Analyse disque dur
J’entreprends le dépoussierage de plusieurs disques durs : pouvez-vous m’aider à me confirmer qu’ils sont bons pour la casse ou non ?
Voici un premier rapport. J’ai lu que si le ‹ remaining › est à 00% après un self-test alors le disque n’est pas mort. Confirmez-vous ?
sudo smartctl --all /dev/sda
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.0-58-generic] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Seagate Barracuda 7200.7 and 7200.7 Plus
Device Model:     ST380013AS
Serial Number:    5MR02MHD
Firmware Version: 8.12
User Capacity:    80 000 000 000 bytes [80,0 GB]
Sector Size:      512 bytes logical/physical
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA/ATAPI-6 T13/1410D revision 2
Local Time is:    Thu Apr  6 14:03:24 2023 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82)	Offline data collection activity
					was completed without error.
					Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(  430) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					No Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					No General Purpose Logging support.
Short self-test routine
recommended polling time: 	 (   1) minutes.
Extended self-test routine
recommended polling time: 	 (  47) minutes.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   058   050   006    Pre-fail  Always       -       190722777
  3 Spin_Up_Time            0x0003   098   098   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   099   099   020    Old_age   Always       -       1051
  5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   084   060   030    Pre-fail  Always       -       247535861
  9 Power_On_Hours          0x0032   096   096   000    Old_age   Always       -       4283
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   099   099   020    Old_age   Always       -       1204
194 Temperature_Celsius     0x0022   024   046   000    Old_age   Always       -       24 (0 13 0 0 0)
195 Hardware_ECC_Recovered  0x001a   058   050   000    Old_age   Always       -       190722777
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0000   100   253   000    Old_age   Offline      -       0
202 Data_Address_Mark_Errs  0x0032   100   253   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short captive       Completed without error       00%      1803         -
# 2  Short captive       Completed without error       00%        14         -
# 3  Short offline       Completed without error       00%         0         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Non, ça veut juste dire que le dernier n’a pas eu d’erreur, ça ne veut rien dire de plus.
Si tu veux avoir des données plus récente, n’hésite pas à lancer un auto-test.
Bonsoir
Par contre ces données ne sont pas un bon signe par rapport à la santé du disque
5 et 197 ne sont pas les valeurs, mais les identifiants, les valeurs sont respectivement 0 et 0, ce qui est très bien, surtout pour un disque qui n’a tourné que 4283 heures (modulo 65536).
Oui tout à fait,
je me suis trompé de colonne entre VALUE et RAW_VALUE
Autant pour moi :wink: Désolé
