Hello
il m’arrive un truc bizzard, je règle dans alsamixergui ce qui va bien et sa marche,
reboot
je regarde les valeur on pas changer.
je lance amarock pas de son…
je relance alsamixer ou alsamixergui. les valeur on changer comme par miracle ?!
j’ai essayer avec alsactl store mai pareil meme problème
dpkg -l |grep alsa
ii alsa-base 1.0.21+dfsg-2 ALSA driver configuration files
ii alsa-oss 1.0.17-3 ALSA wrapper for OSS applications
ii alsa-tools 1.0.21-1 Console based ALSA utilities for specific hardware
ii alsa-tools-gui 1.0.21-1 GUI based ALSA utilities for specific hardware
ii alsa-utils 1.0.21-1 ALSA utilities
ii alsamixergui 0.9.0rc2-1-9 graphical soundcard mixer for ALSA soundcard driver
ii alsaplayer-alsa 0.99.80-4 PCM player designed for ALSA (ALSA output module)
ii alsaplayer-common 0.99.80-4 PCM player designed for ALSA (common files)
ii alsaplayer-gtk 0.99.80-4 PCM player designed for ALSA (GTK+ version)
ii alsaplayer-oss 0.99.80-4 PCM player designed for ALSA (OSS output module)
ii libalsa-ocaml 0.1.4-2 OCaml bindings for the ALSA library
ii libalsaplayer0 0.99.80-4 PCM player designed for ALSA (interface library)
ii libsdl1.2debian-alsa 1.2.13-5 Simple DirectMedia Layer (with X11 and ALSA options)
ii libsnack2-alsa 2.2.10-dfsg1-9 Sound extension to Tcl/Tk and Python/Tkinter - Tcl/Tk library
je pourrait faire un script qui force le volume de tout les canaux a fond ,mai comment (qu’elle commande permet de monter le volume de X cannaux ?)
