Nouvelle tentative de démarrage cette fois sous Buster donc. Mêmes symptômes le clignotement en moins. Voici le log correspondant :
[ 112.057]
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
[ 112.057] Build Operating System: Linux 4.9.0-8-amd64 x86_64 Debian
[ 112.057] Current Operating System: Linux pc-debian 4.19.0-5-amd64 #1 SMP Debian 4.19.37-5+deb10u2 (2019-08-08) x86_64
[ 112.057] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-5-amd64 root=UUID=43423358-6c1c-4043-9d18-bb392bf62cde ro single
[ 112.057] Build Date: 05 March 2019 08:11:12PM
[ 112.057] xorg-server 2:1.20.4-1 (https://www.debian.org/support)
[ 112.057] Current version of pixman: 0.36.0
[ 112.057] Before reporting problems, check http://wiki.x.org
[ 112.057] Markers: (--) probed, (**) from config file, (==) default setting,
[ 112.057] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Aug 30 15:35:18 2019
[ 112.057] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 112.057] (==) No Layout section. Using the first Screen section.
[ 112.057] (==) No screen section available. Using defaults.
[ 112.057] (**) |-->Screen "Default Screen Section" (0)
[ 112.057] (**) | |-->Monitor "<default monitor>"
[ 112.057] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 112.058] (==) Automatically adding devices
[ 112.058] (==) Automatically enabling devices
[ 112.058] (==) Automatically adding GPU devices
[ 112.058] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 112.058] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 112.058] Entry deleted from font path.
[ 112.058] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 112.058] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 112.058] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 112.058] (II) Loader magic: 0x55deb8cb7e20
[ 112.058] (II) Module ABI versions:
[ 112.058] X.Org ANSI C Emulation: 0.4
[ 112.058] X.Org Video Driver: 24.0
[ 112.058] X.Org XInput driver : 24.1
[ 112.058] X.Org Server Extension : 10.0
[ 112.058] (++) using VT number 7
[ 112.058] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 112.059] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 112.062] (--) PCI:*(1@0:0:0) 10de:1f82:1043:86b9 rev 161, Mem @ 0xf9000000/16777216, 0xd0000000/268435456, 0xee000000/33554432, I/O @ 0x0000bf00/128, BIOS @ 0x????????/131072
[ 112.062] (II) LoadModule: "glx"
[ 112.062] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 112.063] (II) Module glx: vendor="X.Org Foundation"
[ 112.063] compiled for 1.20.4, module version = 1.0.0
[ 112.063] ABI class: X.Org Server Extension, version 10.0
[ 112.063] (II) Applying OutputClass "nvidia" to /dev/dri/card0
[ 112.063] loading driver: nvidia
[ 112.313] (==) Matched nvidia as autoconfigured driver 0
[ 112.313] (==) Matched nouveau as autoconfigured driver 1
[ 112.313] (==) Matched nv as autoconfigured driver 2
[ 112.313] (==) Matched modesetting as autoconfigured driver 3
[ 112.313] (==) Matched fbdev as autoconfigured driver 4
[ 112.313] (==) Matched vesa as autoconfigured driver 5
[ 112.313] (==) Assigned the driver to the xf86ConfigLayout
[ 112.313] (II) LoadModule: "nvidia"
[ 112.313] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 112.313] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 112.313] compiled for 4.0.2, module version = 1.0.0
[ 112.313] Module class: X.Org Video Driver
[ 112.314] (II) LoadModule: "nouveau"
[ 112.314] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 112.314] (II) Module nouveau: vendor="X.Org Foundation"
[ 112.314] compiled for 1.20.3, module version = 1.0.16
[ 112.314] Module class: X.Org Video Driver
[ 112.314] ABI class: X.Org Video Driver, version 24.0
[ 112.314] (II) LoadModule: "nv"
[ 112.314] (WW) Warning, couldn't open module nv
[ 112.314] (EE) Failed to load module "nv" (module does not exist, 0)
[ 112.314] (II) LoadModule: "modesetting"
