voici le contenu de monprofil.pressed, simple-cdd.conf et monprofil.packages
simple-cddconf :
# what components to be added to image
mirror_components="main contrib non-free"
monprofil.packages :
wireshark
monprofil.pressed :
#!/bin/bash
### Localization
# Preseeding only locale sets language, country and locale.
d-i debian-installer/fallbacklocale select fr_FR.UTF-8
d-i debian-installer/locale select fr_FR.UTF-8
# The values can also be preseeded individually for greater flexibility.
#d-i debian-installer/language string fr
#d-i debian-installer/country string FR
#d-i debian-installer/locale string fr_FR.UTF-8
# Optionally specify additional locales to be generated.
# d-i localechooser/supported-locales multiselect fr_FR.UTF-8
### Description: Language:
# Choose the language to be used for the installation process. The selected
# language will also be the default language for the installed system.
# d-i localechooser/languagelist select fr
# Possible choices: ${NAMES_EN}
# d-i localechooser/language-name string French
# Keyboard selection.
#d-i console-keymaps-at/keymap select fr-latin9
d-i keyboard-configuration/xkb-keymap select fr
# d-i keyboard-configuration/toggle select No toggling
#d-i console-setup/ask_detect boolean false
d-i debian-installer/keymap string fr-latin9
### Description: Country of origin for the keyboard:
# The layout of keyboards varies per country, with some countries
# having multiple common layouts. Please select the country of origin
# for the keyboard of this computer.
#d-i keyboard-configuration/layout select fr_FR.UTF-8
# Possible choices: ${CHOICES}
### Description: For internal use (keyboard chosen by user)
#d-i debian-installer/keymap string fr
#d-i console-data/keymap/policy select keymap from arch list
#d-i console-data/keymap/family select azerty
#d-i console-data/keymap/template/layout select French
#d-i console-data/keymap/template/variant select With Euro (latin 9)
#d-i keyboard-configuration/model select PC générique 105 touches (internat.)
#d-i keyboard-configuration/layout select Français
#_preseed_V1
### Network configuration
# Disable network configuration entirely. This is useful for cdrom
# installations on non-networked devices where the network questions,
# warning and long timeouts are a nuisance.
#d-i netcfg/enable boolean false
# netcfg will choose an interface that has link if possible. This makes it
# skip displaying a list if there is more than one interface.
d-i netcfg/choose_interface select auto
# To pick a particular interface instead:
#d-i netcfg/choose_interface select eth1
# To set a different link detection timeout (default is 3 seconds).
# Values are interpreted as seconds.
#d-i netcfg/link_wait_timeout string 10
# If you have a slow dhcp server and the installer times out waiting for
# it, this might be useful.
#d-i netcfg/dhcp_timeout string 60
#d-i netcfg/dhcpv6_timeout string 60
# If you prefer to configure the network manually, uncomment this line and
# the static network configuration below.
#d-i netcfg/disable_autoconfig boolean true
# If you want the preconfiguration file to work on systems both with and
# without a dhcp server, uncomment these lines and the static network
# configuration below.
d-i netcfg/dhcp_failed note
d-i netcfg/dhcp_options select Configure network manually
# Static network configuration.
# IPv4 example
d-i netcfg/get_ipaddress string 192.168.1.200
d-i netcfg/get_netmask string 255.255.255.0
d-i netcfg/get_gateway string 192.168.1.254
d-i netcfg/get_nameservers string 192.168.1.254
d-i netcfg/confirm_static boolean true
# IPv6 example
#d-i netcfg/get_ipaddress string fc00::2
#d-i netcfg/get_netmask string ffff:ffff:ffff:ffff::
