG_SND_WAVEFRONT=m
CONFIG_SND_PCI=y
CONFIG_SND_AD1889=m
CONFIG_SND_ALS300=m
CONFIG_SND_ALS4000=m
CONFIG_SND_ALI5451=m
CONFIG_SND_ATIIXP=m
CONFIG_SND_ATIIXP_MODEM=m
CONFIG_SND_AU8810=m
CONFIG_SND_AU8820=m
CONFIG_SND_AU8830=m
CONFIG_SND_AW2 is not set
CONFIG_SND_BT87X=m
CONFIG_SND_BT87X_OVERCLOCK is not set
CONFIG_SND_CA0106=m
CONFIG_SND_CMIPCI=m
CONFIG_SND_OXYGEN_LIB=m
CONFIG_SND_OXYGEN=m
CONFIG_SND_CS4281=m
CONFIG_SND_CS46XX is not set
CONFIG_SND_CS5530=m
CONFIG_SND_CS5535AUDIO=m
CONFIG_SND_CTXFI is not set
CONFIG_SND_DARLA20=m
CONFIG_SND_GINA20=m
CONFIG_SND_LAYLA20=m
CONFIG_SND_DARLA24=m
CONFIG_SND_GINA24=m
CONFIG_SND_LAYLA24=m
CONFIG_SND_MONA=m
CONFIG_SND_MIA=m
CONFIG_SND_ECHO3G=m
CONFIG_SND_INDIGO=m
CONFIG_SND_INDIGOIO=m
CONFIG_SND_INDIGODJ=m
CONFIG_SND_INDIGOIOX=m
CONFIG_SND_INDIGODJX=m
CONFIG_SND_EMU10K1=m
CONFIG_SND_EMU10K1X=m
CONFIG_SND_ENS1370=m
CONFIG_SND_ENS1371=m
CONFIG_SND_ES1938=m
CONFIG_SND_ES1968=m
CONFIG_SND_FM801=m
CONFIG_SND_HDA_INTEL=m
CONFIG_SND_HDA_HWDEP=y
CONFIG_SND_HDA_INPUT_BEEP=y
CONFIG_SND_HDA_INPUT_JACK is not set
CONFIG_SND_HDA_CODEC_REALTEK=y
CONFIG_SND_HDA_CODEC_ANALOG=y
CONFIG_SND_HDA_CODEC_SIGMATEL=y
CONFIG_SND_HDA_CODEC_VIA=y
CONFIG_SND_HDA_CODEC_ATIHDMI=y
CONFIG_SND_HDA_CODEC_NVHDMI=y
CONFIG_SND_HDA_CODEC_INTELHDMI=y
CONFIG_SND_HDA_ELD=y
CONFIG_SND_HDA_CODEC_CONEXANT=y
CONFIG_SND_HDA_CODEC_CA0110=y
CONFIG_SND_HDA_CODEC_CMEDIA=y
CONFIG_SND_HDA_CODEC_SI3054=y
CONFIG_SND_HDA_GENERIC=y
CONFIG_SND_HDA_POWER_SAVE=y
CONFIG_SND_HDA_POWER_SAVE_DEFAULT=0
CONFIG_SND_HDSP=m
CONFIG_SND_HDSPM=m
CONFIG_SND_HIFIER=m
CONFIG_SND_ICE1712=m
CONFIG_SND_ICE1724=m
CONFIG_SND_INTEL8X0=m
CONFIG_SND_INTEL8X0M=m
CONFIG_SND_KORG1212=m
CONFIG_SND_LX6464ES is not set
CONFIG_SND_MAESTRO3=m
CONFIG_SND_MIXART=m
CONFIG_SND_NM256=m
CONFIG_SND_PCXHR=m
CONFIG_SND_RIPTIDE=m
CONFIG_SND_RME32=m
CONFIG_SND_RME96=m
CONFIG_SND_RME9652=m
CONFIG_SND_SIS7019=m
CONFIG_SND_SONICVIBES=m
CONFIG_SND_TRIDENT=m
CONFIG_SND_VIA82XX=m
CONFIG_SND_VIA82XX_MODEM=m
CONFIG_SND_VIRTUOSO=m
CONFIG_SND_VX222=m
CONFIG_SND_YMFPCI=m
CONFIG_SND_SPI=y
CONFIG_SND_USB=y
CONFIG_SND_USB_AUDIO=m
CONFIG_SND_USB_USX2Y=m