[ 112.315] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 112.315] (II) Module modesetting: vendor="X.Org Foundation"
[ 112.315] compiled for 1.20.4, module version = 1.20.4
[ 112.315] Module class: X.Org Video Driver
[ 112.315] ABI class: X.Org Video Driver, version 24.0
[ 112.315] (II) LoadModule: "fbdev"
[ 112.315] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 112.315] (II) Module fbdev: vendor="X.Org Foundation"
[ 112.315] compiled for 1.20.0, module version = 0.5.0
[ 112.315] (II) LoadModule: "vesa"
[ 112.315] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 112.315] (II) Module vesa: vendor="X.Org Foundation"
[ 112.315] compiled for 1.20.1, module version = 2.4.0
[ 112.316] (II) NVIDIA dlloader X Driver 418.74 Wed May 1 11:26:02 CDT 2019
[ 112.316] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 112.316] (II) NOUVEAU driver Date: Mon Jan 28 23:25:58 2019 -0500
[ 112.316] (II) NOUVEAU driver for NVIDIA chipset families :
[ 112.316] RIVA TNT (NV04)
[ 112.316] RIVA TNT2 (NV05)
[ 112.316] GeForce 256 (NV10)
[ 112.316] GeForce 2 (NV11, NV15)
[ 112.316] GeForce 4MX (NV17, NV18)
[ 112.316] GeForce 3 (NV20)
[ 112.316] GeForce 4Ti (NV25, NV28)
[ 112.316] GeForce FX (NV3x)
[ 112.316] GeForce 6 (NV4x)
[ 112.316] GeForce 7 (G7x)
[ 112.316] GeForce 8 (G8x)
[ 112.316] GeForce 9 (G9x)
[ 112.316] GeForce GTX 2xx/3xx (GT2xx)
[ 112.316] GeForce GTX 4xx/5xx (GFxxx)
[ 112.316] GeForce GTX 6xx/7xx (GKxxx)
[ 112.316] GeForce GTX 9xx (GMxxx)
[ 112.316] GeForce GTX 10xx (GPxxx)
[ 112.316] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 112.316] (II) FBDEV: driver for framebuffer: fbdev
[ 112.316] (II) VESA: driver for VESA chipsets: vesa
[ 112.317] (II) Loading sub module "fb"
[ 112.317] (II) LoadModule: "fb"
[ 112.317] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 112.318] (II) Module fb: vendor="X.Org Foundation"
[ 112.318] compiled for 1.20.4, module version = 1.0.0
[ 112.318] ABI class: X.Org ANSI C Emulation, version 0.4
[ 112.318] (II) Loading sub module "wfb"
[ 112.318] (II) LoadModule: "wfb"
[ 112.318] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 112.318] (II) Module wfb: vendor="X.Org Foundation"
[ 112.318] (II) Loading sub module "ramdac"
[ 112.318] (II) LoadModule: "ramdac"
[ 112.318] (II) Module "ramdac" already built-in
[ 112.319] (WW) Falling back to old probe method for modesetting
[ 112.319] (WW) Falling back to old probe method for fbdev
[ 112.319] (II) Loading sub module "fbdevhw"
[ 112.319] (II) LoadModule: "fbdevhw"
[ 112.319] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 112.319] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 112.319] compiled for 1.20.4, module version = 0.0.2
[ 112.319] ABI class: X.Org Video Driver, version 24.0
[ 112.319] (EE) open /dev/fb0: No such file or directory
[ 112.319] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 112.320] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 112.320] (==) NVIDIA(0): RGB weight 888
[ 112.320] (==) NVIDIA(0): Default visual is TrueColor
[ 112.320] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 112.320] (**) NVIDIA(0): Enabling 2D acceleration
[ 112.320] (II) Loading sub module "glxserver_nvidia"
[ 112.320] (II) LoadModule: "glxserver_nvidia"
[ 112.320] (II) Loading /usr/lib/xorg/modules/extensions/libglxserver_nvidia.so
[ 112.325] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 112.325] compiled for 4.0.2, module version = 1.0.0
[ 112.325] Module class: X.Org Server Extension
[ 112.325] (II) NVIDIA GLX Module 418.74 Wed May 1 11:24:49 CDT 2019
[ 116.326] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA GPU at PCI:1:0:0. Please
[ 116.326] (EE) NVIDIA(GPU-0): check your system's kernel log for additional error
[ 116.326] (EE) NVIDIA(GPU-0): messages and refer to Chapter 8: Common Problems in the
[ 116.326] (EE) NVIDIA(GPU-0): README for additional information.
