juste accepter la solution 1 puis ensuite recommencer avec le numero 2, le reste a la mano
aussi, avez-vous essayer de forcer ?
Re,
À cette heure, voici ce qu’il me reste du Gnome.
Avant.
[code]root@Feu-le-Gnome:~# dpkg -l | grep gnome
ii gir1.2-gnomebluetooth-1.0
ii gir1.2-gnomekeyring-1.0
ii gkbd-capplet
ii gnome
ii gnome-accessibility-themes
ii gnome-applets
ii gnome-applets-data
ii gnome-backgrounds
ii gnome-bluetooth
ii gnome-color-manager
ii gnome-contacts
ii gnome-control-center
ii gnome-control-center-data
ii gnome-core
ii gnome-desktop3-data
ii gnome-dictionary
ii gnome-disk-utility
ii gnome-documents
ii gnome-font-viewer
ii gnome-games
ii gnome-games-data
ii gnome-games-extra-data
ii gnome-icon-theme
ii gnome-icon-theme-extras
ii gnome-icon-theme-symbolic
ii gnome-js-common
ii gnome-keyring
ii gnome-mag
ii gnome-media
ii gnome-menus
ii gnome-mime-data
ii gnome-nettool
ii gnome-online-accounts
ii gnome-orca
ii gnome-packagekit
ii gnome-packagekit-data
ii gnome-panel
ii gnome-panel-data
ii gnome-power-manager
ii gnome-screensaver
ii gnome-screenshot
ii gnome-session
ii gnome-session-bin
ii gnome-session-common
ii gnome-session-fallback
ii gnome-settings-daemon
ii gnome-shell
ii gnome-shell-common
ii gnome-shell-extensions
ii gnome-sudoku
ii gnome-sushi
ii gnome-system-log
ii gnome-system-monitor
ii gnome-terminal
ii gnome-terminal-data
ii gnome-themes-standard
ii gnome-themes-standard-data
ii gnome-tweak-tool
ii gnome-user-guide
ii gnome-user-share
ii gnome-video-effects
ii libgnome-bluetooth10
ii libgnome-desktop-3-2
ii libgnome-keyring-common
ii libgnome-keyring0:amd64
ii libgnome-mag2
ii libgnome-media-profiles-3.0-0
ii libgnome-menu-3-0
ii libgnome2-0
ii libgnome2-common
ii libgnomecanvas2-0
ii libgnomecanvas2-common
ii libgnomekbd-common
ii libgnomekbd7
ii libgnomeui-0
ii libgnomeui-common
ii libgnomevfs2-0
ii libgnomevfs2-common
ii libgnomevfs2-extra
ii libpam-gnome-keyring
ii libreoffice-gnome
ii libsoup-gnome2.4-1:amd64
ii network-manager-gnome
ii policykit-1-gnome
ii python-gnome2
task-gnome-desktop
Après.
loreleil@Feu-le-Gnome:~$ dpkg -l | grep gnome
ii gnome-icon-theme 3.4.0-2 all GNOME Desktop icon theme
ii gnome-js-common 0.1.2-1 all Common modules for GNOME JavaScript interpreters
ii gnome-keyring 3.4.1-5 amd64 GNOME keyring services (daemon and tools)
ii gnome-mime-data 2.18.0-1 all base MIME and Application database for GNOME.
ii libgnome-keyring-common 3.4.1-1 all GNOME keyring services library - data files
ii libgnome-keyring0:amd64 3.4.1-1 amd64 GNOME keyring services library
ii libgnome2-0 2.32.1-3 amd64 The GNOME library - runtime files
ii libgnome2-common 2.32.1-3 all The GNOME library - common files
ii libgnomecanvas2-0 2.30.3-1.2 amd64 powerful object-oriented display engine - runtime files
ii libgnomecanvas2-common 2.30.3-1.2 all powerful object-oriented display engine - common files
ii libgnomekbd-common 3.4.0.2-1 all GNOME library to manage keyboard configuration - common files
ii libgnomekbd7 3.4.0.2-1 amd64 GNOME library to manage keyboard configuration - shared library
ii libgnomeui-0 2.24.5-2 amd64 GNOME user interface library - runtime files
ii libgnomeui-common 2.24.5-2 all GNOME user interface library - common files
ii libgnomevfs2-0 1:2.24.4-2 amd64 GNOME Virtual File System (runtime libraries)
ii libgnomevfs2-common 1:2.24.4-2 all GNOME Virtual File System (common files)
ii libgnomevfs2-extra 1:2.24.4-2 amd64 GNOME Virtual File System (extra modules)
ii libpam-gnome-keyring 3.4.1-5 amd64 PAM module to unlock the GNOME keyring upon login
ii libsoup-gnome2.4-1:amd64 2.38.1-3 amd64 HTTP library implementation in C -- GNOME support library
ii policykit-1-gnome 0.105-2 amd64 GNOME authentication agent for PolicyKit-1
ii python-gnome2 2.28.1+dfsg-1 amd64 Python bindings for the GNOME desktop environment
J’ai quelques trucs à vérifiés/comparés sur une autre machine (KDE-4).
C’est ici que la version ncurses d’aptitude devient bien pratique.
Lance-la avec [mono]aptitude[/mono] sans argument, puis affiche les détails du paquet [mono]gnome-core[/mono] ([mono]l[/mono] pour limiter l’affichage aux paquets contenant une chaîne de caractères données).
Tu obtiendras un écran semblable à celui-ci :
(avec probablement beaucoup moins de rouge que chez moi où les dépendances de gnome-core ne sont pas installées)
Place toi sur la ligne “Dépend” (avec les flèches directionnelles du clavier), et appuie sur [mono]-[/mono] pour marquer toutes les dépendances de gnome-core pour suppression.
Il se peut qu’un bandeau rouge apparaisse en bas de ton écran, comme sur l’image suivante :
Dans ce cas appuie sur [mono]e[/mono] et suis les instructions à l’écran pour régler les éventuels conflits.
Enfin, appuie une fois sur [mono]g[/mono] pour examiner la solution proposée par aptitude, puis une seconde fois pour les appliquer.
Si une étape n’est pas claire, reviens par ici et j’essaierai de te guider.
Merci vv222, je vais essayer ton truc.
Petit problème : comme tu as vu plus haut, j’ai désinstallé gnome-core ! Que faire ? Le réinstaller pour le désinstaller selon ta méthode ?
ncurses c’est cette interface que tu peux voir dans les images que j’ai posté, qui imite des applications graphiques en console.
Si aptitude est installé, tu as accès à cette interface sans installer de paquet supplémentaire.
Oui, merci j’ai découvert cette interface.
Maintenant j’ai le problème suivant : je n’ai plus gnome-core…
edit : trop tard, je continuerai demain… (J’ai vu un truc très bizarre, aptitude se propose de me désinstaller AUSSI xfce4 et xfce4-goodies… ???)
[quote=“laso6”]Oui, merci j’ai découvert cette interface.
Maintenant j’ai le problème suivant : je n’ai plus gnome-core…[/quote]
C’est le but, non ?
Quand aptitude te propose une liste de propositions pour résoudre les conflits de dépendances (après un appui sur [mono]e[/mono]), tu peux l’orienter précisément.
Pour ça, sélectionne une proposition (avec les flèches directionnelles), et appuie sur [mono]r[/mono] pour rejeter une option (elle se colore en rouge) ou [mono]a[/mono] pour l’approuver (elle se colore en vert).
Quand tu appuieras sur [mono].[/mono] pour obtenir la suggestion suivante d’aptitude tes choix seront pris en compte dans le nouveau calcul de résolution des dépendances.
Dans ton cas, tu vas probablement vouloir rejeter la désinstallation de xfce4 et xfce4-goodies, ce qui impliquera de conserver installés quelques paquets qui sont aussi des dépendances de gnome-core (c’est le principe des dépendances, elles sont très souvent utilisées par plusieurs paquets).
Bon… Comme je ne maîtrise rien du tout, j’ai fait comme j’ai pu et ça a donné à peu près ça :
[code]Suppression de gcr …
Suppression de libgcr-3-1 …
Suppression de gcalctool …
Suppression de evolution-webcal …
Suppression de libedataserverui-3.0-1 …
Suppression de libevdocument3-4 …
Suppression de dconf-tools …
Suppression de libclutter-imcontext-0.1-bin …
Suppression de libclutter-imcontext-0.1-0:i386 …
Suppression de libclutter-gtk-1.0-0:i386 …
Suppression de libcluttergesture-0.0.2-0:i386 …
Suppression de libchamplain-0.12-0:i386 …
Suppression de libclutter-gst-1.0-0:i386 …
Suppression de libclutter-1.0-0:i386 …
Suppression de gir1.2-caribou-1.0 …
Suppression de libcaribou0:i386 …
Suppression de libcaribou-gtk3-module:i386 …
Suppression de libavahi-ui-gtk3-0:i386 …
Suppression de libgtk-3-0:i386 …
Suppression de libgtk-3-common …
Suppression de gnome-video-effects …
Suppression de libtelepathy-farstream2:i386 …
Suppression de telepathy-haze …
Suppression de libpurple-bin …
Suppression de libpurple0 …
Suppression de libfarstream-0.1-0:i386 …
Suppression de gstreamer0.10-plugins-bad:i386 …
Suppression de xfce4-goodies …
Suppression de xfce4-screenshooter …
Suppression de midori …
Suppression de gimp …
Suppression de libwebkitgtk-1.0-0 …
Suppression de gir1.2-totem-plparser-1.0 …
Suppression de grilo-plugins-0.1:i386 …
Suppression de libtotem-plparser17 …
Suppression de telepathy-salut …
Suppression de telepathy-gabble …
Suppression de rygel-playbin …
Suppression de rygel …
Suppression de gir1.2-gdata-0.0 …
Suppression de gir1.2-soup-2.4 …
Suppression de libsocialweb-service …
Suppression de libsocialweb0:i386 …
Suppression de librest-extras-0.7-0:i386 …
Suppression de librest-0.7-0:i386 …
Suppression de libgdata13 …
Suppression de soundconverter …
Suppression de gstreamer0.10-plugins-good:i386 …
Suppression de libsoup-gnome2.4-1:i386 …
Suppression de gstreamer0.10-nice:i386 …
Suppression de libnice10:i386 …
Suppression de libepc-1.0-3 …
Suppression de libdmapsharing-3.0-2 …
Suppression de libgupnp-igd-1.0-4:i386 …
Suppression de libgupnp-av-1.0-2 …
Suppression de libgupnp-1.0-4 …
Suppression de libgssdp-1.0-3 …
Suppression de libgrilo-0.1-0:i386 …
Suppression de libgeocode-glib0 …
Suppression de libedata-cal-1.2-15 …
Suppression de libecal-1.2-11 …
Suppression de libreoffice-evolution …
Suppression de libebook-1.2-13 …
Suppression de libebackend-1.2-2 …
Suppression de libedataserver-1.2-16 …
Suppression de libsoup2.4-1:i386 …
Suppression de glib-networking:i386 …
Suppression de evince-common …
Suppression de libcaribou-gtk-module:i386 …
Suppression de gsettings-desktop-schemas …
Suppression de gnome-shell-common …
Suppression de gnome-panel-data …
Suppression de gnome-games-data …
Suppression de gedit-common …
Suppression de evolution-data-server-common …
Suppression de evolution-common …
Suppression de libatk-adaptor-data …
Suppression de dconf-gsettings-backend:i386 …
Suppression de empathy-common …
Suppression de finger …
Suppression de fonts-cantarell …
Suppression de fonts-sil-gentium …
Suppression de libreoffice …
Suppression de ttf-sil-gentium-basic …
Suppression de fonts-sil-gentium-basic …
Suppression de tomboy …
Suppression de stardict-plugin-festival …
Suppression de stardict-plugin-espeak …
Suppression de stardict-plugin …
Suppression de stardict …
Suppression de stardict-gnome …
Suppression de libreoffice-gnome …
Suppression de libgweather-common …
Suppression de hamster-applet …
Suppression de python-gnome2 …
Suppression de libgnomeui-0 …
Suppression de libbonoboui2-0 …
Suppression de libgnome2-0 …
Suppression de libgnome2-common …
Suppression de gksu …
Suppression de libgksu2-0 …
update-alternatives: utilisation de « /usr/share/libgksu/debian/gconf-defaults.libgksu-sudo » pour fournir « /usr/share/gconf/defaults/10_libgksu » (libgksu-gconf-defaults) en mode automatique
Suppression de libcanberra-gtk-module:i386 …
Suppression de gstreamer0.10-gconf:i386 …
Suppression de libgnomevfs2-extra …
Suppression de inkscape …
Suppression de libgnomevfs2-0 …
Suppression de libgnomevfs2-common …
Suppression de gnome-terminal-data …
Suppression de gnome-applets-data …
Suppression de gconf2 …
Suppression de gir1.2-gnomekeyring-1.0 …
Suppression de gir1.2-gtop-2.0 …
Suppression de gir1.2-tracker-0.14 …
Suppression de gnash …
Suppression de gnash-common …
Suppression de gnome-backgrounds …
dpkg : avertissement : lors de la suppression de gnome-backgrounds, le répertoire « /usr/share/backgrounds/gnome » n’était pas vide, donc il n’a pas été supprimé
Suppression de gnome-games-extra-data …
Suppression de gnome-menus …
Suppression de gnome-packagekit-data …
Suppression de gnuchess-book …
Suppression de gnuchess …
Suppression de xfce4 …
Suppression de xfce4-mixer …
Suppression de gstreamer0.10-plugins-base:i386 …
Suppression de xfce4-volumed …
Suppression de gstreamer0.10-pulseaudio:i386 …
Suppression de gtk2-engines:i386 …
Suppression de guile-2.0-libs …
Suppression de gvfs-bin …
Suppression de hyphen-en-us …
Suppression de iceweasel-l10n-fr …
Suppression de iceweasel …
Suppression de « détournement de /usr/bin/firefox en /usr/bin/firefox.real par iceweasel »
Suppression de iputils-tracepath …
Suppression de python-pyatspi2 …
Suppression de python-pyatspi …
Suppression de libatk-adaptor:i386 …
Suppression de libavahi-gobject0:i386 …
Suppression de libblas3gf …
Suppression de libboost-program-options1.49.0 …
Suppression de libcanberra-pulse:i386 …
Suppression de libreoffice-calc …
Suppression de lp-solve …
Suppression de libcolamd2.7.1 …
Suppression de zeitgeist-core …
Suppression de libdee-1.0-4 …
Suppression de libdiscid0:i386 …
Suppression de libestools2.1:i386 …
Suppression de libgdict-common …
Suppression de libgexiv2-1 …
Suppression de libgpod-common …
Suppression de libgpod4:i386 …
Suppression de libgupnp-dlna-1.0-2 …
Suppression de libgvnc-1.0-0 …
Suppression de libicc2:i386 …
Suppression de libimdi0:i386 …
Suppression de liblinear-tools …
Suppression de nmap …
Suppression de liblinear1 …
Suppression de pstoedit …
Suppression de libpstoedit0c2a …
Suppression de libmagick++5:i386 …
Suppression de libminiupnpc5 …
Suppression de libnatpmp1 …
Suppression de libpam-gnome-keyring …
Suppression de libplot2c2 …
Suppression de libraw5:i386 …
Suppression de libreoffice-impress …
Suppression de libreoffice-draw …
Suppression de libreoffice-filter-mobiledev …
Suppression de libreoffice-gtk …
Suppression de libreoffice-help-en-us …
Suppression de libreoffice-report-builder-bin …
Suppression de telepathy-rakia …
Suppression de libsofia-sip-ua-glib3 …
Suppression de libsofia-sip-ua0 …
Suppression de libsvm-tools …
Suppression de libvisio-0.0-0 …
Suppression de media-player-info …
Suppression de minissdpd …
Suppression de mobile-broadband-provider-info …
Suppression de mythes-en-us …
Suppression de perlmagick …
Suppression de pulseaudio-module-x11 …
Suppression de pulseaudio …
[warn] PulseAudio configured for per-user sessions … (warning).
Suppression de python-gconf …
Suppression de python-gst0.10 …
Suppression de python-mako …
Suppression de python-markupsafe …
Suppression de python-pyorbit …
Suppression de python-wnck …
Suppression de python-zeitgeist …
Suppression de rdesktop …
Suppression de sound-theme-freedesktop …
Suppression de stardict-common …
Suppression de telepathy-idle …
Suppression de transmission-common …
Suppression de ttf-liberation …
Suppression de unoconv …
Traitement des actions différées (« triggers ») pour « hicolor-icon-theme »…
Traitement des actions différées (« triggers ») pour « man-db »…
Traitement des actions différées (« triggers ») pour « libglib2.0-0:i386 »…
Aucun fichier schéma trouvé : fichier de sortie existant supprimé.
