PascalHambourg merci pour ta repense
Malheureusement je ne sais pas recompiler ni module ni le noyau
quand j ai utiliser
ifconfig -a
[code]eth0 Link encap:Ethernet HWaddr 00:19:66:89:46:75
Interruption:248 Adresse de base:0x8000
lo Link encap:Boucle locale
adr inet6: ::1/128 Scope:Hôte
RX packets:45 errors:0 dropped:0 overruns:0 frame:0
TX packets:45 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:19789 (19.3 KiB) TX bytes:19789 (19.3 KiB)
wlan0 Link encap:Ethernet HWaddr 00:23:cd:b7:70:f9
wmaster0 Link encap:UNSPEC HWaddr 00-23-CD-B7-70-F9-00-00-00-00-00-00-00-00-00-00
lsmod:
[code]Module Size Used by
nls_utf8 6272 1
nls_cp437 11136 1
vfat 14976 1
fat 51128 1 vfat
nls_base 12932 4 nls_utf8,nls_cp437,vfat,fat
nvidia 8105072 24
i2c_core 27936 1 nvidia
ppdev 11656 0
lp 14724 0
ipv6 288456 25
powernow_k8 17156 0
cpufreq_userspace 8452 0
cpufreq_powersave 6400 0
cpufreq_ondemand 11792 1
cpufreq_stats 9120 0
freq_table 9344 3 powernow_k8,cpufreq_ondemand,cpufreq_stats
cpufreq_conservative 11784 0
loop 19468 0
sd_mod 29376 2
irtty_sir 9728 0
sir_dev 16904 1 irtty_sir
parport_pc 31016 1
parport 41776 3 ppdev,lp,parport_pc
irda 117732 1 sir_dev
arc4 6272 2
ecb 7296 2
crypto_blkcipher 21636 1 ecb
k8temp 9216 0
crc_ccitt 6528 1 irda
pcspkr 7040 0
snd_hda_intel 436696 1
snd_pcm 81800 1 snd_hda_intel
snd_seq 54304 0
snd_timer 25744 2 snd_pcm,snd_seq
snd_seq_device 11668 1 snd_seq
snd 63688 7 snd_hda_intel,snd_pcm,snd_seq,snd_timer,snd_seq_device
soundcore 12064 1 snd
snd_page_alloc 13072 2 snd_hda_intel,snd_pcm
zd1211rw 49928 0
firmware_class 12544 1 zd1211rw
mac80211 162992 1 zd1211rw
cfg80211 30224 1 mac80211
wmi 11712 0
button 11680 0
evdev 14208 3
ext3 125072 1
jbd 51240 1 ext3
mbcache 12804 1 ext3
usbhid 45792 0
hid 41792 1 usbhid
ff_memless 9224 1 usbhid
ide_disk 16512 3
ide_cd_mod 36360 0
cdrom 37928 1 ide_cd_mod
usb_storage 95936 1
amd74xx 13448 0 [permanent]
ide_pci_generic 9220 0 [permanent]
ide_core 128284 4 ide_disk,ide_cd_mod,amd74xx,ide_pci_generic
forcedeth 54032 0
ata_generic 10116 0
libata 165600 1 ata_generic
scsi_mod 161016 3 sd_mod,usb_storage,libata
dock 14112 1 libata
ehci_hcd 36108 0
ohci_hcd 25092 0
thermal 22688 0
processor 42304 2 powernow_k8,thermal
fan 9352 0
thermal_sys 17728 3 thermal,processor,fan
dmesg:
[code][ 0.220171] pnp 00:04: io min 0x2e8 max 0x2e8 align 1 size 8 flags 0x1
[ 0.220175] pnp 00:04: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1
[ 0.220178] pnp 00:04: dma bitmask 0xf flags 0x0
[ 0.220180] pnp 00:04: end dependent options
[ 0.220222] pnp 00:04: Plug and Play ACPI device, IDs PNP0510 (active)
[ 0.220747] pnp 00:05: parse allocated resources
[ 0.221327] pnp 00:05: add io 0x378-0x37f flags 0x1
[ 0.221329] pnp 00:05: add io 0x778-0x77f flags 0x1
[ 0.221337] pnp 00:05: add irq 7 flags 0x1
[ 0.221339] pnp 00:05: add dma 3 flags 0x0
[ 0.221341] pnp 00:05: parse resource options
[ 0.221343] pnp 00:05: new independent option
[ 0.221569] pnp 00:05: new dependent option (priority 0x0)
[ 0.221571] pnp 00:05: io min 0x378 max 0x378 align 1 size 8 flags 0x1
[ 0.221574] pnp 00:05: io min 0x778 max 0x778 align 1 size 8 flags 0x1
[ 0.221579] pnp 00:05: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000080 flags 0x1
[ 0.221582] pnp 00:05: dma bitmask 0x8 flags 0x0
[ 0.221584] pnp 00:05: new dependent option (priority 0x1)
[ 0.221587] pnp 00:05: io min 0x378 max 0x378 align 1 size 8 flags 0x1
[ 0.221590] pnp 00:05: io min 0x778 max 0x778 align 1 size 8 flags 0x1
[ 0.221594] pnp 00:05: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1
[ 0.221598] pnp 00:05: dma bitmask 0xf flags 0x0
[ 0.221600] pnp 00:05: new dependent option (priority 0x1)
[ 0.221602] pnp 00:05: io min 0x278 max 0x278 align 1 size 8 flags 0x1
[ 0.221605] pnp 00:05: io min 0x678 max 0x678 align 1 size 8 flags 0x1
[ 0.221610] pnp 00:05: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1
[ 0.221613] pnp 00:05: dma bitmask 0xf flags 0x0
