[resolu]au secours je viens de tout planter !
poste ton “xfree86.conf” qui doit etre qq part dans "/etc/X11"ou un sous répertoire genre XFree86 (et pis sinon Xorg c’est “plus mieux” je crois m’enfin je suppose que ca dépend de ton noyau :stuck_out_tongue:)
ci-joint les fichiers de configuration de xfree86 :
XF86Config-4 :
XF86Config-4 (XFree86 X Window System server configuration file)
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the XF86Config-4 manual page.
(Type “man XF86Config-4” at the shell prompt.)
This file is automatically updated on xserver-xfree86 package upgrades only
if it has not been modified since the last upgrade of the xserver-xfree86
package.
If you have edited this file but would like it to be automatically updated
again, run the following commands as root:
cp /etc/X11/XF86Config-4 /etc/X11/XF86Config-4.custom
md5sum /etc/X11/XF86Config-4 >/var/lib/xfree86/XF86Config-4.md5sum
dpkg-reconfigure xserver-xfree86
Section "Files"
FontPath “unix/:7100” # local font server
# if the local font server has problems, we can fall back on these
FontPath "/usr/lib/X11/fonts/misc"
FontPath "/usr/lib/X11/fonts/cyrillic"
FontPath "/usr/lib/X11/fonts/100dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/75dpi/:unscaled"
FontPath "/usr/lib/X11/fonts/Type1"
FontPath "/usr/lib/X11/fonts/CID"
FontPath "/usr/lib/X11/fonts/Speedo"
FontPath "/usr/lib/X11/fonts/100dpi"
FontPath "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "keyboard"
Option "CoreKeyboard"
Option “XkbRules” "xfree86"
Option “XkbModel” "pc105"
Option “XkbLayout” "fr"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
Option “Device” "/dev/input/mice"
Option “Protocol” "ImPS/2"
Option “Emulate3Buttons” "true"
Option “ZAxisMapping” "4 5"
EndSection
Section "Device"
Identifier "radeon 9200 SE "
Driver "vesa"
EndSection
Section "Monitor"
Identifier "e1770NSL/T"
HorizSync 30-57
VertRefresh 43-72
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "radeon 9200 SE "
Monitor "e1770NSL/T"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes “800x600” "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
EndSection
Section "DRI"
Mode 0666
EndSection
XF86Config-4.custom :
package.
Section "Files"
EndSection
Section "Module"
Load "GLcore"
Load "bitmap"
Load "dbe"
Load "ddc"
Load "dri"
Load "extmod"
Load "freetype"
Load "glx"
Load "int10"
Load "record"
Load "speedo"
Load "type1"
Load "vbe"
EndSection
Driver "keyboard"
EndSection
Driver "mouse"
EndSection
Section "Device"
Identifier "radeon 9200 SE Family"
Driver "vesa"
EndSection
Section "Monitor"
HorizSync 30-60
VertRefresh 50-75
Option "DPMS"
EndSection
Section "Screen"
Device "radeon 9200 SE Family"
DefaultDepth 24
Depth 1
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
EndSection
Section "DRI"
Mode 0666
EndSection
dans ton fichier .conf (l’autre est juste une sauve) tu peux essayer de remplacer le protocole “imPS/2” par “auto-dev”, on sait jamais sinon un ptit dpkg -reconfigure xserver-xfree86 pourrait peut etre aider (en particulier en ce qui concerne ta souris), dans les sections concernant la souris choisis les trucs “génériques” ou, si tu les trouves, les pilotes de ta souris.
il y a sûrement un moyen de connaître les pilotes de la souris et d’ une manière générale tout ce dont j’ ai besoin pour reconfigurer xfree. Cela doit être dans un dossier. Comment savoir lequel ?
En ce qui concerne la modif dans le fichier de conf de xfree, je peux la faire par l’ intermédiaire de explore 2 fs ? j’ vois pas comment ! Il me semble que s’ est plus facile par debian ; mais dans ce cas je dois éditer un fichier et je tapes quelle commande pour çà ?
bah il te faut un éditeur de texte, n’importe lequel peut faire l’affaire pourvu que tu saches l’utiliser. Tu peux tres bien l’installer et l’utiliser en mode console sous linux.
Si tu installes emacs par exemple (apt-get install emacs) tu devrais avoir de quoi faire (perso je trouve vim particulièrement déroutant quand on arrive sous linux donc je pense que si tu installes emacs c’est pas plus mal).
Ce qu’il faut savoir c’est que, la ou tu en es, tu peux tres bien utiliser ta machine en mode console. Tu dis OK/ANNULER le nombre de fois qu’il faut pour virer les ecrans d’erreur du gdm et tu vas te retrouver en mode console.
De la, tu peux te logger, installer un éditeur de texte si tu as le net, ou en utiliser un deja dispo, et éditer ton fichier de conf de serveur X.
C’est pas forcément confort le mode console … mais ca sauve la mise des fois =).
Une fois que tu as fait tes modifs :
#/etc/init.d/gdm restart
pour tester. Ca devrait te stopper ton gdm puis le relancer en prennant en compte ta nouvelle config.
j’ arrive pas à quitter l’ écran noir du boot. C’ est comme s’ il me servait de console saur que je peux rien éditer : # gedit ne renvoir rien ni # emacs.
le systeme de propose pas de te logger ?
