[code]Linux version 2.6.8-3-686-smp (pbuilder@dl360-g3) (gcc version 3.3.5 (Debian 1:3.3.5-13)) #1 SMP Thu Sep 7 04:39:15 UTC 2006
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000ca000 - 00000000000cc000 (reserved)
BIOS-e820: 00000000000dc000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000001fef0000 (usable)
BIOS-e820: 000000001fef0000 - 000000001fefc000 (ACPI data)
BIOS-e820: 000000001fefc000 - 000000001ff00000 (ACPI NVS)
BIOS-e820: 000000001ff00000 - 0000000020000000 (usable)
BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
BIOS-e820: 00000000fffe0000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
512MB LOWMEM available.
found SMP MP-table at 000f6ce0
On node 0 totalpages: 131072
DMA zone: 4096 pages, LIFO batch:1
Normal zone: 126976 pages, LIFO batch:16
HighMem zone: 0 pages, LIFO batch:1
DMI present.
ACPI: RSDP (v000 PTLTD ) @ 0x000f6c70
ACPI: RSDT (v001 PTLTD RSDT 0x06040000 LTP 0x00000000) @ 0x1fef7c02
ACPI: FADT (v001 INTEL 440BX 0x06040000 PTL 0x000f4240) @ 0x1fefbf14
ACPI: MADT (v001 PTLTD APIC 0x06040000 LTP 0x00000000) @ 0x1fefbf88
ACPI: BOOT (v001 PTLTD $SBFTBL$ 0x06040000 LTP 0x00000001) @ 0x1fefbfd8
ACPI: DSDT (v001 PTLTD Custom 0x06040000 MSFT 0x0100000d) @ 0x00000000
ACPI: PM-Timer IO Port: 0x1008
ACPI: Local APIC address 0xfee00000
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Processor #0 15:2 APIC version 17
ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
IOAPIC[0]: Assigned apic_id 1
IOAPIC[0]: apic_id 1, version 17, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 high edge)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
Enabling APIC mode: Flat. Using 1 I/O APICs
Using ACPI (MADT) for SMP configuration information
Built 1 zonelists
Kernel command line: root=/dev/sda1 ro vga=771
Initializing CPU#0
PID hash table entries: 4096 (order 12: 32768 bytes)
Detected 1599.348 MHz processor.
Using pmtmr for high-res timesource
Console: colour dummy device 80x25
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 510332k/524288k available (1666k kernel code, 13148k reserved, 769k data, 172k init, 0k highmem)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay loop... 3072.00 BogoMIPS
Security Scaffold v1.0.0 initialized
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
CPU: After generic identify, caps: 0febfbff 00000000 00000000 00000000
CPU: After vendor identify, caps: 0febfbff 00000000 00000000 00000000
CPU: Trace cache: 12K uops, L1 D cache: 8K
CPU: L2 cache: 512K
CPU: After all inits, caps: 0febfbff 00000000 00000000 00000080
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Checking 'hlt' instruction... OK.
CPU0: Intel(R) Pentium(R) 4 CPU 2.40GHz stepping 08
per-CPU timeslice cutoff: 1462.36 usecs.
task migration cache decay timeout: 2 msecs.
enabled ExtINT on CPU#0
ESR value before enabling vector: 00000000
ESR value after enabling vector: 00000000
Total of 1 processors activated (3072.00 BogoMIPS).
ENABLING IO-APIC IRQs
init IO_APIC IRQs
IO-APIC (apicid-pin) 1-0, 1-16, 1-17, 1-18, 1-19, 1-20, 1-21, 1-22, 1-23 not connected.
..TIMER: vector=0x31 pin1=2 pin2=-1
Using local APIC timer interrupts.
calibrating APIC timer ...
..... CPU clock speed is 1599.0735 MHz.
..... host bus clock speed is 65.0976 MHz.
Brought up 1 CPUs
CPU0: online
domain 0: span 01
groups: 01
domain 1: span 01
groups: 01
checking if image is initramfs...it isn't (ungzip failed); looks like an initrd
Freeing initrd memory: 5012k freed
NET: Registered protocol family 16
PCI: PCI BIOS revision 2.10 entry at 0xfd9a0, last bus=1
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20040326
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (00:00)
PCI: Probing PCI hardware (bus 00)
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 11 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 *11 14 15)
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 *10 11 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 *9 10 11 14 15)
Linux Plug and Play Support v0.97 (c) Adam Belay
PnPBIOS: Scanning system for PnP BIOS support...
