Je confirme que les deux écrans fonctionnent.
Avec l’écran PC seul
$ xrandr --verbose
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192
DIN disconnected (normal left inverted right x axis y axis)
Identifier: 0x51
Timestamp: 21046226
Subpixel: no subpixels
Clones:
CRTCs: 0 1
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
TearFree: auto
supported: off, on, auto
tv standard: ntsc
supported: ntsc, pal, pal-m, pal-60, ntsc-j, scart-pal, pal-cn, secam
load detection: 1
range: (0, 1)
link-status: Good
supported: Good, Bad
CONNECTOR_ID: 46
supported: 46
non-desktop: 0
range: (0, 1)
DVI-0 connected primary 1920x1080+0+0 (0x55) normal (normal left inverted right x axis y axis) 527mm x 296mm
Identifier: 0x52
Timestamp: 21046226
Subpixel: horizontal rgb
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1
filter:
EDID:
00ffffffffffff0026cd2f612e0a0000
271b010380351e782add75a5554e9d27
0b5054a56b80710081408180a940b300
9500950fd1c0023a801871382d40582c
45000f282100001e000000ff00313135
31313733394132363036000000fd0037
4c1e5311000a202020202020000000fc
00504c32343932480a2020202020015f
020322f14f9005040302011112131406
0715161f230907078301000065030c00
1000023a801871382d40582c45000f28
2100001f011d8018711c1620582c2500
0f282100009e011d007251d01e206e28
55000f282100001e8c0ad08a20e02d10
103e96000f28210000182a4480a07038
2740302035000f282100001a00000070
TearFree: auto
load detection: 1
range: (0, 1)
audio: auto
scaling mode: None
supported: None, Full, Center, Full aspect
dither: off
supported: off, on
underscan vborder: 0
range: (0, 128)
underscan hborder: 0
range: (0, 128)
underscan: off
coherent: 1
range: (0, 1)
link-status: Good
CONNECTOR_ID: 48
supported: 48
non-desktop: 0
range: (0, 1)
1920x1080 (0x55) 148.500MHz +HSync +VSync *current +preferred
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.50KHz
v: height 1080 start 1084 end 1089 total 1125 clock 60.00Hz
1920x1080 (0x56) 148.500MHz +HSync +VSync
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 56.25KHz
v: height 1080 start 1084 end 1089 total 1125 clock 50.00Hz
1920x1080 (0x57) 148.352MHz +HSync +VSync
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 67.43KHz
v: height 1080 start 1084 end 1089 total 1125 clock 59.94Hz
1920x1080i (0x58) 74.250MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.75KHz
v: height 1080 start 1084 end 1094 total 1125 clock 60.00Hz
1920x1080i (0x59) 74.250MHz +HSync +VSync Interlace
h: width 1920 start 2448 end 2492 total 2640 skew 0 clock 28.12KHz
v: height 1080 start 1084 end 1094 total 1125 clock 50.00Hz
1920x1080i (0x5a) 74.176MHz +HSync +VSync Interlace
h: width 1920 start 2008 end 2052 total 2200 skew 0 clock 33.72KHz
v: height 1080 start 1084 end 1094 total 1125 clock 59.94Hz
1600x1200 (0x5b) 162.000MHz +HSync +VSync
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.00KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.00Hz
1680x1050 (0x5c) 119.000MHz +HSync -VSync
h: width 1680 start 1728 end 1760 total 1840 skew 0 clock 64.67KHz
v: height 1050 start 1053 end 1059 total 1080 clock 59.88Hz
1280x1024 (0x5d) 135.000MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 79.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.02Hz
1280x1024 (0x5e) 108.000MHz +HSync +VSync
h: width 1280 start 1328 end 1440 total 1688 skew 0 clock 63.98KHz
v: height 1024 start 1025 end 1028 total 1066 clock 60.02Hz
1440x900 (0x5f) 136.750MHz -HSync +VSync
h: width 1440 start 1536 end 1688 total 1936 skew 0 clock 70.64KHz
v: height 900 start 903 end 909 total 942 clock 74.98Hz
1440x900 (0x60) 88.750MHz +HSync -VSync
h: width 1440 start 1488 end 1520 total 1600 skew 0 clock 55.47KHz
v: height 900 start 903 end 909 total 926 clock 59.90Hz
1280x960 (0x61) 108.000MHz +HSync +VSync
h: width 1280 start 1376 end 1488 total 1800 skew 0 clock 60.00KHz
v: height 960 start 961 end 964 total 1000 clock 60.00Hz
1152x864 (0x62) 108.000MHz +HSync +VSync
h: width 1152 start 1216 end 1344 total 1600 skew 0 clock 67.50KHz
v: height 864 start 865 end 868 total 900 clock 75.00Hz
1280x720 (0x63) 74.250MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.00KHz
v: height 720 start 725 end 730 total 750 clock 60.00Hz
