Alerte de bug lors d’un aptitude upgrade (#1019855 & #1019564)
Tags: #<Tag:0x00007f46ad8bc9c8> #<Tag:0x00007f46ad8bc770> #<Tag:0x00007f46ad8bc3d8>
J’essaye de mettre à jour une Debian Bullseye mais je reçois un avertissement de bug assez anxiogène :
 % sudo aptitude upgrade
Resolving dependencies...
The following NEW packages will be installed:
  linux-headers-5.10.0-18-amd64{a} linux-headers-5.10.0-18-common{a} linux-image-5.10.0-18-amd64{a}
The following packages will be REMOVED:
  sse3-support{u}
The following packages will be upgraded:
  avahi-autoipd avahi-daemon base-files bind9-dnsutils bind9-host bind9-libs chromium chromium-common chromium-sandbox clamav clamav-base clamav-freshclam cri-tools curl dpkg dpkg-dev
  fig2dev firefox-esr firefox-esr-l10n-fr fonts-opensymbol gir1.2-ayatanaappindicator3-0.1 gir1.2-gdkpixbuf-2.0 gir1.2-javascriptcoregtk-4.0 gir1.2-lokdocview-0.1 gir1.2-webkit2-4.0
  gping grub-common grub-pc grub-pc-bin grub2-common krb5-locales kubeadm kubectl kubelet kubernetes-cni libavahi-client3 libavahi-common-data libavahi-common3 libavahi-compat-libdnssd1
  libavahi-core7 libavahi-glib1 libayatana-appindicator1 libayatana-appindicator3-1 libc-bin libc-dev-bin libc-devtools libc-l10n libc6 libc6-dev libclamav9 libcurl3-gnutls libcurl4
  libdatetime-timezone-perl libdpkg-perl libexpat1 libexpat1-dev libgdk-pixbuf-2.0-0 libgdk-pixbuf-2.0-dev libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common libgssapi-krb5-2
  libhttp-daemon-perl libhttp-parser2.9 libjavascriptcoregtk-4.0-18 libjs-bootstrap4 libjuh-java libjurt-java libk5crypto3 libkrb5-3 libkrb5support0 liblibreoffice-java
  liblibreofficekitgtk libnss-myhostname libnss-systemd libpam-systemd libpcre2-16-0 libpcre2-32-0 libpcre2-8-0 libpcre2-dev libpcre2-posix2 libpoppler-cpp0v5 libpoppler-glib8
  libpoppler-qt5-1 libpoppler102 libpq5 libreoffice-base-core libreoffice-calc libreoffice-common libreoffice-core libreoffice-draw libreoffice-gnome libreoffice-gtk3
  libreoffice-help-common libreoffice-help-en-us libreoffice-help-fr libreoffice-impress libreoffice-l10n-fr libreoffice-math libreoffice-style-colibre libreoffice-style-elementary
  libreoffice-writer libreofficekit-data libridl-java libsystemd0 libudev1 libuno-cppu3 libuno-cppuhelpergcc3-3 libuno-purpenvhelpergcc3-3 libuno-sal3 libuno-salhelpergcc3-3
  libunoloader-java libwebkit2gtk-4.0-37 libxnvctrl0 libxslt1.1 linux-compiler-gcc-10-x86 linux-headers-amd64 linux-image-amd64 linux-kbuild-5.10 linux-libc-dev locales poppler-utils
  publicsuffix python3-uno systemd systemd-sysv systemd-timesyncd thunderbird tzdata udev uno-libs-private ure virtualbox virtualbox-dkms virtualbox-qt zlib1g zlib1g-dev
The following packages are RECOMMENDED but will NOT be installed:
  libnss-nis libnss-nisplus
136 packages upgraded, 3 newly installed, 1 to remove and 0 not upgraded.
Need to get 0 B/540 MB of archives. After unpacking 400 MB will be used.
Do you want to continue? [Y/n/?] y
Retrieving bug reports... Done
Parsing Found/Fixed information... Done
critical bugs of libc6 (2.31-13+deb11u3 -> 2.31-13+deb11u4) <Outstanding>
 b1 - #1019855 - Fwd: libc6: immediately crashes with SIGILL on 4th gen Intel Core CPUs (seems related to AVX2 instructions), bricking the whole system
grave bugs of grub-pc (2.04-20 -> 2.06-3~deb11u2) <Outstanding>
 b2 - #1019564 - (during upgrade) grub-install: warning: Attempting to install GRUB to a disk with multiple partition labels.  This is not supported yet..
Summary:
 libc6(1 bug), grub-pc(1 bug)
Are you sure you want to install/upgrade the above packages? [Y/n/?/...]
Concrètement, dois-je vraiment m’alarmer de ce bug ? Que sont concrètement les risques ou les comportements indésirés qu’ils peuvent causer ? Puis-je les éviter ?
Et surtout Puis-je malgré tout continuer l’installation avec y ?
Bonjour.
Concernant le premier bogue sur la libc6, la question à te poser est la suivante : est-ce que ta machine fonctionne avec un CPU Intel de 4ème Génération ? C’est la génération « Haswell ». Si oui, tu utilises la touche P - pour Pin - pour ne pas mettre à jour sur ce bogue. Sinon, tu peux continuer l’installation.
cf: Haswell (microarchitecture) — Wikipédia
Concernant le second bogue, je n’ai pas d’avis en soit, si ce n’est de rester prudent, et donc d’utiliser le Pin.
Je ne sais pas si j’ai bien compris le sujet, mais, pour ma part, j’ai fait la mise à jour de libc6 et mon système fonctionne aussi bien (ou plutôt « Haswell », d’accord, je sors), mais n’ayant même pas de processeur Intel, je ne sais pas si ça me concerne vraiment.
Quant à grub-pc, je n’ai pas de souci et je ne comprends pas bien dans quel contexte le problème se pose, mais ça n’a pas l’air d’être une configuration courante, à mon avis, si tu ne sais pas si tu es dans cette situation ou non, c’est que tu ne dois pas y être.
