Sur une machine (disque chiffré mais une autre n’a pas eu ce probleme), j’ai le problème chkboot suivant:
~$ su -
Mot de passe :
CHKBOOT ALERT!
Changes have been detected in your boot files!
The following list of files contained in have changed since the last time this script was run (filename sha512):
List of changed files on jeu. 21 sept. 2023 18:47:10 CEST:
This notification will continue to appear until you either run "chkboot" again as root or restart your computer
root@dsrvtest01:~# chkboot
diff: /var/lib/chkboot/DISKHEAD-last: Aucun fichier ou dossier de ce type
diff: /var/lib/chkboot/DISKHEAD-20230921-184905: Aucun fichier ou dossier de ce type
root@dsrvtest01:~# ls -al /var/lib/chkboot/
total 172
drwxr-xr-x  2 root root  4096 21 sept. 18:49 .
drwxr-xr-x 32 root root  4096 21 sept. 18:47 ..
-rw-r-----  1 root root    60 21 sept. 18:49 boot-differences
-rw-r-----  1 root root   122 21 sept. 18:49 boot-differences-log
-rw-r-----  1 root root     0 21 sept. 18:47 boot-differences-now
-rw-r--r--  1 root root 52759 21 sept. 18:47 BOOTFILES-20230921-184706
-rw-r-----  1 root root 52759 21 sept. 18:47 BOOTFILES-20230921-184710
-rw-r-----  1 root root 52759 21 sept. 18:49 BOOTFILES-20230921-184905
lrwxrwxrwx  1 root root    42 21 sept. 18:49 BOOTFILES-last -> /var/lib/chkboot/BOOTFILES-20230921-184905
lrwxrwxrwx  1 root root    41 21 sept. 18:49 DISKHEAD-last -> /var/lib/chkboot/DISKHEAD-20230921-184905
Il me dit qu’il y a une alerte.
Je lance chkboot pour valider
il y a un message d’erreur sur des fichiers qui pourtant existent.
