Plus de serveur x moi non plus
En principe, l’acceleration 3D ne fait pas planter le serveur, si celle-ci est justement désactivée. Je verrais bien ton /etc/X11/XF86Config-4, histoire de vérifier ta résolution…
XF86Config-4 (XFree86 X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the XF86Config-4 manual page.
(Type “man XF86Config-4” at the shell prompt.)
This file is automatically updated on xserver-xfree86 package upgrades only
if it has not been modified since the last upgrade of the xserver-xfree86
package.
If you have edited this file but would like it to be automatically updated
again, run the following commands as root:
cp /etc/X11/XF86Config-4 /etc/X11/XF86Config-4.custom
md5sum /etc/X11/XF86Config-4 >/var/lib/xfree86/XF86Config-4.md5sum
dpkg-reconfigure xserver-xfree86
Section "Files"
FontPath “unix/:7100” # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/Speedo"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option “XkbRules” "xfree86"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
Option “ZAxisMapping” "4 5"
EndSection
Section "Device"
Identifier "ATI Technologies, Inc. RV280 [Radeon 9200 SE]"
Driver "radeon"
BusID "PCI:1:0:0"
Screen 0
EndSection
Section "Device"
Identifier "ATIDriverTV"
Driver "radeon"
BusID "PCI:1:0:1"
Screen 1
EndSection
Section "Monitor"
Identifier "L1915S"
HorizSync 30-83
VertRefresh 56-75
Option "DPMS"
EndSection
Section "Monitor"
Identifier "TV"
HorizSync 31.5
VertRefresh 50 - 70
Option "DPMS"
EndSection
Section "Screen"
Identifier "Screen0"
Device "ATI Technologies, Inc. RV280 [Radeon 9200 SE]"
Monitor "L1915S"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “1280x1024” “1280x960” “1152x864” “1024x768” “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "ATIDriverTV"
Monitor "TV"
DefaultDepth 24
#Option “backingstore”
Subsection "Display"
    Depth       16
    Modes       "800x600"
    ViewPort    0 0  # initial origin if mode is smaller than desktop
Virtual 1280 1024
EndSubsection
    Depth       24
    Modes       "800x600"
Virtual 1280 1024
EndSubsection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Screen0"
Screen “Screen1” RightOf "Screen0"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
Tu utilises 2 ecrans, screen 0 et screen 1, avec par défaut, screen 0 en couleurs 24 bits en 1280x1024 et screen 1 en 24 bits en 800x600.
Pourquoi tu mets ViewPort 0 0 dans la section 24 bits de screen 1 ?
Essaye de mettre ViewPort 0 1 dans celle-ci et ViewPort 1 0 dans celle de screen 0.
Deplus, il faut une carte graphique costaude pour supporter deux écrans en couleurs 24 bits dont l’un est en 1280x1024…
Je ne sais pas il faudrait demander à dpkg c’est lui qui à reconfiguré le XF86.
Le deuxieme ecran c’est la TV et je n’ai jammais reussi à la faire fonctionner correctement sous linux, mais ce sera le probleme d’un autre jour. Dans 99% du temps elle n’est pas connectée.
OK, que regle ce paramètre? Je ne sais pas si le XF86Config-4 peut etre mis en cause vu que l’affichage fonctionne en root?
Que penses-tu de:
quote Open APM failed (/dev/apm_bios) (No such file or directory)
C’est un warning, un avertissement, ce n’est pas essentiel.
Je crois que l’apm est utilisé pour la gestion avancée des ressources électriques (batterie, mise en veille, etc). Ca se règle dans le bios, en principe.
Sinon, pour en revenir à ton problème de serveur X, le second écran est sûrement la cause du problème. Si en plus, c’est une télé que tu n’utilises pas, refait ta config pour un écran uniquement, avec dpkg-reconfigure xserver-xfree.
[quote]Sinon, pour en revenir à ton problème de serveur X, le second écran est sûrement la cause du problème. Si en plus, c’est une télé que tu n’utilises pas, refait ta config pour un écran uniquement, avec dpkg-reconfigure xserver-xfree.
Je vais essayer, mais j’ai des doutes car, cela n’explique pas la cause de la panne, le serverx fonctionne en roo, et le XF86Config à déjà été généré par dpkg-reconfigure…
J’ai débranché le TV et fait un dpkg-reconfigure, mais cela n’a rien changé…
L’affichage fonctionne toujours en root, mais pas en user.
tu as essayé un apt-get install --reinstall des paquets X, pour remettre les droits au carré si ça vient de là ?
Non j’y pensais, mais je voulais savoir si je pouvais essayer d’autres trucs avant, je vais essayer…
Comment quitter le mode su pour retourner en user en console?
J’ai eu un pb dans le genre une fois, et c’était connement ma souris qui était pas sur /dev/mouse mais sur /dev/input/mouse… ça me foutait une erreur du meme genre que la tienne, j’ai galéré un moment en pensant que ça venait de ma carte graphique (une ati aussi, réputées pour leurs pbs sur linux).
:smt067
Je ne sais plus quoi faire…
Le server x ne fonctionne toujours pas (enfin si 1s avant de tenter de se relancer 6 fois ou en root).
Mais au bout de 2 minutes c’est reparti pour 2 minute d’ecran noir meme sur les autres sessions.
J’ai reinstallé xfree86-comon et xserver-xfree86.
Déjà qu’en console c’est déprimant, mais avec ces attentes forcées c’est à mettre des coups dans la machine…
Pourquoi ne pas désinstaller tout xfree en purgeant, et passer à xorg ?
+1, c’est l’occasion rêvée …
C’est tentant mais cela ne resoud pas le probleme, qui ne vient peut etre pas du server x…
Bon j’ai reinstallé tous les paquet que j’ai pu trouver en liaison avec xfree. Cela ne change rien, le probleme se situe a l’appariton de la fentre avec “les modules” ou quelque chose dans le genre qui s’initialisent. J’ai un fond d’ecran mais pas de bureau, ni de barre ni d’icones.
J’ai la messagerie instantanée qui se lance, mais la fenetre n’est pas complete.
Si je relance le serveur x j’ai des messages d’erreur, qui me disent que l’application est crashée, qu’il manque le theme…
J’ai donc reinstallé gdm gnome-core et quelques autres paquets liés à gnomes, mais rien de mieux…
PS
Si je ne repond pas au message qui me dit qui qu’il essayera de relancer le server dans 2 minute, je peux passer sur une autre session et lancer le serverx qui fonctionne admirablement en root…
Quels logs puis-je consulter?
Persone n’a d’idée sur la question?
Bon ben je vais voir du coté de xorg…
Pfff
Plus j’essaye de réparer moins ca marche…
j’ai essayé un dist-upgrade mais il ne va pas jusqu’au bout.
Je sais que la reinstallation est vivement deconseillée, mais la je ne vois plus ce que je peut faire d’autre.
prendre un p’tit bain de soleil :wink:
Le problème vient peut-être (sûrement) de Gnome.
Essaye avec un autre WM, comme KDE, pour voir.
Si KDE fonctionne, tu sauras au moins que le problème ne vient pas d’Xfree, mais bien de Gnome.
