J’ai essayé une autre bibliothèque de log glog https://github.com/google/glog
Ça fonctionne mais c’est du google. C’est quand même étrange que les autres bibliothèque sois si compliqué a compilé.
sudo apt install libgoogle-glog-dev
g++ src/main.cpp -o app -lglog
Pour ce que ça intéresse voici la totalité des logs :
g++ -v src/main.cpp -o bin/program -lboost_log -lpthread
Using built-in specs.
COLLECT_GCC=g++
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-linux-gnu/10/lto-wrapper
OFFLOAD_TARGET_NAMES=nvptx-none:amdgcn-amdhsa:hsa
OFFLOAD_TARGET_DEFAULT=1
Target: x86_64-linux-gnu
Configured with: ../src/configure -v --with-pkgversion='Debian 10.2.1-6' --with-bugurl=file:///usr/share/doc/gcc-10/README.Bugs --enable-languages=c,ada,c++,go,brig,d,fortran,objc,obj-c++,m2 --prefix=/usr --with-gcc-major-version-only --program-suffix=-10 --program-prefix=x86_64-linux-gnu- --enable-shared --enable-linker-build-id --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --libdir=/usr/lib --enable-nls --enable-bootstrap --enable-clocale=gnu --enable-libstdcxx-debug --enable-libstdcxx-time=yes --with-default-libstdcxx-abi=new --enable-gnu-unique-object --disable-vtable-verify --enable-plugin --enable-default-pie --with-system-zlib --enable-libphobos-checking=release --with-target-system-zlib=auto --enable-objc-gc=auto --enable-multiarch --disable-werror --with-arch-32=i686 --with-abi=m64 --with-multilib-list=m32,m64,mx32 --enable-multilib --with-tune=generic --enable-offload-targets=nvptx-none=/build/gcc-10-Km9U7s/gcc-10-10.2.1/debian/tmp-nvptx/usr,amdgcn-amdhsa=/build/gcc-10-Km9U7s/gcc-10-10.2.1/debian/tmp-gcn/usr,hsa --without-cuda-driver --enable-checking=release --build=x86_64-linux-gnu --host=x86_64-linux-gnu --target=x86_64-linux-gnu --with-build-config=bootstrap-lto-lean --enable-link-mutex
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 10.2.1 20210110 (Debian 10.2.1-6)
COLLECT_GCC_OPTIONS='-v' '-o' 'bin/program' '-shared-libgcc' '-mtune=generic' '-march=x86-64'
/usr/lib/gcc/x86_64-linux-gnu/10/cc1plus -quiet -v -imultiarch x86_64-linux-gnu -D_GNU_SOURCE src/main.cpp -quiet -dumpbase main.cpp -mtune=generic -march=x86-64 -auxbase main -version -fasynchronous-unwind-tables -o /tmp/ccRp0anL.s
GNU C++14 (Debian 10.2.1-6) version 10.2.1 20210110 (x86_64-linux-gnu)
compiled by GNU C version 10.2.1 20210110, GMP version 6.2.1, MPFR version 4.1.0, MPC version 1.2.0, isl version isl-0.23-GMP
GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
ignoring duplicate directory "/usr/include/x86_64-linux-gnu/c++/10"
ignoring nonexistent directory "/usr/local/include/x86_64-linux-gnu"
ignoring nonexistent directory "/usr/lib/gcc/x86_64-linux-gnu/10/include-fixed"
ignoring nonexistent directory "/usr/lib/gcc/x86_64-linux-gnu/10/../../../../x86_64-linux-gnu/include"
#include "..." search starts here:
#include <...> search starts here:
/usr/include/c++/10
/usr/include/c++/10/backward
/usr/local/include
/usr/include
End of search list.
