Bluetooth ne fonctionne pas
Tags: #<Tag:0x00007f39f3ff2678> #<Tag:0x00007f39f3ff2240>
Je viens d’installer Debian 12 sur un vieux pc portable HP :
  • Hewlett-Packard HP Compaq 6830s
  • 3.0 GiB
  • intel® Core™2 Duo T5870 × 2
  • AMD RV620
    équipé d’un dongle tp-link pout le bluetooth.
    Je cherche à connecter une petite enceinte bluetooth mais impossible
Quel est le modèle de ton TP-Link?
bluetooth 5.0
Modèle : UB500
sudo apt-get install bluetooth blueman bluez bluez-obexd bluez-firmware pulseaudio-module-bluetooth gnome-bluetooth-3-common gnome-bluetooth-sendto ubertooth
Ça ne fonctionne toujours pas.
J’ai bien l’interupteur dans « Settings/Bluetooth »
Bus 004 Device 003: ID 2357:0604 TP-Link TP-Link UB500 Adapter
:arrow_forward: modprobe btusb
bash: modprobe: command not found
:arrow_forward: sudo systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; preset: enabled)
Active: active (running) since Thu 2023-12-21 08:46:38 CET; 46min ago
Docs: man:bluetoothd(8)
Main PID: 545 (bluetoothd)
Status: « Running »
Tasks: 1 (limit: 3463)
Memory: 2.2M
CPU: 72ms
CGroup: /system.slice/bluetooth.service
└─545 /usr/libexec/bluetooth/bluetoothd
Dec 21 08:46:38 debian bluetoothd[545]: Bluetooth daemon 5.66
Dec 21 08:46:38 debian bluetoothd[545]: Starting SDP server
Dec 21 08:46:38 debian bluetoothd[545]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Dec 21 08:46:38 debian bluetoothd[545]: src/plugin.c:plugin_init() Failed to init vcp plugin
Dec 21 08:46:38 debian bluetoothd[545]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Dec 21 08:46:38 debian bluetoothd[545]: src/plugin.c:plugin_init() Failed to init mcp plugin
Dec 21 08:46:38 debian bluetoothd[545]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Dec 21 08:46:38 debian bluetoothd[545]: src/plugin.c:plugin_init() Failed to init bap plugin
Dec 21 08:46:38 debian systemd[1]: Started bluetooth.service - Bluetooth service.
Dec 21 08:46:38 debian bluetoothd[545]: Bluetooth management interface 1.22 initialized
