[3.16rc4] chkrootkit
à priori j’ai 2 fichiers infectés,
fichiers majeurs!
root@alpha30:~# chkrootkit
ROOTDIR is `/'
Checking `amd'...                                           not found
Checking `basename'...                                      not infected
Checking `biff'...                                          not found
Checking `chfn'...                                          not infected
Checking `chsh'...                                          not infected
Checking `cron'...                                          not infected
Checking `crontab'...                                       not infected
Checking `date'...                                          not infected
Checking `du'...                                            not infected
Checking `dirname'...                                       not infected
Checking `echo'...                                          not infected
Checking `egrep'...                                         not infected
Checking `env'...                                           not infected
Checking `find'...                                          not infected
Checking `fingerd'...                                       not found
Checking `gpm'...                                           not found
Checking `grep'...                                          not infected
Checking `hdparm'...                                        not infected
Checking `su'...                                            not infected
Checking `ifconfig'...                                      not infected
Checking `inetd'...                                         not infected
Checking `inetdconf'...                                     not infected
Checking `identd'...                                        not found
Checking `init'...                                          not infected
Checking `killall'...                                       not infected
Checking `ldsopreload'...                                   not infected
Checking `login'...                                         not infected
Checking `ls'...                                            not infected
Checking `lsof'...                                          not infected
Checking `mail'...                                          not infected
Checking `mingetty'...                                      not found
Checking `netstat'...                                       not infected
Checking `named'...                                         not infected
Checking `passwd'...                                        not infected
Checking `pidof'...                                         not infected
Checking `pop2'...                                          not found
Checking `pop3'...                                          not found
Checking `ps'...                                            not infected
Checking `pstree'...                                        not infected
Checking `rpcinfo'...                                       not infected
Checking `rlogind'...                                       not found
Checking `rshd'...                                          not found
Checking `slogin'...                                        not infected
Checking `sendmail'...                                      not infected
Checking `sshd'...                                          not infected
Checking `syslogd'...                                       not tested
Checking `tar'...                                           not infected
Checking `tcpd'...                                          not infected
Checking `tcpdump'...                                       not infected
Checking `top'...                                           not infected
Checking `telnetd'...                                       not found
Checking `timed'...                                         not found
Checking `traceroute'...                                    not infected
Checking `vdir'...                                          not infected
Checking `w'...                                             not infected
Checking `write'...                                         not infected
Checking `aliens'...                                        no suspect files
Searching for sniffer's logs, it may take a while...        nothing found
Searching for rootkit HiDrootkit's default files...         nothing found
Searching for rootkit t0rn's default files...               nothing found
Searching for t0rn's v8 defaults...                         nothing found
Searching for rootkit Lion's default files...               nothing found
Searching for rootkit RSHA's default files...               nothing found
Searching for rootkit RH-Sharpe's default files...          nothing found
Searching for Ambient's rootkit (ark) default files and dirs... nothing found
Searching for suspicious files and dirs, it may take a while... The following suspicious files and directories were found:
/usr/lib/jvm/.java-1.6.0-openjdk-amd64.jinfo /usr/lib/jvm/.java-1.7.0-openjdk-amd64.jinfo /usr/lib/ocf/resource.d/heartbeat/.ocf-directories /usr/lib/ocf/resource.d/heartbeat/.ocf-shellfuncs /usr/lib/ocf/resource.d/heartbeat/.ocf-binaries /usr/lib/ocf/resource.d/heartbeat/.ocf-returncodes /usr/lib/icedove/.autoreg /usr/lib/debug/.build-id /usr/lib/python2.7/dist-packages/PyQt4/uic/widget-plugins/.noinit /usr/lib/pymodules/python2.7/.path
Searching for LPD Worm files and dirs...                    nothing found
Searching for Ramen Worm files and dirs...                  nothing found
Searching for Maniac files and dirs...                      nothing found
Searching for RK17 files and dirs...                        nothing found
Searching for Ducoci rootkit...                             nothing found
Searching for Adore Worm...                                 nothing found
Searching for ShitC Worm...                                 nothing found
Searching for Omega Worm...                                 nothing found
Searching for Sadmind/IIS Worm...                           nothing found
Searching for MonKit...                                     nothing found
Searching for Showtee...                                    nothing found
Searching for OpticKit...                                   nothing found
Searching for T.R.K...                                      nothing found
Searching for Mithra...                                     nothing found
Searching for LOC rootkit...                                nothing found
Searching for Romanian rootkit...                           nothing found
Searching for Suckit rootkit...                             Warning: /sbin/init INFECTED
Searching for Volc rootkit...                               nothing found
Searching for Gold2 rootkit...                              nothing found
Searching for TC2 Worm default files and dirs...            nothing found
Searching for Anonoying rootkit default files and dirs...   nothing found
Searching for ZK rootkit default files and dirs...          nothing found
Searching for ShKit rootkit default files and dirs...       nothing found
Searching for AjaKit rootkit default files and dirs...      nothing found
Searching for zaRwT rootkit default files and dirs...       nothing found
Searching for Madalin rootkit default files...              nothing found
Searching for Fu rootkit default files...                   nothing found
Searching for ESRK rootkit default files...                 nothing found
Searching for rootedoor...                                  nothing found
Searching for ENYELKM rootkit default files...              nothing found
Searching for common ssh-scanners default files...          nothing found
Searching for suspect PHP files...                          nothing found
Searching for anomalies in shell history files...           nothing found
Checking `asp'...                                           not infected
Checking `bindshell'...                                     INFECTED (PORTS:  4369)
Checking `lkm'...                                           chkproc: nothing detected
chkdirs: nothing detected
Checking `rexedcs'...                                       not found
Checking `sniffer'...                                       lo: not promisc and no packet sniffer sockets
eth0: PACKET SNIFFER(/usr/sbin/iptotal[21305])
eth1: not promisc and no packet sniffer sockets
Checking `w55808'...                                        not infected
Checking `wted'...                                          chkwtmp: nothing deleted
Checking `scalper'...                                       not infected
Checking `slapper'...                                       not infected
Checking `z2'...                                            chklastlog: nothing deleted
Checking `chkutmp'...                                        The tty of the following user process(es) were not found
 in /var/run/utmp !
! RUID          PID TTY    CMD
! root         2084 tty7   /usr/bin/X :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
! jb1          5444 pts/0  /bin/su root -c /usr/lib/libgksu/gksu-run-helper "/usr/sbin/firestarter"
chkutmp: nothing deleted
Checking `OSX_RSPLUG'...                                    not infected
root@alpha30:~#
A+
JB1
j’ ai eu une réponse sur lists.debian.org,
merci Sylvain
A+
JB1
Qui était ?
