Apparmor bug : profile for /etc/apparmor.d/abstractions not found, skipping
Je n’arrive pas à mettre les profils apparmor en mode aa-enforce:
sudo aa-enforce /etc/apparmor.d/*
Profile for /etc/apparmor.d/abstractions not found, skipping
Traceback (most recent call last):
  File "/usr/sbin/aa-enforce", line 30, in <module>
    tool.cmd_enforce()
  File "/usr/lib/python3/dist-packages/apparmor/tools.py", line 153, in cmd_enforce
    apparmor.read_profiles()
  File "/usr/lib/python3/dist-packages/apparmor/aa.py", line 2572, in read_profiles
    read_profile(profile_dir + '/' + file, True)
  File "/usr/lib/python3/dist-packages/apparmor/aa.py", line 2598, in read_profile
    profile_data = parse_profile_data(data, file, 0)
  File "/usr/lib/python3/dist-packages/apparmor/aa.py", line 2853, in parse_profile_data
    store_list_var(filelist[file]['lvar'], list_var, value, var_operation, file)
  File "/usr/lib/python3/dist-packages/apparmor/aa.py", line 3289, in store_list_var
    raise AppArmorException(_('Redefining existing variable %(variable)s: %(value)s in %(file)s') % { 'variable': list_var, 'value': value, 'file': filename })
apparmor.common.AppArmorException: 'Redefining existing variable @{APT_CACHE_DIR}: /var/cache/apt-cacher-ng in /etc/apparmor.d/usr.sbin.apt-cacher-ng
Merci.
Il faut donner le nom du profile et comme généralement le nom commence par usr
aa-enforce /etc/apparmor.d/usr*
Exemple
etc/apparmor.d# aa-enforce /etc/apparmor.d/usr*
Setting /etc/apparmor.d/usr.bin.evince to enforce mode.
Setting /etc/apparmor.d/usr.bin.firefox to enforce mode.
Setting /etc/apparmor.d/usr.bin.webbrowser-app to enforce mode.
Setting /etc/apparmor.d/usr.lib.snapd.snap-confine to enforce mode.
Setting /etc/apparmor.d/usr.sbin.cups-browsed to enforce mode.
Setting /etc/apparmor.d/usr.sbin.cupsd to enforce mode.
Setting /etc/apparmor.d/usr.sbin.ippusbxd to enforce mode.
Setting /etc/apparmor.d/usr.sbin.rsyslogd to enforce mode.
Setting /etc/apparmor.d/usr.sbin.tcpdump to enforce mode.
https://debian-handbook.info/browse/fr-FR/stable/sect.apparmor.html
Bonsoir,
Quand je fais:
J’obtiens ceci:
Setting /etc/apparmor.d/usr.bin.chromium-browser to enforce mode.
    tool.cmd_enforce()
apparmor.common.AppArmorException: 'Redefining existing variable @{APT_CACHE_DIR}: /var/cache/apt-cacher-ng in /etc/apparmor.d/usr.sbin.apt-cacher-ng'
Merci.
il faut avoir les droits root pour gérer apparmor
Exemple pour vérifier l’état
sudo aa-status
as tu fait
sudo aa-enforce /etc/apparmor.d/usr*
Il me souvient qu’il faut faire une rustine pour que le noyau démarre apparmor
Dans /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT=“quiet apparmor=1 security=apparmor”
puis
sudo update-grub
Et redemarrer
Pour vérifier que c’est bien démarré
systemctl status apparmor
● apparmor.service - AppArmor initialization
   Loaded: loaded (/lib/systemd/system/apparmor.service; enabled; vendor preset:
   Active: active (exited) since mer. 2016-09-28 17:03:24 CEST; 2h 19min ago
     Docs: man:apparmor(7)
           http://wiki.apparmor.net/
 Main PID: 2445 (code=exited, status=0/SUCCESS)
    Tasks: 0 (limit: 4915)
   CGroup: /system.slice/apparmor.service
sept. 28 17:03:22 debian systemd[1]: Starting AppArmor initialization...
sept. 28 17:03:24 debian apparmor[2445]: Starting AppArmor profiles:.
sept. 28 17:03:24 debian systemd[1]: Started AppArmor initialization.
