root@debian:/# apt-cache policy console-data
console-data:
Installed: 2:1.12-2
Candidate: 2:1.12-2
Version table:
*** 2:1.12-2 0
500 http://ftp.fr.debian.org/debian/ wheezy/main amd64 Packages
100 /var/lib/dpkg/status
root@debian:/# aptitude search ~c
[ ERR] Reading state information
E: Could not open lock file /var/lock/aptitude - open (2: No such file or directory)
W: Could not lock the cache file; this usually means that dpkg or another apt tool is already installing packages. Opening in read-only mode; any changes you make to the states of packages will NOT be preserved!
c aptdaemon - transaction based package management service
c baobab - GNOME disk usage analyzer
c caribou - Configurable on screen keyboard with scanning mode
c gnome-orca - Scriptable screen reader
c hplip - HP Linux Printing and Imaging System (HPLIP)
c lib32gcc1 - GCC support library (32 bit Version)
c lib32gomp1 - GCC OpenMP (GOMP) support library (32bit)
c lib32itm1 - GNU Transactional Memory Library (32bit)
c lib32quadmath0 - GCC Quad-Precision Math Library (32bit)
c lib32z1 - compression library - 32 bit runtime
c libboost-chrono1.49.0 - C++ representation of time duration, time point, and clocks
c libboost-date-time1.49.0 - set of date-time libraries based on generic programming concepts
c libboost-filesystem1.49.0 - filesystem operations (portable paths, iteration over directories, etc) in C+
c libboost-graph-parallel1.49.0 - generic graph components and algorithms in C++
c libboost-graph1.49.0 - generic graph components and algorithms in C++
c libboost-locale1.49.0 - C++ facilities for localization
c libboost-math1.49.0 - Boost.Math Library
c libboost-mpi-python1.49.0 - C++ interface to the Message Passing Interface (MPI), Python Bindings
c libboost-mpi1.49.0 - C++ interface to the Message Passing Interface (MPI)
c libboost-python1.49.0 - Boost.Python Library
c libboost-random1.49.0 - Boost Random Number Library
c libboost-regex1.49.0 - regular expression library for C++
c libboost-serialization1.49.0 - serialization library for C++
c libboost-signals1.49.0 - managed signals and slots library for C++
c libboost-system1.49.0 - Operating system (e.g. diagnostics support) library
c libboost-test1.49.0 - components for writing and executing test suites
c libboost-timer1.49.0 - C++ wall clock and CPU process timers
c libboost-wave1.49.0 - C99/C++ preprocessor library
c libespeak1 - Multi-lingual software speech synthesizer: shared library
c liblouis2 - Braille translation library - shared libs
c libnfsidmap2 - NFS idmapping library
c libossp-uuid16 - OSSP uuid ISO-C and C++ - shared library
c libpq5 - PostgreSQL C client library
c libsane-hpaio - HP SANE backend for multi-function peripherals
c libsnmp-dev - SNMP (Simple Network Management Protocol) development files
c libsofia-sip-ua-glib3 - Sofia-SIP library glib/gobject interfaces runtime
c libsofia-sip-ua0 - Sofia-SIP library runtime
c libsonic0 - Simple library to speed up or slow down speech
c libspeechd2 - Speech Dispatcher: Shared libraries
c libtelepathy-farstream2 - Glue library between telepathy and farstream
c libtiffxx0c2 - Tag Image File Format (TIFF) library (old version) -- C++ interface
c logmein-hamachi - LogMeIn Hamachi
c lsb-core - Linux Standard Base 4.1 core support package
c mythes-en-us - English Thesaurus for LibreOffice/OpenOffice.org
c nfs-common - NFS support files common to client and server
c postgresql-9.1 - object-relational SQL database, version 9.1 server
c printer-driver-gutenprint - printer drivers for CUPS
c rpcbind - converts RPC program numbers into universal addresses
c speech-dispatcher - Common interface to speech synthesizers
c xdg-user-dirs-gtk
root@debian:/# uname -a && lsb_release -a
Linux debian 3.2.0-4-amd64 #1 SMP Debian 3.2.60-1+deb7u1 x86_64 GNU/Linux
LSB Version: core-2.0-amd64:core-2.0-noarch:core-3.0-amd64:core-3.0-noarch:core-3.1-amd64:core-3.1-noarch:core-3.2-amd64:core-3.2-noarch:core-4.0-amd64:core-4.0-noarch:core-4.1-amd64:core-4.1-noarch
Distributor ID: Debian
Description: Debian GNU/Linux 7.6 (wheezy)
Release: 7.6
Codename: wheezy
root@debian:/# apt-cache policy libc6
libc6:
Installed: 2.13-38+deb7u3
Candidate: 2.13-38+deb7u3
Version table:
*** 2.13-38+deb7u3 0
500 http://security.debian.org/ wheezy/updates/main amd64 Packages
2.13-38+deb7u2 0
