Bon, je suis reparti de zéro avec toutes les infos que tu m’as donné.
J’ai repris la conf de squid 3.0 et de squidguard.
J’arrive enfin à avoir quelquechose de très correct, en ligne de commande :
echo "http://www.google.fr/ 192.168.0.6/- - GET" | /usr/sbin/squidGuard -c /etc/squidguard.conf -d
2009-03-06 15:17:48 [18640] New setting: dbhome: /var/lib/squidGuard/db
2009-03-06 15:17:48 [18640] New setting: logdir: /var/log/squidGuard
2009-03-06 15:17:48 [18640] Added User: root
2009-03-06 15:17:48 [18640] Added User: foo
2009-03-06 15:17:48 [18640] Added User: bar
2009-03-06 15:17:48 [18640] destblock good missing active content, set inactive
2009-03-06 15:17:48 [18640] destblock local missing active content, set inactive
2009-03-06 15:17:48 [18640] init domainlist /var/lib/squidGuard/db/dest/adult/domains
2009-03-06 15:17:48 [18640] loading dbfile /var/lib/squidGuard/db/dest/adult/domains.db
2009-03-06 15:17:48 [18640] init urllist /var/lib/squidGuard/db/dest/adult/urls
2009-03-06 15:17:48 [18640] loading dbfile /var/lib/squidGuard/db/dest/adult/urls.db
2009-03-06 15:17:48 [18640] init expressionlist /var/lib/squidGuard/db/dest/adult/expressions
2009-03-06 15:17:48 [18640] squidGuard 1.3 started (1236349068.797)
2009-03-06 15:17:48 [18640] Info: recalculating alarm in 4332 seconds
2009-03-06 15:17:48 [18640] squidGuard ready for requests (1236349068.801)
- Pour un site de la db adult :
echo "http://www.porno.net/ 192.168.0.6/- - GET" | /usr/sbin/squidGuard -c /etc/squidguard.conf -d
2009-03-06 15:18:19 [18642] New setting: dbhome: /var/lib/squidGuard/db
2009-03-06 15:18:19 [18642] New setting: logdir: /var/log/squidGuard
2009-03-06 15:18:19 [18642] Added User: root
2009-03-06 15:18:19 [18642] Added User: foo
2009-03-06 15:18:19 [18642] Added User: bar
2009-03-06 15:18:19 [18642] destblock good missing active content, set inactive
2009-03-06 15:18:19 [18642] destblock local missing active content, set inactive
2009-03-06 15:18:19 [18642] init domainlist /var/lib/squidGuard/db/dest/adult/domains
2009-03-06 15:18:19 [18642] loading dbfile /var/lib/squidGuard/db/dest/adult/domains.db
2009-03-06 15:18:19 [18642] init urllist /var/lib/squidGuard/db/dest/adult/urls
2009-03-06 15:18:19 [18642] loading dbfile /var/lib/squidGuard/db/dest/adult/urls.db
2009-03-06 15:18:19 [18642] init expressionlist /var/lib/squidGuard/db/dest/adult/expressions
2009-03-06 15:18:19 [18642] squidGuard 1.3 started (1236349099.501)
2009-03-06 15:18:19 [18642] Info: recalculating alarm in 4301 seconds
2009-03-06 15:18:19 [18642] squidGuard ready for requests (1236349099.505)
http://admin.foo.bar.de/cgi/blocked?clientaddr=192.168.0.6+clientname=+clientuser=+clientgroup=foo-clients+targetgroup=adult+url=http://www.porno.net/ 192.168.0.6/- - GET
2009-03-06 15:18:19 [18642] squidGuard stopped (1236349099.505)
Je dois encore peaufiner la redirection mais en ligne de commande, ça marche…
PAR CONTRE, et là c’est désormais un peu embêtant, le proxy refuse toute connexion extérieure “Cache administrator does not allow this cache to make direct connections to origin servers, and all configured parent caches are currently unreachable”.
C’est un peu étrange, car à la connexion de l’utilisateur (l’utilisateur de test), aucun souci de surf… Jusqu’à ce que celui-ci tape une adresse interdite… A partir de là, aucun moyen d’afficher de nouvelles pages… A moins de vider le cache…
Je ne pense pas que ce soit bien grave, déjà une marche semble être passée (le Guard !), il y en a certainement plein d’autres avant d’avoir un proxy plus-que-parfait !
Si tu as une idée, n’hésites pas, et sinon encore merci pour votre aide à tous !
Bon week end,