[ 0.221615] pnp 00:05: new dependent option (priority 0x1)
[ 0.221617] pnp 00:05: io min 0x3bc max 0x3bc align 1 size 4 flags 0x1
[ 0.221620] pnp 00:05: io min 0x7bc max 0x7bc align 1 size 4 flags 0x1
[ 0.221625] pnp 00:05: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1
[ 0.221628] pnp 00:05: dma bitmask 0xf flags 0x0
[ 0.221630] pnp 00:05: end dependent options
[ 0.221670] pnp 00:05: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.221687] pnp 00:06: parse allocated resources
[ 0.222344] pnp 00:06: add io 0x10-0x1f flags 0x1
[ 0.222346] pnp 00:06: add io 0x22-0x3f flags 0x1
[ 0.222348] pnp 00:06: add io 0x44-0x4d flags 0x1
[ 0.222350] pnp 00:06: add io 0x50-0x5f flags 0x1
[ 0.222353] pnp 00:06: add io 0x62-0x63 flags 0x1
[ 0.222355] pnp 00:06: add io 0x65-0x6f flags 0x1
[ 0.222357] pnp 00:06: add io 0x72-0x7f flags 0x1
[ 0.222359] pnp 00:06: add io 0x80-0x80 flags 0x1
[ 0.222361] pnp 00:06: add io 0x84-0x86 flags 0x1
[ 0.222363] pnp 00:06: add io 0x88-0x88 flags 0x1
[ 0.222365] pnp 00:06: add io 0x8c-0x8e flags 0x1
[ 0.222368] pnp 00:06: add io 0x90-0x9f flags 0x1
[ 0.222370] pnp 00:06: add io 0xa2-0xbf flags 0x1
[ 0.222372] pnp 00:06: add io 0xe0-0xef flags 0x1
[ 0.222374] pnp 00:06: add io 0x4d0-0x4d1 flags 0x1
[ 0.222376] pnp 00:06: add io 0x800-0x80f flags 0x1
[ 0.222379] pnp 00:06: add io 0x1000-0x107f flags 0x1
[ 0.222381] pnp 00:06: add io 0x1080-0x10ff flags 0x1
[ 0.222383] pnp 00:06: add io 0x1400-0x147f flags 0x1
[ 0.222386] pnp 00:06: add io 0x1480-0x14ff flags 0x1
[ 0.222388] pnp 00:06: add io 0x1800-0x187f flags 0x1
[ 0.222390] pnp 00:06: add io 0x1880-0x18ff flags 0x1
[ 0.222393] pnp 00:06: add io 0x1c00-0x1c7f flags 0x1
[ 0.222395] pnp 00:06: add io 0x1c80-0x1cff flags 0x1
[ 0.222397] pnp 00:06: add mem 0x0-0xffffffffffffffff flags 0x10000000
[ 0.222400] pnp 00:06: add mem 0xfefe0000-0xfefe01ff flags 0x0
[ 0.222402] pnp 00:06: add mem 0xfefe1000-0xfefe1fff flags 0x0
[ 0.222405] pnp 00:06: add mem 0xfee01000-0xfeefffff flags 0x0
[ 0.222408] pnp 00:06: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c
[ 0.222491] pnp 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.222594] pnp 00:07: parse allocated resources
[ 0.222638] pnp 00:07: add io 0x70-0x71 flags 0x1
[ 0.222646] pnp 00:07: add irq 8 flags 0x1
[ 0.222687] pnp 00:07: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.222705] pnp 00:08: parse allocated resources
[ 0.222797] pnp 00:08: add mem 0xfec00000-0xfec00fff flags 0x0
[ 0.222799] pnp 00:08: add mem 0xfee00000-0xfee00fff flags 0x0
[ 0.222802] pnp 00:08: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c
[ 0.222866] pnp 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.222928] pnp 00:09: parse allocated resources
[ 0.222934] pnp 00:09: add io 0x60-0x60 flags 0x1
[ 0.222936] pnp 00:09: add io 0x64-0x64 flags 0x1
[ 0.222944] pnp 00:09: add irq 1 flags 0x1
[ 0.222986] pnp 00:09: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.223297] pnp 00:0a: parse allocated resources
[ 0.223604] pnp 00:0a: add io 0x3f8-0x3ff flags 0x1
[ 0.223612] pnp 00:0a: add irq 4 flags 0x1
[ 0.223614] pnp 00:0a: parse resource options
[ 0.223616] pnp 00:0a: new independent option
[ 0.223653] pnp 00:0a: new dependent option (priority 0x0)
[ 0.223655] pnp 00:0a: io min 0x3f8 max 0x3f8 align 1 size 8 flags 0x1
[ 0.223660] pnp 00:0a: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000010 flags 0x1
[ 0.223663] pnp 00:0a: new dependent option (priority 0x1)
[ 0.223666] pnp 00:0a: io min 0x3f8 max 0x3f8 align 1 size 8 flags 0x1
[ 0.223671] pnp 00:0a: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1
[ 0.223674] pnp 00:0a: new dependent option (priority 0x1)
[ 0.223677] pnp 00:0a: io min 0x2f8 max 0x2f8 align 1 size 8 flags 0x1
[ 0.223681] pnp 00:0a: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1
[ 0.223684] pnp 00:0a: new dependent option (priority 0x1)
[ 0.223687] pnp 00:0a: io min 0x3e8 max 0x3e8 align 1 size 8 flags 0x1
