Voila la configuration varnish que j’utilise pour www.debian-fr.org, pour ceux que ça intéresse.
(forum.appart.debian-fr.org => VPN => maison de ed)
backend forumdebianfr {
.host = "forum.appart.debian-fr.org";
.port = "80";
.max_connections = 5000;
.connect_timeout = 600s;
.first_byte_timeout = 600s;
.between_bytes_timeout = 600s;
sub vcl_recv {
set req.http.host = "www.debian-fr.org";
# Properly handle different encoding types
if (req.http.Accept-Encoding) {
if (req.url ~ "\.(jpg|jpeg|png|ico|gif|tgz|bz2|tbz|mp3|ogg|swf)$") {
# No point in compressing these
remove req.http.Accept-Encoding;
} elsif (req.http.Accept-Encoding ~ "gzip") {
set req.http.Accept-Encoding = "gzip";
} elsif (req.http.Accept-Encoding ~ "deflate") {
set req.http.Accept-Encoding = "deflate";
} else {
# unkown algorithm
# Cache things with these extensions
if (req.url ~ "\.(js|css|jpg|jpeg|ico|png|gif|tgz|bz2|tbz|mp3|ogg|swf)$") {
return (lookup);
# Allow a grace period for offering "stale" data in case backend lags
set req.grace = 5m;
# Force lookup if the request is a no-cache request from the client
if (req.http.Cache-Control ~ "no-cache") {
return (pass);
if (req.url ~ "\.(xml)$") {
return (pass);
sub vcl_fetch {
# Grace to allow varnish to serve content if backend is lagged
set obj.grace = 5m;
# These status codes should always pass through and never cache.
if (obj.status == 404 || obj.status == 503 || obj.status == 500) {
set obj.http.X-Cacheable = "NO: obj.status";
set obj.http.X-Cacheable-status = obj.status;
return (pass);
unset obj.http.set-cookie;
if (!obj.cacheable) {
set obj.http.X-Cacheable = "NO: !obj.cacheable";
return (pass);
else {
# From http://varnish-cache.org/wiki/VCLExampleLongerCaching
/* Remove Expires from backend, it's not long enough */
unset obj.http.expires;
# These TTLs are based on the specific paths and may not apply to your site.
# You could just set a single default TTL if you want.
if (req.url ~ "(.js|.css)$") {
set obj.ttl = 60m; // js and css files ttl 60 minutes
} else {
set obj.ttl = 10m; // default ttl 10 minutes
# marker for vcl_deliver to reset Age:
set obj.http.magicmarker = "1";
# All tests passed, therefore item is cacheable
set obj.http.X-Cacheable = "YES";
return (deliver);
sub vcl_error {
if (obj.status == 503 && req.restarts < 5) {
set obj.http.X-Restarts = req.restarts;
restart;
# Added to let users force refresh
sub vcl_hit {
pass;
# Ignore requests via proxy caches, IE users and badly behaved crawlers
# like msnbot that send no-cache with every request.
if (! (req.http.Via || req.http.User-Agent ~ "bot|MSIE")) {
set obj.ttl = 0s;
return (restart);
deliver;
