nan ! ça c’est tes controleurs usb
ou tu pourrais trouver ça ?
Tu n’as même pas la plus petite idée de quelle cartes réseaux (en nom humain) tu as ?
connais tu ton chipset (le type de ta carte mère) ?
cm = asus c4s8x
chipsets =
sis648 north bridge
sis 963 south bridge
Ds Network feature :
realtech 100/10 mbps lan phys
rj45 connector
Je te repasse le lsmod si ça te cause :
Module Size Used by
xt_state 2240 2
xt_tcpudp 3104 9
iptable_filter 3072 1
iptable_mangle 2848 0
iptable_nat 6980 0
ip_nat 16748 1 iptable_nat
ip_conntrack 48320 3 xt_state,iptable_nat,ip_nat
nfnetlink 6552 2 ip_nat,ip_conntrack
ip_tables 12932 3 iptable_filter,iptable_mangle,iptable_nat
x_tables 13252 4 xt_state,xt_tcpudp,iptable_nat,ip_tables
ipv6 222304 10
ppdev 8516 0
lp 10852 2
dm_snapshot 15680 0
dm_mirror 18768 0
dm_mod 49944 2 dm_snapshot,dm_mirror
ide_generic 1376 0 [permanent]
snd_emu10k1_synth 6912 0
snd_emux_synth 30496 1 snd_emu10k1_synth
snd_seq_virmidi 6912 1 snd_emux_synth
snd_seq_midi_emul 5920 1 snd_emux_synth
snd_seq_dummy 3812 0
snd_seq_oss 28640 0
snd_seq_midi 8128 0
snd_seq_midi_event 6976 3 snd_seq_virmidi,snd_seq_oss,snd_seq_midi
snd_seq 46224 9 snd_emux_synth,snd_seq_virmidi,snd_seq_midi_emul,snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event
snd_emu10k1 101444 1 snd_emu10k1_synth
snd_rawmidi 22560 3 snd_seq_virmidi,snd_seq_midi,snd_emu10k1
snd_ac97_codec 82720 1 snd_emu10k1
snd_ac97_bus 2368 1 snd_ac97_codec
snd_pcm_oss 35968 0
snd_mixer_oss 15872 1 snd_pcm_oss
shpchp 34272 0
snd_pcm 74532 3 snd_emu10k1,snd_ac97_codec,snd_pcm_oss
snd_seq_device 7756 8 snd_emu10k1_synth,snd_emux_synth,snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq,snd_emu10k1,snd_rawmidi
pci_hotplug 27196 1 shpchp
snd_timer 20836 3 snd_seq,snd_emu10k1,snd_pcm
snd_page_alloc 9512 2 snd_emu10k1,snd_pcm
snd_util_mem 4608 2 snd_emux_synth,snd_emu10k1
i2c_sis96x 5316 0
ns558 4800 0
analog 10656 0
snd_hwdep 8676 2 snd_emux_synth,snd_emu10k1
snd 48100 13 snd_emux_synth,snd_seq_virmidi,snd_seq_oss,snd_seq,snd_emu10k1,snd_rawmidi,snd_ac97_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_seq_device,snd_timer,snd_hwdep
parport_pc 32132 1
parport 33160 3 ppdev,lp,parport_pc
pcspkr 3040 0
eth1394 18052 0
i2c_core 19552 1 i2c_sis96x
psmouse 34600 0
serio_raw 6596 0
evdev 9088 0
mousedev 10788 1
tsdev 7392 0
emu10k1_gp 3808 0
gameport 14344 5 ns558,analog,emu10k1_gp
8250_pnp 8704 0
rtc 12340 0
sis_agp 8388 1
agpgart 29864 1 sis_agp
floppy 54276 0
soundcore 9216 1 snd
ext3 118376 2
jbd 50292 1 ext3
mbcache 8324 1 ext3
ide_cd 35680 0
cdrom 32448 1 ide_cd
ide_disk 15072 4
usbhid 35520 0
sis5513 12328 0 [permanent]
8139too 24800 0
sis900 21600 0
ohci1394 30448 0
ieee1394 86584 2 eth1394,ohci1394
generic 4420 0 [permanent]
ide_core 111016 5 ide_generic,ide_cd,ide_disk,sis5513,generic
ohci_hcd 18244 0
ehci_hcd 28040 0
8139cp 20576 0
mii 5312 3 8139too,sis900,8139cp
usbcore 111616 4 usbhid,ohci_hcd,ehci_hcd
sata_promise 11108 0
libata 61420 1 sata_promise
scsi_mod 123080 1 libata
thermal 12904 0
processor 25512 1 thermal
fan 4516 0
ricardo@sid-hdc5:~$
J’ai trouvé ça :
ricardo@sid-hdc5:~$ sudo modinfo sis900
Password:
filename: /lib/modules/2.6.17-2-686/kernel/drivers/net/sis900.ko
author: Jim Huang <cmhuang@sis.com.tw>, Ollie Lho <ollie@sis.com.tw>
description: SiS 900 PCI Fast Ethernet driver
license: GPL
vermagic: 2.6.17-2-686 SMP mod_unload 686 REGPARM gcc-4.1
depends: mii
alias: pci:v00001039d00000900sv*sd*bc*sc*i*
alias: pci:v00001039d00007016sv*sd*bc*sc*i*
parm: sis900_debug:SiS 900/7016 bitmapped debugging message level (int)
parm: max_interrupt_work:SiS 900/7016 maximum events handled per interrupt (int)
parm: multicast_filter_limit:SiS 900/7016 maximum number of filtered multicast addresses (int)
OUI !
on aurait dû commencer par là, ou avais je la tête.
bon et le dernier, c’est 8139too
dc dans l’ordre de /etc/modules (si ce que tu ma donné est le lsmod de la version qui marche)
8139too
8250_pnp
eth1394
Et vous vous en servez de eth1394?