[ 0.223691] pnp 00:0a: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1
[ 0.223694] pnp 00:0a: new dependent option (priority 0x1)
[ 0.223697] pnp 00:0a: io min 0x2e8 max 0x2e8 align 1 size 8 flags 0x1
[ 0.223701] pnp 00:0a: irq bitmask 00000000,00000000,00000000,00000000,00000000,00000000,00000000,00001cf8 flags 0x1
[ 0.223704] pnp 00:0a: end dependent options
[ 0.223748] pnp 00:0a: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.223766] pnp 00:0b: parse allocated resources
[ 0.223886] pnp 00:0b: add io 0x0-0xffffffffffffffff flags 0x10000001
[ 0.223889] pnp 00:0b: add io 0x0-0xffffffffffffffff flags 0x10000001
[ 0.223891] pnp 00:0b: add io 0x290-0x29f flags 0x1
[ 0.223894] pnp 00:0b: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c
[ 0.223959] pnp 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.224034] pnp 00:0c: parse allocated resources
[ 0.224100] pnp 00:0c: add mem 0xe0000000-0xefffffff flags 0x0
[ 0.224103] pnp 00:0c: PNP0c02: calling quirk_system_pci_resources+0x0/0x15c
[ 0.224167] pnp 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.224234] pnp 00:0d: parse allocated resources
[ 0.224449] pnp 00:0d: add mem 0x0-0x9ffff flags 0x1
[ 0.224451] pnp 00:0d: add mem 0xc0000-0xcffff flags 0x0
[ 0.224453] pnp 00:0d: add mem 0xe0000-0xfffff flags 0x0
[ 0.224456] pnp 00:0d: add mem 0x100000-0x7fffffff flags 0x1
[ 0.224458] pnp 00:0d: add mem 0xfec00000-0xffffffff flags 0x0
[ 0.224461] pnp 00:0d: PNP0c01: calling quirk_system_pci_resources+0x0/0x15c
[ 0.224529] pnp 00:0d: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.225780] pnp: PnP ACPI: found 14 devices
[ 0.225782] ACPI: ACPI bus type pnp unregistered
[ 0.225996] usbcore: registered new interface driver usbfs
[ 0.226056] usbcore: registered new interface driver hub
[ 0.226099] usbcore: registered new device driver usb
[ 0.226263] PCI: Using ACPI for IRQ routing
[ 0.236184] ACPI: RTC can wake from S4
[ 0.248022] pnp: the driver ‘system’ has been registered
[ 0.248037] system 00:06: ioport range 0x4d0-0x4d1 has been reserved
[ 0.248040] system 00:06: ioport range 0x800-0x80f has been reserved
[ 0.248043] system 00:06: ioport range 0x1000-0x107f has been reserved
[ 0.248045] system 00:06: ioport range 0x1080-0x10ff has been reserved
[ 0.248048] system 00:06: ioport range 0x1400-0x147f has been reserved
[ 0.248051] system 00:06: ioport range 0x1480-0x14ff has been reserved
[ 0.248054] system 00:06: ioport range 0x1800-0x187f has been reserved
[ 0.248057] system 00:06: ioport range 0x1880-0x18ff has been reserved
[ 0.248060] system 00:06: ioport range 0x1c00-0x1c7f has been reserved
[ 0.248063] system 00:06: ioport range 0x1c80-0x1cff has been reserved
[ 0.248066] system 00:06: iomem range 0xfefe0000-0xfefe01ff has been reserved
[ 0.248069] system 00:06: iomem range 0xfefe1000-0xfefe1fff has been reserved
[ 0.248072] system 00:06: iomem range 0xfee01000-0xfeefffff could not be reserved
[ 0.248075] system 00:06: driver attached
[ 0.248084] system 00:08: iomem range 0xfec00000-0xfec00fff could not be reserved
[ 0.248087] system 00:08: iomem range 0xfee00000-0xfee00fff could not be reserved
[ 0.248090] system 00:08: driver attached
[ 0.248096] system 00:0b: ioport range 0x290-0x29f has been reserved
[ 0.248101] system 00:0b: driver attached
[ 0.248108] system 00:0c: iomem range 0xe0000000-0xefffffff has been reserved
[ 0.248111] system 00:0c: driver attached
[ 0.248119] system 00:0d: iomem range 0x0-0x9ffff could not be reserved
[ 0.248122] system 00:0d: iomem range 0xc0000-0xcffff has been reserved
[ 0.248125] system 00:0d: iomem range 0xe0000-0xfffff could not be reserved
[ 0.248128] system 00:0d: iomem range 0x100000-0x7fffffff could not be reserved
[ 0.248131] system 00:0d: iomem range 0xfec00000-0xffffffff could not be reserved
[ 0.248133] system 00:0d: driver attached
[ 0.248538] PCI: Bridge: 0000:00:08.0
[ 0.248540] IO window: disabled.
