En parallèle de mes problemes de déconnexions intempestives suite au passage au noyau 3.9, j’ai aussi remarqué que ma carte wifi ne fonctionnait plus…
Et ce coup ci je me pose vraiment des questions car:
- sous windows comme sous linux je n’ai pas de wifi
- le bouton est bien sur ON mais la loupiote ne s’allume pas…
- voici le retour d’un lspci et d’un lshw. Dans les deux cas, je ne vois pas ma carte wifi
lspci:
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b4)
00:1c.3 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 (rev b4)
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b4)
00:1c.6 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 7 (rev b4)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation HM65 Express Chipset Family LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller (rev 04)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation GF106M [GeForce GTX 460M] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GF106 High Definition Audio Controller (rev a1)
08:00.0 FireWire (IEEE 1394): O2 Micro, Inc. 1394 OHCI Compliant Host Controller (rev 01)
08:00.1 SD Host controller: O2 Micro, Inc. Integrated MMC/SD Controller (rev 01)
08:00.2 Mass storage controller: O2 Micro, Inc. Integrated MS/MSPRO/xD Controller (rev 01)
0f:00.0 Ethernet controller: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet (rev c0)
lshw -short:
[code]Chemin matériel Périphérique Classe Description
system QOSMIO X500 (PQX34E-01V014FR)
/0 bus Base Board Product Name
/0/0 memory 1MiB BIOS
/0/19 memory 6GiB Mémoire Système
/0/19/0 memory 4GiB SODIMM DDR3 Synchrone 1333
/0/19/1 memory DIMMProject-Id-Version: @(#) $I
/0/19/2 memory 2GiB SODIMM DDR3 Synchrone 1333
/0/19/3 memory DIMMProject-Id-Version: @(#) $I
/0/2a processor Intel® Core™ i7-2630QM CPU
/0/2a/2c memory 32KiB L1 cache
/0/2a/2d memory 256KiB L2 cache
/0/2a/2e memory 6MiB L3 cache
/0/2b memory 32KiB L1 cache
/0/100 bridge 2nd Generation Core Processor F
/0/100/1 bridge Xeon E3-1200/2nd Generation Cor
/0/100/1/0 display GF106M [GeForce GTX 460M]
/0/100/1/0.1 multimedia GF106 High Definition Audio Con
/0/100/16 communication 6 Series/C200 Series Chipset Fa
/0/100/1a bus 6 Series/C200 Series Chipset Fa
/0/100/1b multimedia 6 Series/C200 Series Chipset Fa
/0/100/1c bridge 6 Series/C200 Series Chipset Fa
/0/100/1c.3 bridge 6 Series/C200 Series Chipset Fa
/0/100/1c.3/0 bus 1394 OHCI Compliant Host Contro
/0/100/1c.3/0.1 generic Integrated MMC/SD Controller
/0/100/1c.3/0.2 storage Integrated MS/MSPRO/xD Controll
/0/100/1c.4 bridge 6 Series/C200 Series Chipset Fa
/0/100/1c.6 bridge 6 Series/C200 Series Chipset Fa
/0/100/1c.6/0 eth0 network AR8151 v2.0 Gigabit Ethernet
/0/100/1d bus 6 Series/C200 Series Chipset Fa
/0/100/1f bridge HM65 Express Chipset Family LPC
/0/100/1f.2 storage 6 Series/C200 Series Chipset Fa
/0/100/1f.3 bus 6 Series/C200 Series Chipset Fa
/0/1 scsi0 storage
/0/1/0.0.0 /dev/sda disk 640GB TOSHIBA MK6461GS
/0/1/0.0.0/1 /dev/sda1 volume 9999MiB Linux swap volume
/0/1/0.0.0/2 /dev/sda2 volume 146GiB Extended partition
/0/1/0.0.0/2/5 /dev/sda5 volume 28GiB Linux filesystem partitio
/0/1/0.0.0/2/6 /dev/sda6 volume 118GiB Linux filesystem partiti
/0/1/0.0.0/4 /dev/sda4 volume 439GiB Windows NTFS volume
/0/2 scsi1 storage
/0/2/0.0.0 /dev/sdb disk 640GB TOSHIBA MK6461GS
/0/2/0.0.0/1 /dev/sdb1 volume 195GiB Windows NTFS volume
/0/3 scsi4 storage
/0/3/0.0.0 /dev/cdrom disk CDDVDW TS-L633C
/0/3/0.0.0/0 /dev/cdrom disk
/0/3/0.0.0/0/2 volume 15EiB Windows FAT volume
/0/4 scsi6 storage
/0/4/0.0.0 /dev/sdc disk 1TB Elements 1042
/0/4/0.0.0/1 /dev/sdc1 volume 931GiB Windows NTFS volume
/1 power OEM_Define5
/2 power CRB Battery 0
Ce n’est pas non plus un probleme de driver, ma carte wifi est une realtek et j’ai bien le firmware-realtek pour jessie d’installé…
Donc voila, vous pensez que c’est un probleme logiciel ou bien c’est simplement ma carte wifi qui a grillée ?
Merci d’avance,
