bonjour ,
juste par curiosité j’ai voulu comparer la commande recommandée ( je suppose )
( dmesg -l err ) avec celle que j’utilisais avant ( dmesg | egrep « failed|error » ) et pour cela j’ai testé bookworm qui est en attente sur un ssd externe . Comme il s’agit d’une version en cours de test j’espérais des erreurs et effectivement :
~$ sudo dmesg | egrep "failed|error"
[sudo] Mot de passe de mm :
[ 5.579904] systemd[1]: File System Check on Root Device was skipped because of a failed condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[ 5.588543] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[ 5.611166] EXT4-fs (sdb1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
[ 5.613513] systemd[1]: Platform Persistent Storage Archival was skipped because of a failed condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[ 5.642921] systemd[1]: First Boot Complete was skipped because of a failed condition check (ConditionFirstBoot=yes).
[ 6.583648] wl: module verification failed: signature and/or required key missing - tainting kernel
[ 7.404014] bluetooth hci0: firmware: failed to load brcm/BCM43142A0-04ca-2006.hcd (-2)
[ 7.404124] bluetooth hci0: firmware: failed to load brcm/BCM-04ca-2006.hcd (-2)
mm@ssd2:~$ sudo dmesg -l err
[ 7.404063] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[ 7.404180] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[ 7.404226] Bluetooth: hci0: BCM: 'brcm/BCM43142A0-04ca-2006.hcd'
[ 7.404265] Bluetooth: hci0: BCM: 'brcm/BCM-04ca-2006.hcd'
[ 9.433930] Bluetooth: hci0: command 0x1003 tx timeout
[ 9.435166] Bluetooth: hci0: unexpected event for opcode 0x1003
je constate principalement que ( dmesg -l err ) ne détecte pas " File System Check on Root Device was skipped … ) ce qui pourrait être problématique ( en fait je n’en ai aucune idée ) .
Comme il s’agit de bookworm je ne vais pas me lancer dans une tentative de correction qui n’a peut-être pas lieu d’être , mais est-il normal que ce problème éventuel ne soit pas signalé par ( dmesg -l err ) ?