[ 0.248544] MEM window: disabled.
[ 0.248546] PREFETCH window: disabled.
[ 0.248550] PCI: Bridge: 0000:00:0b.0
[ 0.248551] IO window: disabled.
[ 0.248553] MEM window: 0xfbf00000-0xfdffffff
[ 0.248556] PREFETCH window: 0x00000000d0000000-0x00000000dfffffff
[ 0.248559] PCI: Bridge: 0000:00:0c.0
[ 0.248560] IO window: disabled.
[ 0.248562] MEM window: disabled.
[ 0.248564] PREFETCH window: disabled.
[ 0.248567] PCI: Bridge: 0000:00:0d.0
[ 0.248568] IO window: disabled.
[ 0.248570] MEM window: disabled.
[ 0.248572] PREFETCH window: disabled.
[ 0.248575] PCI: Bridge: 0000:00:0e.0
[ 0.248576] IO window: disabled.
[ 0.248578] MEM window: disabled.
[ 0.248580] PREFETCH window: disabled.
[ 0.248582] PCI: Bridge: 0000:00:0f.0
[ 0.248584] IO window: disabled.
[ 0.248586] MEM window: disabled.
[ 0.248588] PREFETCH window: disabled.
[ 0.248590] PCI: Bridge: 0000:00:10.0
[ 0.248592] IO window: disabled.
[ 0.248594] MEM window: disabled.
[ 0.248596] PREFETCH window: disabled.
[ 0.248598] PCI: Bridge: 0000:00:11.0
[ 0.248600] IO window: disabled.
[ 0.248602] MEM window: disabled.
[ 0.248604] PREFETCH window: disabled.
[ 0.248614] PCI: Setting latency timer of device 0000:00:08.0 to 64
[ 0.248624] PCI: Setting latency timer of device 0000:00:0b.0 to 64
[ 0.248631] PCI: Setting latency timer of device 0000:00:0c.0 to 64
[ 0.248637] PCI: Setting latency timer of device 0000:00:0d.0 to 64
[ 0.248644] PCI: Setting latency timer of device 0000:00:0e.0 to 64
[ 0.248650] PCI: Setting latency timer of device 0000:00:0f.0 to 64
[ 0.248656] PCI: Setting latency timer of device 0000:00:10.0 to 64
[ 0.248662] PCI: Setting latency timer of device 0000:00:11.0 to 64
[ 0.248691] NET: Registered protocol family 2
[ 0.284135] IP route cache hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.285261] TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
[ 0.290510] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.291775] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.291779] TCP reno registered
[ 0.300145] NET: Registered protocol family 1
[ 0.300271] checking if image is initramfs… it is
[ 0.752027] Switched to high resolution mode on CPU 0
[ 0.752164] Freeing initrd memory: 6537k freed
[ 0.760718] audit: initializing netlink socket (disabled)
[ 0.760738] type=2000 audit(1255418227.760:1): initialized
[ 0.760958] Total HugeTLB memory allocated, 0
[ 0.761066] VFS: Disk quotas dquot_6.5.1
[ 0.761098] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.761145] msgmni has been set to 4029
[ 0.761253] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.761256] io scheduler noop registered
[ 0.761259] io scheduler anticipatory registered
[ 0.761261] io scheduler deadline registered
[ 0.761271] io scheduler cfq registered (default)
[ 0.761302] pci 0000:00:00.0: Enabling HT MSI Mapping
[ 0.809616] pci 0000:00:07.0: Enabling HT MSI Mapping
[ 0.809631] pci 0000:00:08.0: Enabling HT MSI Mapping
[ 0.809647] pci 0000:00:0a.0: Enabling HT MSI Mapping
[ 0.809661] pci 0000:00:0b.0: Enabling HT MSI Mapping
[ 0.809675] pci 0000:00:0c.0: Enabling HT MSI Mapping
[ 0.809690] pci 0000:00:0d.0: Enabling HT MSI Mapping
[ 0.809704] pci 0000:00:0e.0: Enabling HT MSI Mapping
[ 0.809719] pci 0000:00:0f.0: Enabling HT MSI Mapping
[ 0.809734] pci 0000:00:10.0: Enabling HT MSI Mapping
[ 0.809748] pci 0000:00:11.0: Enabling HT MSI Mapping
[ 0.809771] pci 0000:02:00.0: Boot video device
[ 0.809888] PCI: Setting latency timer of device 0000:00:0b.0 to 64
[ 0.809908] assign_interrupt_mode Found MSI capability
[ 0.809929] Allocate Port Service[0000:00:0b.0:pcie00]
[ 0.809970] Allocate Port Service[0000:00:0b.0:pcie03]
[ 0.810029] PCI: Setting latency timer of device 0000:00:0c.0 to 64