Dans Grub, j’avais déjà noté ceci:
GRUB_CMDLINE_LINUX=apparmor="1 security=apparmor"
J’ai alors rajouté ce que tu m’as dit:
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor"
● apparmor.service - LSB: AppArmor initialization
Loaded: loaded (/etc/init.d/apparmor)
Active: active (exited) since jeu 2016-09-29 12:42:00 CEST; 1min 17s ago
Process: 217 ExecStart=/etc/init.d/apparmor start (code=exited, status=0/SUCCESS)
sudo aa-status
apparmor module is loaded.
61 profiles are loaded.
30 profiles are in enforce mode.
   /usr/bin/evince
   /usr/bin/evince-previewer
   /usr/bin/evince-previewer//sanitized_helper
   /usr/bin/evince-thumbnailer
   /usr/bin/evince-thumbnailer//sanitized_helper
   /usr/bin/evince//sanitized_helper
   /usr/bin/freshclam
   /usr/bin/irssi
   /usr/bin/pidgin
   /usr/bin/pidgin//launchpad_integration
   /usr/bin/pidgin//sanitized_helper
   /usr/bin/totem
   /usr/bin/totem-audio-preview
   /usr/bin/totem-video-thumbnailer
   /usr/lib/chromium-browser/chromium-browser
   /usr/lib/chromium-browser/chromium-browser//browser_java
   /usr/lib/chromium-browser/chromium-browser//browser_openjdk
   /usr/lib/chromium-browser/chromium-browser//chromium_browser_sandbox
   /usr/lib/chromium-browser/chromium-browser//lsb_release
   /usr/lib/chromium-browser/chromium-browser//sanitized_helper
   /usr/lib/chromium-browser/chromium-browser//xdgsettings
   /usr/lib/cups/backend/cups-pdf
   /usr/sbin/apt-cacher-ng
   /usr/sbin/clamd
   /usr/sbin/cups-browsed
   /usr/sbin/cupsd
   /usr/sbin/cupsd//third_party
   /usr/sbin/ntpd
   /usr/sbin/tcpdump
   gst_plugin_scanner
31 profiles are in complain mode.
   /sbin/klogd
   /sbin/syslog-ng
   /sbin/syslogd
   /usr/lib/dovecot/anvil
   /usr/lib/dovecot/auth
   /usr/lib/dovecot/config
   /usr/lib/dovecot/deliver
   /usr/lib/dovecot/dict
   /usr/lib/dovecot/dovecot-auth
   /usr/lib/dovecot/dovecot-lda
   /usr/lib/dovecot/imap
   /usr/lib/dovecot/imap-login
   /usr/lib/dovecot/lmtp
   /usr/lib/dovecot/log
   /usr/lib/dovecot/managesieve
   /usr/lib/dovecot/managesieve-login
   /usr/lib/dovecot/pop3
   /usr/lib/dovecot/pop3-login
   /usr/lib/dovecot/ssl-params
   /usr/sbin/avahi-daemon
   /usr/sbin/dnsmasq
   /usr/sbin/dovecot
   /usr/sbin/identd
   /usr/sbin/mdnsd
   /usr/sbin/nmbd
   /usr/sbin/nscd
   /usr/sbin/smbd
   /usr/sbin/smbldap-useradd
   /usr/sbin/smbldap-useradd///etc/init.d/nscd
   /usr/{sbin/traceroute,bin/traceroute.db}
   /{usr/,}bin/ping
6 processes have profiles defined.
4 processes are in enforce mode.
   /usr/bin/freshclam (498)
   /usr/sbin/clamd (535)
   /usr/sbin/cups-browsed (532)
   /usr/sbin/cupsd (531)
2 processes are in complain mode.
   /usr/sbin/avahi-daemon (512)
   /usr/sbin/avahi-daemon (520)
0 processes are unconfined but have a profile defined.
    tool.cmd_enforce()
Ps: la commande “sudo” ne fonctionne jamais. Après avoir tapé mon mon de passe, elle me retourne toujours qu’il est erroné. Je dois faire au préalable su pour que celle-ci fonctionne.
Merci.