Compiler executable checksum: 048fcaee3460a99eb0d68522358720e1
as -v --64 -o /tmp/ccQ1D3vL.o /tmp/ccRp0anL.s
Version de l'assembleur GNU 2.35.2 (x86_64-linux-gnu) utilisant la version BFD (GNU Binutils for Debian) 2.35.2
COMPILER_PATH=/usr/lib/gcc/x86_64-linux-gnu/10/:/usr/lib/gcc/x86_64-linux-gnu/10/:/usr/lib/gcc/x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/10/:/usr/lib/gcc/x86_64-linux-gnu/
LIBRARY_PATH=/usr/lib/gcc/x86_64-linux-gnu/10/:/usr/lib/gcc/x86_64-linux-gnu/10/../../../x86_64-linux-gnu/:/usr/lib/gcc/x86_64-linux-gnu/10/../../../../lib/:/lib/x86_64-linux-gnu/:/lib/../lib/:/usr/lib/x86_64-linux-gnu/:/usr/lib/../lib/:/usr/lib/gcc/x86_64-linux-gnu/10/../../../:/lib/:/usr/lib/
/usr/lib/gcc/x86_64-linux-gnu/10/collect2 -plugin /usr/lib/gcc/x86_64-linux-gnu/10/liblto_plugin.so -plugin-opt=/usr/lib/gcc/x86_64-linux-gnu/10/lto-wrapper -plugin-opt=-fresolution=/tmp/ccKAHUjI.res -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc -plugin-opt=-pass-through=-lc -plugin-opt=-pass-through=-lgcc_s -plugin-opt=-pass-through=-lgcc --build-id --eh-frame-hdr -m elf_x86_64 --hash-style=gnu --as-needed -dynamic-linker /lib64/ld-linux-x86-64.so.2 -pie -o bin/program /usr/lib/gcc/x86_64-linux-gnu/10/../../../x86_64-linux-gnu/Scrt1.o /usr/lib/gcc/x86_64-linux-gnu/10/../../../x86_64-linux-gnu/crti.o /usr/lib/gcc/x86_64-linux-gnu/10/crtbeginS.o -L/usr/lib/gcc/x86_64-linux-gnu/10 -L/usr/lib/gcc/x86_64-linux-gnu/10/../../../x86_64-linux-gnu -L/usr/lib/gcc/x86_64-linux-gnu/10/../../../../lib -L/lib/x86_64-linux-gnu -L/lib/../lib -L/usr/lib/x86_64-linux-gnu -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/10/../../.. /tmp/ccQ1D3vL.o -lboost_log -lpthread -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /usr/lib/gcc/x86_64-linux-gnu/10/crtendS.o /usr/lib/gcc/x86_64-linux-gnu/10/../../../x86_64-linux-gnu/crtn.o
/usr/bin/ld : /tmp/ccQ1D3vL.o : dans la fonction « main » :
main.cpp:(.text+0x11) : référence indéfinie vers « boost::log::v2s_mt_posix::trivial::logger::get() »
/usr/bin/ld : main.cpp:(.text+0x60) : référence indéfinie vers « boost::log::v2s_mt_posix::trivial::logger::get() »
/usr/bin/ld : /tmp/ccQ1D3vL.o : dans la fonction « boost::log::v2s_mt_posix::record::reset() » :
main.cpp:(.text._ZN5boost3log12v2s_mt_posix6record5resetEv[_ZN5boost3log12v2s_mt_posix6record5resetEv]+0x23) : référence indéfinie vers « boost::log::v2s_mt_posix::record_view::public_data::destroy(boost::log::v2s_mt_posix::record_view::public_data const*) »
