Configurer un Dual screen
bonjour
je viens de récupérer un second écran et je souhaiterais l’activer sous debian mais voila je n’arrive pas à l’activer j’ai bien le check du bios sur le 2 éme écran mais une fois arriver à la séction login plus rien il clignote de tout les couleurs :laughing:
voici le xorg.conf
[code]# /etc/X11/xorg.conf (xorg X Window System server configuration file)
Section “Files”
FontPath “/usr/share/fonts/X11/misc”
FontPath “/usr/X11R6/lib/X11/fonts/misc”
FontPath “/usr/share/fonts/X11/cyrillic”
FontPath “/usr/X11R6/lib/X11/fonts/cyrillic”
FontPath “/usr/share/fonts/X11/100dpi/:unscaled”
FontPath “/usr/X11R6/lib/X11/fonts/100dpi/:unscaled”
FontPath “/usr/share/fonts/X11/75dpi/:unscaled”
FontPath “/usr/X11R6/lib/X11/fonts/75dpi/:unscaled”
FontPath “/usr/share/fonts/X11/Type1”
FontPath “/usr/X11R6/lib/X11/fonts/Type1”
FontPath “/usr/share/fonts/X11/100dpi”
FontPath “/usr/X11R6/lib/X11/fonts/100dpi”
FontPath “/usr/share/fonts/X11/75dpi”
FontPath “/usr/X11R6/lib/X11/fonts/75dpi”
# path to defoma fonts
FontPath “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType”
EndSection
Section “Module”
Load “i2c”
Load “bitmap”
Load “ddc”
Load “dri”
Load “extmod”
Load “freetype”
Load “glx”
Load “int10”
Load “vbe”
EndSection
Section “InputDevice”
Identifier “Generic Keyboard”
Driver “kbd”#
This file was generated by dexconf, the Debian X Configuration tool, using
values from the debconf database.
Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
(Type “man /etc/X11/xorg.conf” at the shell prompt.)
This file is automatically updated on xserver-xorg package upgrades only
if it has not been modified since the last upgrade of the xserver-xorg
package.
If you have edited this file but would like it to be automatically updated
again, run the following command:
sudo dpkg-reconfigure -phigh xserver-xorg
Option		"CoreKeyboard"
Option		"XkbRules"	"xorg"
Option		"XkbModel"	"pc105"
Option		"XkbLayout"	"fr"
Option		"XkbVariant"	"latin9"
EndSection
Identifier “Configured Mouse”
Driver “mouse”
Option “CorePointer”
Option “Device” “/dev/input/mice”
Option “Protocol” “ImPS/2”
Option “Emulate3Buttons” “true”
EndSection
Section “Device”
Identifier “nVidia Corporation NV31 [GeForce FX 5600]”
Driver “nv”
BusID “PCI:1:0:0”
#il s’agit des 3 lignes que j ai rajouter
Option “HSync2” “65”
Option “VRefresh2” “60”
Option “Mode2” “1024x768”
EndSection
Section “Monitor”
Identifier “Écran générique”
Option “DPMS”
HorizSync 28-57
VertRefresh 43-60
EndSection
Section “Screen”
Identifier “Default Screen”
Device “nVidia Corporation NV31 [GeForce FX 5600]”
Monitor “Écran générique”
DefaultDepth 24
SubSection “Display”
Depth 1
Modes “1152x768” “1024x768” “800x600” “640x480”
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section “ServerLayout”
Identifier “Default Layout”
Screen “Default Screen”
InputDevice “Generic Keyboard”
InputDevice “Configured Mouse”
EndSection
Section “DRI”
Mode 0666
EndSection[/code]
merci de votre aide à tous :smt006
j’essaye d’afficher le bureau “étendu” sur mon second écran avec une NVIDIA FX5500.
J’ai installé nvidia-glx-new et nvidia-config
J’ai ensuite tapé nvidia-settings et voici ce qu il me marque comme erreur mais je comprend pas pourquoi
Suivi d'un reboot de ta session graphique.
Suivi d’un reboot de ta session graphique.
tu a du mal lire la probleme [quote]il dit run nvidia-xconfig [/quote]
C’est ce que tu dois faire, lancer nvidia-xconfig en root, puis redémarrer ta session graphique (le début de la commande que je t’ai donné te permet juste d’installer nvidia-xconfig au cas où tu ne l’aurais pas encore fait).
nvidia-xconfig et un paramétre non un paquet
encore merci
Non non, nvidia-xconfig est bien un paquet : $ apt-cache show nvidia-xconfig Package: nvidia-xconfig Priority: optional Section: x11 Installed-Size: 196 Maintainer: Debian NVIDIA Maintainers <pkg-nvidia-devel@lists.alioth.debian.org> Architecture: amd64 Version: 1.0+20080522-2 Depends: pkg-config, libc6 (>= 2.7-1) Suggests: nvidia-glx (>= 1.0.8174) Filename: pool/main/n/nvidia-xconfig/nvidia-xconfig_1.0+20080522-2_amd64.deb Size: 76620 MD5sum: 5e94c62282a17179159f1268392a3338 SHA1: 908891f7af70f8807b988900b23300aa32978273 SHA256: 032728786aa953f5feae60f453747befcc690d5771a0d8ee11359d9a12207f1f Description: The NVIDIA X Configuration Tool nvidia-xconfig: A tool for manipulating X config files, specifically for use by the systems with the NVIDIA Linux graphics driver. Tag: hardware::video, role::program, scope::utility, use::configuring
Son rôle est de te générer un xorg.conf minimaliste, avec le pilote proprio ‘nvidia’ comme choix par défaut.
tu peux mettre Driver "nvidia"dans la section Device du xorg.conf
Dans ce cas, pas la peine d’utiliser nvidia-xconfig, qui ne fait pratiquement rien de plus…
j ai fais comme tu a dis mais sa pose probléme
il me dit impossible de charger le nvidia-kernel module
le paquet se trouve bien installer pourtant
quel est ton noyau (uname -r) ?
comment as-tu installé le driver nvidia ?
voici la reponse du uname-r 2.6.26-2-686
j ai installer le driver nvidia de par synaptic
[quote=“zyriuse”]j ai installer le driver nvidia de par synaptic[/quote]le driver pré-compilé alors ?
peux-tu donner le résultat de:$ apt-cache policy nvidia-kernel-2.6.26-2-686 $ apt-cache policy nvidia-glx
j avais oublier d’installer le kernel :laughing: :laughing:
encore merci pour votre aide