Traitement des actions différées (« triggers ») pour « menu »…
Traitement des actions différées (« triggers ») pour « desktop-file-utils »…
Traitement des actions différées (« triggers ») pour « shared-mime-info »…
Traitement des actions différées (« triggers ») pour « mime-support »…
Traitement des actions différées (« triggers ») pour « sgml-base »…
Traitement des actions différées (« triggers ») pour « python-support »…
Traitement des actions différées (« triggers ») pour « fontconfig »…
Traitement des actions différées (« triggers ») pour « doc-base »…
Traitement de 4 fichiers de documentation supprimés…
Enregistrement des documents avec scrollkeeper…
Traitement des actions différées (« triggers ») pour « install-info »…
Appuyez sur Entrée pour continuer.
so6@dell-so6:~$ su[/code]
puis encore ça…
so6@dell-so6:~$ su
Mot de passe :
root@dell-so6:/home/so6# aptitude install xfce4 xfce4-goodies
dconf-gsettings-backend{a} glib-networking{a} gsettings-desktop-schemas{a} gstreamer0.10-alsa{a}
gstreamer0.10-plugins-base{a} libsoup2.4-1{a} xfce4 xfce4-goodies xfce4-mixer{a} xfce4-screenshooter{a}
xfce4-volumed{a}
apache2.2-bin{u} aptdaemon{u} aptdaemon-data{u} folks-common{u} freepats{u} geoclue{u} geoclue-hostip{u}
geoclue-localnet{u} geoclue-manual{u} geoclue-yahoo{u} gir1.2-accountsservice-1.0{u} gir1.2-atk-1.0{u}
gir1.2-atspi-2.0{u} gir1.2-cogl-1.0{u} gir1.2-coglpango-1.0{u} gir1.2-folks-0.6{u} gir1.2-freedesktop{u}
gir1.2-gck-1{u} gir1.2-gconf-2.0{u} gir1.2-gdesktopenums-3.0{u} gir1.2-gdkpixbuf-2.0{u} gir1.2-gee-1.0{u}
gir1.2-gmenu-3.0{u} gir1.2-gst-plugins-base-0.10{u} gir1.2-gstreamer-0.10{u} gir1.2-json-1.0{u}
gir1.2-networkmanager-1.0{u} gir1.2-pango-1.0{u} gir1.2-polkit-1.0{u} gir1.2-telepathyglib-0.12{u}
gir1.2-telepathylogger-0.2{u} gir1.2-upowerglib-1.0{u} gir1.2-xkl-1.0{u} gjs{u} gnome-accessibility-themes{u}
gnome-session-common{u} gnome-themes-standard-data{u} gstreamer0.10-ffmpeg{u} gstreamer0.10-plugins-ugly{u}
gstreamer0.10-x{u} hddtemp{u} libapache2-mod-dnssd{u} libapr1{u} libaprutil1{u} libaprutil1-dbd-sqlite3{u}
libaprutil1-ldap{u} libatk-bridge2.0-0{u} libatspi2.0-0{u} libavahi-glib1{u} libcairo-gobject2{u} libcamel-1.2-33{u}
libcdaudio1{u} libcdio-cdda1{u} libcdio-paranoia1{u} libcogl-common{u} libcogl-pango0{u} libcogl9{u} libcpufreq0{u}
libdv4{u} libexempi3{u} libfftw3-3{u} libfolks-telepathy25{u} libfolks25{u} libgail-common{u} libgail18{u}
libgck-1-0{u} libgee2{u} libgeoclue0{u} libgjs0b{u} libgme0{u} libgnome-menu-3-0{u} libgnomecanvas2-0{u}
libgnomecanvas2-common{u} libgsf-1-114{u} libgsf-1-common{u} libgstreamer-plugins-bad0.10-0{u} libgtop2-7{u}
libgtop2-common{u} libiec61883-0{u} libiptcdata0{u} libjavascriptcoregtk-3.0-0{u} libjson-glib-1.0-0{u} libmimic0{u}
libmission-control-plugins0{u} libmms0{u} libmozjs185-1.0{u} libmusicbrainz5-0{u} liboauth0{u} libofa0{u}
libopenal-data{u} libopenal1{u} libopencore-amrnb0{u} libopencore-amrwb0{u} libopenobex1{u} libopus0{u} libpst4{u}
libpulse-mainloop-glib0{u} libsidplay1{u} libslv2-9{u} libsoundtouch0{u} libspandsp2{u} libtelepathy-glib0{u}
libtelepathy-logger2{u} libtracker-extract-0.14-0{u} libtracker-miner-0.14-0{u} libtracker-sparql-0.14-0{u}
libunistring0{u} libvo-aacenc0{u} libvo-amrwbenc0{u} libwavpack1{u} libwildmidi-config{u} libwildmidi1{u} libzbar0{u}
obex-data-server{u} pulseaudio-utils{u} python-aptdaemon{u} python-defer{u} python-gnupginterface{u} python-gobject{u}
python-httplib2{u} python-pycurl{u} python-software-properties{u} unattended-upgrades{u} xfprint4{u} zenity-common{u}
0 paquets mis à jour, 11 nouvellement installés, 125 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 1 898 ko/4 146 ko d'archives. Après dépaquetage, 98,2 Mo seront libérés.
Voulez-vous continuer ? [Y/n/?] y
Prendre : 1 ftp://ftp.fr.debian.org/debian/ wheezy/main dconf-gsettings-backend i386 0.12.1-3 [21,4 kB]
Prendre : 2 ftp://ftp.fr.debian.org/debian/ wheezy/main gsettings-desktop-schemas all 3.4.2-3 [114 kB]
Prendre : 3 ftp://ftp.fr.debian.org/debian/ wheezy/main glib-networking i386 2.32.3-1 [57,3 kB]
Prendre : 4 ftp://ftp.fr.debian.org/debian/ wheezy/main gstreamer0.10-alsa i386 0.10.36-1.1 [596 kB]
Prendre : 5 ftp://ftp.fr.debian.org/debian/ wheezy/main gstreamer0.10-plugins-base i386 0.10.36-1.1 [1 109 kB]
1 898 ko téléchargés en 2s (723 ko/s)
(Lecture de la base de données... 93062 fichiers et répertoires déjà installés.)
Suppression de libapache2-mod-dnssd ...
Suppression de apache2.2-bin ...
Suppression de aptdaemon ...
Suppression de aptdaemon-data ...
Suppression de folks-common ...
Suppression de freepats ...
Suppression de geoclue-yahoo ...
Suppression de geoclue-manual ...
Suppression de geoclue-localnet ...
Suppression de geoclue-hostip ...
Suppression de geoclue ...
Suppression de gir1.2-accountsservice-1.0 ...
Suppression de gir1.2-atk-1.0 ...
Suppression de gir1.2-atspi-2.0 ...
Suppression de gir1.2-coglpango-1.0 ...
Suppression de gir1.2-cogl-1.0 ...
Suppression de gir1.2-folks-0.6 ...
Suppression de gir1.2-pango-1.0 ...
Suppression de gir1.2-networkmanager-1.0 ...
Suppression de gir1.2-xkl-1.0 ...
Suppression de gir1.2-gst-plugins-base-0.10 ...
Suppression de gir1.2-gstreamer-0.10 ...
Suppression de gir1.2-freedesktop ...
Suppression de gir1.2-gck-1 ...
Suppression de gir1.2-gconf-2.0 ...
Suppression de gir1.2-gdesktopenums-3.0 ...
Suppression de gir1.2-gdkpixbuf-2.0 ...
Suppression de gir1.2-gee-1.0 ...
Suppression de gir1.2-gmenu-3.0 ...
Suppression de gir1.2-json-1.0 ...
Suppression de gir1.2-polkit-1.0 ...
Suppression de gir1.2-telepathylogger-0.2 ...
Suppression de gir1.2-telepathyglib-0.12 ...
Suppression de gir1.2-upowerglib-1.0 ...
Suppression de gjs ...
Suppression de gnome-accessibility-themes ...
Suppression de gnome-session-common ...
Suppression de gnome-themes-standard-data ...
Suppression de gstreamer0.10-ffmpeg:i386 ...
Suppression de gstreamer0.10-plugins-ugly:i386 ...
Suppression de gstreamer0.10-x:i386 ...
Suppression de hddtemp ...
Suppression de libaprutil1-ldap ...
Suppression de libaprutil1-dbd-sqlite3 ...
Suppression de libaprutil1 ...
Suppression de libapr1 ...
Suppression de libatk-bridge2.0-0:i386 ...
Suppression de libatspi2.0-0:i386 ...
Suppression de libavahi-glib1:i386 ...
Suppression de libgjs0b ...
Suppression de libcairo-gobject2:i386 ...
Suppression de libcamel-1.2-33 ...
Suppression de libcdaudio1 ...
Suppression de libcdio-paranoia1 ...
Suppression de libcdio-cdda1 ...
Suppression de libcogl-common ...
Suppression de libcogl-pango0:i386 ...
Suppression de libcogl9:i386 ...
Suppression de libcpufreq0 ...
Suppression de libdv4:i386 ...
Suppression de libtracker-extract-0.14-0 ...
Suppression de libexempi3:i386 ...
Suppression de libofa0 ...
Suppression de libfftw3-3:i386 ...
Suppression de libfolks-telepathy25 ...
Suppression de libfolks25 ...
Suppression de libgail-common:i386 ...
Suppression de libgnomecanvas2-0 ...
Suppression de libgail18:i386 ...
Suppression de libgck-1-0 ...
Suppression de libgee2:i386 ...
Suppression de libgeoclue0 ...
Suppression de libgme0 ...
Suppression de libgnome-menu-3-0 ...
Suppression de libgnomecanvas2-common ...
Suppression de libgsf-1-114 ...
Suppression de libgsf-1-common ...
Suppression de libgstreamer-plugins-bad0.10-0:i386 ...
Suppression de libgtop2-7 ...
Suppression de libgtop2-common ...
Suppression de libiec61883-0 ...
Suppression de libiptcdata0 ...
Suppression de libjavascriptcoregtk-3.0-0 ...
Suppression de libjson-glib-1.0-0:i386 ...
Suppression de libmimic0 ...
Suppression de libmission-control-plugins0 ...
Suppression de libmms0:i386 ...
Suppression de libmozjs185-1.0 ...
Suppression de libmusicbrainz5-0:i386 ...
Suppression de liboauth0:i386 ...
Suppression de libopenal1:i386 ...
Suppression de libopenal-data ...
Suppression de libopencore-amrnb0:i386 ...
Suppression de libopencore-amrwb0:i386 ...
Suppression de obex-data-server ...
Suppression de libopenobex1 ...
Suppression de libopus0 ...
Suppression de libpst4:i386 ...
Suppression de libpulse-mainloop-glib0:i386 ...
Suppression de libsidplay1 ...
Suppression de libslv2-9 ...
Suppression de libsoundtouch0:i386 ...
Suppression de libspandsp2 ...
Suppression de libtelepathy-logger2:i386 ...
Suppression de libtelepathy-glib0:i386 ...
Suppression de libtracker-miner-0.14-0 ...
Suppression de libtracker-sparql-0.14-0 ...
Suppression de libunistring0:i386 ...
Suppression de libvo-aacenc0:i386 ...
Suppression de libvo-amrwbenc0:i386 ...
Suppression de libwavpack1:i386 ...
Suppression de libwildmidi1:i386 ...
Suppression de libwildmidi-config ...
Suppression de libzbar0 ...
Suppression de pulseaudio-utils ...
Suppression de python-aptdaemon ...
Suppression de python-defer ...
Suppression de python-software-properties ...
Suppression de python-gnupginterface ...
Suppression de python-gobject ...
Suppression de python-httplib2 ...
Suppression de python-pycurl ...
Suppression de unattended-upgrades ...
Suppression de xfprint4 ...
Suppression de zenity-common ...
Traitement des actions différées (« triggers ») pour « man-db »...
Traitement des actions différées (« triggers ») pour « hicolor-icon-theme »...
Traitement des actions différées (« triggers ») pour « desktop-file-utils »...
Traitement des actions différées (« triggers ») pour « doc-base »...
Traitement de 3 fichiers de documentation supprimés…
Traitement des actions différées (« triggers ») pour « python-support »...
Traitement des actions différées (« triggers ») pour « menu »...
Sélection du paquet dconf-gsettings-backend:i386 précédemment désélectionné.
(Lecture de la base de données... 87613 fichiers et répertoires déjà installés.)
Dépaquetage de dconf-gsettings-backend:i386 (à partir de .../dconf-gsettings-backend_0.12.1-3_i386.deb) ...
Sélection du paquet gsettings-desktop-schemas précédemment désélectionné.
Dépaquetage de gsettings-desktop-schemas (à partir de .../gsettings-desktop-schemas_3.4.2-3_all.deb) ...
Sélection du paquet glib-networking:i386 précédemment désélectionné.
Dépaquetage de glib-networking:i386 (à partir de .../glib-networking_2.32.3-1_i386.deb) ...
Sélection du paquet libsoup2.4-1:i386 précédemment désélectionné.
Dépaquetage de libsoup2.4-1:i386 (à partir de .../libsoup2.4-1_2.38.1-3_i386.deb) ...
Sélection du paquet gstreamer0.10-alsa:i386 précédemment désélectionné.
Dépaquetage de gstreamer0.10-alsa:i386 (à partir de .../gstreamer0.10-alsa_0.10.36-1.1_i386.deb) ...
Sélection du paquet gstreamer0.10-plugins-base:i386 précédemment désélectionné.
Dépaquetage de gstreamer0.10-plugins-base:i386 (à partir de .../gstreamer0.10-plugins-base_0.10.36-1.1_i386.deb) ...
Sélection du paquet xfce4-mixer précédemment désélectionné.
Dépaquetage de xfce4-mixer (à partir de .../xfce4-mixer_4.8.0-3+b1_i386.deb) ...
Sélection du paquet xfce4 précédemment désélectionné.
Dépaquetage de xfce4 (à partir de .../archives/xfce4_4.8.0.3_all.deb) ...
Sélection du paquet xfce4-screenshooter précédemment désélectionné.
Dépaquetage de xfce4-screenshooter (à partir de .../xfce4-screenshooter_1.8.1-1+b1_i386.deb) ...
Sélection du paquet xfce4-volumed précédemment désélectionné.
Dépaquetage de xfce4-volumed (à partir de .../xfce4-volumed_0.1.13-3_i386.deb) ...
Sélection du paquet xfce4-goodies précédemment désélectionné.
Dépaquetage de xfce4-goodies (à partir de .../xfce4-goodies_4.8.2_i386.deb) ...
Traitement des actions différées (« triggers ») pour « libglib2.0-0:i386 »...
Paramétrage de dconf-gsettings-backend:i386 (0.12.1-3) ...
Paramétrage de gsettings-desktop-schemas (3.4.2-3) ...
Paramétrage de glib-networking:i386 (2.32.3-1) ...
Paramétrage de libsoup2.4-1:i386 (2.38.1-3) ...
Paramétrage de gstreamer0.10-alsa:i386 (0.10.36-1.1) ...
Paramétrage de gstreamer0.10-plugins-base:i386 (0.10.36-1.1) ...
Paramétrage de xfce4-mixer (4.8.0-3+b1) ...
Paramétrage de xfce4 (4.8.0.3) ...
Paramétrage de xfce4-screenshooter (1.8.1-1+b1) ...
Paramétrage de xfce4-volumed (0.1.13-3) ...
Paramétrage de xfce4-goodies (4.8.2) ...
puis…
root@dell-so6:/home/so6# aptitude install stardict tomboy libreoffice rythmbox transmission
Impossible de trouver un paquet dont le nom ou la description corresponde à « rythmbox »
fonts-sil-gentium{a} fonts-sil-gentium-basic{a} gconf2{a} libavahi-glib1 libbonoboui2-0{a} libcairo-gobject2{a}
libcolamd2.7.1{a} libestools2.1{a} libgail18{a} libgnome2-0{a} libgnome2-common{a} libgnomecanvas2-0{a}
libgnomecanvas2-common{a} libgnomeui-0{a} libgnomevfs2-0{a} libgnomevfs2-common libgnomevfs2-extra libgtk-3-0{a}
libgtk-3-bin{a} libgtk-3-common{a} libminiupnpc5{a} libnatpmp1{a} libreoffice libreoffice-calc{a} libreoffice-draw{a}
libreoffice-filter-mobiledev{a} libreoffice-impress{a} libreoffice-report-builder-bin{a} libvisio-0.0-0{a} lp-solve{a}
minissdpd{a} stardict stardict-common{a} stardict-gnome{a} stardict-plugin{a} stardict-plugin-espeak{a}
stardict-plugin-festival{a} tomboy transmission transmission-common{a} transmission-gtk{a} ttf-sil-gentium-basic{a}
0 paquets mis à jour, 42 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 20,2 Mo/29,5 Mo d'archives. Après dépaquetage, 115 Mo seront utilisés.
Prendre : 1 http://security.debian.org/ wheezy/updates/main transmission all 2.52-3+nmu2 [1 096 B]
Prendre : 2 ftp://ftp.fr.debian.org/debian/ wheezy/main libavahi-glib1 i386 0.6.31-2 [37,6 kB]
Prendre : 3 ftp://ftp.fr.debian.org/debian/ wheezy/main libcairo-gobject2 i386 1.12.2-3 [438 kB]
Prendre : 4 ftp://ftp.fr.debian.org/debian/ wheezy/main libgail18 i386 2.24.10-2 [482 kB]
Prendre : 5 ftp://ftp.fr.debian.org/debian/ wheezy/main fonts-sil-gentium all 20081126:1.02-12 [685 kB]
Prendre : 6 ftp://ftp.fr.debian.org/debian/ wheezy/main fonts-sil-gentium-basic all 1.1-5 [871 kB]
Prendre : 7 ftp://ftp.fr.debian.org/debian/ wheezy/main gconf2 i386 3.2.5-1+build1 [416 kB]
Prendre : 8 ftp://ftp.fr.debian.org/debian/ wheezy/main libgnomevfs2-common all 1:2.24.4-2 [757 kB]
Prendre : 9 ftp://ftp.fr.debian.org/debian/ wheezy/main libgnomevfs2-0 i386 1:2.24.4-2 [512 kB]
Prendre : 10 ftp://ftp.fr.debian.org/debian/ wheezy/main libgnome2-common all 2.32.1-3 [916 kB]
Prendre : 11 ftp://ftp.fr.debian.org/debian/ wheezy/main libgnome2-0 i386 2.32.1-3 [473 kB]
Prendre : 12 ftp://ftp.fr.debian.org/debian/ wheezy/main libgnomecanvas2-common all 2.30.3-1.2 [133 kB]
Prendre : 13 ftp://ftp.fr.debian.org/debian/ wheezy/main libgnomecanvas2-0 i386 2.30.3-1.2 [111 kB]
Prendre : 14 ftp://ftp.fr.debian.org/debian/ wheezy/main libbonoboui2-0 i386 2.24.3-1 [234 kB]
Prendre : 15 ftp://ftp.fr.debian.org/debian/ wheezy/main libcolamd2.7.1 i386 1:3.4.0-3 [16,7 kB]
Prendre : 16 ftp://ftp.fr.debian.org/debian/ wheezy/main libgnomeui-0 i386 2.24.5-2 [374 kB]
Prendre : 17 ftp://ftp.fr.debian.org/debian/ wheezy/main libgnomevfs2-extra i386 1:2.24.4-2 [377 kB]
Prendre : 18 ftp://ftp.fr.debian.org/debian/ wheezy/main libminiupnpc5 i386 1.5-2 [36,3 kB]
Prendre : 19 ftp://ftp.fr.debian.org/debian/ wheezy/main libnatpmp1 i386 20110808-3 [9 028 B]
Prendre : 20 ftp://ftp.fr.debian.org/debian/ wheezy/main lp-solve i386 5.5.0.13-7 [303 kB]
Prendre : 21 ftp://ftp.fr.debian.org/debian/ wheezy/main libreoffice-calc i386 1:3.5.4+dfsg2-0+deb7u2 [5 065 kB]
Prendre : 22 ftp://ftp.fr.debian.org/debian/ wheezy/main libvisio-0.0-0 i386 0.0.17-1 [192 kB]
Prendre : 23 ftp://ftp.fr.debian.org/debian/ wheezy/main libreoffice-draw i386 1:3.5.4+dfsg2-0+deb7u2 [2 502 kB]
Prendre : 24 ftp://ftp.fr.debian.org/debian/ wheezy/main libreoffice-impress i386 1:3.5.4+dfsg2-0+deb7u2 [618 kB]
Prendre : 25 ftp://ftp.fr.debian.org/debian/ wheezy/main libreoffice-report-builder-bin i386 1:3.5.4+dfsg2-0+deb7u2 [757 kB]
Prendre : 26 ftp://ftp.fr.debian.org/debian/ wheezy/main ttf-sil-gentium-basic all 1.1-5 [8 028 B]
Prendre : 27 ftp://ftp.fr.debian.org/debian/ wheezy/main libreoffice-filter-mobiledev all 1:3.5.4+dfsg2-0+deb7u2 [159 kB]
Prendre : 28 ftp://ftp.fr.debian.org/debian/ wheezy/main libreoffice i386 1:3.5.4+dfsg2-0+deb7u2 [50,5 kB]
Prendre : 29 ftp://ftp.fr.debian.org/debian/ wheezy/main minissdpd i386 1.1.20120121-1 [17,9 kB]
Prendre : 30 ftp://ftp.fr.debian.org/debian/ wheezy/main tomboy i386 1.10.0-2 [3 655 kB]
20,2 Mo téléchargés en 19s (1 043 ko/s)
Extraction des modèles depuis les paquets : 100%
Sélection du paquet libavahi-glib1:i386 précédemment désélectionné.