#d-i netcfg/get_gateway string fc00::1
#d-i netcfg/get_nameservers string fc00::1
#d-i netcfg/confirm_static boolean true
# Any hostname and domain names assigned from dhcp take precedence over
# values set here. However, setting the values still prevents the questions
# from being shown, even if values come from dhcp.
d-i netcfg/get_hostname string vmssrv
d-i netcfg/get_domain string net.enedwaith.org
# If you want to force a hostname, regardless of what either the DHCP
# server returns or what the reverse DNS entry for the IP is, uncomment
# and adjust the following line.
#d-i netcfg/hostname string vmssrvstd
# Disable that annoying WEP key dialog.
#d-i netcfg/wireless_wep string
# The wacky dhcp hostname that some ISPs use as a password of sorts.
#d-i netcfg/dhcp_hostname string
# If non-free firmware is needed for the network or other hardware, you can
# configure the installer to always try to load it, without prompting. Or
# change to false to disable asking.
d-i hw-detect/load_firmware boolean true
### Network console
# Use the following settings if you wish to make use of the network-console
# component for remote installation over SSH. This only makes sense if you
# intend to perform the remainder of the installation manually.
#d-i anna/choose_modules string network-console
#d-i network-console/authorized_keys_url string http://10.0.0.1/openssh-key
#d-i network-console/password password r00tme
#d-i network-console/password-again password r00tme
#_preseed_V1
### Mirror settings
# If you select ftp, the mirror/country string does not need to be set.
#d-i mirror/protocol string ftp
d-i mirror/country string manual
#d-i mirror/http/hostname string ftp.fr.debian.org
d-i mirror/http/hostname string deb.debian.org
d-i mirror/http/directory string /debian
d-i mirror/http/proxy string
# Suite to install.
#d-i mirror/suite string testing
# Suite to use for loading installer components (optional).
#d-i mirror/udeb/suite string testing
# You now have the option to scan additional CDs or DVDs for use by the
# package manager (apt). Normally these should be from the same set as the
# installation CD/DVD. If you do not have any additional CDs or DVDs
# available, this step can just be skipped.
# If you wish to scan another CD or DVD, please insert it now.
d-i apt-setup/cdrom/set-first boolean false
### Description: for internal use; can be preseeded
# When set to true, apt-setup always disables cdrom entries from APT's
# configuration. Otherwise, it disables them only when a netinst image
# has been used.
# This option can be preseeded for automated installations that should
# not reference the installation media in the target system.
d-i apt-setup/disable-cdrom-entries boolean true
#_preseed_V1
### Account setup
# Skip creation of a root account (normal user account will be able to
# use sudo).
d-i passwd/root-login boolean true
# Alternatively, to skip creation of a normal user account.
#d-i passwd/make-user boolean false
# Root password, either in clear text
#d-i passwd/root-password password myrootpassword
#d-i passwd/root-password-again password myrootpassword
# or encrypted using a crypt(3) hash.
#d-i passwd/root-password-crypted password [crypt(3) hash]
d-i passwd/root-password-crypted password *******je met mon mot de passe chiffré ici*******
# To create a normal user account.
d-i passwd/user-fullname string toto
d-i passwd/username string password
# Normal user's password, either in clear text
#d-i passwd/user-password password myuserpassword
#d-i passwd/user-password-again password myuserpassword
d-i passwd/user-password-crypted password *******je met mon mot de passe chiffré ici*******
# Create the first user with the specified UID instead of the default.
#d-i passwd/user-uid string 1010
# The user account will be added to some standard initial groups. To
# override that, use this.
d-i passwd/user-default-groups string audio cdrom video sudo plugdev dip netdev
#_preseed_V1
### Clock and time zone setup
# Controls whether or not the hardware clock is set to UTC.
d-i clock-setup/utc boolean true
# You may set this to any valid setting for $TZ; see the contents of
# /usr/share/zoneinfo/ for valid values.
d-i time/zone string Europe/Paris
# Controls whether to use NTP to set the clock during the install
d-i clock-setup/ntp boolean true
# NTP server to use. The default is almost always fine here.
d-i clock-setup/ntp-server string 192.168.1.254
#_preseed_V1
### Partitioning
## Partitioning example
# If the system has free space you can choose to only partition that space.
# This is only honoured if partman-auto/method (below) is not set.
#d-i partman-auto/init_automatically_partition select biggest_free
#d-i anna/choose_modules multiselect fdisk-udeb,parted-udeb,disk-detect,cryptsetup-udeb,hw-detect
#d-i partman/early_command string anna-install localechooser fdisk-udeb parted-udeb disk-detect cryptsetup-udeb hw-detect; if [ ! -z `mount | grep -i sda | cut -d ' ' -f 1` ]; then umount `mount | grep -i sda | cut -d ' ' -f 1`; fi; liste=(`ls /dev/sda*`); if [ ${#liste[@]} -ne 1 ]; then sfdisk -f --delete /dev/sda; fi;
#d-i partman/early_command string anna-install localechooser fdisk-udeb parted-udeb disk-detect cryptsetup-udeb hw-detect; sfdisk -f --delete /dev/sda;
