l’Acer d’une amie ventile à fond tout le temps, aspirateur passé, il est à jour (je viens de lui faire une clean install de Bullseye.), Normalement la version Bios est la dernière disponible, Tlp est activé…
~$ systemctl status tlp
● tlp.service - TLP system startup/shutdown
Loaded: loaded (/lib/systemd/system/tlp.service; enabled; vendor preset: e>
Active: active (exited) since Wed 2021-08-18 07:56:50 CEST; 24min ago
Docs: https://linrunner.de/tlp
Process: 1480 ExecStart=/usr/sbin/tlp init start (code=exited, status=0/SUC>
Main PID: 1480 (code=exited, status=0/SUCCESS)
CPU: 294ms
Warning: some journal files were not opened due to insufficient permissions.
lines 1-9/9 (END)
~$ neofetch
_,met$$$$$gg. brigitte@ordi
,g$$$$$$$$$$$$$$$P. -------------
,g$$P" """Y$$.". OS: Debian GNU/Linux 11 (bullseye) x86_64
,$$P' `$$$. Host: Aspire V5-571G V2.18
',$$P ,ggs. `$$b: Kernel: 5.10.0-8-amd64
`d$$' ,$P"' . $$$ Uptime: 27 mins
$$P d$' , $$P Packages: 2390 (dpkg), 5 (flatpak)
$$: $$. - ,d$$' Shell: bash 5.1.4
$$; Y$b._ _,d$P' Resolution: 1366x768
Y$$. `.`"Y$$$$P"' DE: Xfce 4.16
`$$b "-.__ WM: Xfwm4
`Y$$ WM Theme: Kokodi
`Y$$. Theme: Adwaita [GTK2/3]
`$$b. Icons: Numix-Circle [GTK2], Adwaita [GTK3]
`Y$$b. Terminal: xfce4-terminal
`"Y$b._ Terminal Font: Monospace 12
`""" CPU: Intel i3-2377M (4) @ 1.500GHz
GPU: NVIDIA GeForce GT 620M/630M/635M/640M LE
GPU: Intel 2nd Generation Core Processor Family
Memory: 1106MiB / 3725MiB
~$ inxi -Fxxx
System: Host: ordi Kernel: 5.10.0-8-amd64 x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: Xfce 4.16.0 tk: Gtk 3.24.24
info: xfce4-panel, plank wm: xfwm4 dm: LightDM 1.26.0 Distro: Debian GNU/Linux 11 (bullseye)
Machine: Type: Laptop System: Acer product: Aspire V5-571G v: V2.18 serial: <superuser required>
Mobo: Acer model: Aspire V5-571G v: V2.18 serial: <superuser required> UEFI [Legacy]: Phoenix v: 2.18
date: 06/21/2013
Battery: ID-1: BAT0 charge: 27.5 Wh condition: 27.5/37.0 Wh (74%) volts: 17.2/14.8 model: SANYO AL12A32 type: Li-ion
serial: 29961 status: Full
CPU: Info: Dual Core model: Intel Core i3-2377M bits: 64 type: MT MCP arch: Sandy Bridge rev: 7 L2 cache: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 11971
Speed: 798 MHz min/max: 800/1500 MHz Core speeds (MHz): 1: 798 2: 798 3: 798 4: 798
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Acer Incorporated ALI driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:0116 class ID: 0300
Device-2: NVIDIA GF108M [GeForce GT 620M/630M/635M/640M LE] vendor: Acer Incorporated ALI driver: nouveau v: kernel
bus ID: 01:00.0 chip ID: 10de:0de9 class ID: 0300
Device-3: Suyin HD WebCam type: USB driver: uvcvideo bus ID: 3-4:3 chip ID: 064e:e330 class ID: 0e02
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting unloaded: fbdev,vesa resolution: 1366x768~60Hz
s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 20.3.5 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20 class ID: 0403
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0bea
class ID: 0403
Sound Server: ALSA v: k5.10.0-8-amd64
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel port: 2000 bus ID: 03:00.2
chip ID: 10ec:8168 class ID: 0200
IF: enp3s0f2 state: down mac: 20:6a:8a:e9:82:a1
Device-2: Qualcomm Atheros AR9462 Wireless Network Adapter vendor: Foxconn driver: ath9k v: kernel port: 2000
bus ID: 04:00.0 chip ID: 168c:0034 class ID: 0280
IF: wlp4s0 state: up mac: a4:17:31:36:a3:61
Bluetooth: Device-1: Foxconn / Hon Hai type: USB driver: btusb v: 0.8 bus ID: 1-1.4:4 chip ID: 0489:e04e class ID: e001
Report: ID: hci0 state: up running bt-v: 2.1 lmp-v: 4.0 sub-v: 1 hci-v: 4.1 rev: 1102 address: A4:17:31:36:A3:62
Drives: Local Storage: total: 698.64 GiB used: 18.01 GiB (2.6%)
ID-1: /dev/sda vendor: Seagate model: ST750LM022 HN-M750MBB size: 698.64 GiB speed: 3.0 Gb/s rotation: 5400 rpm
serial: S2UNJ9CC923424 rev: 0001 temp: 31 C scheme: GPT
Partition: ID-1: / size: 91.02 GiB used: 12.18 GiB (13.4%) fs: ext4 dev: /dev/sda2
ID-2: /home size: 590.06 GiB used: 5.83 GiB (1.0%) fs: ext4 dev: /dev/sda3
Swap: ID-1: swap-1 type: partition size: 4.62 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda4
Sensors: System Temperatures: cpu: 73.0 C mobo: 63.0 C gpu: nouveau temp: 71.0 C
Fan Speeds (RPM): N/A
Info: Processes: 182 Uptime: 29m wakeups: 1 Memory: 3.64 GiB used: 1.37 GiB (37.6%) Init: systemd v: 247 runlevel: 5
Compilers: gcc: 10.2.1 alt: 10 Packages: 2395 apt: 2390 flatpak: 5 Shell: Bash v: 5.1.4 running in: xfce4-terminal
inxi: 3.3.01
Une bonne âme aurait-elle une piste à explorer ?