[ 116.326] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA graphics device!
[ 116.326] (EE) NVIDIA(0): Failing initialization of X screen 0
[ 116.326] (II) UnloadModule: "nvidia"
[ 116.326] (II) UnloadSubModule: "glxserver_nvidia"
[ 116.326] (II) Unloading glxserver_nvidia
[ 116.326] (II) UnloadSubModule: "wfb"
[ 116.326] (II) UnloadSubModule: "fb"
[ 116.326] (EE) Screen(s) found, but none have a usable configuration.
[ 116.326] (EE)
Fatal server error:
[ 116.326] (EE) no screens found(EE)
[ 116.326] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 116.326] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 116.326] (EE)
[ 116.326] (EE) Server terminated with error (1). Closing log file.
Une tentative avec nouveau. J’arrive à me connecter en graphique, et à ouvrir Blender 2.80 (motivation d’achat de la carte), mais les mouvements dans Blender sont saccadés. Apparemment le module nv ne se charge pas, et je ne sais pas quel pilote a pris le relais. Le log :
[ 21.243]
[ 21.243] Build Operating System: Linux 4.9.0-8-amd64 x86_64 Debian
[ 21.243] Current Operating System: Linux pc-debian 4.19.0-5-amd64 #1 SMP Debian 4.19.37-5+deb10u2 (2019-08-08) x86_64
[ 21.243] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.19.0-5-amd64 root=UUID=43423358-6c1c-4043-9d18-bb392bf62cde ro quiet
[ 21.243] Build Date: 05 March 2019 08:11:12PM
[ 21.243] xorg-server 2:1.20.4-1 (https://www.debian.org/support)
[ 21.243] Current version of pixman: 0.36.0
[ 21.243] Before reporting problems, check http://wiki.x.org
[ 21.243] Markers: (--) probed, (**) from config file, (==) default setting,
[ 21.243] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Aug 30 15:53:25 2019
[ 21.429] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 21.662] (==) No Layout section. Using the first Screen section.
[ 21.662] (==) No screen section available. Using defaults.
[ 21.662] (**) |-->Screen "Default Screen Section" (0)
[ 21.662] (**) | |-->Monitor "<default monitor>"
[ 21.681] (==) No monitor specified for screen "Default Screen Section".
[ 21.681] (==) Automatically adding devices
[ 21.681] (==) Automatically enabling devices
[ 21.681] (==) Automatically adding GPU devices
[ 21.681] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 21.751] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 21.751] Entry deleted from font path.
[ 21.805] (==) FontPath set to:
built-ins
[ 21.805] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 21.805] (II) The server relies on udev to provide the list of input devices.
[ 21.805] (II) Loader magic: 0x55a7b5c01e20
[ 21.805] (II) Module ABI versions:
[ 21.805] X.Org ANSI C Emulation: 0.4
[ 21.805] X.Org Video Driver: 24.0
[ 21.805] X.Org XInput driver : 24.1
[ 21.805] X.Org Server Extension : 10.0
[ 21.805] (++) using VT number 7
[ 21.805] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 21.810] (--) PCI:*(1@0:0:0) 10de:1f82:1043:86b9 rev 161, Mem @ 0xf9000000/16777216, 0xd0000000/268435456, 0xee000000/33554432, I/O @ 0x0000bf00/128, BIOS @ 0x????????/131072
[ 21.810] (II) LoadModule: "glx"
[ 21.847] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 22.012] (II) Module glx: vendor="X.Org Foundation"
[ 22.012] compiled for 1.20.4, module version = 1.0.0
[ 22.012] ABI class: X.Org Server Extension, version 10.0
[ 22.142] (==) Matched nouveau as autoconfigured driver 0
[ 22.142] (==) Matched nv as autoconfigured driver 1
[ 22.142] (==) Matched modesetting as autoconfigured driver 2