# anna-install fdisk-udeb parted-udeb disk-detect cryptsetup-udeb hw-detect; \
# /bin/dd if=/dev/zero of=/dev/sda bs=512 count=1;
# umount /dev/sda2; \
# Keep that one set to true so we end up with a UEFI enabled
# system. If set to false, /var/lib/partman/uefi_ignore will be touched
d-i partman-efi/non_efi_system boolean true
# enforce usage of GPT - a must have to use EFI!
d-i partman-basicfilesystems/choose_label string gpt
d-i partman-basicfilesystems/default_label string gpt
d-i partman-partitioning/choose_label string gpt
d-i partman-partitioning/default_label string gpt
d-i partman/choose_label string gpt
d-i partman/default_label string gpt
# Alternatively, you may specify a disk to partition. If the system has only
# one disk the installer will default to using that, but otherwise the device
# name must be given in traditional, non-devfs format (so e.g. /dev/sda
# and not e.g. /dev/discs/disc0/disc).
# For example, to use the first SCSI/SATA hard disk:
d-i partman-auto/disk string /dev/sda
# In addition, you'll need to specify the method to use.
# The presently available methods are:
# - regular: use the usual partition types for your architecture
# - lvm: use LVM to partition the disk
# - crypto: use LVM within an encrypted partition
#d-i partman-auto/method string lvm
d-i partman-auto-lvm/new_vg_name string vg01
# You can define the amount of space that will be used for the LVM volume
# group. It can either be a size with its unit (eg. 20 GB), a percentage of
# free space or the 'max' keyword.
d-i partman-auto-lvm/guided_size string max
# If one of the disks that are going to be automatically partitioned
# contains an old LVM configuration, the user will normally receive a
# warning. This can be preseeded away...
d-i partman-lvm/device_remove_lvm boolean true
# The same applies to pre-existing software RAID array:
d-i partman-md/device_remove_md boolean true
# And the same goes for the confirmation to write the lvm partitions.
d-i partman-lvm/confirm boolean true
d-i partman-lvm/confirm_nooverwrite boolean true
# You can choose one of the three predefined partitioning recipes:
# - atomic: all files in one partition
# - home: separate /home partition
# - multi: separate /home, /var, and /tmp partitions
d-i partman-auto/choose_recipe select boot-root
# Or provide a recipe of your own...
# If you have a way to get a recipe file into the d-i environment, you can
# just point at it.
#d-i partman-auto/expert_recipe_file string /hd-media/recipe
# Default filesystem used for new partitions
d-i partman/default_filesystem string ext4
# If not, you can put an entire recipe into the preconfiguration file in one
# (logical) line. This example creates a small /boot partition, suitable
# swap, and uses the rest of the space for the root partition:
#d-i partman-auto/expert_recipe string \
# boot-root :: \
# 40 50 100 ext3 \
# $primary{ } $bootable{ } \
# method{ format } format{ } \
# use_filesystem{ } filesystem{ ext3 } \
# mountpoint{ /boot } \
# 500 10000 1000000000 ext3 \
# mountpoint{ / } \
# 64 512 300% linux-swap \
# method{ swap } format{ } \
boot-root :: \
256 512 320 ext4 \
$primary{ } \
$bootable{ } \
use_filesystem{ } filesystem{ ext4 } \
label{ BOOT } \
200 512 220 free \
$iflabel{ gpt } \
$reusemethod{ } \
method{ efi } \
format{ } \
300% 2048 8000 linux-swap \
$lvmok{ } lv_name{ swap } \
10000 2260000 100000 ext4 \
$lvmok{ } lv_name{ root } \
method{ lvm } format{ } \
label{ ROOT } \
mountpoint{ / } \
options/relatime{ relatime } \
options/errors{ errors=remount-ro } \
4000 904000 25000 ext4 \
$lvmok{ } lv_name{ home } \
label{ HOME } \
mountpoint{ /home } \
options/nodev{ nodev } \
options/nosuid{ nosuid } \
$lvmok{ } lv_name{ var } \
label{ VAR } \
mountpoint{ /var } \
$lvmok{ } lv_name{ var_log } \
label{ LOG } \
mountpoint{ /var/log } \
options/noexec{ noexec } \
$lvmok{ } lv_name{ var_log_audit } \
label{ AUDIT } \
mountpoint{ /var/log/audit } \
2000 452000 8000 ext4 \
$lvmok{ } lv_name{ var_tmp } \
label{ VARTMP } \
mountpoint{ /var/tmp } \
$lvmok{ } lv_name{ tmp } \
label{ TMP } \
mountpoint{ /tmp } \
1 1 -1 ext4 \
$lvmok{ } lv_name{ todelete } \
# This makes partman automatically partition without confirmation, provided
# that you told it what to do using one of the methods above.
d-i partman-partitioning/confirm_write_new_label boolean true