(Lecture de la base de données... 87989 fichiers et répertoires déjà installés.)
Dépaquetage de libavahi-glib1:i386 (à partir de .../libavahi-glib1_0.6.31-2_i386.deb) ...
Sélection du paquet libcairo-gobject2:i386 précédemment désélectionné.
Dépaquetage de libcairo-gobject2:i386 (à partir de .../libcairo-gobject2_1.12.2-3_i386.deb) ...
Sélection du paquet libestools2.1:i386 précédemment désélectionné.
Dépaquetage de libestools2.1:i386 (à partir de .../libestools2.1_1%3a2.1~release-5_i386.deb) ...
Sélection du paquet libgail18:i386 précédemment désélectionné.
Dépaquetage de libgail18:i386 (à partir de .../libgail18_2.24.10-2_i386.deb) ...
Sélection du paquet libgtk-3-common précédemment désélectionné.
Dépaquetage de libgtk-3-common (à partir de .../libgtk-3-common_3.4.2-7_all.deb) ...
Sélection du paquet libgtk-3-0:i386 précédemment désélectionné.
Dépaquetage de libgtk-3-0:i386 (à partir de .../libgtk-3-0_3.4.2-7_i386.deb) ...
Sélection du paquet fonts-sil-gentium précédemment désélectionné.
Dépaquetage de fonts-sil-gentium (à partir de .../fonts-sil-gentium_20081126%3a1.02-12_all.deb) ...
Sélection du paquet fonts-sil-gentium-basic précédemment désélectionné.
Dépaquetage de fonts-sil-gentium-basic (à partir de .../fonts-sil-gentium-basic_1.1-5_all.deb) ...
Sélection du paquet gconf2 précédemment désélectionné.
Dépaquetage de gconf2 (à partir de .../gconf2_3.2.5-1+build1_i386.deb) ...
Sélection du paquet libgnomevfs2-common précédemment désélectionné.
Dépaquetage de libgnomevfs2-common (à partir de .../libgnomevfs2-common_1%3a2.24.4-2_all.deb) ...
Sélection du paquet libgnomevfs2-0 précédemment désélectionné.
Dépaquetage de libgnomevfs2-0 (à partir de .../libgnomevfs2-0_1%3a2.24.4-2_i386.deb) ...
Sélection du paquet libgnome2-common précédemment désélectionné.
Dépaquetage de libgnome2-common (à partir de .../libgnome2-common_2.32.1-3_all.deb) ...
Sélection du paquet libgnome2-0 précédemment désélectionné.
Dépaquetage de libgnome2-0 (à partir de .../libgnome2-0_2.32.1-3_i386.deb) ...
Sélection du paquet libgnomecanvas2-common précédemment désélectionné.
Dépaquetage de libgnomecanvas2-common (à partir de .../libgnomecanvas2-common_2.30.3-1.2_all.deb) ...
Sélection du paquet libgnomecanvas2-0 précédemment désélectionné.
Dépaquetage de libgnomecanvas2-0 (à partir de .../libgnomecanvas2-0_2.30.3-1.2_i386.deb) ...
Sélection du paquet libbonoboui2-0 précédemment désélectionné.
Dépaquetage de libbonoboui2-0 (à partir de .../libbonoboui2-0_2.24.3-1_i386.deb) ...
Sélection du paquet libcolamd2.7.1 précédemment désélectionné.
Dépaquetage de libcolamd2.7.1 (à partir de .../libcolamd2.7.1_1%3a3.4.0-3_i386.deb) ...
Sélection du paquet libgnomeui-0 précédemment désélectionné.
Dépaquetage de libgnomeui-0 (à partir de .../libgnomeui-0_2.24.5-2_i386.deb) ...
Sélection du paquet libgnomevfs2-extra précédemment désélectionné.
Dépaquetage de libgnomevfs2-extra (à partir de .../libgnomevfs2-extra_1%3a2.24.4-2_i386.deb) ...
Sélection du paquet libgtk-3-bin précédemment désélectionné.
Dépaquetage de libgtk-3-bin (à partir de .../libgtk-3-bin_3.4.2-7_i386.deb) ...
Ajout de « détournement de /usr/sbin/update-icon-caches en /usr/sbin/update-icon-caches.gtk2 par libgtk-3-bin »
Ajout de « détournement de /usr/share/man/man8/update-icon-caches.8.gz en /usr/share/man/man8/update-icon-caches.gtk2.8.gz par libgtk-3-bin »
Sélection du paquet libminiupnpc5 précédemment désélectionné.
Dépaquetage de libminiupnpc5 (à partir de .../libminiupnpc5_1.5-2_i386.deb) ...
Sélection du paquet libnatpmp1 précédemment désélectionné.
Dépaquetage de libnatpmp1 (à partir de .../libnatpmp1_20110808-3_i386.deb) ...
Sélection du paquet lp-solve précédemment désélectionné.
Dépaquetage de lp-solve (à partir de .../lp-solve_5.5.0.13-7_i386.deb) ...
Sélection du paquet libreoffice-calc précédemment désélectionné.
Dépaquetage de libreoffice-calc (à partir de .../libreoffice-calc_1%3a3.5.4+dfsg2-0+deb7u2_i386.deb) ...
Sélection du paquet libvisio-0.0-0 précédemment désélectionné.
Dépaquetage de libvisio-0.0-0 (à partir de .../libvisio-0.0-0_0.0.17-1_i386.deb) ...
Sélection du paquet libreoffice-draw précédemment désélectionné.
Dépaquetage de libreoffice-draw (à partir de .../libreoffice-draw_1%3a3.5.4+dfsg2-0+deb7u2_i386.deb) ...
Sélection du paquet libreoffice-impress précédemment désélectionné.
Dépaquetage de libreoffice-impress (à partir de .../libreoffice-impress_1%3a3.5.4+dfsg2-0+deb7u2_i386.deb) ...
Sélection du paquet libreoffice-report-builder-bin précédemment désélectionné.
Dépaquetage de libreoffice-report-builder-bin (à partir de .../libreoffice-report-builder-bin_1%3a3.5.4+dfsg2-0+deb7u2_i386.deb) ...
Sélection du paquet ttf-sil-gentium-basic précédemment désélectionné.
Dépaquetage de ttf-sil-gentium-basic (à partir de .../ttf-sil-gentium-basic_1.1-5_all.deb) ...
Sélection du paquet libreoffice-filter-mobiledev précédemment désélectionné.
Dépaquetage de libreoffice-filter-mobiledev (à partir de .../libreoffice-filter-mobiledev_1%3a3.5.4+dfsg2-0+deb7u2_all.deb) ...
Sélection du paquet libreoffice précédemment désélectionné.
Dépaquetage de libreoffice (à partir de .../libreoffice_1%3a3.5.4+dfsg2-0+deb7u2_i386.deb) ...
Sélection du paquet minissdpd précédemment désélectionné.
Dépaquetage de minissdpd (à partir de .../minissdpd_1.1.20120121-1_i386.deb) ...
Sélection du paquet stardict-common précédemment désélectionné.
Dépaquetage de stardict-common (à partir de .../stardict-common_3.0.1-9.2_all.deb) ...
Sélection du paquet stardict-gnome précédemment désélectionné.
Dépaquetage de stardict-gnome (à partir de .../stardict-gnome_3.0.1-9.2_i386.deb) ...
Sélection du paquet stardict précédemment désélectionné.
Dépaquetage de stardict (à partir de .../stardict_3.0.1-9.2_all.deb) ...
Sélection du paquet stardict-plugin précédemment désélectionné.
Dépaquetage de stardict-plugin (à partir de .../stardict-plugin_3.0.1-9.2_i386.deb) ...
Sélection du paquet stardict-plugin-espeak précédemment désélectionné.
Dépaquetage de stardict-plugin-espeak (à partir de .../stardict-plugin-espeak_3.0.1-9.2_i386.deb) ...
Sélection du paquet stardict-plugin-festival précédemment désélectionné.
Dépaquetage de stardict-plugin-festival (à partir de .../stardict-plugin-festival_3.0.1-9.2_i386.deb) ...
Sélection du paquet tomboy précédemment désélectionné.
Dépaquetage de tomboy (à partir de .../tomboy_1.10.0-2_i386.deb) ...
Sélection du paquet transmission-common précédemment désélectionné.
Dépaquetage de transmission-common (à partir de .../transmission-common_2.52-3+nmu2_all.deb) ...
Sélection du paquet transmission-gtk précédemment désélectionné.
Dépaquetage de transmission-gtk (à partir de .../transmission-gtk_2.52-3+nmu2_i386.deb) ...
Sélection du paquet transmission précédemment désélectionné.
Dépaquetage de transmission (à partir de .../transmission_2.52-3+nmu2_all.deb) ...
Traitement des actions différées (« triggers ») pour « fontconfig »...
Traitement des actions différées (« triggers ») pour « mime-support »...
Traitement des actions différées (« triggers ») pour « shared-mime-info »...
Paramétrage de libavahi-glib1:i386 (0.6.31-2) ...
Paramétrage de libcairo-gobject2:i386 (1.12.2-3) ...
Paramétrage de libestools2.1:i386 (1:2.1~release-5) ...
Paramétrage de libgail18:i386 (2.24.10-2) ...
Paramétrage de libgtk-3-common (3.4.2-7) ...
Paramétrage de libgtk-3-0:i386 (3.4.2-7) ...
Paramétrage de fonts-sil-gentium (20081126:1.02-12) ...
Paramétrage de fonts-sil-gentium-basic (1.1-5) ...
Paramétrage de gconf2 (3.2.5-1+build1) ...
Paramétrage de libgnomevfs2-common (1:2.24.4-2) ...
Paramétrage de libgnomevfs2-0 (1:2.24.4-2) ...
Paramétrage de libgnome2-common (2.32.1-3) ...
Paramétrage de libgnome2-0 (2.32.1-3) ...
Paramétrage de libgnomecanvas2-common (2.30.3-1.2) ...
Paramétrage de libgnomecanvas2-0 (2.30.3-1.2) ...
Paramétrage de libbonoboui2-0 (2.24.3-1) ...
Paramétrage de libcolamd2.7.1 (1:3.4.0-3) ...
Paramétrage de libgnomeui-0 (2.24.5-2) ...
Paramétrage de libgnomevfs2-extra (1:2.24.4-2) ...
Paramétrage de libgtk-3-bin (3.4.2-7) ...
Paramétrage de libminiupnpc5 (1.5-2) ...
Paramétrage de libnatpmp1 (20110808-3) ...
Paramétrage de lp-solve (5.5.0.13-7) ...
Paramétrage de libreoffice-calc (1:3.5.4+dfsg2-0+deb7u2) ...
Paramétrage de libvisio-0.0-0 (0.0.17-1) ...
Paramétrage de libreoffice-draw (1:3.5.4+dfsg2-0+deb7u2) ...
Paramétrage de libreoffice-impress (1:3.5.4+dfsg2-0+deb7u2) ...
Paramétrage de libreoffice-report-builder-bin (1:3.5.4+dfsg2-0+deb7u2) ...
Paramétrage de ttf-sil-gentium-basic (1.1-5) ...
Paramétrage de libreoffice-filter-mobiledev (1:3.5.4+dfsg2-0+deb7u2) ...
Paramétrage de libreoffice (1:3.5.4+dfsg2-0+deb7u2) ...
Paramétrage de minissdpd (1.1.20120121-1) ...
Paramétrage de stardict-common (3.0.1-9.2) ...
Paramétrage de stardict-gnome (3.0.1-9.2) ...
Paramétrage de stardict (3.0.1-9.2) ...
Paramétrage de stardict-plugin (3.0.1-9.2) ...
Paramétrage de stardict-plugin-espeak (3.0.1-9.2) ...
Paramétrage de stardict-plugin-festival (3.0.1-9.2) ...
Paramétrage de tomboy (1.10.0-2) ...
Paramétrage de transmission-common (2.52-3+nmu2) ...
Paramétrage de transmission-gtk (2.52-3+nmu2) ...
Paramétrage de transmission (2.52-3+nmu2) ...
puis…
root@dell-so6:/home/so6# aptitude install midori iceweasel
freepats{a} gnome-icon-theme{a} gstreamer0.10-ffmpeg{a} gstreamer0.10-gconf{a} gstreamer0.10-plugins-bad{a}
gstreamer0.10-plugins-good{a} gstreamer0.10-x{a} iceweasel libcdaudio1{a} libdv4{a} libfftw3-3{a} libgeoclue0{a}
libgme0{a} libgstreamer-plugins-bad0.10-0{a} libiec61883-0{a} libmimic0{a} libmms0{a} libofa0{a} libopenal-data{a}
libopenal1{a} libopus0{a} libslv2-9{a} libsoundtouch0{a} libsoup-gnome2.4-1{a} libspandsp2{a} libvo-aacenc0{a}
libvo-amrwbenc0{a} libwavpack1{a} libwebkitgtk-1.0-0{a} libwildmidi-config{a} libwildmidi1{a} libzbar0{a} midori
0 paquets mis à jour, 33 nouvellement installés, 0 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 49,9 Mo/56,8 Mo d'archives. Après dépaquetage, 104 Mo seront utilisés.
Prendre : 1 ftp://ftp.fr.debian.org/debian/ wheezy/main libdv4 i386 1.0.0-6 [81,4 kB]
Prendre : 2 ftp://ftp.fr.debian.org/debian/ wheezy/main libfftw3-3 i386 3.3.2-3.1 [1 434 kB]
Prendre : 3 ftp://ftp.fr.debian.org/debian/ wheezy/main libopenal-data all 1:1.14-4 [11,1 kB]
Prendre : 4 ftp://ftp.fr.debian.org/debian/ wheezy/main libopenal1 i386 1:1.14-4 [183 kB]
Prendre : 5 ftp://ftp.fr.debian.org/debian/ wheezy/main libsoundtouch0 i386 1.6.0-3 [40,9 kB]
Prendre : 6 ftp://ftp.fr.debian.org/debian/ wheezy/main libvo-aacenc0 i386 0.1.2-1 [70,8 kB]
Prendre : 7 ftp://ftp.fr.debian.org/debian/ wheezy/main libvo-amrwbenc0 i386 0.1.2-1 [67,5 kB]
Prendre : 8 ftp://ftp.fr.debian.org/debian/ wheezy/main libwavpack1 i386 4.60.1-3 [91,3 kB]
Prendre : 9 ftp://ftp.fr.debian.org/debian/ wheezy/main libwildmidi-config all 0.2.3.4-2.1 [15,9 kB]
Prendre : 10 ftp://ftp.fr.debian.org/debian/ wheezy/main libwildmidi1 i386 0.2.3.4-2.1 [62,3 kB]
Prendre : 11 ftp://ftp.fr.debian.org/debian/ wheezy/main libcdaudio1 i386 0.99.12p2-12 [49,8 kB]
Prendre : 12 ftp://ftp.fr.debian.org/debian/ wheezy/main libgme0 i386 0.5.5-2 [142 kB]
Prendre : 13 ftp://ftp.fr.debian.org/debian/ wheezy/main libmimic0 i386 1.0.4-2.1 [20,6 kB]
Prendre : 14 ftp://ftp.fr.debian.org/debian/ wheezy/main libofa0 i386 0.9.3-5 [56,8 kB]
Prendre : 15 ftp://ftp.fr.debian.org/debian/ wheezy/main libopus0 i386 0.9.14+20120615-1+nmu1 [151 kB]
Prendre : 16 ftp://ftp.fr.debian.org/debian/ wheezy/main libslv2-9 i386 0.6.6+dfsg1-2 [28,2 kB]
Prendre : 17 ftp://ftp.fr.debian.org/debian/ wheezy/main libspandsp2 i386 0.0.6~pre20-3.1 [328 kB]
Prendre : 18 ftp://ftp.fr.debian.org/debian/ wheezy/main libzbar0 i386 0.10+doc-8 [102 kB]
Prendre : 19 ftp://ftp.fr.debian.org/debian/ wheezy/main freepats all 20060219-1 [29,0 MB]
Prendre : 20 ftp://ftp.fr.debian.org/debian/ wheezy/main gnome-icon-theme all 3.4.0-2 [9 516 kB]
Prendre : 21 ftp://ftp.fr.debian.org/debian/ wheezy/main gstreamer0.10-ffmpeg i386 0.10.13-5 [181 kB]
Prendre : 22 ftp://ftp.fr.debian.org/debian/ wheezy/main gstreamer0.10-gconf i386 0.10.31-3+nmu1 [707 kB]
Prendre : 23 ftp://ftp.fr.debian.org/debian/ wheezy/main libiec61883-0 i386 1.2.0-0.1 [32,7 kB]
Prendre : 24 ftp://ftp.fr.debian.org/debian/ wheezy/main gstreamer0.10-plugins-good i386 0.10.31-3+nmu1 [1 978 kB]
Prendre : 25 ftp://ftp.fr.debian.org/debian/ wheezy/main gstreamer0.10-x i386 0.10.36-1.1 [626 kB]
Prendre : 26 ftp://ftp.fr.debian.org/debian/ wheezy/main libgeoclue0 i386 0.12.0-4 [36,1 kB]
Prendre : 27 ftp://ftp.fr.debian.org/debian/ wheezy/main libwebkitgtk-1.0-0 i386 1.8.1-3.4 [4 937 kB]
49,9 Mo téléchargés en 36s (1 361 ko/s)
Sélection du paquet libdv4:i386 précédemment désélectionné.
(Lecture de la base de données... 90413 fichiers et répertoires déjà installés.)
Dépaquetage de libdv4:i386 (à partir de .../libdv4_1.0.0-6_i386.deb) ...
Sélection du paquet libfftw3-3:i386 précédemment désélectionné.
Dépaquetage de libfftw3-3:i386 (à partir de .../libfftw3-3_3.3.2-3.1_i386.deb) ...
Sélection du paquet libmms0:i386 précédemment désélectionné.
Dépaquetage de libmms0:i386 (à partir de .../libmms0_0.6.2-3+deb7u1_i386.deb) ...
Sélection du paquet libopenal-data précédemment désélectionné.
Dépaquetage de libopenal-data (à partir de .../libopenal-data_1%3a1.14-4_all.deb) ...