CONFIG_SND_USB_CAIAQ=m
CONFIG_SND_USB_CAIAQ_INPUT=y
CONFIG_SND_PCMCIA=y
CONFIG_SND_VXPOCKET=m
CONFIG_SND_PDAUDIOCF=m
CONFIG_SND_SOC is not set
CONFIG_SOUND_PRIME is not set
CONFIG_AC97_BUS=m
CONFIG_HID_SUPPORT=y
CONFIG_HID=m
CONFIG_HID_DEBUG is not set
CONFIG_HIDRAW=y[/color]
USB Input Devices
CONFIG_USB_HID=m
CONFIG_HID_PID=y
CONFIG_USB_HIDDEV=y
Special HID drivers
CONFIG_HID_A4TECH=m
CONFIG_HID_APPLE=m
CONFIG_HID_BELKIN=m
CONFIG_HID_CHERRY=m
CONFIG_HID_CHICONY=m
CONFIG_HID_CYPRESS=m
CONFIG_HID_DRAGONRISE=m
CONFIG_DRAGONRISE_FF is not set
CONFIG_HID_EZKEY=m
CONFIG_HID_KYE=m
CONFIG_HID_GYRATION=m
CONFIG_HID_KENSINGTON=m
CONFIG_HID_LOGITECH=m
CONFIG_LOGITECH_FF=y
CONFIG_LOGIRUMBLEPAD2_FF=y
CONFIG_HID_MICROSOFT=m
CONFIG_HID_MONTEREY=m
CONFIG_HID_NTRIG=m
CONFIG_HID_PANTHERLORD=m
CONFIG_PANTHERLORD_FF=y
CONFIG_HID_PETALYNX=m
CONFIG_HID_SAMSUNG=m
CONFIG_HID_SONY=m
CONFIG_HID_SUNPLUS=m
CONFIG_HID_GREENASIA=m
CONFIG_GREENASIA_FF is not set
CONFIG_HID_SMARTJOYPLUS=m
CONFIG_SMARTJOYPLUS_FF is not set
CONFIG_HID_TOPSEED=m
CONFIG_HID_THRUSTMASTER=m
CONFIG_THRUSTMASTER_FF is not set
CONFIG_HID_WACOM=m
CONFIG_HID_ZEROPLUS=m
CONFIG_ZEROPLUS_FF is not set
CONFIG_USB_SUPPORT=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB_ARCH_HAS_OHCI=y
CONFIG_USB_ARCH_HAS_EHCI=y
CONFIG_USB=y
CONFIG_USB_DEBUG is not set
CONFIG_USB_ANNOUNCE_NEW_DEVICES=y
Miscellaneous USB options
CONFIG_USB_DEVICEFS=y
CONFIG_USB_DEVICE_CLASS=y
CONFIG_USB_DYNAMIC_MINORS is not set
CONFIG_USB_SUSPEND=y
CONFIG_USB_MON=m
CONFIG_USB_WUSB_CBAF=m
CONFIG_USB_WUSB_CBAF_DEBUG is not set
USB Host Controller Drivers
CONFIG_USB_C67X00_HCD=m
CONFIG_USB_EHCI_HCD=m
CONFIG_USB_EHCI_ROOT_HUB_TT=y
CONFIG_USB_OXU210HP_HCD=m
CONFIG_USB_ISP116X_HCD=m
CONFIG_USB_OHCI_HCD=m
CONFIG_USB_OHCI_BIG_ENDIAN_DESC is not set
CONFIG_USB_OHCI_BIG_ENDIAN_MMIO is not set
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_UHCI_HCD=m
CONFIG_USB_U132_HCD=m
CONFIG_USB_SL811_HCD=m
CONFIG_USB_SL811_CS=m
CONFIG_USB_R8A66597_HCD=m
CONFIG_USB_GADGET_MUSB_HDRC is not set
USB Device Class drivers
CONFIG_USB_ACM=m
CONFIG_USB_PRINTER=m
CONFIG_USB_WDM=m
