Visiblement, c’es le service bluetooth qui refuse de démarrer (segfault)
Quelqu’un peut il m’aider à comprendre cet extrait de strace bluetoothd
map2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x4000a000
set_tls(0x4000a6d0, 0x4000add7, 0x4000add8, 0x4000a6d0, 0x401af000) = 0
mprotect(0x40424000, 8192, PROT_READ) = 0
mprotect(0x40093000, 4096, PROT_READ) = 0
mprotect(0x40020000, 4096, PROT_READ) = 0
mprotect(0x40084000, 4096, PROT_READ) = 0
mprotect(0x402f5000, 4096, PROT_READ) = 0
mprotect(0x402d7000, 4096, PROT_READ) = 0
mprotect(0x401ae000, 4096, PROT_READ) = 0
munmap(0x40099000, 37051) = 0
set_tid_address(0x4000a278) = 4256
set_robust_list(0x4000a280, 0xc) = 0
futex(0xbeaecce4, FUTEX_WAIT_BITSET_PRIVATE|FUTEX_CLOCK_REALTIME, 1, NULL, 402f6000) = -1 EAGAIN (Resource temporarily unavailable)
rt_sigaction(SIGRTMIN, {0x402dd434, [], SA_SIGINFO|0x4000000}, NULL, 8) = 0
rt_sigaction(SIGRT_1, {0x402dd2d4, [], SA_RESTART|SA_SIGINFO|0x4000000}, NULL, 8) = 0
rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0
getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM_INFINITY}) = 0
brk(0) = 0x4014f000
brk(0x40170000) = 0x4014f000
mmap2(NULL, 1048576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x40469000
uname({sys="Linux", node="sheevaplug-debian", ...}) = 0
--- SIGSEGV (Segmentation fault) @ 0 (0) ---
+++ killed by SIGSEGV +++
Erreur de segmentation
ça se termine très abruptement, mais je ne comprends pas quel est le problème
