Avec un peu de retard, 5 mises à jour du 15 et une du 17 mars :
[quote]Package : firebird2.1
Vulnerability : buffer overflow
Problem type : remote
Debian-specific: no
CVE ID : CVE-2013-2492
Debian Bug : 702735
A buffer overflow was discovered in the Firebird database server, which
could result in the execution of arbitrary code.
For the stable distribution (squeeze), this problem has been fixed in
version 2.1.3.18185-0.ds1-11+squeeze1.
For the testing distribution (wheezy), firebird2.1 will be removed in
favour of firebird2.5.
For the unstable distribution (sid), firebird2.1 will be removed in
We recommend that you upgrade your firebird2.1 packages.[/quote]
[quote]Package : firebird2.5
Vulnerability : several
Debian-specific: no
CVE ID : CVE-2012-5529 CVE-2013-2492
could result in the execution of arbitrary code. In addition, a denial
of service vulnerability was discovered in the TraceManager.
For the stable distribution (squeeze), these problems have been fixed in
version 2.5.0.26054~ReleaseCandidate3.ds2-1+squeeze1.
For the testing distribution (wheezy), these problems will be fixed soon.
For the unstable distribution (sid), these problems will be fixed soon.
We recommend that you upgrade your firebird2.5 packages.[/quote]
[quote]Package : typo3-src
Debian-specific: no
CVE ID : CVE-2013-1842 CVE-2013-1843
Debian Bug : 702574
Typo3, a PHP-based content management system, was found vulnerable to several vulnerabilities.
CVE-2013-1842
Helmut Hummel and Markus Opahle discovered that the Extbase database layer
was not correctly sanitizing user input when using the Query object model.
This can lead to SQL injection by a malicious user inputing crafted
relation values.
CVE-2013-1843
Missing user input validation in the access tracking mechanism could lead
to arbitrary URL redirection.
Note: the fix will break already published links. Upstream advisory on
[typo3.org/teams/security/securit ... -2013-001/](http://typo3.org/teams/security/security-bulletins/typo3-core/typo3-core-sa-2013-001/)
has more information on how to mitigate that.
version 4.3.9+dfsg1-1+squeeze8.
For the testing distribution (wheezy), these problems have been fixed in
version 4.5.19+dfsg1-5.
For the unstable distribution (sid), these problems have been fixed in
We recommend that you upgrade your typo3-src packages.[/quote]
[quote]Package : lighttpd
Vulnerability : fixed socket name in world-writable directory
Problem type : local
Debian-specific: yes
CVE ID : CVE-2013-1427
Debian Bug :
Stefan Bühler discovered that the Debian specific configuration file for
lighttpd webserver FastCGI PHP support used a fixed socket name in the
world-writable /tmp directory. A symlink attack or a race condition could be
exploited by a malicious user on the same machine to take over the PHP control
socket and for example force the webserver to use a different PHP version.
As the fix is in a configuration file lying in /etc, the update won’t be
enforced if the file has been modified by the administrator. In that case, care
should be taken to manually apply the fix.
version 1.4.28-2+squeeze1.3.
For the testing distribution (wheezy), this problem has been fixed in
version 1.4.31-4.
For the unstable distribution (sid), this problem has been fixed in
version 1.4.31-4.
We recommend that you upgrade your lighttpd packages.[/quote]
[quote]Package : libvirt-bin
Vulnerability : files and device nodes ownership change to kvm group
CVE ID : CVE-2013-1766
Debian Bug : 701649
Bastian Blank discovered that libvirtd, a daemon for management of virtual
machines, network and storage, would change ownership of devices files so they
would be owned by user libvirt-qemu
and group kvm
, which is a general
purpose group not specific to libvirt, allowing unintended write access to
those devices and files for the kvm group members.
version 0.8.3-5+squeeze4.
version 0.9.12-11.
version 0.9.12-11.
We recommend that you upgrade your libvirt-bin packages.[/quote]
Debian Bug : 701649
The recent security update for libvirt was found to cause a regression.
The kvm/qemu processes weren’t run as the kvm
user anymore in order to
fix the file/device ownership changes, but the processes where not
correctly configured to use the kvm
group either. When the user would
try to run a virtual machine, the process was denied access to the
/dev/kvm device node, preventing the virtual machine to run.
version 0.8.3-5+squeeze5.
We recommend that you upgrade your libvirt packages.[/quote]
Usti