[ 22.142] (==) Matched fbdev as autoconfigured driver 3
[ 22.142] (==) Matched vesa as autoconfigured driver 4
[ 22.142] (==) Assigned the driver to the xf86ConfigLayout
[ 22.142] (II) LoadModule: "nouveau"
[ 22.296] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 22.372] (II) Module nouveau: vendor="X.Org Foundation"
[ 22.372] compiled for 1.20.3, module version = 1.0.16
[ 22.372] Module class: X.Org Video Driver
[ 22.372] ABI class: X.Org Video Driver, version 24.0
[ 22.372] (II) LoadModule: "nv"
[ 22.372] (WW) Warning, couldn't open module nv
[ 22.372] (EE) Failed to load module "nv" (module does not exist, 0)
[ 22.372] (II) LoadModule: "modesetting"
[ 22.372] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 22.396] (II) Module modesetting: vendor="X.Org Foundation"
[ 22.396] compiled for 1.20.4, module version = 1.20.4
[ 22.396] Module class: X.Org Video Driver
[ 22.396] ABI class: X.Org Video Driver, version 24.0
[ 22.396] (II) LoadModule: "fbdev"
[ 22.397] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 22.411] (II) Module fbdev: vendor="X.Org Foundation"
[ 22.411] compiled for 1.20.0, module version = 0.5.0
[ 22.411] Module class: X.Org Video Driver
[ 22.411] ABI class: X.Org Video Driver, version 24.0
[ 22.411] (II) LoadModule: "vesa"
[ 22.411] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 22.429] (II) Module vesa: vendor="X.Org Foundation"
[ 22.429] compiled for 1.20.1, module version = 2.4.0
[ 22.429] Module class: X.Org Video Driver
[ 22.429] ABI class: X.Org Video Driver, version 24.0
[ 22.429] (II) NOUVEAU driver Date: Mon Jan 28 23:25:58 2019 -0500
[ 22.429] (II) NOUVEAU driver for NVIDIA chipset families :
[ 22.429] RIVA TNT (NV04)
[ 22.429] RIVA TNT2 (NV05)
[ 22.430] GeForce 256 (NV10)
[ 22.430] GeForce 2 (NV11, NV15)
[ 22.430] GeForce 4MX (NV17, NV18)
[ 22.430] GeForce 3 (NV20)
[ 22.430] GeForce 4Ti (NV25, NV28)
[ 22.430] GeForce FX (NV3x)
[ 22.430] GeForce 6 (NV4x)
[ 22.430] GeForce 7 (G7x)
[ 22.430] GeForce 8 (G8x)
[ 22.430] GeForce 9 (G9x)
[ 22.430] GeForce GTX 2xx/3xx (GT2xx)
[ 22.430] GeForce GTX 4xx/5xx (GFxxx)
[ 22.430] GeForce GTX 6xx/7xx (GKxxx)
[ 22.430] GeForce GTX 9xx (GMxxx)
[ 22.430] GeForce GTX 10xx (GPxxx)
[ 22.430] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 22.430] (II) FBDEV: driver for framebuffer: fbdev
[ 22.430] (II) VESA: driver for VESA chipsets: vesa
[ 22.566] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
[ 22.566] (EE) open /dev/dri/card0: No such file or directory
[ 22.566] (WW) Falling back to old probe method for modesetting
[ 22.567] (EE) open /dev/dri/card0: No such file or directory
[ 22.567] (II) Loading sub module "fbdevhw"
[ 22.567] (II) LoadModule: "fbdevhw"
[ 22.567] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 22.580] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 22.580] compiled for 1.20.4, module version = 0.0.2
[ 22.580] ABI class: X.Org Video Driver, version 24.0
[ 22.581] (EE) Unable to find a valid framebuffer device
[ 22.581] (WW) Falling back to old probe method for fbdev
[ 22.581] (II) Loading sub module "fbdevhw"
[ 22.581] (II) LoadModule: "fbdevhw"
[ 22.581] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 22.581] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 22.581] compiled for 1.20.4, module version = 0.0.2
[ 22.581] ABI class: X.Org Video Driver, version 24.0
[ 22.581] (EE) open /dev/fb0: No such file or directory
[ 22.581] (EE) Screen 0 deleted because of no matching config section.
