J’ai vu qu’il y avait une version plus récente du petit jeu Berusky (1.4-1 dans les dépôts et 1.7 sur sourceforge). J’ai donc téléchargé le dossier et je rame consciencieusement pour compiler.
le log de config.log : http://paste.debian.net/hidden/9ed47fab/
Et la commande make :
$ make
make all-recursive
make[1]: Entering directory '/media/Jeulinux/berusky/berusky-1.7'
Making all in po
make[2]: Entering directory '/media/Jeulinux/berusky/berusky-1.7/po'
make[2]: Nothing to be done for 'all'.
make[2]: Leaving directory '/media/Jeulinux/berusky/berusky-1.7/po'
Making all in src
make[2]: Entering directory '/media/Jeulinux/berusky/berusky-1.7/src'
g++ -DHAVE_CONFIG_H -I. -I.. -pthread -I/usr/include/gtk-2.0 -I/usr/lib/x86_64-linux-gnu/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/pango-1.0 -I/usr/include/harfbuzz -I/usr/include/gtk-2.0 -I/usr/lib/x86_64-linux-gnu/gtk-2.0/include -I/usr/include/gio-unix-2.0/ -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/libpng12 -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -Wall -Wint-to-pointer-cast -g -g -O2 -MT 2d_graph.o -MD -MP -MF .deps/2d_graph.Tpo -c -o 2d_graph.o 2d_graph.cpp
2d_graph.cpp:31:21: fatal error: SDL/SDL.h: Aucun fichier ou dossier de ce type
#include <SDL/SDL.h>
compilation terminated.
Makefile:436: recipe for target '2d_graph.o' failed
make[2]: *** [2d_graph.o] Error 1
make[2]: Leaving directory '/media/Jeulinux/berusky/berusky-1.7/src'
Makefile:418: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/media/Jeulinux/berusky/berusky-1.7'
Makefile:328: recipe for target 'all' failed
make: *** [all] Error 2
lylyrian@ordi:/media/Jeulinux/berusky/berusky-1.7$ ldd 2d_graph
ldd: ./2d_graph: Aucun fichier ou dossier de ce type
J’ai déjà résolu quelques soucis : il ne trouvait pas gtk2± avant
configure: error: Package requirements (gtk+-2.0 gdk-2.0) were not met:
No package 'gtk+-2.0' found
No package 'gdk-2.0' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
En installant les paquets -dev l’erreur a été résolue (et un peu tout ce qui avait “gtk” dans son nom dans les dépôts).
Là, 2d_graph.o je ne sais pas où chercher… et ça fait déjà 2h que je court après les erreurs pour installer un simple jeu, il est temps que je vienne demander de l’aide ![]()
Je n’avais pas percuté sur “sdl” et je me focalisais sur 2d_graph que je ne trouvais pas…