1280x720 (0x64) 74.250MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.50KHz
v: height 720 start 725 end 730 total 750 clock 50.00Hz
1280x720 (0x65) 74.176MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 44.96KHz
v: height 720 start 725 end 730 total 750 clock 59.94Hz
1024x768 (0x66) 78.750MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.02KHz
v: height 768 start 769 end 772 total 800 clock 75.03Hz
1024x768 (0x67) 65.000MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.36KHz
v: height 768 start 771 end 777 total 806 clock 60.00Hz
832x624 (0x68) 57.284MHz -HSync -VSync
h: width 832 start 864 end 928 total 1152 skew 0 clock 49.73KHz
v: height 624 start 625 end 628 total 667 clock 74.55Hz
800x600 (0x69) 49.500MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.88KHz
v: height 600 start 601 end 604 total 625 clock 75.00Hz
800x600 (0x6a) 40.000MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.88KHz
v: height 600 start 601 end 605 total 628 clock 60.32Hz
720x576 (0x6b) 27.000MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.25KHz
v: height 576 start 581 end 586 total 625 clock 50.00Hz
720x576i (0x6c) 13.500MHz -HSync -VSync Interlace
h: width 720 start 732 end 795 total 864 skew 0 clock 15.62KHz
v: height 576 start 580 end 586 total 625 clock 50.00Hz
720x480 (0x6d) 27.027MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.50KHz
v: height 480 start 489 end 495 total 525 clock 60.00Hz
720x480 (0x6e) 27.000MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.47KHz
v: height 480 start 489 end 495 total 525 clock 59.94Hz
720x480i (0x6f) 13.514MHz -HSync -VSync Interlace
h: width 720 start 739 end 801 total 858 skew 0 clock 15.75KHz
v: height 480 start 488 end 494 total 525 clock 60.00Hz
720x480i (0x70) 13.500MHz -HSync -VSync Interlace
h: width 720 start 739 end 801 total 858 skew 0 clock 15.73KHz
v: height 480 start 488 end 494 total 525 clock 59.94Hz
640x480 (0x71) 31.500MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.50KHz
v: height 480 start 481 end 484 total 500 clock 75.00Hz
640x480 (0x72) 25.200MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.50KHz
v: height 480 start 490 end 492 total 525 clock 60.00Hz
640x480 (0x73) 25.175MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.47KHz
v: height 480 start 490 end 492 total 525 clock 59.94Hz
720x400 (0x74) 28.320MHz -HSync +VSync
h: width 720 start 738 end 846 total 900 skew 0 clock 31.47KHz
v: height 400 start 412 end 414 total 449 clock 70.08Hz
DVI-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x53
Timestamp: 21046226
Clones:
CRTCs: 0 1
filter:
TearFree: auto
load detection: 1
range: (0, 1)
audio: auto
scaling mode: None
dither: off
supported: off, on
range: (0, 128)
range: (0, 128)
underscan: off
coherent: 1
range: (0, 1)
link-status: Good
CONNECTOR_ID: 51
supported: 51
non-desktop: 0
range: (0, 1)
Avec les deux écrans
$ xrandr --verbose
Identifier: 0x51
Timestamp: 25539096
Clones:
CRTCs: 0 1
filter:
TearFree: auto
tv standard: ntsc
load detection: 1
range: (0, 1)
link-status: Good
CONNECTOR_ID: 46
supported: 46
non-desktop: 0
range: (0, 1)
Identifier: 0x52
Timestamp: 25539096
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1
filter:
EDID:
TearFree: auto
load detection: 1
range: (0, 1)
audio: auto
scaling mode: None
DVI-1 connected 1920x1080+0+0 (0x55) normal (normal left inverted right x axis y axis) 1600mm x 900mm
Identifier: 0x53
Timestamp: 25539096
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 1
CRTCs: 0 1
filter:
EDID:
00ffffffffffff004dd901c901010101
0113010380a05a780a0dc9a057479827
12484c21080081800101010101010101
010101010101023a801871382d40582c
450040846300001e011d007251d01e20
6e28550040846300001e000000fc0053
4f4e592054560a2020202020000000fd
00303e0e460f000a20202020202001e4
02033570521f10202122140513041211
03021615070601290907071507505507
00830100006c030c0020008000c00808
1111e20039023a80d072382d40102c45
8040846300001e011d00bc52d01e20b8
28554040846300001e011d8018711c16
20582c250040846300009e011d80d072
1c1620102c258040846300009e000091
TearFree: auto
load detection: 1
range: (0, 1)
audio: auto
scaling mode: None