GRUB_CMDLINE_LINUX c’est pour le démarrage en recovery
je pense que la syntaxe n’est pas bonne
je mettrais
GRUB_CMDLINE_LINUX=“apparmor=1 security=apparmor”
Quel est ton system d’init?
Si par la commande
pstree
tu vois
@debian:~$ pstree
systemd─┬─ModemManager─┬─{gdbus}
c’est que tu es en systemd
mais j’ai pas l’impression que tu y sois
Sinon pour sudo, il faut que le paquet sudo soit installé et que ton utilisateur soit bien dans le group sudo
grep sudo /etc/group
J’ai changé la syntaxe et refait sudo reboot mais malheureusement sans aucun changement.
Je pense que je suis en systemd:
        │              └─{gmain}
        ├─NetworkManager─┬─{NetworkManager}
        │                ├─{gdbus}
        │                └─{gmain}
        ├─acpid
        ├─agetty
        ├─applet.py───{gmain}
        ├─2*[at-spi-bus-laun─┬─dbus-daemon]
        │                    ├─{dconf worker}]
        │                    ├─{gdbus}]
        │                    └─{gmain}]
        ├─2*[at-spi2-registr───{gdbus}]
        ├─atd
        ├─avahi-daemon───avahi-daemon
        ├─clamd───2*[{clamd}]
        ├─clamscan─┬─clamscan
        │          ├─inotifywait
        │          └─sed
        ├─cron───cron───sh───clamav-unoffici───dig───3*[{dig}]
        ├─cups-browsed
        ├─cupsd
        ├─3*[dbus-daemon]
        ├─2*[dbus-launch]
        ├─exim4
        ├─freshclam
        ├─gconfd-2
        ├─gpg-agent
        ├─gvfs-udisks2-vo─┬─{gdbus}
        │                 └─{gmain}
        ├─gvfsd───{gdbus}
        ├─gvfsd-trash─┬─{gdbus}
        │             ├─{gmain}
        │             └─{pool}
        ├─lightdm─┬─Xorg───2*[{Xorg}]
        │         ├─lightdm─┬─sh─┬─ssh-agent
        │         │         │    └─xfce4-session─┬─Thunar
        │         │         │                    ├─xfce4-panel─┬─panel-2-action+
        │         │         │                    │             ├─panel-6-systra+
        │         │         │                    │             ├─{gdbus}
        │         │         │                    │             └─{gmain}
        │         │         │                    ├─xfdesktop─┬─{gdbus}
        │         │         │                    │           └─{gmain}
        │         │         │                    ├─xfwm4
        │         │         │                    ├─{gdbus}
        │         │         │                    └─{gmain}
        │         │         ├─{gdbus}
        │         │         └─{gmain}
        │         ├─{gdbus}
        │         └─{gmain}
        ├─nm-applet─┬─{dconf worker}
        │           └─{gdbus}
        ├─polkit-gnome-au───{gdbus}
        ├─polkitd─┬─{gdbus}
        │         └─{gmain}
        ├─pulseaudio─┬─{alsa-sink-ALC27}
        │            ├─{alsa-sink-HDMI }
        │            └─{alsa-source-ALC}
        ├─rpc.idmapd
        ├─rpc.statd
        ├─rpcbind
        ├─rsyslogd─┬─{in:imklog}
        │          ├─{in:imuxsock}
        │          └─{rs:main Q:Reg}
        ├─rtkit-daemon───2*[{rtkit-daemon}]
        ├─start-pulseaudi───xprop
        ├─2*[systemd───(sd-pam)]
        ├─systemd-journal
        ├─systemd-logind
        ├─systemd-udevd
        ├─tumblerd─┬─{gdbus}
        │          ├─{gmain}
        │          └─2*[{pool}]
        ├─udisksd─┬─{cleanup}
        │         ├─{gdbus}
        │         ├─{gmain}
        │         └─{probing-thread}
        ├─upowerd─┬─{gdbus}
        │         └─{gmain}
        ├─wpa_supplicant
        ├─xfce4-notifyd
        ├─xfce4-power-man───{gdbus}
        ├─xfce4-power-man
        ├─xfce4-terminal─┬─bash───su───bash
        │                ├─bash───pstree
        │                ├─gnome-pty-helpe
        │                ├─{gdbus}
        │                └─{gmain}
        ├─xfce4-volumed─┬─{gdbus}
        │               ├─{task0}
        │               └─{task1}
        ├─xfconfd
        ├─xfsettingsd─┬─{gdbus}
        │             └─{gmain}
        └─xscreensaver
ce qui est interessant
debian:~$ systemctl status apparmor
   Active: active (exited) since jeu. 2016-09-29 17:07:36 CEST; 1h 22min ago
 Main PID: 2483 (code=exited, status=0/SUCCESS)
sept. 29 17:07:34 debian systemd[1]: Starting AppArmor initialization...
