Bonjour a tous et eventuellement aux quelques toutes… dans ce monde impitoyable de la gnu /linux!!
Je suis tout nouveau tout frais dans ce forum debian…
informaticien de base avec quelque notions en administration linux…
4h46, du mat en essayant de me connecté a mon serveur (conf debian lenny) grace a nomachine (comme ce que j’ai fait jusqu’a ce jour et que tout marché nickel!! Avant…)
ma surprise est que j’ai reçus ce foutu message dans la goule:
[code]NX> 203 NXSSH running with pid: 2504
NX> 285 Enabling check on switch command
NX> 285 Enabling skip of SSH config files
NX> 285 Setting the preferred NX options
NX> 200 Connected to address: 82.241.32.238 on port: 22
NX> 202 Authenticating user: nx
NX> 208 Using auth method: publickey
HELLO NXSERVER - Version 3.3.0-22 - LFE
NX> 105 Hello NXCLIENT - Version 3.3.0
NX> 134 Accepted protocol: 3.3.0
NX> 105 Set shell_mode: shell
NX> 105 Set auth_mode: password
NX> 105 Login
NX> 101 User: najel
NX> 102 Password: *******
NX> 103 Welcome to: serveur user: najel
NX> 105 Listsession --user=“najel” --status=“suspended\054running” --geometry=“1280x800x32+render” --type="unix-kde"
NX> 127 Available sessions:
Display Type Session ID Options Depth Screen Status Session Name
NX> 148 Server capacity: not reached for user: najel
NX> 105 Start session with: --link=“adsl” --backingstore=“1” --encryption=“1” --cache=“16M” --images=“64M” --shmem=“1” --shpix=“1” --strict=“0” --composite=“1” --media=“0” --session=“najel” --type=“unix-kde” --geometry=“1280x770” --client=“winnt” --keyboard=“pc102\057fr” --screeninfo="1280x770x32+render"
Sun Jul 19 04:41:55 2009 running as user: ‘nx’ (uid: 109, pid: 22580) on 'serveur’
Info: user login is najel (NXShell)
Info: user password is ‘******’ (NXShell)
Info: using ‘sshd authentication’ (NXShell)
Info: selected user ‘najel’ is authenticated (NXNodeExec)
Info: password for selected user is in ‘text’ mode (NXNodeExec)
Info: preferred auth method is ‘’ (NXNodeExec)
Info: selected NX Node with host name ‘localhost’, port ‘22’ (NXNodeExec)
Info: selected publickey method to login NX Node (NXNodeExec)
Info: nxssh command line is ‘/usr/NX/bin/nxssh -nxservermode -l najel localhost -p 22 -x -2 -i /usr/NX/etc/keys/node.localhost.id_dsa -o ‘PubkeyAuthentication yes’ -o ‘RSAAuthentication yes’ -o ‘RhostsAuthentication no’ -o ‘PasswordAuthentication no’ -o ‘RhostsRSAAuthentication no’ -o ‘StrictHostKeyChecking no’ /usr/NX/bin/nxnode’ (NXNodeExec)
Info: nxssh child pid is: 22592 (NXNodeExec)
Info: received data in out channel from NX Node: ‘NX> 618 Your evaluation period has expired. Please visit
NX> 618 the NoMachine Web site at http://www.nomachine.com/
NX> 618 to acquire a valid subscription.
’ (NXNodeExec)
Info: received data in out channel from NX Node: ‘NX> 690 Bye.
’ (NXNodeExec)
Info: NX Node out channel was closed (NXNodeExec)
Info: NX Node err channel was closed (NXNodeExec)
Info: closing nxssh’s in, out, err FDs (flagfinished is: 0) (NXNodeExec)
Error: no ‘CONNECTED’ message from NX Node (NXNodeExec)
NX> 595 ERROR: A fatal error occurred in NX Server.
NX> 595 ERROR: The exception id is: 7ADF4D8A. To get detailed information about
NX> 595 ERROR: the error search for the string 7ADF4D8A in the system log
NX> 595 ERROR: file (usually ‘/var/log/messages’).
NX> 500 ERROR: Last operation failed.