Sélection du paquet libopenal1:i386 précédemment désélectionné.
Dépaquetage de libopenal1:i386 (à partir de .../libopenal1_1%3a1.14-4_i386.deb) ...
Sélection du paquet libsoundtouch0:i386 précédemment désélectionné.
Dépaquetage de libsoundtouch0:i386 (à partir de .../libsoundtouch0_1.6.0-3_i386.deb) ...
Sélection du paquet libsoup-gnome2.4-1:i386 précédemment désélectionné.
Dépaquetage de libsoup-gnome2.4-1:i386 (à partir de .../libsoup-gnome2.4-1_2.38.1-3_i386.deb) ...
Sélection du paquet libvo-aacenc0:i386 précédemment désélectionné.
Dépaquetage de libvo-aacenc0:i386 (à partir de .../libvo-aacenc0_0.1.2-1_i386.deb) ...
Sélection du paquet libvo-amrwbenc0:i386 précédemment désélectionné.
Dépaquetage de libvo-amrwbenc0:i386 (à partir de .../libvo-amrwbenc0_0.1.2-1_i386.deb) ...
Sélection du paquet libwavpack1:i386 précédemment désélectionné.
Dépaquetage de libwavpack1:i386 (à partir de .../libwavpack1_4.60.1-3_i386.deb) ...
Sélection du paquet libwildmidi-config précédemment désélectionné.
Dépaquetage de libwildmidi-config (à partir de .../libwildmidi-config_0.2.3.4-2.1_all.deb) ...
Sélection du paquet libwildmidi1:i386 précédemment désélectionné.
Dépaquetage de libwildmidi1:i386 (à partir de .../libwildmidi1_0.2.3.4-2.1_i386.deb) ...
Sélection du paquet libcdaudio1 précédemment désélectionné.
Dépaquetage de libcdaudio1 (à partir de .../libcdaudio1_0.99.12p2-12_i386.deb) ...
Sélection du paquet libgme0 précédemment désélectionné.
Dépaquetage de libgme0 (à partir de .../libgme0_0.5.5-2_i386.deb) ...
Sélection du paquet libgstreamer-plugins-bad0.10-0:i386 précédemment désélectionné.
Dépaquetage de libgstreamer-plugins-bad0.10-0:i386 (à partir de .../libgstreamer-plugins-bad0.10-0_0.10.23-7.1+deb7u1_i386.deb) ...
Sélection du paquet libmimic0 précédemment désélectionné.
Dépaquetage de libmimic0 (à partir de .../libmimic0_1.0.4-2.1_i386.deb) ...
Sélection du paquet libofa0 précédemment désélectionné.
Dépaquetage de libofa0 (à partir de .../libofa0_0.9.3-5_i386.deb) ...
Sélection du paquet libopus0 précédemment désélectionné.
Dépaquetage de libopus0 (à partir de .../libopus0_0.9.14+20120615-1+nmu1_i386.deb) ...
Sélection du paquet libslv2-9 précédemment désélectionné.
Dépaquetage de libslv2-9 (à partir de .../libslv2-9_0.6.6+dfsg1-2_i386.deb) ...
Sélection du paquet libspandsp2 précédemment désélectionné.
Dépaquetage de libspandsp2 (à partir de .../libspandsp2_0.0.6~pre20-3.1_i386.deb) ...
Sélection du paquet libzbar0 précédemment désélectionné.
Dépaquetage de libzbar0 (à partir de .../libzbar0_0.10+doc-8_i386.deb) ...
Sélection du paquet gstreamer0.10-plugins-bad:i386 précédemment désélectionné.
Dépaquetage de gstreamer0.10-plugins-bad:i386 (à partir de .../gstreamer0.10-plugins-bad_0.10.23-7.1+deb7u1_i386.deb) ...
Sélection du paquet freepats précédemment désélectionné.
Dépaquetage de freepats (à partir de .../freepats_20060219-1_all.deb) ...
Sélection du paquet gnome-icon-theme précédemment désélectionné.
Dépaquetage de gnome-icon-theme (à partir de .../gnome-icon-theme_3.4.0-2_all.deb) ...
Sélection du paquet gstreamer0.10-ffmpeg:i386 précédemment désélectionné.
Dépaquetage de gstreamer0.10-ffmpeg:i386 (à partir de .../gstreamer0.10-ffmpeg_0.10.13-5_i386.deb) ...
Sélection du paquet gstreamer0.10-gconf:i386 précédemment désélectionné.
Dépaquetage de gstreamer0.10-gconf:i386 (à partir de .../gstreamer0.10-gconf_0.10.31-3+nmu1_i386.deb) ...
Sélection du paquet libiec61883-0 précédemment désélectionné.
Dépaquetage de libiec61883-0 (à partir de .../libiec61883-0_1.2.0-0.1_i386.deb) ...
Sélection du paquet gstreamer0.10-plugins-good:i386 précédemment désélectionné.
Dépaquetage de gstreamer0.10-plugins-good:i386 (à partir de .../gstreamer0.10-plugins-good_0.10.31-3+nmu1_i386.deb) ...
Sélection du paquet gstreamer0.10-x:i386 précédemment désélectionné.
Dépaquetage de gstreamer0.10-x:i386 (à partir de .../gstreamer0.10-x_0.10.36-1.1_i386.deb) ...
Sélection du paquet iceweasel précédemment désélectionné.
Dépaquetage de iceweasel (à partir de .../iceweasel_24.7.0esr-1~deb7u1_i386.deb) ...
Ajout de « détournement de /usr/bin/firefox en /usr/bin/firefox.real par iceweasel »
Sélection du paquet libgeoclue0 précédemment désélectionné.
Dépaquetage de libgeoclue0 (à partir de .../libgeoclue0_0.12.0-4_i386.deb) ...
Sélection du paquet libwebkitgtk-1.0-0 précédemment désélectionné.
Dépaquetage de libwebkitgtk-1.0-0 (à partir de .../libwebkitgtk-1.0-0_1.8.1-3.4_i386.deb) ...
Sélection du paquet midori précédemment désélectionné.
Dépaquetage de midori (à partir de .../midori_0.4.3+dfsg-0.1_i386.deb) ...
Traitement de 1 fichier de documentation ajouté…
Traitement des actions différées (« triggers ») pour « gconf2 »...
Paramétrage de libdv4:i386 (1.0.0-6) ...
Paramétrage de libfftw3-3:i386 (3.3.2-3.1) ...
Paramétrage de libmms0:i386 (0.6.2-3+deb7u1) ...
Paramétrage de libopenal-data (1:1.14-4) ...
Paramétrage de libopenal1:i386 (1:1.14-4) ...
Paramétrage de libsoundtouch0:i386 (1.6.0-3) ...
Paramétrage de libsoup-gnome2.4-1:i386 (2.38.1-3) ...
Paramétrage de libvo-aacenc0:i386 (0.1.2-1) ...
Paramétrage de libvo-amrwbenc0:i386 (0.1.2-1) ...
Paramétrage de libwavpack1:i386 (4.60.1-3) ...
Paramétrage de libwildmidi-config (0.2.3.4-2.1) ...
Paramétrage de libwildmidi1:i386 (0.2.3.4-2.1) ...
Paramétrage de libcdaudio1 (0.99.12p2-12) ...
Paramétrage de libgme0 (0.5.5-2) ...
Paramétrage de libgstreamer-plugins-bad0.10-0:i386 (0.10.23-7.1+deb7u1) ...
Paramétrage de libmimic0 (1.0.4-2.1) ...
Paramétrage de libofa0 (0.9.3-5) ...
Paramétrage de libopus0 (0.9.14+20120615-1+nmu1) ...
Paramétrage de libslv2-9 (0.6.6+dfsg1-2) ...
Paramétrage de libspandsp2 (0.0.6~pre20-3.1) ...
Paramétrage de libzbar0 (0.10+doc-8) ...
Paramétrage de gstreamer0.10-plugins-bad:i386 (0.10.23-7.1+deb7u1) ...
Paramétrage de freepats (20060219-1) ...
Paramétrage de gnome-icon-theme (3.4.0-2) ...
update-alternatives: utilisation de « /usr/share/icons/gnome/scalable/places/debian-swirl.svg » pour fournir « /usr/share/icons/gnome/scalable/places/start-here.svg » (start-here.svg) en mode automatique
Paramétrage de gstreamer0.10-ffmpeg:i386 (0.10.13-5) ...
Paramétrage de gstreamer0.10-gconf:i386 (0.10.31-3+nmu1) ...
Paramétrage de libiec61883-0 (1.2.0-0.1) ...
Paramétrage de gstreamer0.10-plugins-good:i386 (0.10.31-3+nmu1) ...
Paramétrage de gstreamer0.10-x:i386 (0.10.36-1.1) ...
Paramétrage de iceweasel (24.7.0esr-1~deb7u1) ...
update-alternatives: utilisation de « /usr/bin/iceweasel » pour fournir « /usr/bin/x-www-browser » (x-www-browser) en mode automatique
update-alternatives: utilisation de « /usr/bin/iceweasel » pour fournir « /usr/bin/gnome-www-browser » (gnome-www-browser) en mode automatique
Paramétrage de libgeoclue0 (0.12.0-4) ...
Paramétrage de libwebkitgtk-1.0-0 (1.8.1-3.4) ...
Paramétrage de midori (0.4.3+dfsg-0.1) ...
rmdir: échec de suppression de « /etc/xdg/midori/extensions/libadblock.so »: Aucun fichier ou dossier de ce type
Voilà où j’en suis donc.
Je reboote et… je suis en console, pas d’écran de connexion.
Je dois démarrer avec la commande startx, pour accéder au bureau.
Help please ?
edit : J’ai installé lightdm.
Je rencontre des problèmes avec le terminal xfce4 : la lettre “t” a disparu… Quand je tape “t” : rien.
et, par exemple,
so6@dell-so6:~$ ifconfig -a
bash: ifconfig : commande introuvable
Je m’abonne …
Autre chose : je cherche le moyen de gérer les connexions réseau. Il semble que j’ai encore network-manager d’installé…
Doucement !
Tu as pu voir le nombre d’échanges nécessaires à la résolution d’un problème, imagine un peu le boxon que ce serait pour résoudre trois ou quatre problèmes en simultané…
Si tu t’es enfin débarrassé de GNOME 3, marque ce sujet-ci comme résolu (à l’aide de la coche verte présente sur chaque message) et ouvre un nouveau sujet par problème qui se pose à toi.
Depuis l’installateur (à la base) Debian, [mono]task-gnome-desktop[/mono] engendre pas moins de 1167 paquets avec lui.
De là à affirmer que le Gnome est viré, …
PS : [mono]ncurses[/mono], sur ce coup là …
[quote=“BelZéButh”]Depuis l’installateur (à la base) Debian, [mono]task-gnome-desktop[/mono] engendre pas moins de 1167 paquets avec lui.
De là à affirmer que le Gnome est viré, …[/quote]
Le gros du bouzin dépend de gnome-core, et était probablement déjà parti avant qu’on lance aptitude.
Une fois que les dépendances de ce dernier ont aussi été enlevées, je suis confiant sur le fait qu’il ne reste plus grand chose de GNOME sur la Debian de laso6.
Cette interface est ce qui fait d’aptitude un logiciel aussi puissant, ce serait dommage de s’en priver
Moi, non.
Et c’est un adepte d’[mono]apt-get[/mono] qui me vante les mérites d’[mono]aptitude[/mono], c’est fort de café, quand même …
Moi, non. [/quote]
Tu peux aussi répondre de manière productive, par exemple en proposant de lancer une commande du type [mono]dpkg -l gnome | grep ^ii[/mono].
Et c’est un adepte d’[mono]apt-get[/mono] qui me vante les mérites d’[mono]aptitude[/mono], c’est fort de café, quand même … [/quote]
Deux logiciels, deux usages.
Chacun est adapté à différents types de situations, et contrairement à ce qu’ont lit souvent ils sont compatibles mais pas forcément interchangeables.
Certes.
PS : laso6, ne pas reproduire ce qui suit sur ta machine sans avis préalable à moins que tu ne saches ce que tu fais …
Depuis une Wheezy (le 12 Aoû 2014 14:48, avant … [mono]ncurses[/mono])ayant pour environnement (à la base) le Gnome puis l’installation d’Xfce4.
root@Feu-le-Gnome:~# aptitude hold lightdm-gtk-greeter
[code]root@Feu-le-Gnome:~# aptitude remove --purge gnome-session-bin gnome-control-center gnome-panel gnome-shell gnome-session-fallback gnome-control-center-data gnome-media gnome-online-accounts gnome-panel-data gnome-session task-gnome-desktop gnome-screensaver gnome-core gnome-applets alacarte mousetweaks gdm3 gnome gnome-shell-extensions gnome-accessibility-themes gnome-backgrounds gnome-color-manager gnome-contacts gnome-accessibility-themes gnome-themes-standard gnome-tweak-tool gnome-disk-utility gnome-packagekit gnome-packagekit-data
[…][/code]
[code]root@Feu-le-Gnome:~# aptitude remove --purge gir1.2-gnomebluetooth-1.0 gnome-bluetooth gnome-user-share network-manager-gnome gnome-applets-data gkbd-capplet gnome-desktop3-data cheese eog evolution evolution-plugins gnome-documents gnome-power-manager gnome-settings-daemon gnome-sushi libevolution libgnome-desktop-3-2 nautilus nautilus-sendto
[…][/code]
root@Feu-le-Gnome:~# shutdown -r now
[code][14:06:14]:~$ ssh 192.168.1.20
loreleil@192.168.1.20’s password:
Linux Feu-le-Gnome 3.2.0-4-amd64 #1 SMP Debian 3.2.60-1+deb7u3 x86_64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue Aug 12 13:36:08 2014 from pc-2-loreleil.home
loreleil@Feu-le-Gnome:~$ su -
Mot de passe :
root@Feu-le-Gnome:~# aptitude remove --purge gnome-games-extra-data gnome-games-data gnome-games glchess glines gnect gnibbles gnobots2 gnome-sudoku gnomine gnomine gnotravex gnotski iagno lightsoff mahjongg quadrapassel swell-foop gtali
[…][/code]
[code]root@Feu-le-Gnome:~# aptitude remove --purge gnome-dictionary gnome-font-viewer gnome-icon-theme-extras gnome-icon-theme-symbolic totem-plugins totem
[…][/code]
[code]root@Feu-le-Gnome:~# aptitude remove --purge gnome-mag gnome-menus gnome-nettool gnome-orca gnome-screenshot gnome-session-common gnome-shell-common gnome-system-log gnome-system-monitor gnome-terminal gnome-terminal-data gnome-themes-standard-data gnome-user-guide gnome-video-effects libreoffice-gnome libgnome-mag2 libgnome-media-profiles-3.0-0 libgnome-menu-3-0 gir1.2-gmenu-3.0 yelp
[…][/code]
[code]root@Feu-le-Gnome:~# aptitude remove --purge libgnome-bluetooth10 gir1.2-gnomekeyring-1.0 rhythmbox-plugins rhythmbox rhythmbox-plugin-cdrecorder rhythmbox-data
[…][/code]
root@Feu-le-Gnome:~# aptitude remove --purge brasero empathy evince gdebi
[code]root@Feu-le-Gnome:~# aptitude remove --purge libpam-gnome-keyring gnome-keyring seahorse gvfs-backends gksu
Voilà.
Ci-dessous, en version hard.
PS : à ne pas reproduire chez vous.
[code]root@Feu-le-Gnome:~# aptitude remove --purge apt-listbugs libruby1.8 ruby-debian ruby-gettext ruby-httpclient ruby-locale ruby-xmlparser ruby-xmlparser
0 paquets mis à jour, 0 nouvellement installés, 7 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 0 o d’archives. Après dépaquetage, 8 721 ko seront libérés.
Les paquets suivants ont des dépendances non satisfaites :
ruby1.8 : Dépend: libruby1.8 (= 1.8.7.358-7.1+deb7u1) mais il ne sera pas installé.