sept. 29 17:07:36 debian apparmor[2483]: Starting AppArmor profiles:.
sept. 29 17:07:36 debian systemd[1]: Started AppArmor initialization.
on voit Loaded: loaded (/lib/systemd/system/apparmor.service; enabled; qui prouve que systemd gere apparmor
Que dois-je faire alors?
deja verifier l’état
cat /sys/module/apparmor/parameters/enabled
si tout est ok il doit y avoir Y dedans
root@debian:/# cat /sys/module/apparmor/parameters/enabled
Y
root@debian:/#
il y a un bug dans lequel je suis tombé, il existe peut etre toujours
passer la commande pour activer, sous root
systemctl enable apparmor
pour voir l’état des profiles apparmor
root@debian:/# aa-status
Exemple
64 profiles are loaded.
27 profiles are in enforce mode.
   /usr/bin/evince
   /usr/bin/irssi
   /usr/bin/pidgin
   /usr/bin/totem
   /usr/sbin/cupsd
   /usr/sbin/tcpdump
   gst_plugin_scanner
   icedove
   icedove//gpg
   icedove//gpg2
   icedove//sanitized_helper
37 profiles are in complain mode.
   /usr/lib/dovecot/dovecot-lda///usr/sbin/sendmail
   /usr/sbin/dnsmasq
   /usr/sbin/dnsmasq//libvirt_leaseshelper
   /usr/sbin/dovecot
   /usr/sbin/identd
   /usr/sbin/mdnsd
   /usr/sbin/nmbd
   /usr/sbin/nscd
   /usr/sbin/smbd
   /{usr/,}bin/ping
   klogd
   syslog-ng
   syslogd
4 processes have profiles defined.
2 processes are in enforce mode.
   /usr/sbin/cups-browsed (1962)
   /usr/sbin/cupsd (1922)
   /usr/sbin/avahi-daemon (1914)
   /usr/sbin/avahi-daemon (1940)
J’ai vérifié et je n’ai pas ce bug.
Mais toujours impossible de mettre en enforce.
Vu tous tes autres messages par ailleurs, je pense que tu as un problème global.
Probablement une mauvaise installation
Verifier ces dossiers
root@debian:/etc/apparmor.d# ls -alrt
total 252
-rw-r--r--   1 root root   469 mars  24  2016 usr.sbin.cups-browsed
-rw-r--r--   1 root root  5119 mars  25  2016 usr.sbin.cupsd
drwxr-xr-x   2 root root  4096 mars  30  2016 force-complain
-rw-r--r--   1 root root   842 mars  30  2016 usr.sbin.traceroute
-rw-r--r--   1 root root  1413 mars  30  2016 usr.sbin.smbd
-rw-r--r--   1 root root   761 mars  30  2016 usr.sbin.nmbd
-rw-r--r--   1 root root   964 mars  30  2016 usr.sbin.mdnsd
-rw-r--r--   1 root root  1013 mars  30  2016 usr.sbin.identd
-rw-r--r--   1 root root  2012 mars  30  2016 usr.sbin.dovecot
-rw-r--r--   1 root root   790 mars  30  2016 usr.lib.dovecot.ssl-params
-rw-r--r--   1 root root   967 mars  30  2016 usr.lib.dovecot.pop3-login
-rw-r--r--   1 root root   900 mars  30  2016 usr.lib.dovecot.pop3