[ 0.810046] assign_interrupt_mode Found MSI capability
[ 0.810061] Allocate Port Service[0000:00:0c.0:pcie00]
[ 0.810094] Allocate Port Service[0000:00:0c.0:pcie03]
[ 0.810151] PCI: Setting latency timer of device 0000:00:0d.0 to 64
[ 0.810169] assign_interrupt_mode Found MSI capability
[ 0.810183] Allocate Port Service[0000:00:0d.0:pcie00]
[ 0.810217] Allocate Port Service[0000:00:0d.0:pcie03]
[ 0.810273] PCI: Setting latency timer of device 0000:00:0e.0 to 64
[ 0.810291] assign_interrupt_mode Found MSI capability
[ 0.810305] Allocate Port Service[0000:00:0e.0:pcie00]
[ 0.810340] Allocate Port Service[0000:00:0e.0:pcie03]
[ 0.810399] PCI: Setting latency timer of device 0000:00:0f.0 to 64
[ 0.810416] assign_interrupt_mode Found MSI capability
[ 0.810430] Allocate Port Service[0000:00:0f.0:pcie00]
[ 0.810465] Allocate Port Service[0000:00:0f.0:pcie03]
[ 0.810521] PCI: Setting latency timer of device 0000:00:10.0 to 64
[ 0.810538] assign_interrupt_mode Found MSI capability
[ 0.810552] Allocate Port Service[0000:00:10.0:pcie00]
[ 0.810586] Allocate Port Service[0000:00:10.0:pcie03]
[ 0.810642] PCI: Setting latency timer of device 0000:00:11.0 to 64
[ 0.810659] assign_interrupt_mode Found MSI capability
[ 0.810674] Allocate Port Service[0000:00:11.0:pcie00]
[ 0.810709] Allocate Port Service[0000:00:11.0:pcie03]
[ 0.812105] Linux agpgart interface v0.103
[ 0.812109] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 0.812258] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.812368] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.812530] pnp: the driver ‘serial’ has been registered
[ 0.812718] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.812758] serial 00:0a: driver attached
[ 0.814197] brd: module loaded
[ 0.814277] input: Macintosh mouse button emulation as /class/input/input0
[ 0.814378] pnp: the driver ‘i8042 kbd’ has been registered
[ 0.814394] i8042 kbd 00:09: driver attached
[ 0.814425] pnp: the driver ‘i8042 aux’ has been registered
[ 0.814462] PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 0.814464] PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.814907] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.820332] mice: PS/2 mouse device common for all mice
[ 0.820371] pnp: the driver ‘rtc_cmos’ has been registered
[ 0.820450] rtc_cmos 00:07: rtc core: registered rtc_cmos as rtc0
[ 0.820475] rtc0: alarms up to one year, y3k
[ 0.820477] rtc_cmos 00:07: driver attached
[ 0.820505] cpuidle: using governor ladder
[ 0.820507] cpuidle: using governor menu
[ 0.820513] No iBFT detected.
[ 0.820928] TCP cubic registered
[ 0.820931] NET: Registered protocol family 17
[ 0.821053] registered taskstats version 1
[ 0.821257] rtc_cmos 00:07: setting system clock to 2009-10-13 07:17:08 UTC (1255418228)
[ 0.821267] Freeing unused kernel memory: 392k freed
[ 0.839374] input: AT Translated Set 2 keyboard as /class/input/input1
[ 0.913464] ACPI: ACPI0007:00 is registered as cooling_device0
[ 1.520658] ohci_hcd: 2006 August 04 USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.521111] ACPI: PCI Interrupt Link [LUB0] enabled at IRQ 23
[ 1.521122] ACPI: PCI Interrupt 0000:00:02.0[A] -> Link [LUB0] -> GSI 23 (level, low) -> IRQ 23
[ 1.521141] PCI: Setting latency timer of device 0000:00:02.0 to 64
[ 1.521144] ohci_hcd 0000:00:02.0: OHCI Host Controller
[ 1.521309] ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 1
[ 1.521333] ohci_hcd 0000:00:02.0: irq 23, io mem 0xfbe7f000
[ 1.578159] usb usb1: configuration #1 chosen from 1 choice
[ 1.578194] hub 1-0:1.0: USB hub found
[ 1.578208] hub 1-0:1.0: 6 ports detected
[ 1.578378] No dock devices found.
[ 1.595915] SCSI subsystem initialized
[ 1.610860] libata version 3.00 loaded.