Supprimer les paquets suivants :
ruby1.8
Accepter cette solution ? [Y/n/q/?] y
[…][/code]
root@Feu-le-Gnome:~# aptitude remove --purge `cat simulation-install-task-gnome-desktop_copie_bis`
accountsservice acl aisleriot alacarte alsa-base alsa-utils anacron ant ant-optional apache2.2-bin apg app-install-data apt-xapian-index aptdaemon aptdaemon-data argyll
at-spi2-core avahi-daemon baobab binfmt-support bluez bogofilter bogofilter-bdb bogofilter-common brasero brasero-common browser-plugin-gnash ca-certificates-java caribou
caribou-antler cdrdao cheese cheese-common cli-common colord consolekit cpp cpp-4.7 crda cryptsetup-bin cups-pk-helper dbus dbus-x11 dconf-gsettings-backend dconf-service
dconf-tools default-jre default-jre-headless desktop-base desktop-file-utils dnsmasq-base docbook-xml dosfstools empathy empathy-common enchant eog espeak-data evince
evince-common evolution evolution-common evolution-data-server evolution-data-server-common evolution-plugins evolution-webcal file-roller finger folks-common fontconfig
fontconfig-config fonts-cantarell fonts-droid fonts-liberation fonts-lyx fonts-opensymbol fonts-sil-gentium fonts-sil-gentium-basic fonts-stix freepats fuse gcalctool
gconf-service gconf2 gconf2-common gcr gdebi gdebi-core gdm3 gedit gedit-common gedit-plugins geoclue geoclue-hostip geoclue-localnet geoclue-manual geoclue-yahoo
ghostscript gimp gimp-data gir1.2-accountsservice-1.0 gir1.2-atk-1.0 gir1.2-atspi-2.0 gir1.2-caribou-1.0 gir1.2-clutter-1.0 gir1.2-clutter-gst-1.0 gir1.2-cogl-1.0
gir1.2-coglpango-1.0 gir1.2-evince-3.0 gir1.2-folks-0.6 gir1.2-freedesktop gir1.2-gck-1 gir1.2-gconf-2.0 gir1.2-gcr-3 gir1.2-gdata-0.0 gir1.2-gdesktopenums-3.0
gir1.2-gdkpixbuf-2.0 gir1.2-gee-1.0 gir1.2-gkbd-3.0 gir1.2-glib-2.0 gir1.2-gmenu-3.0 gir1.2-gnomebluetooth-1.0 gir1.2-gnomekeyring-1.0 gir1.2-goa-1.0
gir1.2-gst-plugins-base-0.10 gir1.2-gstreamer-0.10 gir1.2-gtk-3.0 gir1.2-gtkclutter-1.0 gir1.2-gtksource-3.0 gir1.2-gtop-2.0 gir1.2-gucharmap-2.90
gir1.2-javascriptcoregtk-3.0 gir1.2-json-1.0 gir1.2-mutter-3.0 gir1.2-networkmanager-1.0 gir1.2-panelapplet-4.0 gir1.2-pango-1.0 gir1.2-peas-1.0 gir1.2-polkit-1.0
gir1.2-rb-3.0 gir1.2-soup-2.4 gir1.2-telepathyglib-0.12 gir1.2-telepathylogger-0.2 gir1.2-totem-1.0 gir1.2-totem-plparser-1.0 gir1.2-tracker-0.14 gir1.2-upowerglib-1.0
gir1.2-vte-2.90 gir1.2-webkit-3.0 gir1.2-wnck-3.0 gir1.2-xkl-1.0 gjs gkbd-capplet gksu glchess glib-networking glib-networking-common glib-networking-services glines gnash
gnash-common gnect gnibbles gnobots2 gnome gnome-accessibility-themes gnome-applets gnome-applets-data gnome-backgrounds gnome-bluetooth gnome-color-manager gnome-contacts
gnome-control-center gnome-control-center-data gnome-core gnome-desktop3-data gnome-dictionary gnome-disk-utility gnome-documents gnome-font-viewer gnome-games
gnome-games-data gnome-games-extra-data gnome-icon-theme gnome-icon-theme-extras gnome-icon-theme-symbolic gnome-js-common gnome-keyring gnome-mag gnome-media gnome-menus
gnome-mime-data gnome-nettool gnome-online-accounts gnome-orca gnome-packagekit gnome-packagekit-data gnome-panel gnome-panel-data gnome-power-manager gnome-screensaver
gnome-screenshot gnome-session gnome-session-bin gnome-session-common gnome-session-fallback gnome-settings-daemon gnome-shell gnome-shell-common gnome-shell-extensions
gnome-sudoku gnome-sushi gnome-system-log gnome-system-monitor gnome-terminal gnome-terminal-data gnome-themes-standard gnome-themes-standard-data gnome-tweak-tool
gnome-user-guide gnome-user-share gnome-video-effects gnomine gnotravex gnotski gnuchess gnuchess-book gnuplot gnuplot-nox grilo-plugins-0.1 groff gsettings-desktop-schemas
gsfonts gstreamer0.10-ffmpeg gstreamer0.10-gconf gstreamer0.10-nice gstreamer0.10-plugins-bad gstreamer0.10-plugins-base gstreamer0.10-plugins-good
gstreamer0.10-plugins-ugly gstreamer0.10-pulseaudio gstreamer0.10-x gtali gtk2-engines gucharmap guile-2.0-libs gvfs gvfs-backends gvfs-bin gvfs-common gvfs-daemons
gvfs-libs hamster-applet hdparm hicolor-icon-theme hunspell-en-us hwdata hyphen-en-us iagno icedtea-6-jre-cacao icedtea-6-jre-jamvm icedtea-netx icedtea-netx-common
iceweasel imagemagick imagemagick-common inkscape iputils-tracepath iw java-common liba52-0.7.4 libaa1 libaacs0 libaccountsservice0 libamd2.2.0 libao-common libao4
libapache-pom-java libapache2-mod-dnssd libapr1 libaprutil1 libaprutil1-dbd-sqlite3 libaprutil1-ldap libarchive12 libart-2.0-2 libasound2 libasound2-plugins libass4
libasyncns0 libatasmart4 libatk-adaptor libatk-adaptor-data libatk-bridge2.0-0 libatk-wrapper-java libatk-wrapper-java-jni libatk1.0-0 libatk1.0-data libatkmm-1.6-1
libatspi1.0-0 libatspi2.0-0 libaudio2 libaudit0 libavahi-client3 libavahi-common-data libavahi-common3 libavahi-core7 libavahi-glib1 libavahi-gobject0 libavahi-ui-gtk3-0
libavc1394-0 libavcodec53 libavformat53 libavutil51 libbabl-0.1-0 libblas3 libblas3gf libbluetooth3 libbluray1 libbonobo2-0 libbonobo2-common libbonoboui2-0
libbonoboui2-common libboost-program-options1.49.0 libboost-thread1.49.0 libbrasero-media3-1 libbrlapi0.5 libburn4 libcaca0 libcairo-gobject2 libcairo-perl libcairo2
libcairomm-1.0-1 libcamel-1.2-33 libcanberra-gtk-module libcanberra-gtk0 libcanberra-gtk3-0 libcanberra-gtk3-module libcanberra-pulse libcanberra0 libcap-ng0 libcap2-bin
libcaribou-common libcaribou-gtk-module libcaribou-gtk3-module libcaribou0 libcdaudio1 libcdio-cdda1 libcdio-paranoia1 libcdio13 libcdparanoia0 libchamplain-0.12-0
libchamplain-gtk-0.12-0 libcheese-gtk21 libcheese3 libck-connector0 libclutter-1.0-0 libclutter-1.0-common libclutter-gst-1.0-0 libclutter-gtk-1.0-0
libclutter-imcontext-0.1-0 libclutter-imcontext-0.1-bin libcluttergesture-0.0.2-0 libcmis-0.2-0 libcogl-common libcogl-pango0 libcogl9 libcolamd2.7.1 libcolorblind0
libcolord1 libcommons-beanutils-java libcommons-collections3-java libcommons-compress-java libcommons-digester-java libcommons-logging-java libcommons-parent-java
libcpufreq0 libcroco3 libcryptsetup4 libcups2 libcupsimage2 libcurl3-gnutls libdaemon0 libdatrie1 libdb-java libdb-je-java libdb5.1-java libdb5.1-java-jni libdbus-1-3
libdbus-glib-1-2 libdbus-glib1.0-cil libdbus1.0-cil libdc1394-22 libdca0 libdconf0 libdee-1.0-4 libdevmapper-event1.02.1 libdirac-encoder0 libdirectfb-1.2-9 libdiscid0
libdjvulibre-text libdjvulibre21 libdmapsharing-3.0-2 libdotconf1.0 libdrm-intel1 libdrm-nouveau1a libdrm-radeon1 libdrm2 libdv4 libdvdnav4 libdvdread4 libebackend-1.2-2
libebook-1.2-13 libecal-1.2-11 libedata-book-1.2-13 libedata-cal-1.2-15 libedataserver-1.2-16 libedataserverui-3.0-1 libelf1 libenca0 libenchant1c2a libencode-locale-perl
libepc-1.0-3 libepc-common libepc-ui-1.0-3 libespeak1 libevdocument3-4 libevolution libevview3-3 libexempi3 libexif12 libexiv2-12 libexttextcat-data libexttextcat0 libfaad2
libfam0 libfarstream-0.1-0 libffi5 libfftw3-3 libfile-basedir-perl libfile-copy-recursive-perl libfile-desktopentry-perl libfile-listing-perl libfile-mimeinfo-perl libflac8
libflite1 libfolks-eds25 libfolks-telepathy25 libfolks25 libfont-afm-perl libfontconfig1 libfontenc1 libfribidi0 libfs6 libgadu3 libgail-3-0 libgail-common libgail18
libgck-1-0 libgconf-2-4 libgconf2-4 libgconf2.0-cil libgcr-3-1 libgcr-3-common libgd2-xpm libgdata-common libgdata13 libgdict-1.0-6 libgdict-common libgdiplus
libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-common libgdu-gtk0 libgdu0 libgee2 libgegl-0.2-0 libgeoclue0 libgeocode-glib0 libgexiv2-1 libgfortran3 libgif4 libgimp2.0
libgirepository-1.0-1 libgjs0b libgksu2-0 libgl1-mesa-dri libgl1-mesa-glx libglade2-0 libglapi-mesa libglew1.7 libglib-perl libglib2.0-0 libglib2.0-bin libglib2.0-cil
libglib2.0-data libglibmm-2.4-1c2a libglu1-mesa libgme0 libgmime-2.6-0 libgmime2.6-cil libgmp10 libgnome-bluetooth10 libgnome-desktop-3-2 libgnome-keyring-common
libgnome-keyring0 libgnome-mag2 libgnome-media-profiles-3.0-0 libgnome-menu-3-0 libgnome2-0 libgnome2-common libgnomecanvas2-0 libgnomecanvas2-common libgnomekbd-common
libgnomekbd7 libgnomeui-0 libgnomeui-common libgnomevfs2-0 libgnomevfs2-common libgnomevfs2-extra libgoa-1.0-0 libgoa-1.0-common libgomp1 libgphoto2-2 libgphoto2-l10n
libgphoto2-port0 libgpod-common libgpod4 libgraphite2-2.0.0 libgrilo-0.1-0 libgs9 libgs9-common libgsf-1-114 libgsf-1-common libgsl0ldbl libgsm1 libgssdp-1.0-3
libgstreamer-plugins-bad0.10-0 libgstreamer-plugins-base0.10-0 libgstreamer0.10-0 libgtk-3-0 libgtk-3-bin libgtk-3-common libgtk-vnc-2.0-0 libgtk2-perl libgtk2.0-0
libgtk2.0-bin libgtk2.0-cil libgtk2.0-common libgtkhtml-4.0-0 libgtkhtml-4.0-common libgtkhtml-editor-4.0-0 libgtkmm-2.4-1c2a libgtkmm-3.0-1 libgtksourceview-3.0-0
libgtksourceview-3.0-common libgtkspell0 libgtop2-7 libgtop2-common libgucharmap-2-90-7 libgudev-1.0-0 libgupnp-1.0-4 libgupnp-av-1.0-2 libgupnp-dlna-1.0-2
libgupnp-igd-1.0-4 libgusb2 libgvnc-1.0-0 libgweather-3-0 libgweather-common libgxps2 libhsqldb-java libhtml-form-perl libhtml-format-perl libhtml-parser-perl
libhtml-tagset-perl libhtml-tree-perl libhttp-cookies-perl libhttp-daemon-perl libhttp-date-perl libhttp-message-perl libhttp-negotiate-perl libhunspell-1.3-0 libhyphen0
libical0 libicc2 libice6 libicu48 libicu4j-java libidl0 libiec61883-0 libieee1284-3 libijs-0.35 libilmbase6 libimdi0 libimobiledevice2 libio-socket-ip-perl
libio-socket-ssl-perl libiptcdata0 libisofs6 libjack-jackd2-0 libjasper1 libjavascriptcoregtk-1.0-0 libjavascriptcoregtk-3.0-0 libjaxp1.3-java libjbig0 libjbig2dec0
libjim0debian2 libjline-java libjpeg8 libjson-glib-1.0-0 libjson0 libjte1 libjtidy-java libkate1 libkpathsea6 liblapack3 liblcms1 liblcms2-2 liblensfun-data liblensfun0
liblinear-tools liblinear1 liblircclient0 liblouis-data liblouis2 liblqr-1-0 libltdl7 liblua5.1-0 liblucene2-java liblvm2app2.2 liblwp-mediatypes-perl
liblwp-protocol-https-perl libmad0 libmagick++5 libmagickcore5 libmagickcore5-extra libmagickwand5 libmailtools-perl libmeanwhile1 libmetacity-private0a libmhash2 libmimic0
libminiupnpc5 libmission-control-plugins0 libmms0 libmng1 libmodplug1 libmono-addins-gui0.2-cil libmono-addins0.2-cil libmono-cairo4.0-cil libmono-corlib4.0-cil
libmono-i18n-west4.0-cil libmono-i18n4.0-cil libmono-posix4.0-cil libmono-security4.0-cil libmono-sharpzip4.84-cil libmono-system-configuration4.0-cil
libmono-system-core4.0-cil libmono-system-drawing4.0-cil libmono-system-security4.0-cil libmono-system-xml4.0-cil libmono-system4.0-cil libmozjs185-1.0 libmozjs24d
libmp3lame0 libmpc2 libmpcdec6 libmpeg2-4 libmpfr4 libmtdev1 libmtp-common libmtp-runtime libmtp9 libmusicbrainz5-0 libmutter0 libmx-1.0-2 libmx-bin libmx-common
libmythes-1.2-0 libnatpmp1 libnautilus-extension1a libneon27-gnutls libnet-dbus-perl libnet-http-perl libnet-ssleay-perl libnetfilter-conntrack3 libnetpbm10 libnettle4
libnice10 libnl-3-200 libnl-genl-3-200 libnl-route-3-200 libnm-glib-vpn1 libnm-glib4 libnm-gtk-common libnm-gtk0 libnm-util2 libnotify4 libnspr4 libnss-mdns libnss3
libnss3-1d liboauth0 libofa0 libogg0 libopenal-data libopenal1 libopencore-amrnb0 libopencore-amrwb0 libopenexr6 libopenjpeg2 libopenobex1 libopenraw1 libopus0 liborbit2
liborc-0.4-0 libpackagekit-glib2-14 libpam-cap libpam-ck-connector libpam-gnome-keyring libpanel-applet-4-0 libpango-perl libpango1.0-0 libpangomm-1.4-1 libpaper-utils
libpaper1 libparted0debian1 libpcap0.8 libpciaccess0 libpcsclite1 libpeas-1.0-0 libpeas-common libperl5.14 libpixman-1-0 libplist1 libplot2c2 libpng12-0 libpolkit-agent-1-0
libpolkit-backend-1-0 libpolkit-gobject-1-0 libpoppler-glib8 libpoppler19 libportaudio2 libpostproc52 libproxy0 libpst4 libpstoedit0c2a libpulse-mainloop-glib0 libpulse0
libpurple-bin libpurple0 libpython2.7 libquadmath0 libquvi-scripts libquvi7 libraptor2-0 librarian0 librasqal3 libraw1394-11 libraw5 librdf0 libreadline5 libregexp-java
libreoffice libreoffice-base libreoffice-base-core libreoffice-calc libreoffice-common libreoffice-core libreoffice-draw libreoffice-emailmerge libreoffice-evolution
libreoffice-filter-binfilter libreoffice-filter-mobiledev libreoffice-gnome libreoffice-gtk libreoffice-help-en-us libreoffice-impress libreoffice-java-common
libreoffice-math libreoffice-report-builder-bin libreoffice-style-galaxy libreoffice-style-tango libreoffice-writer librest-0.7-0 librest-extras-0.7-0 librhythmbox-core6
librsvg2-2 librsvg2-common librtmp0 libsamplerate0 libsane libsane-common libsane-extras libsane-extras-common libschroedinger-1.0-0 libsdl1.2debian libseed-gtk3-0
libservlet2.5-java libsgutils2-2 libshout3 libsidplay1 libslv2-9 libsm6 libsmbclient libsndfile1 libsocialweb-client2 libsocialweb-common libsocialweb-service libsocialweb0
libsocket-perl libsofia-sip-ua-glib3 libsofia-sip-ua0 libsonic0 libsoundtouch0 libsoup-gnome2.4-1 libsoup2.4-1 libspandsp2 libspectre1 libspeechd2 libspeex1 libspeexdsp1
libssh2-1 libstartup-notification0 libsvm-tools libswscale2 libsystemd-daemon0 libsystemd-login0 libt1-5 libtag1-vanilla libtag1c2a libtalloc2 libtdb1
libtelepathy-farstream2 libtelepathy-glib0 libtelepathy-logger2 libthai-data libthai0 libtheora0 libtidy-0.99-0 libtie-ixhash-perl libtiff4 libtimedate-perl
libtotem-plparser17 libtotem0 libtracker-extract-0.14-0 libtracker-miner-0.14-0 libtracker-sparql-0.14-0 libts-0.0-0 libtwolame0 libumfpack5.4.0 libunique-3.0-0
libunistring0 libupower-glib1 liburi-perl libusbmuxd1 libutempter0 libv4l-0 libv4lconvert0 libva1 libvisio-0.0-0 libvisual-0.4-0 libvisual-0.4-plugins libvo-aacenc0
libvo-amrwbenc0 libvorbis0a libvorbisenc2 libvorbisfile3 libvpx1 libvte-2.90-9 libvte-2.90-common libvte-common libvte9 libwacom-common libwacom2 libwavpack1 libwbclient0
libwebkitgtk-1.0-0 libwebkitgtk-1.0-common libwebkitgtk-3.0-0 libwebkitgtk-3.0-common libwebrtc-audio-processing-0 libwildmidi-config libwildmidi1 libwmf-bin libwmf0.2-7
libwnck-3-0 libwnck-3-common libwnck-common libwnck22 libwpd-0.9-9 libwpg-0.2-2 libwps-0.2-2 libwww-perl libwww-robotrules-perl libx11-protocol-perl libx11-xcb1 libx264-123
libx86-1 libxalan2-java libxaw7 libxcb-dri2-0 libxcb-glx0 libxcb-render0 libxcb-shape0 libxcb-shm0 libxcb-util0 libxcomposite1 libxcursor1 libxdamage1 libxerces2-java
libxfixes3 libxfont1 libxft2 libxi6 libxinerama1 libxkbfile1 libxklavier16 libxml-commons-external-java libxml-commons-resolver1.1-java libxml-parser-perl libxml-twig-perl
libxml-xpathengine-perl libxmu6 libxpm4 libxrandr2 libxrender1 libxres1 libxslt1.1 libxss1 libxt6 libxtst6 libxv1 libxvidcore4 libxvmc1 libxxf86dga1 libxxf86vm1 libxz-java
libyajl2 libyelp0 libzbar0 libzephyr4 libzvbi-common libzvbi0 lightsoff lp-solve mahjongg media-player-info menu mesa-utils metacity metacity-common minissdpd
mobile-broadband-provider-info modemmanager mono-4.0-gac mono-gac mono-runtime mousetweaks mutter-common mythes-en-us nautilus nautilus-data nautilus-sendto
nautilus-sendto-empathy netpbm network-manager network-manager-gnome nmap notification-daemon ntfs-3g obex-data-server obexd-client openjdk-6-jre openjdk-6-jre-headless
openjdk-6-jre-lib p7zip-full packagekit packagekit-backend-aptcc packagekit-tools perlmagick pidgin-data pm-utils policykit-1 policykit-1-gnome poppler-data powermgmt-base
ppp pstoedit psutils pulseaudio pulseaudio-module-x11 pulseaudio-utils python-aptdaemon python-aptdaemon.gtk3widgets python-beautifulsoup python-brlapi python-cairo
python-dbus python-dbus-dev python-defer python-feedparser python-gconf python-gi python-gi-cairo python-gnome2 python-gnupginterface python-gobject python-gobject-2
python-gtk2 python-httplib2 python-libxml2 python-louis python-mako python-markupsafe python-notify python-numpy python-packagekit python-pkg-resources python-pyatspi
python-pyatspi2 python-pycurl python-pyorbit python-software-properties python-speechd python-uno python-utidylib python-wnck python-xapian python-xdg python-zeitgeist
quadrapassel rarian-compat rdesktop rhythmbox rhythmbox-data rhythmbox-plugin-cdrecorder rhythmbox-plugins rtkit rygel rygel-playbin rygel-preferences rygel-tracker
sane-utils seahorse sgml-data shared-mime-info shotwell shotwell-common simple-scan software-properties-common software-properties-gtk sound-juicer sound-theme-freedesktop
speech-dispatcher sudo swell-foop synaptic task-desktop task-gnome-desktop telepathy-gabble telepathy-haze telepathy-idle telepathy-logger telepathy-mission-control-5
telepathy-rakia telepathy-salut tomboy totem totem-common totem-plugins tracker tracker-extract tracker-gui tracker-miner-fs tracker-utils transmission-common
transmission-gtk tsconf ttf-dejavu ttf-dejavu-core ttf-dejavu-extra ttf-liberation ttf-sil-gentium-basic tzdata-java udisks ufraw-batch unattended-upgrades uno-libs3
unoconv unzip update-inetd upower ure usb-modeswitch usb-modeswitch-data usbmuxd vbetool vinagre vino wireless-regdb wpasupplicant x11-apps x11-common x11-session-utils
x11-utils x11-xfs-utils x11-xkb-utils x11-xserver-utils xbitmaps xbrlapi xdg-user-dirs xdg-user-dirs-gtk xdg-utils xfonts-100dpi xfonts-75dpi xfonts-base xfonts-encodings
xfonts-mathml xfonts-scalable xfonts-utils xinit xorg xorg-docs-core xserver-common xserver-xephyr xserver-xorg xserver-xorg-core xserver-xorg-input-all
xserver-xorg-input-evdev xserver-xorg-input-mouse xserver-xorg-input-synaptics xserver-xorg-input-vmmouse xserver-xorg-input-wacom xserver-xorg-video-all
xserver-xorg-video-apm xserver-xorg-video-ark xserver-xorg-video-ati xserver-xorg-video-chips xserver-xorg-video-cirrus xserver-xorg-video-fbdev xserver-xorg-video-i128
xserver-xorg-video-intel xserver-xorg-video-mach64 xserver-xorg-video-mga xserver-xorg-video-neomagic xserver-xorg-video-nouveau xserver-xorg-video-openchrome
xserver-xorg-video-r128 xserver-xorg-video-radeon xserver-xorg-video-rendition xserver-xorg-video-s3 xserver-xorg-video-s3virge xserver-xorg-video-savage
xserver-xorg-video-siliconmotion xserver-xorg-video-sis xserver-xorg-video-sisusb xserver-xorg-video-tdfx xserver-xorg-video-trident xserver-xorg-video-tseng
xserver-xorg-video-vesa xserver-xorg-video-vmware xserver-xorg-video-voodoo xterm xulrunner-24.0 yelp yelp-xsl zeitgeist-core zenity zenity-common
0 paquets mis à jour, 0 nouvellement installés, 1168 à enlever et 0 non mis à jour.