PnPBIOS: Found PnP BIOS installation structure at 0xc00f6ca0
PnPBIOS: PnP BIOS version 1.0, entry 0xf0000:0x9486, dseg 0x400
pnp: 00:0b: ioport range 0x4d0-0x4d1 has been reserved
pnp: 00:0b: ioport range 0x1000-0x103f has been reserved
pnp: 00:0b: ioport range 0x1040-0x104f has been reserved
PnPBIOS: 20 nodes reported by PnP BIOS; 20 recorded by driver
PCI: Using ACPI for IRQ routing
ACPI: PCI interrupt 0000:00:07.2[D] -> GSI 19 (level, low) -> IRQ 169
ACPI: PCI interrupt 0000:00:10.0[A] -> GSI 17 (level, low) -> IRQ 177
ACPI: PCI interrupt 0000:00:11.0[A] -> GSI 18 (level, low) -> IRQ 185
ACPI: PCI interrupt 0000:00:12.0[A] -> GSI 19 (level, low) -> IRQ 169
number of MP IRQ sources: 15.
number of IO-APIC #1 registers: 24.
testing the IO APIC.......................
IO APIC #1......
.... register #00: 01000000
....... : physical APIC id: 01
....... : Delivery Type: 0
....... : LTS : 0
.... register #01: 00170011
....... : max redirection entries: 0017
....... : PRQ implemented: 0
....... : IO APIC version: 0011
.... register #02: 01000000
....... : arbitration: 01
.... IRQ redirection table:
NR Log Phy Mask Trig IRR Pol Stat Dest Deli Vect:
00 000 00 1 0 0 0 0 0 0 00
01 001 01 0 0 0 0 0 1 1 39
02 001 01 0 0 0 0 0 1 1 31
03 001 01 0 0 0 0 0 1 1 41
04 001 01 0 0 0 0 0 1 1 49
05 001 01 0 0 0 0 0 1 1 51
06 001 01 0 0 0 0 0 1 1 59
07 001 01 0 0 0 0 0 1 1 61
08 001 01 0 0 0 0 0 1 1 69
09 001 01 0 1 0 1 0 1 1 71
0a 001 01 0 0 0 0 0 1 1 79
0b 001 01 0 0 0 0 0 1 1 81
0c 001 01 0 0 0 0 0 1 1 89
0d 001 01 0 0 0 0 0 1 1 91
0e 001 01 0 0 0 0 0 1 1 99
0f 001 01 0 0 0 0 0 1 1 A1
10 000 00 1 0 0 0 0 0 0 00
11 001 01 1 1 0 1 0 1 1 B1
12 001 01 1 1 0 1 0 1 1 B9
13 001 01 1 1 0 1 0 1 1 A9
14 000 00 1 0 0 0 0 0 0 00
15 000 00 1 0 0 0 0 0 0 00
16 000 00 1 0 0 0 0 0 0 00
17 000 00 1 0 0 0 0 0 0 00
Using vector-based indexing
IRQ to pin mappings:
IRQ0 -> 0:2
IRQ1 -> 0:1
IRQ3 -> 0:3
IRQ4 -> 0:4
IRQ5 -> 0:5
IRQ6 -> 0:6
IRQ7 -> 0:7
IRQ8 -> 0:8
IRQ9 -> 0:9
IRQ10 -> 0:10
IRQ11 -> 0:11
IRQ12 -> 0:12
IRQ13 -> 0:13
IRQ14 -> 0:14
IRQ15 -> 0:15
IRQ177 -> 0:17
IRQ185 -> 0:18
IRQ169 -> 0:19
.................................... done.
PCI: Cannot allocate resource region 4 of device 0000:00:07.1
Simple Boot Flag at 0x36 set to 0x1
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x0
Initializing Cryptographic API
Limiting direct PCI/PCI transfers.
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 48 ports, IRQ sharing enabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
input: AT Translated Set 2 keyboard on isa0060/serio0
NET: Registered protocol family 2
IP: routing cache hash table of 4096 buckets, 32Kbytes
TCP: Hash tables configured (established 131072 bind 65536)
NET: Registered protocol family 8
NET: Registered protocol family 20
ACPI: (supports S0 S1 S5)
RAMDISK: cramfs filesystem found at block 0
RAMDISK: Loading 5012 blocks [1 disk] into ram disk... done.
VFS: Mounted root (cramfs filesystem) readonly.