/usr/bin/ld : /tmp/ccQ1D3vL.o : dans la fonction « boost::log::v2s_mt_posix::record boost::log::v2s_mt_posix::sources::basic_composite_logger<char, boost::log::v2s_mt_posix::sources::severity_logger_mt<boost::log::v2s_mt_posix::trivial::severity_level>, boost::log::v2s_mt_posix::sources::multi_thread_model<boost::log::v2s_mt_posix::aux::light_rw_mutex>, boost::log::v2s_mt_posix::sources::features<boost::log::v2s_mt_posix::sources::severity<boost::log::v2s_mt_posix::trivial::severity_level> > >::open_record<boost::parameter::aux::tagged_argument_list_of_1<boost::parameter::aux::tagged_argument<boost::log::v2s_mt_posix::keywords::tag::severity, boost::log::v2s_mt_posix::trivial::severity_level const> > >(boost::parameter::aux::tagged_argument_list_of_1<boost::parameter::aux::tagged_argument<boost::log::v2s_mt_posix::keywords::tag::severity, boost::log::v2s_mt_posix::trivial::severity_level const> > const&) » :
main.cpp:(.text._ZN5boost3log12v2s_mt_posix7sources22basic_composite_loggerIcNS2_18severity_logger_mtINS1_7trivial14severity_levelEEENS2_18multi_thread_modelINS1_3aux14light_rw_mutexEEENS2_8featuresIJNS2_8severityIS6_EEEEEE11open_recordINS_9parameter3aux25tagged_argument_list_of_1INSJ_15tagged_argumentINS1_8keywords3tag8severityEKS6_EEEEEENS1_6recordERKT_[_ZN5boost3log12v2s_mt_posix7sources22basic_composite_loggerIcNS2_18severity_logger_mtINS1_7trivial14severity_levelEEENS2_18multi_thread_modelINS1_3aux14light_rw_mutexEEENS2_8featuresIJNS2_8severityIS6_EEEEEE11open_recordINS_9parameter3aux25tagged_argument_list_of_1INSJ_15tagged_argumentINS1_8keywords3tag8severityEKS6_EEEEEENS1_6recordERKT_]+0x2d) : référence indéfinie vers « boost::log::v2s_mt_posix::core::get_logging_enabled() const »
/usr/bin/ld : /tmp/ccQ1D3vL.o : dans la fonction « boost::log::v2s_mt_posix::aux::record_pump<boost::log::v2s_mt_posix::sources::severity_logger_mt<boost::log::v2s_mt_posix::trivial::severity_level> >::record_pump(boost::log::v2s_mt_posix::sources::severity_logger_mt<boost::log::v2s_mt_posix::trivial::severity_level>&, boost::log::v2s_mt_posix::record&) » :
main.cpp:(.text._ZN5boost3log12v2s_mt_posix3aux11record_pumpINS1_7sources18severity_logger_mtINS1_7trivial14severity_levelEEEEC2ERS8_RNS1_6recordE[_ZN5boost3log12v2s_mt_posix3aux11record_pumpINS1_7sources18severity_logger_mtINS1_7trivial14severity_levelEEEEC5ERS8_RNS1_6recordE]+0x2f) : référence indéfinie vers « boost::log::v2s_mt_posix::aux::stream_provider<char>::allocate_compound(boost::log::v2s_mt_posix::record&) »
/usr/bin/ld : /tmp/ccQ1D3vL.o : dans la fonction « boost::log::v2s_mt_posix::aux::record_pump<boost::log::v2s_mt_posix::sources::severity_logger_mt<boost::log::v2s_mt_posix::trivial::severity_level> >::auto_release::~auto_release() » :
main.cpp:(.text._ZN5boost3log12v2s_mt_posix3aux11record_pumpINS1_7sources18severity_logger_mtINS1_7trivial14severity_levelEEEE12auto_releaseD2Ev[_ZN5boost3log12v2s_mt_posix3aux11record_pumpINS1_7sources18severity_logger_mtINS1_7trivial14severity_levelEEEE12auto_releaseD5Ev]+0x17) : référence indéfinie vers « boost::log::v2s_mt_posix::aux::stream_provider<char>::release_compound(boost::log::v2s_mt_posix::aux::stream_provider<char>::stream_compound*) »
/usr/bin/ld : /tmp/ccQ1D3vL.o : dans la fonction « boost::log::v2s_mt_posix::sources::aux::severity_level<boost::log::v2s_mt_posix::trivial::severity_level>::set_value(boost::log::v2s_mt_posix::trivial::severity_level) » :