Il est nécessaire de télécharger 0 o d'archives. Après dépaquetage, 2 419 Mo seront libérés.
(Lecture de la base de données... 126612 fichiers et répertoires déjà installés.)
Suppression de task-gnome-desktop ...
Suppression de gnome ...
Suppression de gnome-core ...
Suppression de gnome-control-center ...
Suppression de gdm3 ...
[ ok ] Stopping GNOME Display Manager: gdm3.
Suppression de accountsservice ...
Suppression de simple-scan ...
Suppression de sane-utils ...
saned disabled; edit /etc/default/saned
Suppression de gnome-color-manager ...
Suppression de colord ...
Suppression de libsane:amd64 ...
Suppression de acl ...
Suppression de aisleriot ...
Suppression de alacarte ...
Suppression de alsa-base ...
Suppression de alsa-utils ...
Suppression de anacron ...
Suppression de ant-optional ...
Suppression de ant ...
Suppression de gnome-user-share ...
Suppression de apg ...
Suppression de packagekit-tools ...
Suppression de gnome-packagekit ...
Suppression de packagekit ...
Suppression de packagekit-backend-aptcc ...
Suppression de app-install-data ...
Suppression de apt-xapian-index ...
Removing index /var/lib/apt-xapian-index...
Suppression de software-properties-gtk ...
Suppression de python-aptdaemon.gtk3widgets ...
Suppression de argyll ...
Suppression de at-spi2-core ...
Suppression de telepathy-salut ...
Suppression de libnss-mdns ...
Checking NSS setup...
Suppression de avahi-daemon ...
[ ok ] Stopping Avahi mDNS/DNS-SD Daemon: avahi-daemon.
Suppression de baobab ...
Suppression de binfmt-support ...
[ ok ] Disabling additional executable binary formats: binfmt-support.
Suppression de gnome-shell-extensions ...
Suppression de gnome-session ...
update-alternatives: utilisation de « /usr/bin/gnome-session-fallback » pour fournir « /usr/bin/x-session-manager » (x-session-manager) en mode automatique
Suppression de gnome-shell ...
Suppression de gnome-bluetooth ...
Suppression de bluez ...
[ ok ] Stopping bluetooth: rfcomm /usr/sbin/bluetoothd.
Suppression de bogofilter ...
Suppression de bogofilter-bdb ...
Suppression de bogofilter-common ...
Suppression de brasero ...
Suppression de sound-juicer ...
Suppression de rhythmbox-plugin-cdrecorder ...
Suppression de libbrasero-media3-1 ...
Suppression de brasero-common ...
Suppression de browser-plugin-gnash ...
Suppression de icedtea-netx:amd64 ...
Suppression de libreoffice ...
Suppression de libreoffice-filter-mobiledev ...
Suppression de libreoffice-report-builder-bin ...
Suppression de libreoffice-evolution ...
Suppression de libreoffice-base ...
Suppression de default-jre ...
Suppression de openjdk-6-jre:amd64 ...
Suppression de icedtea-6-jre-jamvm:amd64 ...
Suppression de icedtea-6-jre-cacao:amd64 ...
Suppression de default-jre-headless ...
Suppression de caribou-antler ...
Suppression de caribou ...
Suppression de cdrdao ...
Suppression de cheese ...
Suppression de nautilus-sendto-empathy ...
Suppression de empathy ...
Suppression de libcheese-gtk21:amd64 ...
Suppression de libcheese3:amd64 ...
Suppression de cheese-common ...
Suppression de tomboy ...
Suppression de libmono-addins-gui0.2-cil ...
Removing libmono-addins-gui0.2-cil from Mono
Suppression de libmono-addins0.2-cil ...
Removing libmono-addins0.2-cil from Mono
Suppression de libgtk2.0-cil ...
Removing libgtk2.0-cil from Mono
Suppression de libgconf2.0-cil ...
Removing libgconf2.0-cil from Mono
Suppression de libgmime2.6-cil ...
Removing libgmime2.6-cil from Mono
Suppression de libglib2.0-cil ...
Removing libglib2.0-cil from Mono
Suppression de libdbus-glib1.0-cil ...
Removing libdbus-glib1.0-cil from Mono
Suppression de libdbus1.0-cil ...
Removing libdbus1.0-cil from Mono
Suppression de cli-common ...
Suppression de pulseaudio-module-x11 ...
Suppression de libcanberra-pulse:amd64 ...
Suppression de pulseaudio ...
[warn] PulseAudio configured for per-user sessions ... (warning).
Suppression de network-manager-gnome ...
Suppression de gnome-session-fallback ...
Suppression de policykit-1-gnome ...
Suppression de gnome-system-log ...
Suppression de policykit-1 ...
Suppression de gnome-power-manager ...
Suppression de consolekit ...
Suppression de task-desktop ...
Suppression de xorg ...
Suppression de x11-xserver-utils ...
Suppression de x11-session-utils ...
Suppression de x11-apps ...
Suppression de hamster-applet ...
Suppression de python-gnome2 ...
Suppression de python-pyorbit ...
Suppression de libgnomeui-0 ...
Suppression de libbonoboui2-0 ...
Suppression de libgnome2-0 ...
Suppression de gnome-mag ...
Suppression de libatspi1.0-0 ...
Suppression de libbonobo2-0 ...
Suppression de libgnome-mag2 ...
Suppression de liborbit2 ...
Suppression de libidl0 ...
Suppression de cpp ...
Suppression de cpp-4.7 ...
Suppression de crda ...
Suppression de cryptsetup-bin ...
Suppression de cups-pk-helper ...
Suppression de gnome-screensaver ...
Suppression de gnome-session-bin ...
Suppression de gnome-applets ...
Suppression de upower ...
Suppression de gvfs-backends ...
Suppression de nautilus-sendto ...
Suppression de gnome-sushi ...
Suppression de nautilus ...
Suppression de gvfs:amd64 ...
Suppression de gvfs-daemons ...
Suppression de gnome-disk-utility ...
Suppression de libgdu0 ...
Suppression de udisks ...
Suppression de tracker-utils ...
Suppression de tracker-miner-fs ...
Suppression de tracker-gui ...
Suppression de tracker-extract ...
Suppression de rygel-tracker ...
Suppression de gnome-documents ...
Suppression de tracker ...
Suppression de rhythmbox-plugins ...
Suppression de rhythmbox ...
Suppression de network-manager ...
[ ok ] Stopping network connection manager: NetworkManager.
Suppression de shotwell ...
Suppression de libunique-3.0-0 ...
Suppression de inkscape ...
Suppression de libgnomevfs2-extra ...
Suppression de libgnomevfs2-0 ...
Suppression de evolution-plugins ...
Suppression de evolution ...
Suppression de seahorse ...
Suppression de gnome-keyring ...
Suppression de gcr ...
Suppression de libreoffice-gnome ...
Suppression de gnome-panel ...
Suppression de gnome-contacts ...
Suppression de libfolks-eds25 ...
Suppression de evolution-data-server ...
Suppression de libgweather-3-0 ...
Suppression de libgweather-common ...
Suppression de gnome-media ...
Suppression de libgnome-media-profiles-3.0-0 ...
Suppression de libgnome2-common ...
Suppression de gdebi ...
Suppression de gksu ...
Suppression de libgksu2-0 ...
update-alternatives: utilisation de « /usr/share/libgksu/debian/gconf-defaults.libgksu-sudo » pour fournir « /usr/share/gconf/defaults/10_libgksu » (libgksu-gconf-defaults) en mode automatique
Suppression de libcanberra-gtk3-module:amd64 ...
Suppression de libcanberra-gtk-module:amd64 ...
Suppression de totem-plugins ...
Suppression de totem ...
Suppression de gnome-video-effects ...
Suppression de libtelepathy-farstream2:amd64 ...
Suppression de telepathy-haze ...
Suppression de libpurple-bin ...
Suppression de libpurple0 ...
Suppression de libfarstream-0.1-0:amd64 ...
Suppression de gstreamer0.10-plugins-good:amd64 ...
Suppression de gstreamer0.10-gconf:amd64 ...
Suppression de libgnomevfs2-common ...
Suppression de gnome-themes-standard ...
Suppression de gnome-terminal ...
update-alternatives: utilisation de « /usr/bin/lxterm » pour fournir « /usr/bin/x-terminal-emulator » (x-terminal-emulator) en mode automatique
Suppression de gnome-terminal-data ...
Suppression de gnome-panel-data ...
Suppression de gnome-applets-data ...
Suppression de evolution-webcal ...
Suppression de gconf2 ...
Suppression de dbus-x11 ...
Suppression de dbus ...
[ ok ] Stopping system message bus: dbus.
Suppression de gnome-user-guide ...
Suppression de yelp ...
Suppression de vino ...
Suppression de vinagre ...
Suppression de totem-common ...
Suppression de telepathy-mission-control-5 ...
Suppression de telepathy-logger ...
Suppression de shotwell-common ...
Suppression de rhythmbox-data ...
Suppression de gnome-settings-daemon ...
Suppression de file-roller ...
Suppression de nautilus-data ...
Suppression de gir1.2-mutter-3.0 ...
Suppression de libmutter0 ...
Suppression de mutter-common ...
Suppression de mousetweaks ...
Suppression de metacity ...
Suppression de libmetacity-private0a ...
Suppression de metacity-common ...
Suppression de gkbd-capplet ...
Suppression de gir1.2-gkbd-3.0 ...
Suppression de libgnomekbd7 ...
Suppression de libgnomekbd-common ...
Suppression de gucharmap ...
Suppression de libevolution ...
Suppression de libgtkhtml-editor-4.0-0 ...
Suppression de libgtkhtml-4.0-0 ...
Suppression de libgtkhtml-4.0-common ...
Suppression de gnome-icon-theme-symbolic ...
Suppression de gnome-icon-theme-extras ...
Suppression de evince ...
Suppression de eog ...
Suppression de gnome-icon-theme ...
update-alternatives: utilisation de « /usr/share/icons/gnome/scalable/places/gnome-foot.svg » pour fournir « /usr/share/icons/gnome/scalable/places/start-here.svg » (start-here.svg) en mode automatique
update-alternatives: avertissement: création de /usr/share/icons/gnome/256x256/places/start-here.png abandonnée car le fichier associé /usr/share/icons/gnome/256x256/places/gnome-foot.png (du groupe de liens start-here.svg) n'existe pas
Suppression de libgtk-3-bin ...
Suppression de « détournement de /usr/sbin/update-icon-caches en /usr/sbin/update-icon-caches.gtk2 par libgtk-3-bin »
Suppression de « détournement de /usr/share/man/man8/update-icon-caches.8.gz en /usr/share/man/man8/update-icon-caches.gtk2.8.gz par libgtk-3-bin »
Suppression de transmission-gtk ...
Suppression de zenity ...
Suppression de libyelp0 ...
Suppression de xdg-user-dirs-gtk ...
Suppression de gir1.2-webkit-3.0 ...
Suppression de gir1.2-javascriptcoregtk-3.0 ...
Suppression de gir1.2-rb-3.0 ...
Suppression de librhythmbox-core6 ...
Suppression de gnome-online-accounts ...
Suppression de gir1.2-goa-1.0 ...
Suppression de libedata-book-1.2-13 ...
Suppression de libgoa-1.0-0:amd64 ...
Suppression de libwebkitgtk-3.0-0 ...
Suppression de gedit-plugins ...
Suppression de gir1.2-vte-2.90 ...
Suppression de libvte-2.90-9 ...
Suppression de gir1.2-totem-1.0 ...
Suppression de libtotem0 ...
Suppression de gedit ...
Suppression de gir1.2-peas-1.0 ...
Suppression de libpeas-1.0-0 ...
Suppression de libseed-gtk3-0 ...
Suppression de rygel-preferences ...
Suppression de notification-daemon ...
Suppression de libnm-gtk0 ...
Suppression de libnautilus-extension1a ...
Suppression de libmx-1.0-2:amd64 ...
Suppression de gnome-orca ...
Suppression de gir1.2-wnck-3.0 ...
Suppression de gnome-system-monitor ...
Suppression de libwnck-3-0 ...
Suppression de libepc-ui-1.0-3 ...
Suppression de libchamplain-gtk-0.12-0:amd64 ...
Suppression de gnome-screenshot ...
Suppression de gnome-games ...
Suppression de quadrapassel ...
Suppression de iagno ...
Suppression de gnobots2 ...
Suppression de gnibbles ...
Suppression de gnect ...
Suppression de libcanberra-gtk3-0:amd64 ...
Suppression de gir1.2-gucharmap-2.90 ...
Suppression de libgucharmap-2-90-7 ...
Suppression de gir1.2-gtksource-3.0 ...
Suppression de libgtksourceview-3.0-0:amd64 ...
Suppression de libgtkmm-3.0-1:amd64 ...
Suppression de libgtk-vnc-2.0-0 ...
Suppression de gir1.2-evince-3.0 ...
Suppression de libevview3-3 ...
Suppression de libgail-3-0:amd64 ...
Suppression de gnome-tweak-tool ...
Suppression de gir1.2-panelapplet-4.0 ...
Suppression de gnome-sudoku ...
Suppression de gir1.2-gnomebluetooth-1.0 ...
Suppression de gir1.2-gcr-3 ...
Suppression de gir1.2-gtkclutter-1.0 ...
Suppression de gir1.2-clutter-gst-1.0 ...
Suppression de gir1.2-clutter-1.0 ...
Suppression de gir1.2-gtk-3.0 ...
Suppression de libpanel-applet-4-0 ...
Suppression de gnome-nettool ...
Suppression de swell-foop ...
Suppression de mahjongg ...
Suppression de lightsoff ...
Suppression de gtali ...
Suppression de gnotski ...
Suppression de gnotravex ...
Suppression de gnomine ...
Suppression de glines ...
Suppression de glchess ...
Suppression de gnome-font-viewer ...
Suppression de libgdu-gtk0 ...
Suppression de gnome-dictionary ...
Suppression de libgdict-1.0-6 ...
Suppression de libgnome-desktop-3-2 ...
Suppression de libgnome-bluetooth10 ...
Suppression de libgcr-3-1 ...
Suppression de gcalctool ...
Suppression de libedataserverui-3.0-1 ...
Suppression de libevdocument3-4 ...
Suppression de dconf-tools ...
Suppression de libclutter-imcontext-0.1-bin ...
Suppression de libclutter-imcontext-0.1-0:amd64 ...
Suppression de libclutter-gtk-1.0-0:amd64 ...
Suppression de libcluttergesture-0.0.2-0:amd64 ...
Suppression de libchamplain-0.12-0:amd64 ...
Suppression de libclutter-gst-1.0-0:amd64 ...
Suppression de libclutter-1.0-0:amd64 ...
Suppression de gir1.2-caribou-1.0 ...
Suppression de libcaribou0:amd64 ...
Suppression de libcaribou-gtk3-module:amd64 ...
Suppression de libavahi-ui-gtk3-0:amd64 ...
Suppression de libgtk-3-0:amd64 ...
Suppression de libgtk-3-common ...
Suppression de gstreamer0.10-plugins-bad:amd64 ...
Suppression de gimp ...
Suppression de libwebkitgtk-1.0-0 ...
Suppression de gir1.2-totem-plparser-1.0 ...
Suppression de grilo-plugins-0.1:amd64 ...
Suppression de libtotem-plparser17 ...
Suppression de telepathy-gabble ...
Suppression de rygel-playbin ...
Suppression de rygel ...
Suppression de gir1.2-gdata-0.0 ...
Suppression de gir1.2-soup-2.4 ...
Suppression de libsocialweb-service ...
Suppression de libsocialweb0:amd64 ...
Suppression de librest-extras-0.7-0:amd64 ...
Suppression de librest-0.7-0:amd64 ...
Suppression de libgdata13 ...
Suppression de libsoup-gnome2.4-1:amd64 ...
Suppression de gstreamer0.10-nice:amd64 ...
Suppression de libnice10:amd64 ...
Suppression de libepc-1.0-3 ...
Suppression de libdmapsharing-3.0-2 ...
Suppression de libgupnp-igd-1.0-4:amd64 ...
Suppression de libgupnp-av-1.0-2 ...
Suppression de libgupnp-1.0-4 ...
Suppression de libgssdp-1.0-3 ...
Suppression de libgrilo-0.1-0:amd64 ...
Suppression de libgeocode-glib0 ...
Suppression de libedata-cal-1.2-15 ...
Suppression de libecal-1.2-11 ...