NX> 280 Exiting on signal: 15[/code]
Contenu du /var/log/messages:
Jul 19 04:27:35 serveur NXNODE-3.3.0-17[13476]: WARNING: Your evaluation period has expired. Please visit
Jul 19 04:27:35 serveur NXNODE-3.3.0-17[13476]: WARNING: the NoMachine Web site at http://www.nomachine.com/
Jul 19 04:27:35 serveur NXNODE-3.3.0-17[13476]: WARNING: to acquire a valid subscription.
Jul 19 04:27:51 serveur kernel: [115890.137202] udevd version 125 started
Jul 19 04:28:03 serveur dhcdbd: Started up.
Jul 19 04:28:04 serveur kernel: [115902.908756] eth0: setting half-duplex.
Jul 19 04:28:04 serveur kernel: [115902.909408] ADDRCONF(NETDEV_UP): eth0: link is not ready
Jul 19 04:29:17 serveur NXNODE-3.3.0-17[21327]: WARNING: Your evaluation period has expired. Please visit
Jul 19 04:29:17 serveur NXNODE-3.3.0-17[21327]: WARNING: the NoMachine Web site at http://www.nomachine.com/
Jul 19 04:29:17 serveur NXNODE-3.3.0-17[21327]: WARNING: to acquire a valid subscription.
Jul 19 04:41:26 serveur NXSERVER-3.3.0-22[22562]: Cannot read from stdin: NX client disconnected before the 'bye' message: exiting cleanly 'NXShell::handleE$
Jul 19 04:41:51 serveur NXSERVER-3.3.0-22[22580]: User 'najel' logged in from '89.88.179.119'. 'NXLogin::set'
Jul 19 04:41:52 serveur NXSERVER-3.3.0-22[22580]: Selected node host:localhost with port:22 'main::selectNode'
Jul 19 04:41:52 serveur NXSERVER-3.3.0-22[22580]: Current selected node: localhost is in status: running 'main::selectNode'
Jul 19 04:41:52 serveur NXSERVER-3.3.0-22[22580]: Selected session type: unix-kde allowed in the profile of user: najel 'NXShell::Static'
Jul 19 04:41:53 serveur NXNODE-3.3.0-17[22596]: WARNING: Your evaluation period has expired. Please visit
Jul 19 04:41:53 serveur NXNODE-3.3.0-17[22596]: WARNING: the NoMachine Web site at http://www.nomachine.com/
Jul 19 04:41:53 serveur NXNODE-3.3.0-17[22596]: WARNING: to acquire a valid subscription.
Jul 19 04:41:55 serveur NXSERVER-3.3.0-22[22580]: ERROR: nxssh process exited with '1' 'NXNodeExec::exec'
Jul 19 04:41:55 serveur NXSERVER-3.3.0-22[22580]: ERROR: (exception id 7ADF4D8A) Error: no 'CONNECTED' message from NX Node
Jul 19 04:41:55 serveur NXSERVER-3.3.0-22[22580]: ERROR: (exception id 7ADF4D8A) NXNodeExec::exec('startsession', 'user=najel&userip=89%2e88%2e179%2e119&uni$
Jul 19 04:41:55 serveur NXSERVER-3.3.0-22[22580]: ERROR: (exception id 7ADF4D8A) NXShell::handler_session_start('--link="adsl" --backingstore="1" --encrypti$
Jul 19 04:41:55 serveur NXSERVER-3.3.0-22[22580]: ERROR: (exception id 7ADF4D8A) NXShell::handle_command('startsession', '--link="adsl" --backingstore="1" -$
Jul 19 04:41:55 serveur NXSERVER-3.3.0-22[22580]: ERROR: (exception id 7ADF4D8A) NXShell::run() called at nxserver.pl line 4470
Jul 19 04:41:55 serveur NXSERVER-3.3.0-22[22580]: ERROR: (exception id 7ADF4D8A) eval {...} called at nxserver.pl line 4429
avec ma modeteste connaissance, je sais que nomachine est gratuit a vie, a ce jour j’ai d’autre serveurs que j’ai installé avec nomachine bien avant celle ci, et qui se connectent encore sans problémes…
si qulqu’un sais d’ou peut venir le probléme et commen je peux le resoudre, qu’il eclaire ma lanterne PLZ!!
