Squeeze mise à jour php 5.4 et soucis avec phpmyadmin
je viens de tout recommencer a 0
# /etc/init.d/mysql stop
Stopping MySQL database server: mysqld140604 16:44:11 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
[1]+  Done                    mysqld_safe --skip-grant-tables
# mysqld_safe --skip-grant-tables &
[1] 25926
# 140604 16:44:27 mysqld_safe Logging to syslog.
140604 16:44:27 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
mysql -u root
Welcome to the MySQL monitor.  Commands end with ; or \g.
Your MySQL connection id is 1
Server version: 5.1.73-1 (Debian)
Copyright (c) 2000, 2013, Oracle and/or its affiliates. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql> use mysql;
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
mysql> select host,user,password from user;
| host         | user             | password                                  |
| localhost    | root             | *wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww |
| minusserveur | root             | *xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx |
| 127.0.0.1    | root             | *ffffffffffffffffffffffffffffffffffffffff |
| localhost    | debian-sys-maint | *eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee |
| localhost    | phpmyadmin       | *zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz |
| localhost    | roundcube        | *rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr |
| %            | joomla           | *tttttttttttttttttttttttttttttttttttttttt |
7 rows in set (0.00 sec)
mysql> update user set password=PASSWORD("xxxxxxxxxx") where User='root';
Query OK, 3 rows affected (0.00 sec)
Rows matched: 3  Changed: 3  Warnings: 0
mysql> flush privileges;
Query OK, 0 rows affected (0.00 sec)
mysql> quit;
Bye
Stopping MySQL database server: mysqld140604 16:49:03 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
# /etc/init.d/mysql start
Starting MySQL database server: mysqld.
Checking for corrupt, not cleanly closed and upgrade needing tables..
# mysql
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO)
j’en ai encore fait une?
[quote=“BelZéButh”]Au vu de la commande (retour console) lancée …
Pour moi c’est un raccourci [mono]/root/.my.cnf[/mono] as-tu ajusté/corrigé son mdp ?[/quote]
[mono]service mysql status[/mono] ?
[code][17:02:53][root@facteur] ~ # mysql
Your MySQL connection id is 9499
Server version: 5.5.37-0+wheezy1-log (Debian)
Copyright © 2000, 2014, Oracle and/or its affiliates. All rights reserved.
owners.
Type ‘help;’ or ‘\h’ for help. Type ‘\c’ to clear the current input statement.
mysql> quit;
Bye
[17:03:32][root@facteur] ~ # [/code]
[17:03:47][root@facteur] ~ # ll /root/.my.cnf -rw------- 1 root root 145 2013-01-18 19:24 /root/.my.cnf [17:04:03][root@facteur] ~ #
/usr/bin/mysqladmin  Ver 8.42 Distrib 5.1.73, for debian-linux-gnu on x86_64
owners.
Server version          5.1.73-1
Protocol version        10
Connection              Localhost via UNIX socket
UNIX socket             /var/run/mysqld/mysqld.sock
Uptime:                 13 min 46 sec
Threads: 1  Questions: 1373  Slow queries: 0  Opens: 1545  Flush tables: 1  Open tables: 64  Queries per second avg: 1.662.
et la partie administration de mes sites joomla refonctionnent :041
 php -v
PHP Warning:  Module 'mysql' already loaded in Unknown on line 0
PHP Warning:  Module 'mysqli' already loaded in Unknown on line 0
PHP Warning:  Module 'pdo_mysql' already loaded in Unknown on line 0
PHP Warning:  PHP Startup: Unable to load dynamic library '/usr/lib/php5/20100525/suhosin.so' - /usr/lib/php5/20100525/suhosin.so: cannot open shared object file: No such file or directory in Unknown on line 0
PHP 5.4.4-14+deb7u10 (cli) (built: May 30 2014 09:58:21)
Copyright (c) 1997-2012 The PHP Group
Zend Engine v2.4.0, Copyright (c) 1998-2012 Zend Technologies
:023
[mono]# mysql[/mono] ???