Suppression de libebook-1.2-13 ...
Suppression de libebackend-1.2-2 ...
Suppression de libedataserver-1.2-16 ...
Suppression de libsoup2.4-1:amd64 ...
Suppression de glib-networking:amd64 ...
Suppression de evince-common ...
Suppression de libcaribou-gtk-module:amd64 ...
Suppression de gsettings-desktop-schemas ...
Suppression de gnome-shell-common ...
Suppression de gnome-games-data ...
Suppression de gedit-common ...
Suppression de evolution-data-server-common ...
Suppression de evolution-common ...
Suppression de libatk-adaptor-data ...
Suppression de dconf-gsettings-backend:amd64 ...
Suppression de dconf-service ...
Suppression de desktop-base ...
update-alternatives: utilisation de « /usr/share/images/desktop-base/joy-inksplat-wallpaper_1920x1080.svg » pour fournir « /usr/share/images/desktop-base/desktop-background » (desktop-background) en mode automatique
update-alternatives: utilisation de « /usr/share/images/desktop-base/spacefun-wallpaper.svg » pour fournir « /usr/share/images/desktop-base/desktop-background » (desktop-background) en mode automatique
update-alternatives: utilisation de « /usr/share/images/desktop-base/spacefun-wallpaper-widescreen.svg » pour fournir « /usr/share/images/desktop-base/desktop-background » (desktop-background) en mode automatique
update-alternatives: utilisation de « /usr/share/images/desktop-base/moreblue-orbit-wallpaper-widescreen.svg » pour fournir « /usr/share/images/desktop-base/desktop-background » (desktop-background) en mode automatique
update-alternatives: utilisation de « /usr/share/images/desktop-base/nightly-wallpaper.png » pour fournir « /usr/share/images/desktop-base/desktop-background » (desktop-background) en mode automatique
update-alternatives: utilisation de « /usr/share/images/desktop-base/debian-blueish-wallpaper.svg » pour fournir « /usr/share/images/desktop-base/desktop-background » (desktop-background) en mode automatique
update-alternatives: utilisation de « /usr/share/images/desktop-base/moreblue-orbit-splash.png » pour fournir « /usr/share/images/desktop-base/desktop-splash » (desktop-splash) en mode automatique
update-alternatives: utilisation de « /usr/share/images/desktop-base/gnome-splash-curves.png » pour fournir « /usr/share/images/desktop-base/desktop-splash » (desktop-splash) en mode automatique
update-alternatives: utilisation de « /usr/share/images/desktop-base/spacefun-grub.png » pour fournir « /usr/share/images/desktop-base/desktop-grub.png » (desktop-grub) en mode automatique
update-alternatives: utilisation de « /usr/share/images/desktop-base/spacefun-grub-widescreen.png » pour fournir « /usr/share/images/desktop-base/desktop-grub.png » (desktop-grub) en mode automatique
Generating grub.cfg ...
cat: /boot/grub/video.lst: Aucun fichier ou dossier de ce type
Found linux image: /boot/vmlinuz-3.2.0-4-amd64
Found initrd image: /boot/initrd.img-3.2.0-4-amd64
Found Debian GNU/Linux (7.6) on /dev/sda5
Found Debian GNU/Linux (jessie/sid) on /dev/sda8
done
Suppression de gvfs-libs:amd64 ...
Suppression de gvfs-bin ...
Suppression de gvfs-common ...
Suppression de desktop-file-utils ...
Suppression de dnsmasq-base ...
Suppression de rarian-compat ...
Suppression de docbook-xml ...
Suppression de dosfstools ...
Suppression de empathy-common ...
Suppression de enchant ...
Suppression de speech-dispatcher ...
speech-dispatcher disabled; edit /etc/default/speech-dispatcher
Suppression de libespeak1:amd64 ...
Suppression de espeak-data:amd64 ...
Suppression de finger ...
Suppression de folks-common ...
Suppression de iceweasel ...
Suppression de « détournement de /usr/bin/firefox en /usr/bin/firefox.real par iceweasel »
Suppression de xulrunner-24.0 ...
Suppression de synaptic ...
Suppression de libvte9 ...
Suppression de python-notify ...
Suppression de python-wnck ...
Suppression de python-gtk2 ...
Suppression de libgtkmm-2.4-1c2a ...
Suppression de libpangomm-1.4-1 ...
Suppression de gir1.2-coglpango-1.0 ...
Suppression de gir1.2-pango-1.0 ...
Suppression de libwnck22 ...
Suppression de librsvg2-common:amd64 ...
Suppression de mythes-en-us ...
Suppression de unoconv ...
Suppression de libreoffice-emailmerge ...
Suppression de python-uno ...
Suppression de libreoffice-help-en-us ...
Suppression de libreoffice-writer ...
Suppression de libreoffice-style-tango ...
Suppression de libreoffice-java-common ...
Suppression de libreoffice-filter-binfilter ...
Suppression de libreoffice-math ...
Suppression de libreoffice-impress ...
Suppression de libreoffice-gtk ...
Suppression de libreoffice-draw ...
Suppression de libreoffice-calc ...
Suppression de libreoffice-base-core ...
Suppression de libmagickcore5-extra:amd64 ...
Suppression de libgegl-0.2-0:amd64 ...
Suppression de libgtk2-perl ...
Suppression de libpango-perl ...
Suppression de libgnomecanvas2-0 ...
Suppression de libglade2-0 ...
Suppression de libcanberra-gtk0:amd64 ...
Suppression de libatk-wrapper-java-jni:amd64 ...
Suppression de libgtkspell0 ...
Suppression de gtk2-engines:amd64 ...
Suppression de libgtk2.0-bin ...
Suppression de python-pyatspi2 ...
Suppression de python-pyatspi ...
Suppression de libgail-common:amd64 ...
Suppression de libgail18:amd64 ...
Suppression de gnash ...
Suppression de libgimp2.0 ...
Suppression de libgtk2.0-0:amd64 ...
Suppression de gstreamer0.10-x:amd64 ...
Suppression de libsvm-tools ...
Suppression de gnuplot ...
Suppression de gnuplot-nox ...
Suppression de libcogl-pango0:amd64 ...
Suppression de fonts-cantarell ...
Bonne journée …
[code][…]
Suppression de xterm …
Suppression de x11-utils …
Suppression de libpoppler-glib8:amd64 …
Suppression de libpoppler19:amd64 …
Suppression de libmono-system-drawing4.0-cil …
Suppression de libgdiplus …
Suppression de libgphoto2-2:amd64 …
Suppression de libgd2-xpm:amd64 …
Suppression de libass4:amd64 …
Suppression de obex-data-server …
Suppression de pstoedit …
Suppression de libpstoedit0c2a …
Suppression de libmagick++5:amd64 …
Suppression de imagemagick …
Suppression de libmagickwand5:amd64 …
Suppression de perlmagick …
Suppression de libmagickcore5:amd64 …
Suppression de gnash-common …
Suppression de libspectre1:amd64 …
Suppression de ghostscript …
Suppression de libgs9 …
Suppression de python-gi-cairo …
Suppression de python-cairo …
Suppression de libmono-cairo4.0-cil …
Suppression de libgxps2:amd64 …
Suppression de libcairo-perl …
Suppression de gjs …
Suppression de libgjs0b …
Suppression de libcairomm-1.0-1 …
Suppression de gir1.2-networkmanager-1.0 …
Suppression de gir1.2-xkl-1.0 …
Suppression de gir1.2-gst-plugins-base-0.10 …
Suppression de gir1.2-gstreamer-0.10 …
Suppression de gir1.2-cogl-1.0 …
Suppression de gir1.2-freedesktop …
Suppression de libcairo-gobject2:amd64 …
Suppression de fonts-droid …
Suppression de ttf-liberation …
Suppression de fonts-liberation …
Suppression de fonts-lyx …
Suppression de fonts-sil-gentium …
Suppression de ttf-sil-gentium-basic …
Suppression de fonts-sil-gentium-basic …
Suppression de fonts-stix …
Suppression de freepats …
Suppression de ntfs-3g …
Suppression de fuse …
Suppression de python-gconf …
Suppression de geoclue-yahoo …
Suppression de geoclue-manual …
Suppression de geoclue-localnet …
Suppression de geoclue-hostip …
Suppression de geoclue …
Suppression de libgconf2-4:amd64 …
Suppression de gir1.2-gconf-2.0 …
Suppression de libfolks-telepathy25 …
Suppression de libfolks25 …
Suppression de gconf-service …
Suppression de libgconf-2-4:amd64 …
Suppression de gconf2-common …
Suppression de gdebi-core …
Suppression de gimp-data …
Suppression de gir1.2-accountsservice-1.0 …
Suppression de gir1.2-atk-1.0 …
Suppression de gir1.2-atspi-2.0 …
Suppression de gir1.2-folks-0.6 …
Suppression de gir1.2-gck-1 …
Suppression de gir1.2-gdesktopenums-3.0 …
Suppression de gir1.2-gdkpixbuf-2.0 …
Suppression de gir1.2-gee-1.0 …
Suppression de gir1.2-upowerglib-1.0 …
Suppression de gir1.2-tracker-0.14 …
Suppression de gir1.2-telepathylogger-0.2 …
Suppression de gir1.2-telepathyglib-0.12 …
Suppression de software-properties-common …
Suppression de zeitgeist-core …
Suppression de python-zeitgeist …
Suppression de python-gobject …
Suppression de python-gi …
Suppression de gir1.2-polkit-1.0 …
Suppression de gir1.2-gtop-2.0 …
Suppression de gir1.2-gnomekeyring-1.0 …
Suppression de gir1.2-json-1.0 …
Suppression de gir1.2-gmenu-3.0 …
Suppression de gir1.2-glib-2.0 …
Suppression de glib-networking-services …
Suppression de glib-networking-common …
Suppression de gnome-accessibility-themes …
Suppression de gnome-backgrounds …
Suppression de gnome-control-center-data …
Suppression de gnome-desktop3-data …
Suppression de gnome-games-extra-data …
Suppression de gnome-js-common …
Suppression de gnome-menus …
Suppression de gnome-mime-data …
Suppression de gnome-packagekit-data …
Suppression de gnome-session-common …
Suppression de gnome-themes-standard-data …
Suppression de gnuchess-book …
Suppression de gnuchess …
Suppression de groff …
Suppression de gsfonts …
Suppression de gstreamer0.10-ffmpeg:amd64 …
Suppression de gstreamer0.10-plugins-base:amd64 …
Suppression de gstreamer0.10-plugins-ugly:amd64 …
Suppression de gstreamer0.10-pulseaudio:amd64 …
Suppression de guile-2.0-libs …
Suppression de hdparm …
Suppression de hicolor-icon-theme …
Suppression de libenchant1c2a …
Suppression de hunspell-en-us …
Suppression de hwdata …
Suppression de hyphen-en-us …
Suppression de icedtea-netx-common …
Suppression de imagemagick-common …
Suppression de iputils-tracepath …
Suppression de iw …
Suppression de liba52-0.7.4 …
Suppression de libaa1:amd64 …
Suppression de libaacs0:amd64 …
Suppression de libaccountsservice0 …
Suppression de libumfpack5.4.0 …
Suppression de libamd2.2.0 …
Suppression de libao4 …
Suppression de libao-common …
Suppression de libcommons-digester-java …
Suppression de libcommons-beanutils-java …
Suppression de libcommons-logging-java …
Suppression de libcommons-parent-java …
Suppression de libapache-pom-java …
Suppression de libaprutil1-ldap …
Suppression de libaprutil1-dbd-sqlite3 …
Suppression de libaprutil1 …
Suppression de libapr1 …
Suppression de libpackagekit-glib2-14:amd64 …
Suppression de libarchive12:amd64 …
Suppression de libart-2.0-2:amd64 …
Suppression de rdesktop …
Suppression de libportaudio2:amd64 …
Suppression de libvisual-0.4-plugins:amd64 …
Suppression de libsdl1.2debian:amd64 …
Suppression de libcanberra0:amd64 …
Suppression de libflite1:amd64 …
Suppression de libasound2-plugins:amd64 …
Suppression de libasound2:amd64 …
Suppression de pulseaudio-utils …
Suppression de libpulse-mainloop-glib0:amd64 …
Suppression de libgvnc-1.0-0 …
Suppression de libpulse0:amd64 …
Suppression de libasyncns0:amd64 …
Suppression de libatasmart4:amd64 …
Suppression de libatk-adaptor:amd64 …
Suppression de libatk-bridge2.0-0:amd64 …
Suppression de libatk-wrapper-java …
Suppression de libatkmm-1.6-1 …
Suppression de libatk1.0-0:amd64 …
Suppression de libatk1.0-data …
Suppression de libatspi2.0-0:amd64 …
Suppression de libaudio2:amd64 …
Suppression de xserver-xorg …
Suppression de xserver-xorg-video-all …
Suppression de xserver-xorg-video-voodoo …
Suppression de xserver-xorg-video-vmware …
Suppression de xserver-xorg-video-vesa …
Suppression de xserver-xorg-video-tseng …
Suppression de xserver-xorg-video-trident …
Suppression de xserver-xorg-video-tdfx …
Suppression de xserver-xorg-video-sisusb …
Suppression de xserver-xorg-video-sis …
Suppression de xserver-xorg-video-siliconmotion …
Suppression de xserver-xorg-video-savage …
Suppression de xserver-xorg-video-s3virge …
Suppression de xserver-xorg-video-s3 …
Suppression de xserver-xorg-video-rendition …
Suppression de xserver-xorg-video-ati …
Suppression de xserver-xorg-video-r128 …
Suppression de xserver-xorg-video-openchrome …
Suppression de xserver-xorg-video-nouveau …
Suppression de xserver-xorg-video-neomagic …
Suppression de xserver-xorg-video-mga …
Suppression de xserver-xorg-video-mach64 …
Suppression de xserver-xorg-video-intel …
Suppression de xserver-xorg-video-i128 …
Suppression de xserver-xorg-video-fbdev …
Suppression de xserver-xorg-video-cirrus …
Suppression de xserver-xorg-video-chips …
Suppression de xserver-xorg-video-radeon …
Suppression de xserver-xorg-video-ark …
Suppression de xserver-xorg-video-apm …
Suppression de xserver-xorg-input-all …
Suppression de xserver-xorg-input-vmmouse …
Suppression de xserver-xorg-input-synaptics …
Suppression de xserver-xorg-input-mouse …
Suppression de xserver-xorg-input-evdev …
Suppression de xserver-xorg-input-wacom …
Suppression de xserver-xorg-core …
Suppression de xserver-xephyr …
Suppression de libaudit0 …
Suppression de libcupsimage2:amd64 …
Suppression de libavahi-gobject0:amd64 …
Suppression de libavahi-glib1:amd64 …
Suppression de libavahi-core7:amd64 …
Suppression de libavc1394-0:amd64 …
Suppression de libavformat53:amd64 …
Suppression de libavcodec53:amd64 …
Suppression de libswscale2:amd64 …
Suppression de libpostproc52:amd64 …
Suppression de libavutil51:amd64 …
Suppression de libbabl-0.1-0:amd64 …
Suppression de python-numpy …
Suppression de liblapack3 …
Suppression de nmap …
Suppression de liblinear-tools …
Suppression de liblinear1 …
Suppression de libblas3gf …
Suppression de libblas3 …
Suppression de obexd-client …
Suppression de libbluetooth3:amd64 …
Suppression de libbluray1:amd64 …
Suppression de libbonobo2-common …
Suppression de libbonoboui2-common …
Suppression de libboost-program-options1.49.0 …
Suppression de libboost-thread1.49.0 …
Suppression de xbrlapi …
Suppression de python-brlapi …
Suppression de libbrlapi0.5:amd64 …
Suppression de libburn4 …
Suppression de libcaca0:amd64 …
Suppression de libcamel-1.2-33 …
Suppression de libcap-ng0 …
Suppression de libcap2-bin …
Suppression de libcaribou-common …
Suppression de libcdaudio1 …
Suppression de libcdio-paranoia1 …
Suppression de libcdio-cdda1 …
Suppression de libcdio13 …
Suppression de libcdparanoia0 …
Suppression de libpam-ck-connector:amd64 …
Suppression de libck-connector0:amd64 …
Suppression de libclutter-1.0-common …
Suppression de libcogl-common …
Suppression de libcogl9:amd64 …
Suppression de lp-solve …
Suppression de libcolamd2.7.1 …
Suppression de libcolorblind0 …
Suppression de libcolord1:amd64 …
Suppression de libcommons-collections3-java …
Suppression de libcommons-compress-java …
Suppression de libcpufreq0 …
Suppression de libcryptsetup4 …
Suppression de libslv2-9 …
Suppression de python-software-properties …
Suppression de python-pycurl …
Suppression de libquvi7:amd64 …
Suppression de liboauth0:amd64 …
Suppression de libdaemon0 …
Suppression de libdb-java …
Suppression de libdb-je-java …
Suppression de libdb5.1-java …
Suppression de libdb5.1-java-jni:amd64 …
Suppression de wpasupplicant …
Suppression de libupower-glib1 …
Suppression de telepathy-rakia …
Suppression de libmission-control-plugins0 …
Suppression de libtelepathy-logger2:amd64 …
Suppression de telepathy-idle …
Suppression de libtelepathy-glib0:amd64 …
Suppression de rtkit …
Suppression de libnm-glib4 …
Suppression de libnm-glib-vpn1 …
Suppression de libnm-util2 …
Suppression de modemmanager …
Suppression de libsocialweb-client2:amd64 …
Suppression de libnet-dbus-perl …
Suppression de libgnome-keyring0:amd64 …
Suppression de libgeoclue0 …
Suppression de python-packagekit …
Suppression de python-dbus …
Suppression de libdbus-glib-1-2:amd64 …
Suppression de libdc1394-22:amd64 …
Suppression de libdca0 …
Suppression de libdconf0:amd64 …
Suppression de libdee-1.0-4 …
Suppression de liblvm2app2.2:amd64 …
Suppression de libdevmapper-event1.02.1:amd64 …
Suppression de libdirac-encoder0:amd64 …
Suppression de libdirectfb-1.2-9:amd64 …
Suppression de libdiscid0:amd64 …
Suppression de libdjvulibre21 …
Suppression de libdjvulibre-text …
Suppression de libdotconf1.0 …
Suppression de libgl1-mesa-dri:amd64 …
Suppression de libdrm-intel1:amd64 …
Suppression de libdrm-nouveau1a:amd64 …
Suppression de libdrm-radeon1:amd64 …
Suppression de mesa-utils …
Suppression de libglew1.7:amd64 …
Suppression de libglu1-mesa:amd64 …
Suppression de libgl1-mesa-glx:amd64 …
Suppression de libdrm2:amd64 …
