Clocksource/lapic ?
Voilà. J’utilise, en MAO, la distribution Tangostudio, basée sur la 10.04 d’Ubuntu, donc Debian, bien sûr.
Le noyau est : 2.6.33-16-realtime #11 SMP PREEMPT RT Fri Jul 15 19:21:52 UTC 2011 x86_64 GNU/Linux
Lors du boot, j’ai deux messages d’erreur, dont voici les extraits à partir de dmesg.
1er message :
[ 0.226032] HPET: 3 timers in total, 0 timers will be used for per-cpu timer [ 0.226039] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 31 [ 0.226044] hpet0: 3 comparators, 32-bit 25.000000 MHz counter [ 0.230043] Switching to clocksource hpet [ 0.230796] Clockevents: could not switch to one-shot mode: lapic is not func tional. [ 0.230802] Could not switch to high resolution mode on CPU 1 [ 0.230805] Clockevents: could not switch to one-shot mode: lapic is not func tional. [ 0.230809] Could not switch to high resolution mode on CPU 0 [ 0.233533] pnp: PnP ACPI init [ 0.233558] ACPI: bus type pnp registered [ 0.236050] ACPI Error: Field [I9MN] at 544 exceeds Buffer [IORT] size 464 (b its) (20091214/dsopcode-596) [ 0.236058] ACPI Error (psparse-0537): Method parse/execution failed [\_SB_.P CI0.LPC0.PMIO._CRS] (Node ffff8800b9677ad0), AE_AML_BUFFER_LIMIT [ 0.236095] ACPI Error (uteval-0250): Method execution failed [\_SB_.PCI0.LPC 0.PMIO._CRS] (Node ffff8800b9677ad0), AE_AML_BUFFER_LIMIT [ 0.236104] pnp 00:03: can't evaluate _CRS: 12298
2ème message :
[ 0.842050] usb 1-4: new high speed USB device using ehci_hcd and address 2 [ 0.866885] ohci1394 0000:07:05.0: enabling device (0100 -> 0102) [ 0.867375] ACPI: PCI Interrupt Link [LNK1] enabled at IRQ 5 [ 0.867389] ohci1394 0000:07:05.0: PCI INT A -> Link[LNK1] -> GSI 5 (level, l ow) -> IRQ 5 [ 0.921090] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[5] MMIO=[f2100000- f21007ff] Max Packet=[2048] IR/IT contexts=[4/4] [ 0.945273] usb 1-4: device descriptor read/64, error -32
…et mon dmesg se termine par :
Comme ma carte-son est en USB et que Jackd me renvoie des désynchronisations par paquets de plusieurs dizaines (config’ jackd/alsa pourtant OK) malgré une latence indécente, je me dis que tout ceci est peut-être lié et je viens voir à la source Debian si quelqu’un pouvait au moins m’expliquer les deux erreurs au boot.
J’ai cherché (en vain) sur la toile des heures et des heures, fait un tas d’expériences avec différents timers (notsc, clocksource=tsc, acpi_pm, nolapic_timer, etc…) mais rien n’y fait.
Pour que la musique continue…
Merci, à+