Fais le point, parce que là, j’ai du mal à te suivre …
Par ailleurs …
[quote]Si vous désirez vous occuper de ce processus vous-même, vous pouvez refuser cette option.
Sinon, acceptez-la. Lors d’une mise à jour, une sauvegarde de la base de données sera effectuée dans /var/cache/dbconfig-common/backups ;
en cas de problème, vous pourrez restaurer les données à partir de celle-ci.
Heureusement, il existe une sauvegarde de la base de données dans /var/cache/dbconfig-common/backups/phpmyadmin_4:3.3.7-7.mysql créée juste avant la mise à jour.
Si vous êtes un administrateur de bases de données expérimenté et si vous savez que vous voulez procéder à cette configuration vous-même, ou si votre base de données est déjà installée et configurée, vous pouvez refuser cette option. Des précisions sur la procédure se trouvent dans /usr/share/doc/phpmyadmin.
[…][/quote]
Ces modules ne sont-ils pas nécessaire à Joomla ?
[mono]php -v
PHP Warning: Module ‘mysql’ already loaded in Unknown on line 0
PHP Warning: Module ‘mysqli’ already loaded in Unknown on line 0
PHP Warning: Module ‘pdo_mysql’ already loaded in Unknown on line 0[/mono]
Sinon même principe, recherches/commentes le fichier php.ini
Déjà vu, hein …
alors le point:
1/
# mysql -u root -p -e JoomlaPM
Enter password:
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
J’ai bien changé le mdp suivant la technique que tu m’a donné et toujours ce soucis. le mdp que j’ai changé par ta technique ne fonctionne pas.
2/
les bases de données sont toutes la et tout fonctionne de ce coté la (vu via phpmyadmin)
3/
Pour ces modules la je ne sait pas encore, il va falloir que je vois sa avec le support Joomla.
Si pas utile oui je commenterais les lignes dans php.ini
4/
oui il me semble.
correction le mot de passe mysql fonctionne :041
# mysql -p
Enter password:
Your MySQL connection id is 310
owners.
mysql> quit;
Bye
Dans un premier, c’était le mdp de root mysql qui merder, tu as corrigé.
[quote=“Minus”]# mysql -u root -p -e JoomlaPM
Enter password:
ERROR 1045 (28000): Access denied for user ‘root’@‘localhost’ (using password: YES)
Or, actuellement tu t’acharnes à vouloir changer le mdp de root (mysql) au lieu de celui de ton user [mono]JoomlaPM[/mono] … Rien à voir avec [mono]root mysql[/mono], non ? … :whistle:
Vois tu la couille dans le potage ?
Attention, la procédure (commande) n’est pas la même.
[quote=“Minus”]alors le point:
1/
Enter password:
Si tu es dans la situation où ton user [mono]JoomlaPM (?)[/mono] n’a plus accès à sa base, alors il te faut …
Te connecté en tant que [mono]root mysql[/mono]
[mono]# mysql
mysql >[/mono]
Mise à jour (update) du mdp pour l’user : [mono]nom_de_l’user[/mono]
[mono]mysql> update user set password=password(‘MDP_de_nom_de_l’user’) WHERE user=‘nom_de_l’user’;
mysql >
mysql> quit;[/mono]
[mono]# service mysql restart[/mono] :wink:
D’aprés ce que j’ai vu c’est cette commande qu’il faut utiliser pour aller voir la base de donnée JoomlaPM
technique.arscenic.org/lamp-lin … n-ligne-de
Mais la c’est bon joomla fonctionne parfaitement donc les noms de user et mdp associés ne posent pas de probleme, donc je n’y touche plus.
Stopping MySQL database server: mysqld.
Je crois que tout est ok maintenant non?
Certes.
Ma foi, php5, mysql et phpmyadmin en version Wheezy … :083
Il suffira d’ajuster l’épinglage de ces paquets.
Et, un jeu de sauvegarde. (fiable) [mono]/ & /home[/mono] … 8)
Certes.