Avec un
dmesg | grep eth
il n’aurait pas eu son bonheur ?
C’est pour mettre un truc genre camescope (avec du débit) ou un hd géré comme une interface réseau.
Jamais essayé.
[quote]8139too
8250_pnp
eth1394[/quote] Fait et ça fonctionne sur les ‘sid’ mais ‘sarge’ fait la gueule alors je lui ai remis comme avant.
Y-a-t-il un inconvénient à ce que ce soit eth1 plutôt que eth0 ?
J’ai une carte mère avec 2 prises éthernet.
Le fait d’avoir eth0 ou eth1 est indifférent du moment que l’on a mis le fil dans la bonne prise. Je n’ai jamais noté aucun inconvénient.
quote="ricardo"Y-a-t-il un inconvénient à ce que ce soit eth1 plutôt que eth0 ?[/quote]Comme le dit Ginko, tu devra changer le branchement rj45 en changeant de distrib, c’est tout.
Jamais essayé.[/quote]
C’est quand meme tordu d’acceder à son disque en ethernet?
Je comprends qu’on accede a un dd en firewire normal avec du débit mais mettre ethernet dessus pour un dd ca me depasse un peu Je vais reprendre un café et je vais reflechir.
Par contre relier pour relier deux machines je veux bien.
[quote]Comme le dit Ginko, tu devra changer le branchement rj45 en changeant de distrib, c’est tout.[/quote] Changer, physiquement ou logiciellement ?
Pour l’instant, je ne fais ni l’un ni l’autre et ça fonctionne bien.
Voilà mes ‘Sid’ sur hda
ricardo2@sid-hda8:~$ sudo dmesg | grep eth
Password:
eth0: SiS 900 PCI Fast Ethernet at 0x9800, IRQ 177, ff:ff:ff:ff:ff:ff.
eth1: RealTek RTL8139 at 0x8800, 00:08:54:3e:a2:91, IRQ 193
eth1: Identified 8139 chip type 'RTL-8100B/8139D'
eth1394: eth2: IEEE-1394 IPv4 over 1394 Ethernet (fw-host0)
eth1: link up, 100Mbps, full-duplex, lpa 0x45E1
eth1: no IPv6 routers present
et sur hdc :
ricardo@sid-hdc5:~$ sudo dmesg | grep eth
eth0: RealTek RTL8139 at 0x8800, 00:08:54:3e:a2:91, IRQ 193
eth0: Identified 8139 chip type 'RTL-8100B/8139D'
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
eth0: no IPv6 routers present
Est-ce que mon DD hda serait branché sur un port eth-x sur la CM et mon DD hdc sur un port eth-y ??? Inconvénients ?
Grosso modo, eth0 corespond par exemple à la prise du haut et eth1 à celle du bas : si c’est eth0 qui a été choisi, il faut brancher le cable ethernet à la prise du haut sinon pas de réseau.
C’est très bête comme explication mais je ne vois pas comment le dire avec des mots compliqués.
Prise du haut et du bas ?
s’il s’agit de la prise externe, je n’ai qu’une RJ45.
Si c’est un branchement interne là je regarderai demain ds l ventre de la machine s’il y a deux possibilités.
Je croyais que tu avais 2 prises rj45 physiques ?
Si il y en a une seule (c’est le cas le plus courant) alors il y a qu’une seule possibilité pour eth. Si cela fonctionne avec la numérotation actuelle, c’est que c’est la bonne.
Jusqu’à hier j’en avais 2 sur ma carte mère (je l’ai changé hier) et au départ le système me détectait ces 2 prises + ieee1394, soit 3 prises et chacune avait un numéro, en fonction de l’ordre de chergement des modules. Il fallait donc pour eth mettre le numéro de la prise corrspondant à celle sur lequel le cable rj45 était branché.
Millessssssssssssss z’excuses
Je ne me souvenais m^ plus avoir acheté une carte rj45 pour essayer de règler un problème (qui d’ailleurs n’avait rien à voir).
J’ai donc en effet, deux sortie physique rj45 : une intégrée et l’autre ajoutée en carte.
Tt est donc clair et je considère que j’ai ttes mes réponses.
Reste maintenant à mettre tt ça au propre sur mes fiches et … me souvenir où j’ai placé cette fiche
Le premier qui se moque, je lui mets une cyber-claque, compris ?
Merci encore à ts.
Décidément, Debian-fr.org c’est vraiment “l’entraide” parfaite.
Se moquer d’un vieillard et de sa cyberclaque faiblarde serait particulièrement lâche…
[quote=“ricardo”]Millessssssssssssss z’excuses
Merci encore à ts.
Décidément, Debian-fr.org c’est vraiment “l’entraide” parfaite.[/quote]
rien a voir avec l’age, j’ai pesté pendent je ne sais combien de temps sur ma carte TV que je n’arrivais pas a voir… elle était dans mon placard
Oui, ça fait ptet un peu loin du PC mais on ne sais jamais avec une carte wifi ?
quote="avision"rien a voir avec l’age, j’ai pesté pendent je ne sais combien de temps sur ma carte TV que je n’arrivais pas a voir… elle était dans mon placard [/quote]Je l’ai dit à ghost, je te le dis à toi: il est vraiment temps d’arrèter la colle