-rw-r--r--   1 root root  1109 mars  30  2016 usr.lib.dovecot.managesieve-login
-rw-r--r--   1 root root   953 mars  30  2016 usr.lib.dovecot.managesieve
-rw-r--r--   1 root root   680 mars  30  2016 usr.lib.dovecot.log
-rw-r--r--   1 root root  1006 mars  30  2016 usr.lib.dovecot.lmtp
-rw-r--r--   1 root root  1008 mars  30  2016 usr.lib.dovecot.imap-login
-rw-r--r--   1 root root  1056 mars  30  2016 usr.lib.dovecot.dovecot-auth
-rw-r--r--   1 root root   887 mars  30  2016 usr.lib.dovecot.dict
-rw-r--r--   1 root root  1153 mars  30  2016 usr.lib.dovecot.deliver
-rw-r--r--   1 root root   871 mars  30  2016 usr.lib.dovecot.config
-rw-r--r--   1 root root  1204 mars  30  2016 usr.lib.dovecot.auth
-rw-r--r--   1 root root   733 mars  30  2016 usr.lib.dovecot.anvil
-rw-r--r--   1 root root  8243 mars  30  2016 usr.bin.chromium-browser
-rw-r--r--   1 root root  1307 mars  30  2016 sbin.syslogd
-rw-r--r--   1 root root   999 mars  30  2016 sbin.klogd
-rw-r--r--   1 root root  5995 avril 26 21:43 usr.bin.evince
-rw-r--r--   1 root root  1454 avril 30 12:54 usr.sbin.tcpdump
-rw-r--r--   1 root root  2981 avril 30 12:54 usr.bin.pidgin
-rw-r--r--   1 root root  1308 avril 30 12:54 usr.bin.irssi
-rw-r--r--   1 root root   479 avril 30 12:54 gst_plugin_scanner
-rw-r--r--   1 root root   755 juin  25 09:46 usr.sbin.apt-cacher-ng
-rw-r--r--   1 root root   985 juin  25 09:46 usr.bin.totem-previewers
-rw-r--r--   1 root root   833 juin  25 09:46 usr.bin.totem
drwxr-xr-x   2 root root  4096 juil.  1 14:50 disable
-rw-r--r--   1 root root   920 juil.  1 16:12 usr.sbin.smbldap-useradd
-rw-r--r--   1 root root  1255 juil.  1 16:12 usr.sbin.nscd
-rw-r--r--   1 root root  3123 juil.  1 16:12 usr.sbin.dnsmasq
-rw-r--r--   1 root root   916 juil.  1 16:12 usr.sbin.avahi-daemon
-rw-r--r--   1 root root  1003 juil.  1 16:12 usr.lib.dovecot.imap
-rw-r--r--   1 root root  2619 juil.  1 16:12 usr.lib.dovecot.dovecot-lda
-rw-r--r--   1 root root  1929 juil.  1 16:12 sbin.syslog-ng
-rw-r--r--   1 root root   802 juil.  1 16:12 bin.ping
drwxr-xr-x   2 root root  4096 juil.  7 10:46 apache2.d
-rw-r--r--   1 root root  8165 août   1 23:42 usr.bin.icedove.guy
-rw-r--r--   1 root root  8222 août  24 07:50 usr.bin.icedove
drwxr-xr-x   2 root root  4096 sept. 30 09:12 local
drwxr-xr-x   5 root root  4096 sept. 30 09:12 tunables
drwxr-xr-x   4 root root 12288 sept. 30 20:46 abstractions
drwxr-xr-x   9 root root  4096 sept. 30 20:46 .
drwxr-xr-x   2 root root  4096 sept. 30 20:46 cache
drwxr-xr-x 148 root root 12288 oct.   3 13:28 ..