dither: off
supported: off, on
range: (0, 128)
range: (0, 128)
underscan: off
coherent: 1
range: (0, 1)
link-status: Good
CONNECTOR_ID: 51
supported: 51
non-desktop: 0
range: (0, 1)
1920x1080 (0x729) 74.250MHz +HSync +VSync
v: height 1080 start 1084 end 1089 total 1125 clock 30.00Hz
1920x1080 (0x72a) 74.250MHz +HSync +VSync
v: height 1080 start 1084 end 1089 total 1125 clock 25.00Hz
1920x1080 (0x72b) 74.250MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 27.00KHz
v: height 1080 start 1084 end 1089 total 1125 clock 24.00Hz
1920x1080 (0x72c) 74.176MHz +HSync +VSync
v: height 1080 start 1084 end 1089 total 1125 clock 29.97Hz
1920x1080 (0x72d) 74.176MHz +HSync +VSync
h: width 1920 start 2558 end 2602 total 2750 skew 0 clock 26.97KHz
v: height 1080 start 1084 end 1089 total 1125 clock 23.98Hz
Le fichier ci-dessous reste inchangé en branchant le deuxième écran
$ tail -f /var/log/Xorg.0.log
[ 25631.954] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 25631.954] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605628 +hsync +vsync (37.9 kHz e)
[ 25631.954] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771777 806 -hsync -vsync (48.4 kHz e)
[ 25631.954] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 25631.954] (--) RADEON(0): HDMI max TMDS frequency 0KHz
[ 26392.641] (EE) event3 - Microsoft Wired Keyboard 400: client bug: event processing lagging behind by 24ms, your system is too slow
[ 26396.361] (EE) event3 - Microsoft Wired Keyboard 400: client bug: event processing lagging behind by 20ms, your system is too slow
[ 26583.728] (EE) event3 - Microsoft Wired Keyboard 400: client bug: event processing lagging behind by 20ms, your system is too slow
[ 26590.960] (EE) event3 - Microsoft Wired Keyboard 400: client bug: event processing lagging behind by 28ms, your system is too slow
[ 26807.377] (EE) RADEON(0): drmmode_do_crtc_dpms cannot get last vblank counter
[ 26878.429] (II) RADEON(0): EDID vendor "IVM", prod id 24879
[ 26878.429] (II) RADEON(0): Using hsync ranges from config file
[ 26878.429] (II) RADEON(0): Using vrefresh ranges from config file
[ 26878.429] (II) RADEON(0): Printing DDC gathered Modelines:
[ 26878.429] (II) RADEON(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[ 26878.429] (II) RADEON(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725730 750 +hsync +vsync (45.0 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "1920x1080"x0.0 174.50 1920 1968 2000 2080 1080 1083 1088 1119 +hsync -vsync (83.9 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725730 750 +hsync +vsync (37.5 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488494 525 interlace -hsync -vsync (15.7 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580586 625 interlace -hsync -vsync (15.6 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605628 +hsync +vsync (37.9 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769772 800 +hsync +vsync (60.0 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771777 806 -hsync -vsync (48.4 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628667 -hsync -vsync (49.7 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604625 +hsync +vsync (46.9 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "1152x864"x0.0 108.00 1152 1216 1344 1600 864 865868 900 +hsync +vsync (67.5 kHz e)
[ 26878.429] (II) RADEON(0): Modeline "1152x720"x60.0 67.32 1152 1208 1328 1504 720 721724 746 -hsync +vsync (44.8 kHz e)
[ 26878.430] (II) RADEON(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961964 1000 +hsync +vsync (60.0 kHz e)
[ 26878.430] (II) RADEON(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 26878.430] (II) RADEON(0): Modeline "1600x1200"x0.0 162.00 1600 1664 1856 2160 1200 1201 1204 1250 +hsync +vsync (75.0 kHz e)
[ 26878.430] (II) RADEON(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 26878.430] (II) RADEON(0): Modeline "1440x900"x0.0 88.75 1440 1488 1520 1600 900 903909 926 +hsync -vsync (55.5 kHz e)
[ 26878.430] (II) RADEON(0): Modeline "1440x900"x0.0 136.75 1440 1536 1688 1936 900 903909 942 -hsync +vsync (70.6 kHz e)
[ 26878.486] (--) RADEON(0): HDMI max TMDS frequency 0KHz