CONFIG_USB_TMC=m
NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=m
CONFIG_USB_STORAGE_DEBUG is not set
CONFIG_USB_STORAGE_DATAFAB=m
CONFIG_USB_STORAGE_FREECOM=m
CONFIG_USB_STORAGE_ISD200=m
CONFIG_USB_STORAGE_USBAT=m
CONFIG_USB_STORAGE_SDDR09=m
CONFIG_USB_STORAGE_SDDR55=m
CONFIG_USB_STORAGE_JUMPSHOT=m
CONFIG_USB_STORAGE_ALAUDA=m
CONFIG_USB_STORAGE_ONETOUCH=m
CONFIG_USB_STORAGE_KARMA=m
CONFIG_USB_STORAGE_CYPRESS_ATACB=m
CONFIG_USB_LIBUSUAL is not set
USB Imaging devices
CONFIG_USB_MDC800=m
CONFIG_USB_MICROTEK=m
[color=#FF0000]
USB port drivers
CONFIG_USB_SERIAL=m
CONFIG_USB_EZUSB=y
CONFIG_USB_SERIAL_GENERIC=y
CONFIG_USB_SERIAL_AIRCABLE=m
CONFIG_USB_SERIAL_ARK3116=m
CONFIG_USB_SERIAL_BELKIN=m
CONFIG_USB_SERIAL_CH341=m
CONFIG_USB_SERIAL_WHITEHEAT=m
CONFIG_USB_SERIAL_DIGI_ACCELEPORT=m
CONFIG_USB_SERIAL_CP210X=m
CONFIG_USB_SERIAL_CYPRESS_M8=m
CONFIG_USB_SERIAL_EMPEG=m
CONFIG_USB_SERIAL_FTDI_SIO=m
CONFIG_USB_SERIAL_FUNSOFT=m
CONFIG_USB_SERIAL_VISOR=m
CONFIG_USB_SERIAL_IPAQ=m
CONFIG_USB_SERIAL_IR=m
CONFIG_USB_SERIAL_EDGEPORT=m
CONFIG_USB_SERIAL_EDGEPORT_TI=m
CONFIG_USB_SERIAL_GARMIN=m
CONFIG_USB_SERIAL_IPW=m
CONFIG_USB_SERIAL_IUU=m
CONFIG_USB_SERIAL_KEYSPAN_PDA=m
CONFIG_USB_SERIAL_KEYSPAN=m
CONFIG_USB_SERIAL_KLSI=m
CONFIG_USB_SERIAL_KOBIL_SCT=m
CONFIG_USB_SERIAL_MCT_U232=m
CONFIG_USB_SERIAL_MOS7720=m
CONFIG_USB_SERIAL_MOS7840=m
CONFIG_USB_SERIAL_MOTOROLA=m
CONFIG_USB_SERIAL_NAVMAN=m
CONFIG_USB_SERIAL_PL2303=m
CONFIG_USB_SERIAL_OTI6858=m
CONFIG_USB_SERIAL_QUALCOMM=m
CONFIG_USB_SERIAL_SPCP8X5=m
CONFIG_USB_SERIAL_HP4X=m
CONFIG_USB_SERIAL_SAFE=m
CONFIG_USB_SERIAL_SAFE_PADDED=y
CONFIG_USB_SERIAL_SIEMENS_MPI=m
CONFIG_USB_SERIAL_SIERRAWIRELESS=m
CONFIG_USB_SERIAL_SYMBOL=m
CONFIG_USB_SERIAL_TI=m
CONFIG_USB_SERIAL_CYBERJACK=m
CONFIG_USB_SERIAL_XIRCOM=m
CONFIG_USB_SERIAL_OPTION=m
CONFIG_USB_SERIAL_OMNINET=m
CONFIG_USB_SERIAL_OPTICON=m
CONFIG_USB_SERIAL_DEBUG=m
USB Miscellaneous drivers
CONFIG_USB_EMI62=m
CONFIG_USB_EMI26=m
CONFIG_USB_ADUTUX=m
CONFIG_USB_SEVSEG=m
CONFIG_USB_RIO500=m
CONFIG_USB_LEGOTOWER=m
CONFIG_USB_LCD=m
CONFIG_USB_BERRY_CHARGE=m
CONFIG_USB_LED=m
CONFIG_USB_CYPRESS_CY7C63=m
