Clavier qwerty après install PXE (preseed)
Tags: #<Tag:0x00007f5747cbcd48> #<Tag:0x00007f5747cbcc08>
Je souhaiterais installer, de façon automatisée, une debian sur un poste client via PXE.
Le client boot correctement en PXE, interprète le preseed.cfg et lance l’installation jusqu’au reboot. Tout est correcte (partition, hostname etc…) sauf le clavier qui est en qwerty.
Voici les fichiers conf:
/var/lib/tftpboot/debian-installer/i386/boot-screens/syslinux.cfg
# D-I config version 2.0
include debian-installer/i386/boot-screens/menu.cfg
default debian-installer/i386/boot-screens/vesamenu.c32
prompt 0
timeout 0
DEFAULT wheezy
LABEL wheezy
        kernel debian-installer/i386/linux
APPEND vga=normal initrd=debian-installer/i386/initrd.gz auto=true interface=auto netcfg/dhcp_timeout=60 netcfg/choose_interface=auto priority=critical preseed/file=/preseed.cfg IPAPPEND 2
preseed.cfg (que j’ai injecté à la racine de initrd.gz (/var/lib/tftpboot/debian-installer/i386/initrd.gz))
# Localizations
# Install Time
d-i	console-tools/archs string skip-config
d-i 	debian-installer/locale string fr_FR
d-i 	console-keymaps-at/keymap select fr
d-i     languagechooser/language-name-fb    select French
d-i     debian-installer/locale             select fr_FR.UTF-8
## Fuseau horaire
d-i clock-setup/utc boolean true
d-i time/zone string Europe/Paris
d-i clock-setup/ntp boolean true
d-i clock-setup/ntp-server string 0.debian.pool.ntp.org
# Mirroir
d-i     mirror/http/hostname    string ftp.fr.debian.org
d-i     mirror/http/directory   string /debian/
d-i     mirror/suite            string
# Post install APT setup
d-i     apt-setup/uri_type      select d-i
d-i     apt-setup/hostname      string ftp.fr.debian.org
d-i     apt-setup/directory     string /debian/
d-i     apt-setup/another       boolean false
d-i     apt-setup/security-updates      boolean false
d-i     finish-install/reboot_in_progress note
d-i     prebaseconfig/reboot_in_progress        note
d-i     apt-setup/non-free      boolean true
d-i     apt-setup/contrib       boolean true
# Networking
# Network Configuration
#d-i     netcfg/get_hostname     string monhostname
#d-i     netcfg/get_domain       string mondomaine.fr
# Disk Partitioning/Boot loader
d-i     partman-auto/disk               string /dev/sda
d-i     partman-auto/method             string regular
# This makes partman automatically partition without confirmation.
d-i     partman/confirm boolean true
d-i     partman-partitioning/confirm_write_new_label boolean true
d-i     partman/choose_partition select finish
d-i     partman/confirm_nooverwrite boolean true
# This one makes grub-installer install to the MBR even if finds some other OS
# too, which is less safe as it might not be able to boot that other OS.
d-i     grub-installer/with_other_os    boolean true
# X11 config
xserver-xorg     xserver-xorg/autodetect_monitor              boolean true
xserver-xorg     xserver-xorg/config/monitor/selection-method select medium
xserver-xorg     xserver-xorg/config/monitor/mode-list        select 1024x768 @ 60 Hz
xserver-xorg     xserver-xorg/config/display/modes            multiselect 1024x768, 800x600
# User Creation
# Root User
d-i     passwd/root-password-crypted    passwd    monmotdepasse
# Mortal User
d-i     passwd/user-fullname            string monuser
d-i     passwd/username                 string monuser
d-i     passwd/user-password-crypted    passwd monmotdepasse
# Software Selections
tasksel tasksel/first   multiselect     ssh-server standard
# Additional preseed entries (from data/debconf)
exim4-config exim4/no_config boolean true
Pour info, les parties DHCP/DNS sont gérées par dnsmasq et je me suis basé sur http://www.instalinux.com pour générer adapter mon preseed.cfg
Avez-vous une solution?
essai un
setxkbmap fr
pour revenir en azerty en attendant qu’un autre te donne la marche a suivre pour ton soucie
Je n’ai pas récemment utilisé pxe,
mais voici la ligne des paramètres qui me permettent de lancer une version “live” en français:
lang=fr_FR.UTF-8 locales=fr_FR.UTF-8 keyboard-layouts=fr keyboard-model=pc105 timezone=Europe/Paris utc=yes
Il devrait donc être possible de les utiliser dans le fichier /var/lib/tftpboot/debian-installer/i386/boot-screens/syslinux.cfg comme ceci:
prompt 0
timeout 0
DEFAULT wheezy
LABEL wheezy
APPEND vga=normal initrd=debian-installer/i386/initrd.gz lang=fr_FR.UTF-8 locales=fr_FR.UTF-8 keyboard-layouts=fr keyboard-model=pc105 timezone=Europe/Paris utc=yes auto=true interface=auto netcfg/dhcp_timeout=60 netcfg/choose_interface=auto priority=critical preseed/file=/preseed.cfg IPAPPEND 2
tout en ayant commenté les directives correspondantes du fichier preseed.cfg (histoire d’éviter les conflits)
# Localizations
# Install Time
# d-i    debian-installer/locale string fr_FR
# d-i    console-keymaps-at/keymap select fr
# d-i     languagechooser/language-name-fb    select French
# d-i     debian-installer/locale             select fr_FR.UTF-8
## Fuseau horaire
# d-i clock-setup/utc boolean true
# d-i time/zone string Europe/Paris
# Mirroir
# Networking
# X11 config
# User Creation
# Root User
# Mortal User
Ou alors, il faudrait trouver la syntaxe correspondante pour preseed.cfg
EDIT:
d-i keyboard-configuration/variant    select France
d-i keyboard-configuration/xkb-keymap select fr
d-i console-setup/layout	     select  France
d-i console-setup/charmap	    select  UTF-8
d-i console-setup/model		   select  Generic 105-key (Intl) PC
à tester et à adapter au type de clavier.
NOTE: Source: debian.org/releases/wheezy/ … 02.html.fr
... Il faut savoir que le noyau Linux (version 2.6.9 et au delà) accepte un maximum de 32 options ligne de commandes et 32 variables d'environnement.
 Les options ajoutées par l'installateur sont comprises dans ces chiffres.
 S'il y a dépassement, le noyau panique.
 Les précédents noyaux acceptaient moins d'options. ...
Malheureusement, cela ne fonctionne toujours pas… :frowning:
Pour celles et ceux qui seraient intéressés, voici ce qu’il faut mettre dans preseed.cfg pour avoir le prompt en français au reboot du client:
# Locales
d-i debian-installer/fallbacklocale select fr_FR.UTF-8
# Keyboard
d-i console-keymaps-at/keymap select fr-latin9
d-i debian-installer/keymap string fr-latin9
Merci aux contributeurs.
ps: Le titre du sujet peut être précédé de “résolu”.
