Merci Hulk, mais j’ai toujours mes messages d’erreurs (et ma xbox ne peut pas accéder à mon partage
Voici mon fichiers de logs “messages” :
Dec 23 18:05:17 bureau kernel: [ 115.828147] rpcbind: RPC call returned error 1
Dec 23 18:05:17 bureau kernel: [ 115.828174] IN= OUT=eth0 SRC=192.168.0.51 DST=127.0.0.1 LEN=120 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=947 DPT=111 LEN=100
Dec 23 18:05:17 bureau kernel: [ 115.828182] rpcbind: RPC call returned error 1
Dec 23 18:05:17 bureau kernel: [ 115.828208] IN= OUT=eth0 SRC=192.168.0.51 DST=127.0.0.1 LEN=120 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=682 DPT=111 LEN=100
Dec 23 18:05:17 bureau kernel: [ 115.828216] rpcbind: RPC call returned error 1
Dec 23 18:05:17 bureau kernel: [ 115.828249] IN= OUT=eth0 SRC=192.168.0.51 DST=127.0.0.1 LEN=140 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=1009 DPT=111 LEN=120
Dec 23 18:05:17 bureau kernel: [ 115.828257] rpcbind: RPC call returned error 1
Dec 23 18:05:17 bureau kernel: [ 115.828263] svc: failed to register lockdv1 RPC service (errno 1).
Dec 23 18:05:17 bureau kernel: [ 115.828266] lockd_up: makesock failed, error=-1
Dec 23 18:05:17 bureau kernel: [ 115.828289] IN= OUT=eth0 SRC=192.168.0.51 DST=127.0.0.1 LEN=120 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=771 DPT=111 LEN=100
Dec 23 18:05:17 bureau kernel: [ 115.828296] rpcbind: RPC call returned error 1
Dec 23 18:05:17 bureau kernel: [ 115.828323] IN= OUT=eth0 SRC=192.168.0.51 DST=127.0.0.1 LEN=120 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=966 DPT=111 LEN=100
Dec 23 18:05:17 bureau kernel: [ 115.828330] rpcbind: RPC call returned error 1
Dec 23 18:05:17 bureau kernel: [ 115.828355] IN= OUT=eth0 SRC=192.168.0.51 DST=127.0.0.1 LEN=120 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=674 DPT=111 LEN=100
Dec 23 18:05:17 bureau kernel: [ 115.828363] rpcbind: RPC call returned error 1
Dec 23 18:06:16 bureau kernel: [ 174.337167] IN= OUT=eth0 SRC=192.168.0.51 DST=192.168.0.255 LEN=242 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=138 DPT=138 LEN=222
Dec 23 18:06:16 bureau kernel: [ 174.337250] IN= OUT=eth0 SRC=192.168.0.51 DST=192.168.0.255 LEN=235 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=138 DPT=138 LEN=215
Dec 23 18:09:16 bureau kernel: [ 354.480117] IN= OUT=eth0 SRC=192.168.0.51 DST=192.168.0.255 LEN=242 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=138 DPT=138 LEN=222
Dec 23 18:09:16 bureau kernel: [ 354.480194] IN= OUT=eth0 SRC=192.168.0.51 DST=192.168.0.255 LEN=235 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=138 DPT=138 LEN=215
Dec 23 18:13:16 bureau kernel: [ 594.656127] IN= OUT=eth0 SRC=192.168.0.51 DST=192.168.0.255 LEN=242 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=138 DPT=138 LEN=222
Dec 23 18:13:16 bureau kernel: [ 594.656209] IN= OUT=eth0 SRC=192.168.0.51 DST=192.168.0.255 LEN=235 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=138 DPT=138 LEN=215
sachant que j’ai aussi au démarrage (mais je ne sais où les retrouver) des erreurs sur NFS
@ricardo : j’ai reéssayé, mais çà coince ici :
[quote]Sauvegardez le pare-feu une première fois (simulation d’un signal d’arrêt) avec :
/etc/init.d/mon_parefeu stop
Activez ‘mon_parefeu’ avec :
update-rc.d mon_parefeu start XX S . stop YY 0 6 .
(Respectez bien les espacements et les points)[/quote]
j’obtiens :
/etc/init.d # update-rc.d mon_parefeu start 13 S . stop 08 0 6 .
update-rc.d: using dependency based boot sequencing
update-rc.d: warning: mon_parefeu start runlevel arguments (S) do not match LSB Default-Start values (2 3 4 5)
update-rc.d: warning: mon_parefeu stop runlevel arguments (0 6) do not match LSB Default-Stop values (0 1 6)
par contre j’ai pu ouvrir les ports pour ma xbox :
[quote] iptables -A INPUT -p tcp -m tcp --dport 2869 -j ACCEPT;
iptables -A INPUT -p tcp -m tcp --dport 10243 -j ACCEPT;
iptables -A INPUT -p udp -m udp --dport 1900 -j ACCEPT;
iptables -A INPUT -p udp -m udp --dport 10284 -j ACCEPT;
iptables -A INPUT -p udp -m udp --dport 10283 -j ACCEPT;
iptables -A INPUT -p udp -m udp --dport 10282 -j ACCEPT;
iptables -A INPUT -p udp -m udp --dport 10281 -j ACCEPT;
iptables -A INPUT -p udp -m udp --dport 10280 -j ACCEPT;
iptables -A OUTPUT -p tcp -m tcp --dport 2869 -j ACCEPT;
iptables -A OUTPUT -p tcp -m tcp --dport 10243 -j ACCEPT;
iptables -A OUTPUT -p udp -m udp --dport 1900 -j ACCEPT;
iptables -A OUTPUT -p udp -m udp --dport 10284 -j ACCEPT;
iptables -A OUTPUT -p udp -m udp --dport 10283 -j ACCEPT;
iptables -A OUTPUT -p udp -m udp --dport 10282 -j ACCEPT;
iptables -A OUTPUT -p udp -m udp --dport 10281 -j ACCEPT;
iptables -A OUTPUT -p udp -m udp --dport 10280 -j ACCEPT;
et au moins je n’ai pas eu de rejet.
(désolé de paraitre pour un boulet, mais je découvre toujours linux, et je manque de temps (je suis étonné que debian ne propose pas dès l’installation un firewall “pret à l’emploi”, où l’utilisateur lambda s’en sortirai)).