d-i partman/choose_partition select finish
d-i partman/confirm boolean true
d-i partman/confirm_nooverwrite boolean true
### Description: Keep current partition layout and configure LVM?
# After the Logical Volume Manager is configured, no additional changes
# to the partitions in the disks containing physical volumes are
# allowed. Please decide if you are satisfied with the current
# partitioning scheme in these disks before continuing.
d-i partman-lvm/confirm_nochanges boolean true
## Controlling how partitions are mounted
# The default is to mount by UUID, but you can also choose "traditional" to
# use traditional device names, or "label" to try filesystem labels before
# falling back to UUIDs.
#d-i partman/mount_style select uuid
#_preseed_V1
### Base system installation
# Configure APT to not install recommended packages by default. Use of this
# option can result in an incomplete system and should only be used by very
# experienced users.
#d-i base-installer/install-recommends boolean false
# The kernel image (meta) package to be installed; "none" can be used if no
# kernel is to be installed.
d-i base-installer/kernel/image string linux-image-amd64
#_preseed_V1
### Apt setup
# You can choose to install non-free and contrib software.
d-i apt-setup/non-free boolean true
d-i apt-setup/contrib boolean true
# Uncomment this if you don't want to use a network mirror.
#d-i apt-setup/use_mirror boolean false
# Select which update services to use; define the mirrors to be used.
# Values shown below are the normal defaults.
d-i apt-setup/services-select multiselect security, updates, release updates, backports
d-i apt-setup/security_host string deb.debian.org
d-i apt-setup/security_path string /debian-security
### Description: Enable source repositories in APT?
# By default source repositories are listed in /etc/apt/sources.list (with
# appropriate "deb-src" lines) so that "apt-get source" works. However, if
# you don't need this feature, you can disable those entries and save some
# bandwidth during "apt-get update" operations.
d-i apt-setup/enable-source-repositories boolean false
# Additional repositories, local[0-9] available
#d-i apt-setup/local0/repository string \
# http://local.server/debian stable main
#d-i apt-setup/local0/comment string local server
#d-i apt-setup/local0/repository string webminrep.net.enedwaith.org sarge contrib
#d-i apt-setup/local0/comment string Webmin local server
# Enable deb-src lines
#d-i apt-setup/local0/source boolean true
# URL to the public key of the local repository; you must provide a key or
# apt will complain about the unauthenticated repository and so the
# sources.list line will be left commented out
#d-i apt-setup/local0/key string http://local.server/key
#d-i apt-setup/local0/key string https://download.webmin.com/jcameron-key.asc
# By default the installer requires that repositories be authenticated
# using a known gpg key. This setting can be used to disable that
# authentication. Warning: Insecure, not recommended.
#d-i debian-installer/allow_unauthenticated boolean true
# Uncomment this to add multiarch configuration for i386
#d-i apt-setup/multiarch string i386
#_preseed_V1
### Description: Drivers to include in the initrd:
# The primary function of an initrd is to allow the kernel to mount the
# root file system. It therefore needs to contain all drivers and supporting
# programs required to do that.
# A generic initrd is much larger than a targeted one and may even be so
# large that some boot loaders are unable to load it but has the advantage that
# it can be used to boot the target system on almost any hardware. With the
# smaller targeted initrd there is a very small chance that not all needed
# drivers are included.
d-i base-installer/initramfs-tools/driver-policy select include all available drivers
# Possible choices: generic: include all available drivers, targeted: only include drivers needed for this system
#_preseed_V1
### Package selection
#d-i tasksel/first multiselect standard, ssh-server
#d-i tasksel/remove multiselect desktop, gnome-desktop, xfce-desktop, kde-desktop, cinnamon-desktop, mate-desktop, lxde-desktop, lxqt-desktop, web-server, print-server, laptop