[ 22.581] (II) UnloadModule: "modesetting"
[ 22.581] (II) UnloadModule: "fbdev"
[ 22.581] (II) UnloadSubModule: "fbdevhw"
[ 22.581] (II) Loading sub module "vbe"
[ 22.581] (II) LoadModule: "vbe"
[ 22.581] (II) Loading /usr/lib/xorg/modules/libvbe.so
[ 22.582] (II) Module vbe: vendor="X.Org Foundation"
[ 22.582] compiled for 1.20.4, module version = 1.1.0
[ 22.582] ABI class: X.Org Video Driver, version 24.0
[ 22.582] (II) Loading sub module "int10"
[ 22.582] (II) LoadModule: "int10"
[ 22.582] (II) Loading /usr/lib/xorg/modules/libint10.so
[ 22.597] (II) Module int10: vendor="X.Org Foundation"
[ 22.597] compiled for 1.20.4, module version = 1.0.0
[ 22.597] ABI class: X.Org Video Driver, version 24.0
[ 22.597] (II) VESA(0): initializing int10
[ 22.598] (II) VESA(0): Primary V_BIOS segment is: 0xc000
[ 22.637] (II) VESA(0): VESA BIOS detected
[ 22.637] (II) VESA(0): VESA VBE Version 3.0
[ 22.637] (II) VESA(0): VESA VBE Total Mem: 16384 kB
[ 22.637] (II) VESA(0): VESA VBE OEM: NVIDIA
[ 22.637] (II) VESA(0): VESA VBE OEM Software Rev: 144.23
[ 22.637] (II) VESA(0): VESA VBE OEM Vendor: NVIDIA Corporation
[ 22.637] (II) VESA(0): VESA VBE OEM Product: GPU Board
[ 22.637] (II) VESA(0): VESA VBE OEM Product Rev: Chip Rev
[ 22.712] (II) VESA(0): Creating default Display subsection in Screen section
[ 22.712] (==) VESA(0): Depth 24, (--) framebuffer bpp 32
[ 22.712] (==) VESA(0): RGB weight 888
[ 22.712] (==) VESA(0): Default visual is TrueColor
[ 22.712] (==) VESA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 22.712] (II) Loading sub module "ddc"
[ 22.712] (II) LoadModule: "ddc"
[ 22.712] (II) Module "ddc" already built-in
[ 22.713] (II) VESA(0): VESA VBE DDC supported
[ 22.713] (II) VESA(0): VESA VBE DDC Level 2
[ 22.713] (II) VESA(0): VESA VBE DDC transfer in appr. 1 sec.
[ 22.741] (II) VESA(0): VESA VBE DDC read successfully
[ 22.741] (II) VESA(0): Manufacturer: IVM Model: 5608 Serial#: 50152
[ 22.741] (II) VESA(0): Year: 2009 Week: 27
[ 22.741] (II) VESA(0): EDID Version: 1.3
[ 22.741] (II) VESA(0): Digital Display Input
[ 22.741] (II) VESA(0): DFP 1.x compatible TMDS
[ 22.741] (II) VESA(0): Max Image Size [cm]: horiz.: 55 vert.: 34
[ 22.741] (II) VESA(0): Gamma: 2.20
[ 22.741] (II) VESA(0): DPMS capabilities: Off
[ 22.741] (II) VESA(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 22.741] (II) VESA(0): First detailed timing is preferred mode
[ 22.741] (II) VESA(0): redX: 0.646 redY: 0.335 greenX: 0.283 greenY: 0.601
[ 22.741] (II) VESA(0): blueX: 0.149 blueY: 0.072 whiteX: 0.313 whiteY: 0.329
[ 22.741] (II) VESA(0): Supported established timings:
[ 22.741] (II) VESA(0): 720x400@70Hz
[ 22.741] (II) VESA(0): 640x480@60Hz
[ 22.741] (II) VESA(0): 640x480@67Hz
[ 22.741] (II) VESA(0): 640x480@72Hz
[ 22.741] (II) VESA(0): 640x480@75Hz
[ 22.741] (II) VESA(0): 800x600@60Hz
[ 22.741] (II) VESA(0): 800x600@72Hz
[ 22.741] (II) VESA(0): 800x600@75Hz
[ 22.741] (II) VESA(0): 832x624@75Hz
[ 22.741] (II) VESA(0): 1024x768@60Hz
[ 22.741] (II) VESA(0): 1024x768@70Hz
[ 22.741] (II) VESA(0): 1024x768@75Hz
[ 22.741] (II) VESA(0): 1280x1024@75Hz
[ 22.741] (II) VESA(0): 1152x864@75Hz
[ 22.741] (II) VESA(0): Manufacturer's mask: 0
[ 22.741] (II) VESA(0): Supported standard timings:
[ 22.741] (II) VESA(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 22.741] (II) VESA(0): #1: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 22.741] (II) VESA(0): #2: hsize: 1280 vsize 1024 refresh: 75 vid: 36737
[ 22.741] (II) VESA(0): #3: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 22.741] (II) VESA(0): #4: hsize: 1440 vsize 900 refresh: 75 vid: 3989