Et, un jeu de sauvegarde. (fiable) [mono]/ & /home[/mono] … 8)[/quote]
Concernant Joomla et consorts, tu ne me parais pas convaincu :unamused:
l’épinglage des paquets tu l’ajuste comment?
j’avais une question:
avec ces manips tu a fait quoi??
$ aptitude search ~i -F"%p %t “| grep dotdeb où $ aptitude search ~i -F”%p %t "| grep packages.dotdeb ?
$ aptitude search ‘~i~M’ | grep mysql
Merci pour ton aide
[quote=“Minus”]Concernant Joomla et consorts, tu ne me parais pas convaincu :unamused:
Non non, une simple méprise de ma part (les posts qui se croisent), il me semblais (tes retours) que tu avais des soucis mdp concernant l’user joomla, ce qui vraisemblablement n’était pas.
L’etiquetage de paquets via le fichier /etc/apt/preferences un très bon point de départ.
[quote=“Minus”]avec ces manips tu a fait quoi??
$ aptitude search ~i -F"%p %t "| grep dotdeb où $ aptitude search ~i -F"%p %t "| grep packages.dotdeb ? $ aptitude search '~i~M' | grep mysql
[mono]$ aptitude search ~i -F"%p %t "| grep dotdeb[/mono]
[mono]$ aptitude search ~i -F"%p %t "| grep packages.dotdeb[/mono]
Une recherche des paquets installés à partir du dépôt (ex) dotdeb (Cf. ton ex sources.list)
#php 5.4 por sueeze a partir depot wheezy #deb http://packages.dotdeb.org squeeze all #deb-src http://packages.dotdeb.org squeeze all #deb http://packages.dotdeb.org squeeze-php54 all #deb-src http://packages.dotdeb.org squeeze-php54 all
Rechercher les paquets installés manuellement ou automatiquement.
Installés manuellement.
[mono]# aptitude search ‘~i!~M’[/mono]
[mono][10:57:08] ~ # aptitude search ‘~i!~M’ | grep ssmtp
i ssmtp - extremely simple MTA to get mail off the s
[10:57:37] ~ #[/mono]
Installés automatiquement.
[mono]# aptitude search ‘~i~M’[/mono]
[mono][10:57:52] ~ # aptitude search ‘~i~M’ | grep iceweasel
i A iceweasel - navigateur web basé sur Firefox
[10:58:38] ~ #[/mono]
:wink:
ps : ?
Ok pour valider :wink:
Encore merci beaucoup pour ton aide et la formation en mode accélérée par la même occasion :wink:
Je rebondis.
[quote=“Minus”]D’aprés ce que j’ai vu c’est cette commande qu’il faut utiliser pour aller voir la base de donnée JoomlaPM
Je crois que tout est ok maintenant non?[/quote]
[code][09:37:58][root@facteur] ~ # mysql
Your MySQL connection id is 9803
owners.
mysql> [/code]
[code]mysql> show databases;
| Database |
| information_schema |
| Arfooo |
| Crawlprotect |
| Crawltrack |
| Dotclear2 |
| DotclearIndus |
| ProtectIndus |
| TrackIndus |
| amavis |
| bdd_sirrocco |
| dspam |
| libre_debian |
| mysql |
| performance_schema |
| phpmyadmin |
| postfix |
| roundbase |
| spam |
| test |
19 rows in set (0.00 sec)
mysql> [/code]
[code]mysql> use postfix;
Database changed
mysql>[/code]
[code]mysql> show tables;
| Tables_in_postfix |
| admin |
| alias |
| alias_domain |
| config |
| domain |
| domain_admins |
| fetchmail |
| log |
| mailbox |
| postfix_access |
| postfix_hello |
| quota |
| quota2 |
| relay |
| transport |
| vacation |
| vacation_notification |
17 rows in set (0.00 sec)
mysql>[/code]
[code]mysql> flush privileges;
Query OK, 0 rows affected (0.05 sec)
mysql>[/code]
mysql> quit; Bye [09:43:03][root@facteur] ~ #
Etc … :wink:
Genial :023
Merci pour les tuyaux :clap: :text-thankyouyellow: :text-thankyouyellow:
