Bon, finalement, à cause de pb de dépendances, il ne m’installait pas la librairie. Maintenant c’est ok, le configure passe.
Mais :
20:35 root@Opale /usr/local/bin/Sid/swftools-0.7.0/avi2swf# avi2swf -r 44100 test.avi -o test.swf
<init> : Avifile RELEASE-0.7.44-060819-05:28-(Debian
<init> : Available CPU flags: fpu vme de pse tsc msr pae mce cx8 sep mtrr pge mca cmov pat pse36 mmx fxsr sse
<init> : 4294.97 MHz Pentium III (Coppermine) processor detected
<reader> : Checking: test.avi
<AVI reader> : MainHeader: MicroSecPerFrame=66666 MaxBytesPerSec=0
PaddingGranularity=0 Flags=[ HAS_INDEX IS_INTERLEAVED TRUST_CKTYPE ] TotalFrames=1447
InitialFrames=0 Streams=2 SuggestedBufferSize=0 WxH=640x480
Scale=0 Rate=0 Start=0 Length=0
<AVI reader> : StreamHeader: Type=vids Handler=FMP4 Flags=[ ]
InitialFrames=0 Scale=1 Rate=15 Start=0 Length=1447
SuggestedBufferSize=19412 Quality=0 SampleSize=0 Rect l,r,t,b=0,640,0,480
<AVI reader> : StreamHeader: Type=auds Handler=0x1 Flags=[ ]
InitialFrames=2 Scale=1 Rate=7875 Start=0 Length=763778
SuggestedBufferSize=7874 Quality=0 SampleSize=2 Rect l,r,t,b=0,0,0,0
<AVI reader> : InfoChunk Software: MEncoder dev-CVS-060416-09:11-4.0.3
<AVI reader> : Reading index from offset: 11415990
<AVI reader> : Stream 0 vids : FMP4 (0x34504d46) 1447 chunks (5.65KB)
<AVI reader> : Stream 1 auds : PCM (0x1) 194 chunks (1.52KB)
<reader> : Initialized audio stream (chunk tblsz: 1527556, fmtsz: 18)
<reader> : Initialized video stream (chunk tblsz: 1447, fmtsz: 40)
<LDT keeper> : Installed fs segment: 0xb7cd3000
<codec keeper> : Found 9 plugins (/usr/lib/avifile-0.7,A:40,V:85)
<codec keeper> : CreateVideoDecoder(): Unknown codec 0x34504d46 = "FMP4"
<codec keeper> : PCM audio decoder created
formatinfo: format 1, 1 channels, 16 bits/sample, rate 7875, blockalign 2
Error: no sound support compiled in.
zsh: exit 1 avi2swf -r 44100 test.avi -o test.swf
Merci pour vos lumières