CONFIG_USB_CYTHERM=m
CONFIG_USB_IDMOUSE=m
CONFIG_USB_FTDI_ELAN=m
CONFIG_USB_APPLEDISPLAY=m
CONFIG_USB_SISUSBVGA=m
CONFIG_USB_SISUSBVGA_CON=y
CONFIG_USB_LD=m
CONFIG_USB_TRANCEVIBRATOR=m
CONFIG_USB_IOWARRIOR=m
CONFIG_USB_TEST=m
CONFIG_USB_ISIGHTFW=m
CONFIG_USB_VST=m
CONFIG_USB_ATM=m
CONFIG_USB_SPEEDTOUCH=m
CONFIG_USB_CXACRU=m
CONFIG_USB_UEAGLEATM=m
CONFIG_USB_XUSBATM=m
CONFIG_USB_GADGET=m
CONFIG_USB_GADGET_DEBUG_FILES is not set
CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=500
CONFIG_USB_GADGET_SELECTED=y
CONFIG_USB_GADGET_AT91 is not set
CONFIG_USB_GADGET_ATMEL_USBA is not set
CONFIG_USB_GADGET_FSL_USB2 is not set
CONFIG_USB_GADGET_LH7A40X is not set[/color]
CONFIG_USB_GADGET_OMAP is not set
CONFIG_USB_GADGET_PXA25X is not set
CONFIG_USB_GADGET_PXA27X is not set
CONFIG_USB_GADGET_S3C_HSOTG is not set
CONFIG_USB_GADGET_IMX is not set
CONFIG_USB_GADGET_S3C2410 is not set
CONFIG_USB_GADGET_M66592 is not set
CONFIG_USB_GADGET_AMD5536UDC is not set
CONFIG_USB_GADGET_FSL_QE is not set
CONFIG_USB_GADGET_CI13XXX is not set
CONFIG_USB_GADGET_NET2280=y
CONFIG_USB_NET2280=m[color=#FF0000]
CONFIG_USB_GADGET_GOKU is not set
CONFIG_USB_GADGET_LANGWELL is not set
CONFIG_USB_GADGET_DUMMY_HCD is not set
CONFIG_USB_GADGET_DUALSPEED=y
CONFIG_USB_ZERO=m
CONFIG_USB_AUDIO is not set
CONFIG_USB_ETH=m
CONFIG_USB_ETH_RNDIS=y
CONFIG_USB_GADGETFS is not set
CONFIG_USB_FILE_STORAGE=m
CONFIG_USB_FILE_STORAGE_TEST is not set
CONFIG_USB_G_SERIAL=m
CONFIG_USB_MIDI_GADGET is not set
CONFIG_USB_G_PRINTER=m
CONFIG_USB_CDC_COMPOSITE=m[/color]
OTG and related infrastructure
CONFIG_USB_OTG_UTILS=y
CONFIG_NOP_USB_XCEIV=m
CONFIG_MMC=y
CONFIG_MMC_DEBUG is not set
CONFIG_MMC_UNSAFE_RESUME=y
MMC/SD/SDIO Card Drivers
CONFIG_MMC_BLOCK=m
CONFIG_MMC_BLOCK_BOUNCE=y
CONFIG_SDIO_UART=m
CONFIG_MMC_TEST is not set
MMC/SD/SDIO Host Controller Drivers
CONFIG_MMC_SDHCI=m
CONFIG_MMC_SDHCI_PCI=m
CONFIG_MMC_RICOH_MMC=m
CONFIG_MMC_SDHCI_PLTFM is not set
CONFIG_MMC_WBSD=m
CONFIG_MMC_CB710 is not set
CONFIG_MMC_VIA_SDMMC is not set
CONFIG_MEMSTICK=y
CONFIG_MEMSTICK_DEBUG is not set
Security options
CONFIG_KEYS=y