[ 1.680210] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.680215] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.680218] usb usb1: Product: OHCI Host Controller
[ 1.680220] usb usb1: Manufacturer: Linux 2.6.26-2-amd64 ohci_hcd
[ 1.680222] usb usb1: SerialNumber: 0000:00:02.0
[ 1.680714] ACPI: PCI Interrupt Link [UB11] enabled at IRQ 22
[ 1.680726] ACPI: PCI Interrupt 0000:00:04.0[A] -> Link [UB11] -> GSI 22 (level, low) -> IRQ 22
[ 1.680746] PCI: Setting latency timer of device 0000:00:04.0 to 64
[ 1.680749] ohci_hcd 0000:00:04.0: OHCI Host Controller
[ 1.680810] ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 2
[ 1.680836] ohci_hcd 0000:00:04.0: irq 22, io mem 0xfbe7d000
[ 1.738160] usb usb2: configuration #1 chosen from 1 choice
[ 1.738199] hub 2-0:1.0: USB hub found
[ 1.738212] hub 2-0:1.0: 6 ports detected
[ 1.840133] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.840137] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.840140] usb usb2: Product: OHCI Host Controller
[ 1.840142] usb usb2: Manufacturer: Linux 2.6.26-2-amd64 ohci_hcd
[ 1.840144] usb usb2: SerialNumber: 0000:00:04.0
[ 1.840638] ACPI: PCI Interrupt Link [LUB2] enabled at IRQ 21
[ 1.840650] ACPI: PCI Interrupt 0000:00:02.1[B] -> Link [LUB2] -> GSI 21 (level, low) -> IRQ 21
[ 1.840668] PCI: Setting latency timer of device 0000:00:02.1 to 64
[ 1.840671] ehci_hcd 0000:00:02.1: EHCI Host Controller
[ 1.840730] ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 3
[ 1.840767] ehci_hcd 0000:00:02.1: debug port 1
[ 1.840771] PCI: cache line size of 64 is not supported by device 0000:00:02.1
[ 1.840787] ehci_hcd 0000:00:02.1: irq 21, io mem 0xfbe7ec00
[ 1.984008] usb 1-1: new full speed USB device using ohci_hcd and address 2
[ 1.996006] ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 1.996081] usb usb3: configuration #1 chosen from 1 choice
[ 1.996114] hub 3-0:1.0: USB hub found
[ 1.996124] hub 3-0:1.0: 6 ports detected
[ 2.052015] hub 1-0:1.0: unable to enumerate USB device on port 1
[ 2.100084] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.100087] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.100089] usb usb3: Product: EHCI Host Controller
[ 2.100091] usb usb3: Manufacturer: Linux 2.6.26-2-amd64 ehci_hcd
[ 2.100093] usb usb3: SerialNumber: 0000:00:02.1
[ 2.100509] ACPI: PCI Interrupt Link [UB12] enabled at IRQ 20
[ 2.100517] ACPI: PCI Interrupt 0000:00:04.1[B] -> Link [UB12] -> GSI 20 (level, low) -> IRQ 20
[ 2.100531] PCI: Setting latency timer of device 0000:00:04.1 to 64
[ 2.100534] ehci_hcd 0000:00:04.1: EHCI Host Controller
[ 2.100582] ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 4
[ 2.100616] ehci_hcd 0000:00:04.1: debug port 1
[ 2.100619] PCI: cache line size of 64 is not supported by device 0000:00:04.1
[ 2.100632] ehci_hcd 0000:00:04.1: irq 20, io mem 0xfbe7e800
[ 2.112008] ehci_hcd 0000:00:04.1: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 2.112080] usb usb4: configuration #1 chosen from 1 choice
[ 2.112110] hub 4-0:1.0: USB hub found
[ 2.112120] hub 4-0:1.0: 6 ports detected
[ 2.216084] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.216087] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.216089] usb usb4: Product: EHCI Host Controller
[ 2.216091] usb usb4: Manufacturer: Linux 2.6.26-2-amd64 ehci_hcd
[ 2.216093] usb usb4: SerialNumber: 0000:00:04.1
[ 2.216160] forcedeth: Reverse Engineered nForce ethernet driver. Version 0.61.
[ 2.216539] ACPI: PCI Interrupt Link [LMAC] enabled at IRQ 23
[ 2.216542] ACPI: PCI Interrupt 0000:00:0a.0[A] -> Link [LMAC] -> GSI 23 (level, low) -> IRQ 23
[ 2.216547] PCI: Setting latency timer of device 0000:00:0a.0 to 64
[ 2.612007] usb 3-1: new high speed USB device using ehci_hcd and address 2
[ 2.736836] forcedeth 0000:00:0a.0: ifname eth0, PHY OUI 0x732 @ 1, addr 00:19:66:89:46:75
[ 2.736840] forcedeth 0000:00:0a.0: highdma pwrctl mgmt timirq gbit lnktim msi desc-v3
[ 2.743233] Uniform Multi-Platform E-IDE driver
[ 2.743239] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 2.744749] NFORCE-MCP67: 0000:00:06.0 (rev a1) UDMA133 controller
[ 2.744754] NFORCE-MCP67: IDE controller (0x10de:0x0560 rev 0xa1) at PCI slot 0000:00:06.0
[ 2.744783] NFORCE-MCP67: not 100% native mode: will probe irqs later
[ 2.744788] NFORCE-MCP67: BIOS didn’t set cable bits correctly. Enabling workaround.