root@debian:/etc/apparmor.d# cd abstractions
root@debian:/etc/apparmor.d/abstractions# ls
apache2-common		   launchpad-integration     ubuntu-bittorrent-clients
apparmor_api		   ldapclient		     ubuntu-browsers
aspell			   lightdm		     ubuntu-browsers.d
audio			   lightdm_chromium-browser  ubuntu-console-browsers
authentication		   likewise		     ubuntu-console-email
base			   mdns			     ubuntu-email
bash			   mir			     ubuntu-feed-readers
consoles		   mysql		     ubuntu-gnome-terminal
cups-client		   nameservice		     ubuntu-helpers
dbus			   nis			     ubuntu-konsole
dbus-accessibility	   nvidia		     ubuntu-media-players
dbus-accessibility-strict  openssl		     ubuntu-unity7-base
dbus-session		   orbit2		     ubuntu-unity7-launcher
dbus-session-strict	   p11-kit		     ubuntu-unity7-messaging
dbus-strict		   perl			     ubuntu-xterm
dconf			   php5			     user-download
dovecot-common		   postfix-common	     user-mail
enchant			   private-files	     user-manpages
evince			   private-files-strict      user-tmp
fonts			   python		     user-write
freedesktop.org		   ruby			     video
gnome			   samba		     web-data
gnupg			   smbpass		     winbind
gstreamer		   ssl_certs		     wutmp
ibus			   ssl_keys		     X
kde			   svn-repositories	     xad
kerberosclient		   totem		     xdg-desktop
le service apparmor est ici
cat /lib/systemd/system/apparmor.service
[Unit]
Description=AppArmor initialization
After=local-fs.target
Before=sysinit.target
AssertPathIsReadWrite=/sys/kernel/security/apparmor/.load
ConditionVirtualization=!container
ConditionSecurity=apparmor
DefaultDependencies=no
Documentation=man:apparmor(7)
Documentation=http://wiki.apparmor.net/
# Don't start this unit on the Ubuntu Live CD
ConditionPathExists=!/rofs/etc/apparmor.d
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStop=/etc/init.d/apparmor stop
ExecReload=/etc/init.d/apparmor reload
[Install]
WantedBy=sysinit.target
tu peux essayer la séquence en ligne de commande
    root@debian:/# /etc/init.d/apparmor stop
    [ ok ] Stopping apparmor (via systemctl): apparmor.service.
root@debian:/# /etc/init.d/apparmor start
[ ok ] Starting apparmor (via systemctl): apparmor.service.
root@debian:/# systemctl status apparmor
   Active: active (exited) since mar. 2016-10-04 14:44:02 CEST; 7s ago
  Process: 7054 ExecStop=/etc/init.d/apparmor stop (code=exited, status=0/SUCCES
  Process: 7101 ExecStart=/etc/init.d/apparmor start (code=exited, status=0/SUCC
 Main PID: 7101 (code=exited, status=0/SUCCESS)
oct. 04 14:43:52 debian systemd[1]: Starting AppArmor initialization...
oct. 04 14:44:02 debian apparmor[7101]: Starting AppArmor profiles:.
oct. 04 14:44:02 debian systemd[1]: Started AppArmor initialization.
Bonsoir,
Voici les retours des commandes :
cat: /lib/systemd/system/apparmor.service: Aucun fichier ou dossier de ce type
bash: /#: Aucun fichier ou dossier de ce type
   Active: active (exited) since lun 2016-10-10 19:18:20 CEST; 3s ago
  Process: 25607 ExecStop=/etc/init.d/apparmor stop (code=exited, status=0/SUCCESS)
  Process: 25644 ExecStart=/etc/init.d/apparmor start (code=exited, status=0/SUCCESS)
oct 10 19:18:20 pc apparmor[25644]: Starting AppArmor profiles:.
oct 10 19:18:20 pc systemd[1]: Started LSB: AppArmor initialization.
je ne ne vois plus trop où tu en es maintenant
Tout ce que je sais est là
http://wiki.apparmor.net/index.php/Documentation
Bonsoir,
J’ai tout recommencé depuis le début et je l’ai installé en suivant les recommandations de ce site.
https://wiki.debian.org/AppArmor/HowToUse
J’ai ensuite rajouté la rustine dans le fichier /etc/default/grub
Cette commande met tous les profiles en mode enforce ou complain.
cd /usr/share/doc/apparmor-profiles/extras
cp -i . /etc/apparmor.d/
for f in *.* ; do aa-complain /etc/apparmor.d/$f; done
Mais comment fait-on pour mettre 1 seul profile en mode complain ou enforce?
Merci.
