J’ai encore de nouveau soucis avec debian décidemment.
Mais cette fois c’est pour mon disque dur. Il est d’une lenteur impressionnante.
Je vous fait un lspci :
0000:00:00.0 Host bridge: ATI Technologies Inc RS480 Host Bridge (rev 01)
0000:00:02.0 PCI bridge: ATI Technologies Inc RS480 PCI-X Root Port
0000:00:06.0 PCI bridge: ATI Technologies Inc RS480 PCI Bridge
0000:00:07.0 PCI bridge: ATI Technologies Inc RS480 PCI Bridge
0000:00:13.0 USB Controller: ATI Technologies Inc IXP SB400 USB Host Controller
0000:00:13.1 USB Controller: ATI Technologies Inc IXP SB400 USB Host Controller
0000:00:13.2 USB Controller: ATI Technologies Inc IXP SB400 USB2 Host Controller
0000:00:14.0 SMBus: ATI Technologies Inc IXP SB400 SMBus Controller (rev 11)
0000:00:14.1 IDE interface: ATI Technologies Inc Standard Dual Channel PCI IDE Controller ATI
0000:00:14.3 ISA bridge: ATI Technologies Inc IXP SB400 PCI-ISA Bridge
0000:00:14.4 PCI bridge: ATI Technologies Inc IXP SB400 PCI-PCI Bridge
0000:00:14.5 Multimedia audio controller: ATI Technologies Inc IXP SB400 AC'97 Audio Controller (rev 02)
0000:00:14.6 Modem: ATI Technologies Inc ATI SB400 - AC'97 Modem Controller (rev 02)
0000:01:00.0 VGA compatible controller: ATI Technologies Inc Radeon Mobility X700 (PCIE)
0000:06:05.0 Network controller: Broadcom Corporation BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller (rev 02)
0000:06:06.0 CardBus bridge: Texas Instruments PCIxx21/x515 Cardbus Controller
0000:06:06.2 FireWire (IEEE 1394): Texas Instruments OHCI Compliant IEEE 1394 Host Controller
0000:06:06.3 Mass storage controller: Texas Instruments PCIxx21 Integrated FlashMedia Controller
0000:06:06.4 0805: Texas Instruments PCI6411/6421/6611/6621/7411/7421/7611/7621 Secure Digital Controller
0000:06:07.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8169 Gigabit Ethernet (rev 10)
Et ensuite le fameux hdparm.
hdparm -c1 -d1 /dev/hda/
dev/hda:
setting 32-bit IO_support flag to 1
setting using_dma to 1 (on)
HDIO_SET_DMA failed: Operation not permitted
IO_support = 1 (32-bit)
using_dma = 0 (off)
Comme vous pouvez le voir, ça ne marche pas.
Donc j’ai regardé sur internet, essayé le module atiixp
Mais hdparm ne veut toujours pas entendre parler de l’UDMA.
Donc aparemment la seule solution serait de recompiler le kernel
Si quelqu’un aurait une autre solution je suis preneur.
Alors pour recompiler le kernel, vais je perdre toutes les modifications que j’ai fait concernant le matériel ??? Carte wifi, ATI Direct Rendrering ???
Merci.
