Bonsoir à tous,
Je me permet de vous contacter car j’ai mon portable de fonction sous Debian 10, et par moments je n’arrive plus à le sortir de veille, et en allant dans les logs on peut voir qu’à la mise en veille il a fait un kernel panik:
Oct 27 15:42:11 hanuman kernel: [174940.407763] Call Trace:
Oct 27 15:42:11 hanuman kernel: [174940.407789] __schedule+0x2e3/0x740
Oct 27 15:42:11 hanuman kernel: [174940.407802] ? psi_task_change+0xe8/0x320
Oct 27 15:42:11 hanuman kernel: [174940.407813] schedule+0x42/0xb0
Oct 27 15:42:11 hanuman kernel: [174940.407824] io_schedule+0x16/0x40
Oct 27 15:42:11 hanuman kernel: [174940.407838] __lock_page_killable+0x13c/0x270
Oct 27 15:42:11 hanuman kernel: [174940.407850] ? file_fdatawait_range+0x30/0x30
Oct 27 15:42:11 hanuman kernel: [174940.407862] filemap_fault+0x6f2/0xa50
Oct 27 15:42:11 hanuman kernel: [174940.407872] ? alloc_set_pte+0x36c/0x610
Oct 27 15:42:11 hanuman kernel: [174940.407884] ? filemap_map_pages+0x24c/0x380
Oct 27 15:42:11 hanuman kernel: [174940.407893] __do_fault+0x3c/0x130
Oct 27 15:42:11 hanuman kernel: [174940.407901] do_fault+0x24b/0x640
Oct 27 15:42:11 hanuman kernel: [174940.407911] __handle_mm_fault+0x4c5/0x7a0
Oct 27 15:42:11 hanuman kernel: [174940.407923] handle_mm_fault+0xca/0x200
Oct 27 15:42:11 hanuman kernel: [174940.407934] do_user_addr_fault+0x1f9/0x450
Oct 27 15:42:11 hanuman kernel: [174940.407945] __do_page_fault+0x58/0x90
Oct 27 15:42:11 hanuman kernel: [174940.407954] do_page_fault+0x2c/0xe0
Oct 27 15:42:11 hanuman kernel: [174940.407963] page_fault+0x34/0x40
Oct 27 15:42:11 hanuman kernel: [174940.407971] RIP: 0033:0x563a4840abb0
Oct 27 15:42:11 hanuman kernel: [174940.407992] Code: Bad RIP value.
Oct 27 15:42:11 hanuman kernel: [174940.407998] RSP: 002b:00007fffb488be18 EFLAGS: 00010206
Oct 27 15:42:11 hanuman kernel: [174940.408005] RAX: 0000143711ee1b48 RBX: 00007fffb488be60 RCX: 0000000000000008
Oct 27 15:42:11 hanuman kernel: [174940.408009] RDX: 0000000000000030 RSI: 000022bf9f663de8 RDI: 0000143711ee1b48
Oct 27 15:42:11 hanuman kernel: [174940.408013] RBP: 00007fffb488be50 R08: 0000002e00412170 R09: 0000000000000004
Oct 27 15:42:11 hanuman kernel: [174940.408017] R10: 0000000000004000 R11: 00000000df1e42fb R12: 000031e76dfc1a78
Oct 27 15:42:11 hanuman kernel: [174940.408021] R13: 000031e76e0f2580 R14: 000022bf9f663de8 R15: 00002e3f6d5f4060
Oct 27 15:42:11 hanuman kernel: [174940.408324] OOM killer enabled.
Oct 27 15:42:11 hanuman kernel: [174940.408327] Restarting tasks ... done.
Oct 27 15:42:11 hanuman kernel: [174940.450719] thermal thermal_zone7: failed to read out thermal zone (-61)
En naviguant sur des forums j’ai vu qu’on pouvait voir ce qu’était une thermal zone donc j’ai regardé le fichier /sys/class/thermal/thermal_zone7/type, et trouve ceci: x86_pkg_temp
Certains savent ils plus précisemment ce dont il s’agit? Et y’a t’il une possibilité de régler cela de façon logicielle ou ma CM a t’elle un soucis (SSD et RAM vérifiés et OK).
Je précise que ma batterie est très usée, cela peut il avoir un lien?
En vous remerciant par avance,
Bien cordialement.