[ 2.744794] NFORCE-MCP67: IDE port disabled
[ 2.744800] ide0: BM-DMA at 0xffa0-0xffa7
[ 2.744807] Probing IDE interface ide0…
[ 2.755508] usb 3-1: configuration #1 chosen from 1 choice
[ 2.755858] usb 3-1: New USB device found, idVendor=0ace, idProduct=1215
[ 2.755861] usb 3-1: New USB device strings: Mfr=16, Product=32, SerialNumber=0
[ 2.755863] usb 3-1: Product: USB2.0 WLAN
[ 2.755865] usb 3-1: Manufacturer: ZyDAS
[ 2.992016] usb 3-4: new high speed USB device using ehci_hcd and address 3
[ 3.135119] usb 3-4: configuration #1 chosen from 1 choice
[ 3.135316] usb 3-4: New USB device found, idVendor=1005, idProduct=b113
[ 3.135318] usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 3.135321] usb 3-4: Product: USB FLASH DRIVE
[ 3.135322] usb 3-4: Manufacturer:
[ 3.135324] usb 3-4: SerialNumber: 199617815025
[ 3.144136] hda: TSSTcorp CDDVDW SH-S202J, ATAPI CD/DVD-ROM drive
[ 3.157888] Initializing USB Mass Storage driver…
[ 3.316130] scsi0 : SCSI emulation for USB Mass Storage devices
[ 3.316475] usbcore: registered new interface driver usb-storage
[ 3.316479] USB Mass Storage support registered.
[ 3.318677] usb-storage: device found at 3
[ 3.318682] usb-storage: waiting for device to settle before scanning
[ 3.424102] hdb: Maxtor 4R080L0, ATA DISK drive
[ 3.480059] hda: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 3.480232] hda: drive side 80-wire cable detection failed, limiting max speed to UDMA33
[ 3.480235] hda: UDMA/33 mode selected
[ 3.480456] hdb: host max PIO5 wanted PIO255(auto-tune) selected PIO4
[ 3.480596] hdb: UDMA/133 mode selected
[ 3.480754] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 3.480793] isa bounce pool size: 16 pages
[ 3.532201] hda: ATAPI 48X DVD-ROM DVD-R-RAM CD-R/RW drive, 2048kB Cache
[ 3.532209] Uniform CD-ROM driver Revision: 3.20
[ 3.534624] hdb: max request size: 128KiB
[ 3.535232] hdb: 160086528 sectors (81964 MB) w/2048KiB Cache, CHS=65535/16/63
[ 3.535377] hdb: cache flushes supported
[ 3.535425] hdb: hdb1 hdb2 hdb3 < hdb5 >
[ 3.620044] usb 2-1: new low speed USB device using ohci_hcd and address 2
[ 3.834116] usb 2-1: configuration #1 chosen from 1 choice
[ 3.837218] usb 2-1: New USB device found, idVendor=1241, idProduct=1111
[ 3.837222] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.859466] usbcore: registered new interface driver hiddev
[ 3.870402] input: HID 1241:1111 as /class/input/input2
[ 3.876074] input,hidraw0: USB HID v1.10 Mouse [HID 1241:1111] on usb-0000:00:04.0-1
[ 3.876096] usbcore: registered new interface driver usbhid
[ 3.876099] usbhid: v2.6:USB HID core driver
[ 4.077583] PM: Starting manual resume from disk
[ 4.150277] kjournald starting. Commit interval 5 seconds
[ 4.150277] EXT3-fs: mounted filesystem with ordered data mode.
[ 6.403662] udevd version 125 started
[ 7.738600] input: Power Button (FF) as /class/input/input3
[ 7.764091] ACPI: Power Button (FF) [PWRF]
[ 7.764206] input: Power Button (CM) as /class/input/input4
[ 7.792103] ACPI: Power Button (CM) [PWRB]
[ 8.316231] usb-storage: device scan complete
[ 8.318086] scsi 0:0:0:0: Direct-Access USB FLASH DRIVE PMAP PQ: 0 ANSI: 0 CCS
[ 8.390969] ACPI: WMI: Mapper loaded
[ 8.664036] usb 3-1: reset high speed USB device using ehci_hcd and address 2
[ 8.797803] phy0: Selected rate control algorithm ‘pid’
[ 8.879464] ACPI: PCI Interrupt Link [LAZA] enabled at IRQ 22
[ 8.879470] ACPI: PCI Interrupt 0000:00:07.0[A] -> Link [LAZA] -> GSI 22 (level, low) -> IRQ 22
[ 8.879497] PCI: Setting latency timer of device 0000:00:07.0 to 64
[ 8.912164] hda_codec: Unknown model for ALC662, trying auto-probe from BIOS…
[ 9.108178] input: PC Speaker as /class/input/input5
[ 9.209074] zd1211rw 3-1:1.0: phy0
[ 9.209099] usbcore: registered new interface driver zd1211rw
[ 9.224814] NET: Registered protocol family 23
[ 9.246548] pnp: the driver ‘parport_pc’ has been registered
[ 9.246570] parport_pc 00:05: reported by Plug and Play ACPI
[ 9.246624] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 9.340174] parport_pc 00:05: driver attached
[ 9.377617] Driver ‘sd’ needs updating - please use bus_type methods
[ 10.749056] sd 0:0:0:0: [sda] 7831552 512-byte hardware sectors (4010 MB)
[ 10.751920] sd 0:0:0:0: [sda] Write Protect is off
[ 10.751923] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 10.751926] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 10.762046] sd 0:0:0:0: [sda] 7831552 512-byte hardware sectors (4010 MB)
[ 10.764923] sd 0:0:0:0: [sda] Write Protect is off
[ 10.764926] sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00
[ 10.764928] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 10.764965] sda: sda1
[ 10.767151] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 12.052001] Adding 1839400k swap on /dev/hdb5. Priority:-1 extents:1 across:1839400k
[ 12.666905] EXT3 FS on hdb2, internal journal
[ 13.113452] loop: module loaded
[ 15.140336] eth0: no link during initialization.
