bonsoir tout le monde
avec quel programme on coupe et regroupe des gros fichiers sous linux
sous windows je connais winrar , HJSPLIT et d’autres
mais sous linux?
mais sous linux?
tu as rar sous linux aussi
[code]NAME
rar - archive files with compression
-tl Set archive time to latest file. Forces rar to set the date of a changed archive to the date of
the newest file in the archive.
-u Update files.
-v<size>[k|b|f]
Create volumes with size=<size>*1000 [*1024, *1].
-vd Erase disk contents before creating volume.All files and directories on the target disk will be
erased when '-vd' is used. The switch applies only to removable media, the hard disk cannot be
erased using this switch.