main.cpp:(.text._ZN5boost3log12v2s_mt_posix7sources3aux14severity_levelINS1_7trivial14severity_levelEE9set_valueES6_[_ZN5boost3log12v2s_mt_posix7sources3aux14severity_levelINS1_7trivial14severity_levelEE9set_valueES6_]+0x10) : référence indéfinie vers « boost::log::v2s_mt_posix::sources::aux::get_severity_level() »
/usr/bin/ld : /tmp/ccQ1D3vL.o : dans la fonction « boost::log::v2s_mt_posix::record boost::log::v2s_mt_posix::sources::basic_logger<char, boost::log::v2s_mt_posix::sources::severity_logger_mt<boost::log::v2s_mt_posix::trivial::severity_level>, boost::log::v2s_mt_posix::sources::multi_thread_model<boost::log::v2s_mt_posix::aux::light_rw_mutex> >::open_record_unlocked<boost::parameter::aux::tagged_argument_list_of_1<boost::parameter::aux::tagged_argument<boost::log::v2s_mt_posix::keywords::tag::severity, boost::log::v2s_mt_posix::trivial::severity_level const> > >(boost::parameter::aux::tagged_argument_list_of_1<boost::parameter::aux::tagged_argument<boost::log::v2s_mt_posix::keywords::tag::severity, boost::log::v2s_mt_posix::trivial::severity_level const> > const&) » :
main.cpp:(.text._ZN5boost3log12v2s_mt_posix7sources12basic_loggerIcNS2_18severity_logger_mtINS1_7trivial14severity_levelEEENS2_18multi_thread_modelINS1_3aux14light_rw_mutexEEEE20open_record_unlockedINS_9parameter3aux25tagged_argument_list_of_1INSF_15tagged_argumentINS1_8keywords3tag8severityEKS6_EEEEEENS1_6recordERKT_[_ZN5boost3log12v2s_mt_posix7sources12basic_loggerIcNS2_18severity_logger_mtINS1_7trivial14severity_levelEEENS2_18multi_thread_modelINS1_3aux14light_rw_mutexEEEE20open_record_unlockedINS_9parameter3aux25tagged_argument_list_of_1INSF_15tagged_argumentINS1_8keywords3tag8severityEKS6_EEEEEENS1_6recordERKT_]+0x3a) : référence indéfinie vers « boost::log::v2s_mt_posix::core::open_record(boost::log::v2s_mt_posix::attribute_set const&) »
/usr/bin/ld : /tmp/ccQ1D3vL.o : dans la fonction « boost::log::v2s_mt_posix::sources::basic_logger<char, boost::log::v2s_mt_posix::sources::severity_logger_mt<boost::log::v2s_mt_posix::trivial::severity_level>, boost::log::v2s_mt_posix::sources::multi_thread_model<boost::log::v2s_mt_posix::aux::light_rw_mutex> >::push_record_unlocked(boost::log::v2s_mt_posix::record&&) » :
main.cpp:(.text._ZN5boost3log12v2s_mt_posix7sources12basic_loggerIcNS2_18severity_logger_mtINS1_7trivial14severity_levelEEENS2_18multi_thread_modelINS1_3aux14light_rw_mutexEEEE20push_record_unlockedEONS1_6recordE[_ZN5boost3log12v2s_mt_posix7sources12basic_loggerIcNS2_18severity_logger_mtINS1_7trivial14severity_levelEEENS2_18multi_thread_modelINS1_3aux14light_rw_mutexEEEE20push_record_unlockedEONS1_6recordE]+0x43) : référence indéfinie vers « boost::log::v2s_mt_posix::core::push_record_move(boost::log::v2s_mt_posix::record&) »
collect2: error: ld returned 1 exit status