[ 16.785866] powernow-k8: Found 1 AMD Athlon™ 64 Processor 3200+ processors (1 cpu cores) (version 2.20.00)
[ 16.785915] powernow-k8: 0 : fid 0xe (2200 MHz), vid 0x2
[ 16.785917] powernow-k8: 1 : fid 0xc (2000 MHz), vid 0x6
[ 16.785919] powernow-k8: 2 : fid 0xa (1800 MHz), vid 0xa
[ 16.785922] powernow-k8: 3 : fid 0x2 (1000 MHz), vid 0x12
[ 18.091946] NET: Registered protocol family 10
[ 18.092513] lo: Disabled Privacy Extensions
[ 18.093188] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.272109] Marking TSC unstable due to cpufreq changes
[ 18.748016] Clocksource tsc unstable (delta = -262239479 ns)
[ 28.580526] lp0: using parport0 (interrupt-driven).
[ 28.625717] ppdev: user-space parallel port driver
[ 34.949750] firmware: requesting zd1211/zd1211b_ub
[ 35.020098] usb 3-1: Could not load firmware file zd1211/zd1211b_ub. Error number -2
[ 35.020127] zd1211rw 3-1:1.0: couldn’t load firmware. Error number -2
[ 37.720541] firmware: requesting zd1211/zd1211b_ub
[ 37.733177] usb 3-1: Could not load firmware file zd1211/zd1211b_ub. Error number -2
[ 37.733186] zd1211rw 3-1:1.0: couldn’t load firmware. Error number -2
[ 42.137293] nvidia: module license ‘NVIDIA’ taints kernel.
[ 42.404626] ACPI: PCI Interrupt Link [LNEB] enabled at IRQ 19
[ 42.404635] ACPI: PCI Interrupt 0000:02:00.0[A] -> Link [LNEB] -> GSI 19 (level, low) -> IRQ 19
[ 42.404643] PCI: Setting latency timer of device 0000:02:00.0 to 64
[ 42.404812] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 173.14.09 Wed Jun 4 23:40:50 PDT 2008
[ 54.788144] firmware: requesting zd1211/zd1211b_ub
[ 54.800614] usb 3-1: Could not load firmware file zd1211/zd1211b_ub. Error number -2
[ 54.800622] zd1211rw 3-1:1.0: couldn’t load firmware. Error number -2
[ 68.051210] FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 71.828233] firmware: requesting zd1211/zd1211b_ub
[ 71.836223] usb 3-1: Could not load firmware file zd1211/zd1211b_ub. Error number -2
[ 71.836235] zd1211rw 3-1:1.0: couldn’t load firmware. Error number -2
[ 88.892140] firmware: requesting zd1211/zd1211b_ub
[ 88.904659] usb 3-1: Could not load firmware file zd1211/zd1211b_ub. Error number -2
[ 88.904668] zd1211rw 3-1:1.0: couldn’t load firmware. Error number -2
[ 105.972152] firmware: requesting zd1211/zd1211b_ub
[ 105.984679] usb 3-1: Could not load firmware file zd1211/zd1211b_ub. Error number -2
[ 105.984688] zd1211rw 3-1:1.0: couldn’t load firmware. Error number -2
[ 123.008144] firmware: requesting zd1211/zd1211b_ub
[ 123.020813] usb 3-1: Could not load firmware file zd1211/zd1211b_ub. Error number -2
[ 123.020821] zd1211rw 3-1:1.0: couldn’t load firmware. Error number -2
[ 140.064165] firmware: requesting zd1211/zd1211b_ub
[ 140.076882] usb 3-1: Could not load firmware file zd1211/zd1211b_ub. Error number -2
[ 140.076890] zd1211rw 3-1:1.0: couldn’t load firmware. Error number -2
[ 157.104187] firmware: requesting zd1211/zd1211b_ub
[ 157.116952] usb 3-1: Could not load firmware file zd1211/zd1211b_ub. Error number -2
[ 157.116960] zd1211rw 3-1:1.0: couldn’t load firmware. Error number -2
[ 279.144146] firmware: requesting zd1211/zd1211b_ub
[ 279.156704] usb 3-1: Could not load firmware file zd1211/zd1211b_ub. Error number -2
[ 279.156709] zd1211rw 3-1:1.0: couldn’t load firmware. Error number -2