tasksel tasksel/first multiselect standard, desktop, gnome-desktop
tasksel tasksel/remove multiselect print-server
#d-i tasksel/tasks multiselect none
#d-i tasksel/desktop multiselect none
# Pour la configuration de wireshark
d-i wireshark-common/install-setuid boolean false
# Pour la configuration de console-data
d-i openssh-server/permit-root-login boolean false
# d-i console-data/keymap/template/variant select
# Suppress Strongswan Runlevel changes Note prompt
d-i strongswan/runlevel_changes note
d-i strongswan-starter/runlevel_changes note
# pour la configuration grub2
grub-efi-amd64 grub2/force_efi_extra_removable boolean true
# Individual additional packages to install
#d-i pkgsel/include string apt \
# Whether to upgrade packages after debootstrap.
# Allowed values: none, safe-upgrade, full-upgrade
d-i pkgsel/upgrade select safe-upgrade
# Some versions of the installer can report back on what software you have
# installed, and what software you use. The default is not to report back,
# but sending reports helps the project determine what software is most
# popular and include it on CDs.
popularity-contest popularity-contest/participate boolean false
#_preseed_V1
### Boot loader installation
# Grub is the default boot loader (for x86). If you want lilo installed
# instead, uncomment this:
#d-i grub-installer/skip boolean true
# To also skip installing lilo, and install no bootloader, uncomment this
# too:
#d-i lilo-installer/skip boolean true
# This is fairly safe to set, it makes grub install automatically to the MBR
# if no other operating system is detected on the machine.
d-i grub-installer/only_debian boolean true
# This one makes grub-installer install to the MBR if it also finds some other
# OS, which is less safe as it might not be able to boot that other OS.
#d-i grub-installer/with_other_os boolean tru
# Due notably to potential USB sticks, the location of the MBR can not be
# determined safely in general, so this needs to be specified:
d-i grub-installer/bootdev string /dev/sda
# To install to the first device (assuming it is not a USB stick):
#d-i grub-installer/bootdev string default
# Alternatively, if you want to install to a location other than the mbr,
# uncomment and edit these lines:
#d-i grub-installer/only_debian boolean false
#d-i grub-installer/with_other_os boolean false
#d-i grub-installer/bootdev string (hd0,1)
# To install grub to multiple disks:
#d-i grub-installer/bootdev string (hd0,1) (hd1,1) (hd2,1)
#d-i grub-installer/force-efi-extra-removable boolean true
# Optional password for grub, either in clear text
#d-i grub-installer/password password r00tme
#d-i grub-installer/password-again password r00tme
# or encrypted using an MD5 hash, see grub-md5-crypt(8).
#d-i grub-installer/password-crypted password [MD5 hash]
# Use the following option to add additional boot parameters for the
# installed system (if supported by the bootloader installer).
# Note: options passed to the installer will be added automatically.
#d-i debian-installer/add-kernel-opts string nousb
#_preseed_V1
### Finishing up the installation
# During installations from serial console, the regular virtual consoles
# (VT1-VT6) are normally disabled in /etc/inittab. Uncomment the next
# line to prevent this.
#d-i finish-install/keep-consoles boolean true
# Avoid that last message about the install being complete.
d-i finish-install/reboot_in_progress note
# This will prevent the installer from ejecting the CD during the reboot,
# which is useful in some situations.
#d-i cdrom-detect/eject boolean false
# This is how to make the installer shutdown when finished, but not
# reboot into the installed system.
#d-i debian-installer/exit/halt boolean true
# This will power off the machine instead of just halting it.
#d-i debian-installer/exit/poweroff boolean true
#_preseed_V1
### Preseeding other packages
# Depending on what software you choose to install, or if things go wrong
# during the installation process, it's possible that other questions may
# be asked. You can preseed those too, of course. To get a list of every
# possible question that could be asked during an install, do an
# installation, and then run these commands:
# debconf-get-selections --installer > file
# debconf-get-selections >> file
#_preseed_V1
#### Advanced options
### Running custom commands during the installation
# d-i preseeding is inherently not secure. Nothing in the installer checks
# for attempts at buffer overflows or other exploits of the values of a
# preconfiguration file like this one. Only use preconfiguration files from
# trusted locations! To drive that home, and because it's generally useful,
# here's a way to run any shell command you'd like inside the installer,
# automatically.
# This first command is run as early as possible, just after
# preseeding is read.
#d-i preseed/early_command string anna-install some-udeb
# This command is run immediately before the partitioner starts. It may be
# useful to apply dynamic partitioner preseeding that depends on the state
# of the disks (which may not be visible when preseed/early_command runs).
#d-i partman/early_command \
# string debconf-set partman-auto/disk "$(list-devices disk | head -n1)"
# This command is run just before the install finishes, but when there is
# still a usable /target directory. You can chroot to /target and use it
# directly, or use the apt-install and in-target commands to easily install
# packages and run commands in the target system.
#d-i preseed/late_command string apt-install zsh; in-target chsh -s /bin/zsh
#d-i preseed/late_command string in-target /cdrom/scripts/update-fstab.sh
d-i preseed/late_command string \
logger "late_command: remove todelete"; \
current_vg=`lvs | grep -Eoi '^\s+root.*ao' | /target/usr/bin/mawk -F ' ' '{ print $2 }'`; \
if [ ! -n `findmnt /todelete` ]; then umount /dev/mapper/${current_vg}-todelete; fi; \
lvchange -an /dev/mapper/${current_vg}-todelete; \
lvremove -y ${current_vg}/todelete;
# END-OF-FILE