CONFIG_KEYS_DEBUG_PROC_KEYS is not set
CONFIG_SECURITY=y
CONFIG_SECURITYFS=y
CONFIG_SECURITY_NETWORK=y
CONFIG_SECURITY_NETWORK_XFRM=y
CONFIG_SECURITY_PATH is not set
CONFIG_SECURITY_FILE_CAPABILITIES=y
CONFIG_SECURITY_ROOTPLUG is not set
CONFIG_LSM_MMAP_MIN_ADDR=65536
CONFIG_SECURITY_SELINUX=y
CONFIG_SECURITY_SELINUX_BOOTPARAM=y
CONFIG_SECURITY_SELINUX_BOOTPARAM_VALUE=0
CONFIG_SECURITY_SELINUX_DISABLE=y
CONFIG_SECURITY_SELINUX_DEVELOP=y
CONFIG_SECURITY_SELINUX_AVC_STATS=y
CONFIG_SECURITY_SELINUX_CHECKREQPROT_VALUE=1
CONFIG_SECURITY_SELINUX_POLICYDB_VERSION_MAX is not set
CONFIG_SECURITY_SMACK is not set
CONFIG_SECURITY_TOMOYO is not set
CONFIG_IMA is not set
CONFIG_CRYPTO=y
Crypto core or helper
CONFIG_CRYPTO_FIPS=y
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=m
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_PCOMP=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
CONFIG_CRYPTO_GF128MUL=m
CONFIG_CRYPTO_NULL=m
CONFIG_CRYPTO_WORKQUEUE=y
CONFIG_CRYPTO_CRYPTD=m
CONFIG_CRYPTO_AUTHENC=y
CONFIG_CRYPTO_TEST=m
Authenticated Encryption with Associated Data
CONFIG_CRYPTO_CCM=m
CONFIG_CRYPTO_GCM=m
CONFIG_CRYPTO_SEQIV=m
Block modes
CONFIG_CRYPTO_CBC=y
CONFIG_CRYPTO_CTR=m
CONFIG_CRYPTO_CTS=m
CONFIG_CRYPTO_ECB=y
CONFIG_CRYPTO_PCBC=m
Hash modes
CONFIG_CRYPTO_HMAC=y
Digest
CONFIG_CRYPTO_CRC32C=m
CONFIG_CRYPTO_CRC32C_INTEL=m
CONFIG_CRYPTO_MD4=m
CONFIG_CRYPTO_MD5=y
CONFIG_CRYPTO_MICHAEL_MIC=y
CONFIG_CRYPTO_RMD128=m
CONFIG_CRYPTO_RMD160=m
CONFIG_CRYPTO_RMD256=m
CONFIG_CRYPTO_RMD320=m
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_SHA256=m
CONFIG_CRYPTO_SHA512=m
CONFIG_CRYPTO_TGR192=m
CONFIG_CRYPTO_WP512=m
Ciphers
CONFIG_CRYPTO_AES=y
CONFIG_CRYPTO_AES_586=m
CONFIG_CRYPTO_ANUBIS=m
CONFIG_CRYPTO_ARC4=y
CONFIG_CRYPTO_BLOWFISH=m
CONFIG_CRYPTO_CAMELLIA=m
CONFIG_CRYPTO_CAST5=m
CONFIG_CRYPTO_CAST6=m
CONFIG_CRYPTO_DES=y
CONFIG_CRYPTO_FCRYPT=m
CONFIG_CRYPTO_KHAZAD=m
CONFIG_CRYPTO_SEED=m
CONFIG_CRYPTO_SERPENT=m
CONFIG_CRYPTO_TEA=m
CONFIG_CRYPTO_TWOFISH=m
CONFIG_CRYPTO_TWOFISH_COMMON=m
CONFIG_CRYPTO_TWOFISH_586=m
Compression
CONFIG_CRYPTO_DEFLATE=y
CONFIG_CRYPTO_ZLIB=m
CONFIG_CRYPTO_LZO=m