[ 22.741] (II) VESA(0): #5: hsize: 1600 vsize 1200 refresh: 60 vid: 16553
[ 22.741] (II) VESA(0): #6: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 22.741] (II) VESA(0): Supported detailed timing:
[ 22.741] (II) VESA(0): clock: 154.0 MHz Image Size: 550 x 344 mm
[ 22.741] (II) VESA(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2080 h_border: 0
[ 22.741] (II) VESA(0): v_active: 1200 v_sync: 1203 v_sync_end 1209 v_blanking: 1235 v_border: 0
[ 22.741] (II) VESA(0): clock: 138.5 MHz Image Size: 550 x 344 mm
[ 22.741] (II) VESA(0): h_active: 1920 h_sync: 2000 h_sync_end 2032 h_blank_end 2080 h_border: 0
[ 22.741] (II) VESA(0): v_active: 1080 v_sync: 1104 v_sync_end 1109 v_blanking: 1111 v_border: 0
[ 22.741] (II) VESA(0): Ranges: V min: 55 V max: 76 Hz, H min: 29 H max: 81 kHz, PixClock max 175 MHz
[ 22.741] (II) VESA(0): Monitor name: PLE2607WS
[ 22.741] (II) VESA(0): EDID (in hex):
[ 22.741] (II) VESA(0): 00ffffffffffff0026cd0856e8c30000
[ 22.741] (II) VESA(0): 1b130103813722782a7b65a555489926
[ 22.741] (II) VESA(0): 125054bdef80714f8180818f9500950f
[ 22.741] (II) VESA(0): a940b3000101283c80a070b023403020
[ 22.741] (II) VESA(0): 360026582100001a1a3680a070381f40
[ 22.741] (II) VESA(0): 5020850426582100001a000000fd0037
[ 22.741] (II) VESA(0): 4c1d5111000a202020202020000000fc
[ 22.741] (II) VESA(0): 00504c453236303757530a20202000f9
[ 22.741] (II) VESA(0): EDID vendor "IVM", prod id 22024
[ 22.741] (II) VESA(0): Using EDID range info for horizontal sync
[ 22.741] (II) VESA(0): Using EDID range info for vertical refresh
[ 22.741] (II) VESA(0): Printing DDC gathered Modelines:
[ 22.741] (II) VESA(0): Modeline "1920x1200"x0.0 154.00 1920 1968 2000 2080 1200 1203 1209 1235 +hsync -vsync (74.0 kHz eP)
[ 22.741] (II) VESA(0): Modeline "1920x1080"x0.0 138.50 1920 2000 2032 2080 1080 1104 1109 1111 +hsync -vsync (66.6 kHz e)
[ 22.741] (II) VESA(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 22.741] (II) VESA(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 22.741] (II) VESA(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 22.741] (II) VESA(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 22.741] (II) VESA(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 22.741] (II) VESA(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 22.741] (II) VESA(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 22.741] (II) VESA(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 22.741] (II) VESA(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 22.741] (II) VESA(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 22.741] (II) VESA(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 22.741] (II) VESA(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 22.741] (II) VESA(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 22.741] (II) VESA(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 22.741] (II) VESA(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 22.741] (II) VESA(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 22.741] (II) VESA(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 22.741] (II) VESA(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 22.741] (II) VESA(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 22.741] (II) VESA(0): Searching for matching VESA mode(s):
Du coup je lâche l’affaire et je renvois la carte : je n’ai déjà consacré que trop de temps à cette histoire. Je n’aurais pas tout perdu puisque j’ai appris quelques commandes et puisque j’ai maintenant un Buster tout neuf.
Je te remercie sincèrement @mattotop pour tout le temps que tu m’as consacré