Suppression de libdv4:amd64 …
Suppression de libdvdnav4 …
Suppression de libdvdread4 …
Suppression de libglib2.0-bin …
Suppression de libelf1 …
Suppression de libtracker-extract-0.14-0 …
Suppression de libenca0 …
Suppression de libxml-twig-perl …
Suppression de libxml-parser-perl …
Suppression de libhttp-daemon-perl …
Suppression de libhtml-form-perl …
Suppression de libepc-common …
Suppression de libexempi3:amd64 …
Suppression de libexif12:amd64 …
Suppression de ufraw-batch …
Suppression de libgexiv2-1 …
Suppression de libexiv2-12 …
Suppression de libfaad2:amd64 …
Suppression de libfam0 …
Suppression de libmozjs24d …
Suppression de python-gobject-2 …
Suppression de libmozjs185-1.0 …
Suppression de libgirepository-1.0-1 …
Suppression de libjavascriptcoregtk-3.0-0 …
Suppression de libjavascriptcoregtk-1.0-0 …
Suppression de libwacom2:amd64 …
Suppression de libgusb2 …
Suppression de libgudev-1.0-0:amd64 …
Suppression de libtracker-miner-0.14-0 …
Suppression de libtracker-sparql-0.14-0 …
Suppression de libspeechd2 …
Suppression de libsofia-sip-ua-glib3 …
Suppression de libfile-mimeinfo-perl …
Suppression de shared-mime-info …
Suppression de libpolkit-backend-1-0:amd64 …
Suppression de libpolkit-agent-1-0:amd64 …
Suppression de libpolkit-gobject-1-0:amd64 …
Suppression de libmx-bin …
Suppression de libmeanwhile1 …
Suppression de libxklavier16 …
Suppression de libwmf-bin …
Suppression de libwmf0.2-7:amd64 …
Suppression de libnotify4:amd64 …
Suppression de libmms0:amd64 …
Suppression de libmimic0 …
Suppression de liblqr-1-0:amd64 …
Suppression de libgpod-common …
Suppression de libgpod4:amd64 …
Suppression de libimobiledevice2 …
Suppression de libgtop2-7 …
Suppression de libgsf-1-114 …
Suppression de libglib-perl …
Suppression de libgee2:amd64 …
Suppression de liblensfun0 …
Suppression de libjson-glib-1.0-0:amd64 …
Suppression de libgupnp-dlna-1.0-2 …
Suppression de libgstreamer-plugins-bad0.10-0:amd64 …
Suppression de libgnome-menu-3-0 …
Suppression de libgmime-2.6-0 …
Suppression de libglibmm-2.4-1c2a:amd64 …
Suppression de libgck-1-0 …
Suppression de libofa0 …
Suppression de libfftw3-3:amd64 …
Suppression de libfile-desktopentry-perl …
Suppression de libfile-basedir-perl …
Suppression de update-inetd …
Suppression de libfile-copy-recursive-perl …
Suppression de libsndfile1:amd64 …
Suppression de libflac8:amd64 …
Suppression de libhtml-format-perl …
Suppression de libfont-afm-perl …
Suppression de xfonts-scalable …
Suppression de xfonts-mathml …
Suppression de xfonts-base …
Suppression de xfonts-75dpi …
Suppression de xfonts-100dpi …
Suppression de xfonts-utils …
Suppression de libxfont1 …
Suppression de libfontenc1:amd64 …
Suppression de libfribidi0:amd64 …
Suppression de x11-xfs-utils …
Suppression de libfs6:amd64 …
Suppression de libgadu3 …
Suppression de libgcr-3-common …
Suppression de libgdata-common …
Suppression de libgdict-common …
Suppression de libgfortran3:amd64 …
Suppression de libgif4 …
Suppression de libglapi-mesa:amd64 …
Suppression de libglib2.0-data …
Suppression de libgme0 …
Suppression de libmpc2:amd64 …
Suppression de libmpfr4:amd64 …
Suppression de libgnome-keyring-common …
Suppression de libgnomecanvas2-common …
Suppression de libgnomeui-common …
Suppression de libgoa-1.0-common …
Suppression de libgomp1:amd64 …
Suppression de libgphoto2-l10n …
Suppression de libgphoto2-port0:amd64 …
Suppression de libgs9-common …
Suppression de libgsf-1-common …
Suppression de libgsl0ldbl …
Suppression de libgsm1:amd64 …
Suppression de libgtk2.0-common …
Suppression de libgtksourceview-3.0-common …
Suppression de libgtop2-common …
Suppression de libhsqldb-java …
Suppression de libical0 …
Suppression de libicc2:amd64 …
Suppression de libzbar0 …
Suppression de libplot2c2 …
Suppression de xserver-common …
Suppression de x11-xkb-utils …
Suppression de libxaw7:amd64 …
Suppression de libxmu6:amd64 …
Suppression de libxt6:amd64 …
Suppression de libicu4j-java …
Suppression de libiec61883-0 …
Suppression de libieee1284-3:amd64 …
Suppression de libijs-0.35 …
Suppression de libopenexr6 …
Suppression de libilmbase6 …
Suppression de libimdi0:amd64 …
Suppression de libio-socket-ip-perl …
Suppression de libiptcdata0 …
Suppression de libisofs6 …
Suppression de libjack-jackd2-0:amd64 …
Suppression de libraw5:amd64 …
Suppression de libxalan2-java …
Suppression de libjaxp1.3-java …
Suppression de libspandsp2 …
Suppression de netpbm …
Suppression de libjbig2dec0 …
Suppression de usb-modeswitch …
Suppression de libjim0debian2:amd64 …
Suppression de libjline-java …
Suppression de libv4l-0:amd64 …
Suppression de libv4lconvert0:amd64 …
Suppression de libopenraw1:amd64 …
Suppression de libmng1:amd64 …
Suppression de libjson0:amd64 …
Suppression de libjte1 …
Suppression de libjtidy-java …
Suppression de libkate1 …
Suppression de libkpathsea6 …
Suppression de liblcms1:amd64 …
Suppression de liblensfun-data …
Suppression de liblircclient0 …
Suppression de python-louis …
Suppression de liblouis2:amd64 …
Suppression de liblouis-data …
Suppression de liblua5.1-0:amd64 …
Suppression de liblucene2-java …
Suppression de libmad0 …
Suppression de libmailtools-perl …
Suppression de libminiupnpc5 …
Suppression de libmodplug1 …
Suppression de libmono-system-core4.0-cil …
Suppression de libmono-sharpzip4.84-cil …
Suppression de libmono-posix4.0-cil …
Suppression de libmono-i18n-west4.0-cil …
Suppression de libmono-i18n4.0-cil …
Suppression de libmp3lame0:amd64 …
Suppression de libmpcdec6:amd64 …
Suppression de libmpeg2-4 …
Suppression de libmtdev1:amd64 …
Suppression de libmtp-runtime …
Suppression de libmtp9:amd64 …
Suppression de libmtp-common …
Suppression de libmusicbrainz5-0:amd64 …
Suppression de libmx-common …
Suppression de libnatpmp1 …
Suppression de libnetfilter-conntrack3:amd64 …
Suppression de libnetpbm10 …
Suppression de libnettle4:amd64 …
Suppression de libnl-route-3-200:amd64 …
Suppression de libnl-genl-3-200:amd64 …
Suppression de libnl-3-200:amd64 …
Suppression de libnm-gtk-common …
Suppression de libvorbisfile3:amd64 …
Suppression de libvorbisenc2:amd64 …
Suppression de libshout3:amd64 …
Suppression de libvorbis0a:amd64 …
Suppression de libtheora0:amd64 …
Suppression de libogg0:amd64 …
Suppression de libopenal1:amd64 …
Suppression de libopenal-data …
Suppression de libopencore-amrnb0:amd64 …
Suppression de libopencore-amrwb0:amd64 …
Suppression de libopenjpeg2:amd64 …
Suppression de libopenobex1 …
Suppression de libopus0 …
Suppression de libschroedinger-1.0-0:amd64 …
Suppression de libpam-cap:amd64 …
Suppression de libpam-gnome-keyring …
Suppression de libpaper-utils …
Suppression de psutils …
Suppression de libpaper1:amd64 …
Suppression de libparted0debian1:amd64 …
Suppression de ppp …
Stopping all PPP connections…done.
Suppression de libpcap0.8:amd64 …
Suppression de libpciaccess0:amd64 …
Suppression de libpeas-common …
Suppression de libperl5.14 …
Suppression de usbmuxd …
Suppression de libusbmuxd1 …
Suppression de libplist1 …
Suppression de libzvbi0:amd64 …
Suppression de libproxy0:amd64 …
Suppression de libpst4:amd64 …
Suppression de libpython2.7 …
Suppression de libquadmath0:amd64 …
Suppression de libquvi-scripts …
Suppression de librarian0 …
Suppression de libraw1394-11:amd64 …
Suppression de libreadline5:amd64 …
Suppression de libregexp-java …
Suppression de libsamplerate0:amd64 …
Suppression de libsane-common …
Suppression de libsane-extras:amd64 …
Suppression de libsane-extras-common …
Suppression de libservlet2.5-java …
Suppression de libsgutils2-2 …
Suppression de libsidplay1 …
Suppression de libsmbclient:amd64 …
Suppression de libsocialweb-common …
Suppression de libsocket-perl …
Suppression de libsofia-sip-ua0 …
Suppression de libsonic0:amd64 …
Suppression de libsoundtouch0:amd64 …
Suppression de libspeex1:amd64 …
Suppression de libspeexdsp1:amd64 …
Suppression de libstartup-notification0 …
Suppression de libsystemd-daemon0:amd64 …
Suppression de libsystemd-login0:amd64 …
Suppression de libt1-5 …
Suppression de libtag1c2a:amd64 …
Suppression de libtag1-vanilla:amd64 …
Suppression de libtalloc2:amd64 …
Suppression de libtdb1:amd64 …
Suppression de python-utidylib …
Suppression de libtidy-0.99-0 …
Suppression de libtie-ixhash-perl …
Suppression de libts-0.0-0:amd64 …
Suppression de libtwolame0 …
Suppression de libunistring0:amd64 …
Suppression de libutempter0 …
Suppression de libva1:amd64 …
Suppression de libvisio-0.0-0 …
Suppression de libvisual-0.4-0:amd64 …
Suppression de libvo-aacenc0:amd64 …
Suppression de libvo-amrwbenc0:amd64 …
Suppression de libvpx1:amd64 …
Suppression de libvte-2.90-common …
Suppression de libvte-common …
Suppression de libwacom-common …
Suppression de libwavpack1:amd64 …
Suppression de libwbclient0:amd64 …
Suppression de libwebkitgtk-1.0-common …
Suppression de libwebkitgtk-3.0-common …
Suppression de libwebrtc-audio-processing-0:amd64 …
Suppression de libwildmidi1:amd64 …
Suppression de libwildmidi-config …
Suppression de libwnck-3-common …
Suppression de libwnck-common …
Suppression de libwps-0.2-2 …
Suppression de libwpg-0.2-2 …
Suppression de libwpd-0.9-9 …
Suppression de libx11-protocol-perl …
Suppression de libx11-xcb1:amd64 …
Suppression de libx264-123:amd64 …
Suppression de vbetool …
Suppression de libx86-1:amd64 …
Suppression de libxcb-dri2-0:amd64 …
Suppression de libxcb-glx0:amd64 …
Suppression de libxcb-shape0:amd64 …
Suppression de libxcb-util0:amd64 …
Suppression de libxcomposite1:amd64 …
Suppression de libxcursor1:amd64 …
Suppression de libxdamage1:amd64 …
Suppression de libxerces2-java …
Suppression de libxfixes3:amd64 …
Suppression de libxtst6:amd64 …
Suppression de libxi6:amd64 …
Suppression de libxkbfile1:amd64 …
Suppression de libxml-commons-external-java …
Suppression de libxml-commons-resolver1.1-java …
Suppression de libxml-xpathengine-perl …
Suppression de libxpm4:amd64 …
Suppression de libxres1:amd64 …
Suppression de libxss1:amd64 …
Suppression de libxvmc1 …
Suppression de libxv1:amd64 …
Suppression de libxvidcore4:amd64 …
Suppression de libxxf86dga1:amd64 …
Suppression de libxxf86vm1:amd64 …
Suppression de libxz-java …
Suppression de libzephyr4 …
Suppression de libzvbi-common …
Suppression de media-player-info …
Suppression de menu …
Suppression de minissdpd …
Suppression de mobile-broadband-provider-info …
Suppression de p7zip-full …
Suppression de pidgin-data …
Suppression de pm-utils …
Suppression de poppler-data …
Suppression de powermgmt-base …
Suppression de python-beautifulsoup …
Suppression de python-dbus-dev …
Suppression de python-defer …
Suppression de python-feedparser …
Suppression de python-gnupginterface …
Suppression de python-httplib2 …
Suppression de python-libxml2 …
Suppression de python-mako …
Suppression de python-markupsafe …
Suppression de python-pkg-resources …
Suppression de python-speechd …
Suppression de python-xapian …
Suppression de python-xdg …
Suppression de sgml-data …
Suppression de sound-theme-freedesktop …
Suppression de sudo …
Suppression de transmission-common …
Suppression de tsconf …
Suppression de ttf-dejavu …
Suppression de ttf-dejavu-extra …
Suppression de unattended-upgrades …
Suppression de unzip …
Suppression de usb-modeswitch-data …
Suppression de wireless-regdb …
Suppression de xinit …
Suppression de xfonts-encodings …
Suppression de xbitmaps …
Suppression de xdg-user-dirs …
Suppression de xdg-utils …
Suppression de xorg-docs-core …
Suppression de yelp-xsl …
Suppression de zenity-common …
Suppression de libreoffice-common …
rmdir: échec de suppression de « /var/lib/libreoffice/share/prereg/ »: Aucun fichier ou dossier de ce type
rmdir: échec de suppression de « /var/lib/libreoffice/share/ »: Aucun fichier ou dossier de ce type
rmdir: échec de suppression de « /var/lib/libreoffice/program/ »: Aucun fichier ou dossier de ce type
rmdir: échec de suppression de « /var/lib/libreoffice »: Aucun fichier ou dossier de ce type
Suppression de libmono-corlib4.0-cil …
Suppression de openjdk-6-jre-lib …
Suppression de libreoffice-style-galaxy …
Suppression de libreoffice-core …
Suppression de librsvg2-2:amd64 …
Suppression de libpango1.0-0:amd64 …
Suppression de fontconfig …
Suppression de libxft2:amd64 …
Suppression de libcairo2:amd64 …
Suppression de libfontconfig1:amd64 …
Suppression de fontconfig-config …
Suppression de fonts-opensymbol …
Suppression de libcmis-0.2-0 …
Suppression de libcroco3:amd64 …
Suppression de librdf0 …
Suppression de librasqal3 …
Suppression de libraptor2-0 …
Suppression de libcurl3-gnutls:amd64 …
Suppression de libthai0:amd64 …
Suppression de libdatrie1:amd64 …
Suppression de libwww-perl …
Suppression de liblwp-protocol-https-perl …
Suppression de libhttp-negotiate-perl …
Suppression de libhttp-cookies-perl …
Suppression de libhttp-message-perl …
Suppression de libencode-locale-perl …
Suppression de libexttextcat0 …
Suppression de libexttextcat-data …
Suppression de libgstreamer-plugins-base0.10-0:amd64 …
Suppression de libgstreamer0.10-0:amd64 …
Suppression de libgdk-pixbuf2.0-0:amd64 …
Suppression de libglib2.0-0:amd64 …
Suppression de libffi5:amd64 …
Suppression de libfile-listing-perl …
Suppression de libgdk-pixbuf2.0-common …
Suppression de libgmp10:amd64 …
Suppression de libgraphite2-2.0.0 …
Suppression de libhtml-tree-perl …
Suppression de libhtml-parser-perl …
Suppression de libhtml-tagset-perl …
Suppression de libhttp-date-perl …
Suppression de libhunspell-1.3-0:amd64 …
Suppression de libhyphen0 …
Suppression de libsm6:amd64 …
Suppression de libice6:amd64 …
Suppression de libicu48:amd64 …
Suppression de libio-socket-ssl-perl …
Suppression de libjasper1:amd64 …
Suppression de libtiff4:amd64 …
Suppression de libjbig0:amd64 …
Suppression de libltdl7:amd64 …
Suppression de liblwp-mediatypes-perl …
Suppression de libmhash2 …
Suppression de mono-runtime …
Suppression de mono-gac …
Suppression de mono-4.0-gac …
Suppression de libmono-security4.0-cil …
Suppression de libmono-system4.0-cil …
Suppression de libmono-system-configuration4.0-cil …
Suppression de libmythes-1.2-0 …
Suppression de libneon27-gnutls …
Suppression de libnet-http-perl …
Suppression de libnet-ssleay-perl …
Suppression de liborc-0.4-0:amd64 …
Suppression de libpixman-1-0:amd64 …
Suppression de libpng12-0:amd64 …
Suppression de librtmp0:amd64 …
Suppression de libssh2-1:amd64 …
Suppression de libthai-data …
Suppression de libtimedate-perl …
Suppression de libwww-robotrules-perl …
Suppression de liburi-perl …
Suppression de libxcb-render0:amd64 …
Suppression de libxcb-shm0:amd64 …
Suppression de libxinerama1:amd64 …
Suppression de libxrandr2:amd64 …
Suppression de libxrender1:amd64 …
Suppression de libxslt1.1:amd64 …
Suppression de libyajl2 …
Suppression de ttf-dejavu-core …
Suppression de ure …
Suppression de uno-libs3 …
Suppression de x11-common …
Suppression de ca-certificates-java …
Suppression de openjdk-6-jre-headless:amd64 …
Suppression de java-common …
Suppression de libcups2:amd64 …
Suppression de libavahi-client3:amd64 …
Suppression de libavahi-common3:amd64 …
Suppression de libavahi-common-data:amd64 …
Suppression de libdbus-1-3:amd64 …
Suppression de libjpeg8:amd64 …
Suppression de liblcms2-2:amd64 …
Suppression de libmono-system-security4.0-cil …
Suppression de libmono-system-xml4.0-cil …
Suppression de libnss3-1d:amd64 …
Suppression de libnss3:amd64 …
Suppression de libnspr4:amd64 …
Suppression de libpcsclite1:amd64 …
Suppression de tzdata-java …
Traitement des actions différées (« triggers ») pour « man-db »…
Traitement des actions différées (« triggers ») pour « python-support »…
Traitement des actions différées (« triggers ») pour « mime-support »…
Traitement des actions différées (« triggers ») pour « sgml-base »…
Traitement des actions différées (« triggers ») pour « install-info »…
Traitement des actions différées (« triggers ») pour « initramfs-tools »…
update-initramfs: Generating /boot/initrd.img-3.2.0-4-amd64
Traitement des actions différées (« triggers ») pour « ca-certificates »…
Updating certificates in /etc/ssl/certs… 0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d…
updates of cacerts keystore disabled.
done.
root@Feu-le-Gnome:~#[/code]