Freeing unused kernel memory: 172k freed
vesafb: framebuffer at 0xf0000000, mapped to 0xe0827000, size 937k
vesafb: mode is 800x600x8, linelength=800, pages=0
vesafb: protected mode interface info at 00ff:44f0
vesafb: scrolling: redraw
mtrr: your processor doesn't support write-combining
fb0: VESA VGA frame buffer device
Console: switching to colour frame buffer device 100x37
SCSI subsystem initialized
Fusion MPT base driver 3.01.09
Copyright (c) 1999-2004 LSI Logic Corporation
mptbase: Initiating ioc0 bringup
ioc0: 53C1030: Capabilities={Initiator}
Fusion MPT SCSI Host driver 3.01.09
scsi0 : ioc0: LSI53C1030, FwRev=00000000h, Ports=1, MaxQ=128, IRQ=177
Using anticipatory io scheduler
Vendor: VMware, Model: VMware Virtual S Rev: 1.0
Type: Direct-Access ANSI SCSI revision: 02
ACPI: Processor [CPU0] (supports C1, 8 throttling states)
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v2.2
uhci_hcd 0000:00:07.2: Intel Corp. 82371AB/EB/MB PIIX4 USB
uhci_hcd 0000:00:07.2: irq 169, io base 00001060
uhci_hcd 0000:00:07.2: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new driver usbkbd
drivers/usb/input/usbkbd.c: :USB HID Boot Protocol keyboard driver
usbcore: registered new driver hiddev
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.0:USB HID core driver
drivers/usb/serial/usb-serial.c: USB Serial support registered for Generic
usbcore: registered new driver usbserial_generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core v2.0
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Initializing USB Mass Storage driver...
usbcore: registered new driver usb-storage
USB Mass Storage support registered.
inserting floppy driver for 2.6.8-3-686-smp
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
PIIX4: IDE controller at PCI slot 0000:00:07.1
PIIX4: chipset revision 1
PIIX4: not 100% native mode: will probe irqs later
ide1: BM-DMA at 0x14d8-0x14df, BIOS settings: hdc:DMA, hdd:pio
hdc: VMware Virtual IDE CDROM Drive, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
hdc: ATAPI 40X CD-ROM CD-R/RW drive, 8192kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
Linux Kernel Card Services
options: [pci] [cardbus] [pm]
pcnet32.c:v1.30i 06.28.2004 tsbogend@alpha.franken.de
pcnet32: PCnet/PCI II 79C970A at 0x1400, 00 0c 29 03 ab a1 assigned IRQ 185.
eth0: registered as PCnet/PCI II 79C970A
pcnet32: 1 cards_found.
SCSI device sda: 41943040 512-byte hdwr sectors (21475 MB)
sda: asking for cache data failed
sda: assuming drive cache: write through
/dev/scsi/host0/bus0/target0/lun0: p1 p2 < p5 p6 p7 p8 p9 >
Attached scsi disk sda at scsi0, channel 0, id 0, lun 0
Generic RTC Driver v1.07
input: ImPS/2 Generic Wheel Mouse on isa0060/serio1
mice: PS/2 mouse device common for all mice
ts: Compaq touchscreen protocol output
Linux agpgart interface v0.100 (c) Dave Jones
agpgart: Detected an Intel 440BX Chipset.
agpgart: Maximum main memory to use for agp memory: 440M
agpgart: AGP aperture is 64M @ 0xe8000000
cpci_hotplug: CompactPCI Hot Plug Core version: 0.2
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
pciehp: PCI Express Hot Plug Controller Driver version: 0.4
shpchp: shpc_init : shpc_cap_offset == 0
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
input: PC Speaker
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
Adding 746980k swap on /dev/sda7. Priority:-1 extents:1
EXT3 FS on sda1, internal journal
Capability LSM initialized
EXT3 FS on sda9, internal journal
EXT3 FS on sda8, internal journal
EXT3 FS on sda5, internal journal
EXT3 FS on sda6, internal journal
es1371: version v0.32 time 04:57:15 Sep 7 2006
es1371: found chip, vendor id 0x1274 device id 0x1371 revision 0x02
es1371: found es1371 rev 2 at io 0x1480 irq 169 joystick 0x0
ac97_codec: AC97 codec, id: CRY19 (Cirrus Logic CS4297A rev A)
NET: Registered protocol family 17
NET: Registered protocol family 10
Disabled Privacy Extensions on device c031f0c0(lo)
IPv6 over IPv4 tunneling driver
eth0: no IPv6 routers present
DMI present.
Built 1 zonelists
Initializing CPU#0
CPU: L2 cache: 512K
init IO_APIC IRQs
Brought up 1 CPUs
CPU0: online
domain 0: span 01
groups: 01
domain 1: span 01
groups: 01
IO APIC #1......
....... : LTS : 0
IRQ0 -> 0:2
IRQ1 -> 0:1
IRQ3 -> 0:3
IRQ4 -> 0:4
IRQ5 -> 0:5
IRQ6 -> 0:6
IRQ7 -> 0:7
IRQ8 -> 0:8
IRQ9 -> 0:9
IRQ10 -> 0:10
IRQ11 -> 0:11
IRQ12 -> 0:12
IRQ13 -> 0:13
IRQ14 -> 0:14
IRQ15 -> 0:15
IRQ177 -> 0:17
IRQ185 -> 0:18
IRQ169 -> 0:19
input: PC Speaker
