Configuration dovecot
Bonjour tous le monde,
En ce moment, je m’amuse avec mon serveur en montant un serveur mail avec postfix.
J’ai donc suivit ce petit tuto sur un forum bien connut :whistle: Tuto Postfix, tous c’est bien passé jusqu’au paramètrage de Dovecot afin d’accéder au serveur d’un autre poste.
Il faut ajouter au fichier /etc/postfix/postfix.conf les lignes suivantes dans la section auth default { }
socket listen {
  client {
    path  = /var/spool/postfix/private/auth
   group = postfix
   mode  = 0660
Or je ne trouve pas de section auth default { }.
Quelqu’un saurait-il où ajouter mes lignes?
Merci à vous pour votre aide.
Mon fichier postfix.conf
## Dovecot configuration file
# If you're in a hurry, see http://wiki2.dovecot.org/QuickConfiguration
# "doveconf -n" command gives a clean output of the changed settings. Use it
# instead of copy&pasting files when posting to the Dovecot mailing list.
# '#' character and everything after it is treated as comments. Extra spaces
# and tabs are ignored. If you want to use either of these explicitly, put the
# value inside quotes, eg.: key = "# char and trailing whitespace  "
# Default values are shown for each setting, it's not required to uncomment
# those. These are exceptions to this though: No sections (e.g. namespace {})
# or plugin settings are added by default, they're listed only as examples.
# Paths are also just examples with the real defaults being based on configure
# options. The paths listed here are for configure --prefix=/usr
# --sysconfdir=/etc --localstatedir=/var
# Enable installed protocols
!include_try /usr/share/dovecot/protocols.d/*.protocol
# A comma separated list of IPs or hosts where to listen in for connections.
# "*" listens in all IPv4 interfaces, "::" listens in all IPv6 interfaces.
# If you want to specify non-default ports or anything more complex,
# edit conf.d/master.conf.
#listen = *, ::
# Base directory where to store runtime data.
#base_dir = /var/run/dovecot/
# Name of this instance. In multi-instance setup doveadm and other commands
# can use -i <instance_name> to select which instance is used (an alternative
# to -c <config_path>). The instance name is also added to Dovecot processes
# in ps output.
#instance_name = dovecot
# Greeting message for clients.
#login_greeting = Dovecot ready.
# Space separated list of trusted network ranges. Connections from these
# IPs are allowed to override their IP addresses and ports (for logging and
# for authentication checks). disable_plaintext_auth is also ignored for
# these networks. Typically you'd specify your IMAP proxy servers here.
#login_trusted_networks =
# Sepace separated list of login access check sockets (e.g. tcpwrap)
#login_access_sockets =
# With proxy_maybe=yes if proxy destination matches any of these IPs, don't do
# proxying. This isn't necessary normally, but may be useful if the destination
# IP is e.g. a load balancer's IP.
#auth_proxy_self =
# Show more verbose process titles (in ps). Currently shows user name and
# IP address. Useful for seeing who are actually using the IMAP processes
# (eg. shared mailboxes or if same uid is used for multiple accounts).
#verbose_proctitle = no
# Should all processes be killed when Dovecot master process shuts down.
# Setting this to "no" means that Dovecot can be upgraded without
# forcing existing client connections to close (although that could also be
# a problem if the upgrade is e.g. because of a security fix).
#shutdown_clients = yes
# If non-zero, run mail commands via this many connections to doveadm server,
# instead of running them directly in the same process.
#doveadm_worker_count = 0
# UNIX socket or host:port used for connecting to doveadm server
#doveadm_socket_path = doveadm-server
# Space separated list of environment variables that are preserved on Dovecot
# startup and passed down to all of its child processes. You can also give
# key=value pairs to always set specific settings.
#import_environment = TZ
## Dictionary server settings
# Dictionary can be used to store key=value lists. This is used by several
# plugins. The dictionary can be accessed either directly or though a
# dictionary server. The following dict block maps dictionary names to URIs
# when the server is used. These can then be referenced using URIs in format
# "proxy::<name>".
dict {
  #quota = mysql:/etc/dovecot/dovecot-dict-sql.conf.ext
  #expire = sqlite:/etc/dovecot/dovecot-dict-sql.conf.ext
# Most of the actual configuration gets included below. The filenames are
# first sorted by their ASCII value and parsed in that order. The 00-prefixes
# in filenames are intended to make it easier to understand the ordering.
!include conf.d/*.conf
# A config file can also tried to be included without giving an error if
# it's not found:
!include_try local.conf
J’ai rajouté une section auth default à la fin de mon fichier et ajouter le code dedans.
J’ai redémarrer dovecot et j’obtiens ceci :
doveconf: Warning: NOTE: You can get a new clean config file with: doveconf -n > dovecot-new.conf
doveconf: Warning: Obsolete setting in /etc/dovecot/dovecot.conf:99: add auth_ prefix to all settings inside auth {} and remove the auth {} section completely
[....] Restarting IMAP/POP3 mail server: dovecotdoveconf: Warning: NOTE: You can get a new clean config file with: doveconf -n > dovecot-new.conf
. ok
Il a bien démarré mais un warning s’affiche, j’ai l’impression qu’il a quelque chose qu’il ne digère pas.
J’aimerai régler ce problème avant qu’il ne pourrisse la suite.
Le tuto doit être un peu vieux. Depuis la configuration de dovecot a changé.
Si ça peut t’aider, il y avait un topic au sujet de la nouvelle conf : debian-fr.org/dovecot-proble … 44714.html