Normalement quand tu viens de booter comme ca, si tu veux utiliser un terminal tu dois d’abord entrer ton login, ton mot de passe et apres tu dois pouvoir faire tes affaires.
Si tu as deja fait ca : gedit ne risque pas de marcher en mode console pour la bonne raison que c’est un éditeur graphique, il a donc besoin de GDM pour fonctionner.
Quand a emacs, il n’est pas installé par défaut, il faut donc que tu l’installes toi meme.
Pour ce faire :
-soit tu te log directement en root (pas conseillé) et tu tapes “apt-get install emacs”
-soit tu te log en tant qu’utilisateur simple et tu fais :
su
/*tu entres ton mot de passe root losrsque l'on te le demande*/
emacs /etc/X11/XFree86.conf
/*tu edites ton fichier de conf*/
le systeme de propose pas de te logger ? Si je peux me logger en root ou eu user comme je veux.
Rép : çà je ne savais pas. Pourtant j’ ai installé gdm hier en faisant aptitude install gdm !
Code:
su
/tu entres ton mot de passe root losrsque l’on te le demande/
/tu edites ton fichier de conf/
ok j’ y vais et je te tiens au courant
bah le truc c’est que ton gdm il démarre pas, enfin il plante au beau milieu. D’ailleurs qd tu te manges ton message d’erreur ton systeme doit te dire que ton GDM a été désactivé jusqu’a ce que tu regles le problème. En essayant de lancer gedit, tu demandes, entre autres, a ton systeme d’afficher une fenetre alors que l’élément qui le permet est HS donc forcément il aime pas =)
command not found !
il n’ en veut pas.
as tu correctement installé emacs ?
essayes avec “emacs21” au lieu de emacs sinon.
dans le pire des cas utilise vi ou vim mais ne fais pas ca “vite fait” si tu n’as jamais utilisé cet éditeur : trouve toi une solide doc d’abord sur les commandes de base dans vi / vim
aptitude update
aptitude install emacs
réponse fichier inconnu
emacs/etc/X11/XF86Config-4
réponse : fichier introuvable
voilà les fichiers situés dans x11 :
X et gdm avec une flèche bleue
xf86config-4 ; xf86config-4.custom ; Xsession ; Xsession.options ; Xwrapper.config ; default-display-m ; rgb.txt
une aide possible ?
apparament il faut que tu édires xf86config-4
Normal, les seuls fichiers qui soient sont :
XF86Config-4 (pour xfree)
xorg.conf (pour xorg)
jamais entendu parler des autres…
Quant à l’éditeur, il y a tjs nano qui est très simple à utiliser et tjs présent sur Debian.
je suis bien d’ accord avec vous mais le problème est que lorsque je tape
emacs/etc/x11/XF86Config-4
il ne trouve pas le fichier alors qu’ il s’ y trouve ! j’ ai vérifié avec explore2fs.
Je n’ y comprends rien ou alors il y a un problème avec emacs.
bon, le problème provenait bien de emacs. Avec nano, j’ ai pu accéder à mon fichier. Le hic c’ est que je m’ attendais à voir des lignes d’ écritures que je pourrais ensuite modifier. Là rien, un écran noir ou plutôt une soret de cadre avec en bas la mention [Nouveau Fichier]
pui en dessous des symboles bizarres ^G aide ; Ô écrire ; ^Rlire le fichier,…
J’ ai tapé un peu par hasard ctrl+f1 et j’ ai pu ainsi voir l’ aide qui m’ indique que les ^sont en réalité des fonctions comme ctrl.
Je ne suis pas plus avancé pour autant car je ne sais pas trop quoi faire maintenant! J’ ai un curseur qui clignote. Je peux y inscrire des trucs je pense.
[quote]# emacs/etc/x11/XF86Config-4
Non il n’y a pas de problème avec emacs, mais emacs et le nom du fichier sont deux entités différentes qu’il faut séparer par un espace qui n’existe dans aucun de vos posts, ce qui me fait supposer que c’est aussi tapé ainsi dans la console.
Et ça devrait aller mieux :wink:
non, j’ ai essayé avec et sans espace.
Les deux ne fonctionnent pas.
Non, c’est : /etc/X11/XF86Config-4 ! (X11 en majuscule)
Après “emacs” il y a bien un espace, c’est le nom d’une application que tu lances. Et la cible vient après (l’espace), c’est le fichier que tu veux ouvrir.
Avec Nano, ce qu’il y a en bas d’écran, ce sont des commandes, ça ne fait pas partie du fichier.
"Non, c’est : /etc/X11/XF86Config-4 ! (X11 en majuscule)
Après “emacs” il y a bien un espace, c’est le nom d’une application que tu lances. Et la cible vient après (l’espace), c’est le fichier que tu veux ouvrir".
Oui j’ ai essayé aussi mais cela ne marche pas, avec ou sans majuscules ! Je refais un essai ce soir et vous tiens au courant mais j’ ai peu d’ espoir.
Si j’ installais xorg et enlevais xfree ? cela fonctionnerait peut-être!
