oui
si je regarde le ifconfig de ma vm le serveur est monté
/etc/openvpn# ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
collisions:0 txqueuelen:0
tun0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:10.66.0.1 P-t-P:10.66.0.2 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:100
venet0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:127.0.0.2 P-t-P:127.0.0.2 Bcast:0.0.0.0 Mask:255.255.255.255
UP BROADCAST POINTOPOINT RUNNING NOARP MTU:1500 Metric:1
RX packets:2168 errors:0 dropped:0 overruns:0 frame:0
TX packets:1927 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:231844 (226.4 KiB) TX bytes:260748 (254.6 KiB)
venet0:0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
inet addr:172.16.0.101 P-t-P:172.16.0.101 Bcast:172.16.0.101 Mask:255.255.255.255
sur le serveur VPN
/etc/openvpn# ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 16436 qdisc noqueue state UNKNOWN
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
2: venet0: <BROADCAST,POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN
link/void
inet 127.0.0.2/32 scope host venet0
inet 172.16.0.101/32 brd 172.16.0.101 scope global venet0:0
4: tun0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UNKNOWN qlen 100
link/none
inet 10.66.0.1 peer 10.66.0.2/32 scope global tun0
/etc/openvpn# ip route
10.66.0.2 dev tun0 proto kernel scope link src 10.66.0.1
10.66.0.0/24 via 10.66.0.2 dev tun0
10.2.0.0/24 via 10.66.0.2 dev tun0
10.1.0.0/24 via 10.66.0.2 dev tun0
default dev venet0 scope link
sur le client qui est à l’autre bout du vpn
2: eth2: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP qlen 1000
link/ether fc:75:16:61:3c:9d brd ff:ff:ff:ff:ff:ff
inet 192.168.1.254/24 brd 192.168.1.255 scope global eth2
inet6 fe80::fe75:16ff:fe61:3c9d/64 scope link
3: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP qlen 1000
link/ether 00:10:18:2c:1e:00 brd ff:ff:ff:ff:ff:ff
inet 10.1.0.254/24 brd 10.1.0.255 scope global eth0
inet6 fe80::210:18ff:fe2c:1e00/64 scope link
4: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP qlen 1000
link/ether 00:13:72:37:d4:01 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.254/24 brd 192.168.0.255 scope global eth1
inet6 fe80::213:72ff:fe37:d401/64 scope link
5: venet0: <BROADCAST,POINTOPOINT,NOARP,UP,LOWER_UP> mtu 1500 qdisc noqueue state UNKNOWN
link/void
193.252.22.91 via 192.168.1.1 dev eth2
10.1.0.253 dev venet0 scope link
192.168.1.0/24 dev eth2 proto kernel scope link src 192.168.1.254
192.168.0.0/24 dev eth1 proto kernel scope link src 192.168.0.254
10.1.0.0/24 dev eth0 proto kernel scope link src 10.1.0.254
default via 192.168.0.1 dev eth1
