J’ai une Canon Pixma MG5250 que je souhaite utiliser en réseau (via Wifi sur un routeur numéricable), mon desktop est sous Debian Wheezy, GNOME-Shell 3.4.
J’ai avec system-config-printer configuré mon imprimante (l’ancienne interface de GNOME pour, j’ai entendu dire que la nouvelle n’était pas totalement fonctionnelle et elle refuse de trouver mon imprimante…) et je me suis rendu dans localhost:631 et j’ai lancé une page de test, seulement j’obtient le message suivant: /usr/lib/cups/backend/lpd failed après quelques secondes.
J’ai activé le mode debug cupds.conf et j’ai dans error_log ceci:
D [21/Jan/2013:15:05:03 +0100] cupsdReadClient: 22 GET /printers/Gutenberg HTTP/1.1
D [21/Jan/2013:15:05:03 +0100] cupsdSetBusyState: newbusy="Active clients", busy="Not busy"
D [21/Jan/2013:15:05:03 +0100] cupsdAuthorize: Authorized as root using Basic
D [21/Jan/2013:15:05:03 +0100] [CGI] argv[0] = "/usr/lib/cups/cgi-bin/printers.cgi"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[0] = "CUPS_CACHEDIR=/var/cache/cups"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[1] = "CUPS_DATADIR=/usr/share/cups"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[2] = "CUPS_DOCROOT=/usr/share/cups/doc-root"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[3] = "CUPS_FONTPATH=/usr/share/cups/fonts"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[4] = "CUPS_REQUESTROOT=/var/spool/cups"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[5] = "CUPS_SERVERBIN=/usr/lib/cups"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[6] = "CUPS_SERVERROOT=/etc/cups"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[7] = "CUPS_STATEDIR=/var/run/cups"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[8] = "HOME=/var/spool/cups/tmp"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[9] = "PATH=/usr/lib/cups/filter:/usr/bin:/usr/sbin:/bin:/usr/bin"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[10] = "SERVER_ADMIN=root@Onyx"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[11] = "SOFTWARE=CUPS/1.5.3"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[12] = "TMPDIR=/var/spool/cups/tmp"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[13] = "TZ=Europe/Paris"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[14] = "USER=root"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[15] = "CUPS_SERVER=/var/run/cups/cups.sock"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[16] = "CUPS_ENCRYPTION=IfRequested"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[17] = "IPP_PORT=631"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[18] = "AUTH_TYPE=Basic"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[19] = "LANG=fr_FR.UTF8"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[20] = "REDIRECT_STATUS=1"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[21] = "GATEWAY_INTERFACE=CGI/1.1"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[22] = "SERVER_NAME=localhost"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[23] = "SERVER_PORT=631"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[24] = "REMOTE_ADDR=127.0.0.1"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[25] = "REMOTE_HOST=localhost"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[26] = "SCRIPT_NAME=/printers/Gutenberg"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[27] = "SCRIPT_FILENAME=/usr/share/cups/doc-root/printers/Gutenberg"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[28] = "PATH_INFO=/Gutenberg"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[29] = "REMOTE_USER=root"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[30] = "SERVER_PROTOCOL=HTTP/1.1"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[31] = "HTTP_COOKIE=org.cups.sid=df6fd1d4c145464c1fb06e882d1b0587"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[32] = "HTTP_USER_AGENT=Opera/9.80 (X11; Linux x86_64) Presto/2.12.388 Version/12.12"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[33] = "HTTP_REFERER=http://localhost:631/printers/Gutenberg"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[34] = "REQUEST_METHOD=GET"
D [21/Jan/2013:15:05:03 +0100] [CGI] envp[35] = "QUERY_STRING="
D [21/Jan/2013:15:05:03 +0100] [CGI] Started /usr/lib/cups/cgi-bin/printers.cgi (PID 5672)
I [21/Jan/2013:15:05:03 +0100] Started "/usr/lib/cups/cgi-bin/printers.cgi" (pid=5672)
D [21/Jan/2013:15:05:03 +0100] cupsdSendCommand: 22 file=20
D [21/Jan/2013:15:05:03 +0100] [CGI] org.cups.sid cookie is "df6fd1d4c145464c1fb06e882d1b0587"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetVariable: SECTION="printers"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetVariable: REFRESH_PAGE=""
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetVariable: PRINTER_NAME="Gutenberg"
D [21/Jan/2013:15:05:03 +0100] cupsdAcceptClient: 23 from localhost (Domain)
D [21/Jan/2013:15:05:03 +0100] cupsdReadClient: 23 POST / HTTP/1.1
D [21/Jan/2013:15:05:03 +0100] cupsdSetBusyState: newbusy="Active clients", busy="Active clients"
D [21/Jan/2013:15:05:03 +0100] cupsdAuthorize: No authentication data provided.
D [21/Jan/2013:15:05:03 +0100] cupsdReadClient: 23 1.1 CUPS-Get-Default 1
D [21/Jan/2013:15:05:03 +0100] CUPS-Get-Default
D [21/Jan/2013:15:05:03 +0100] Returning IPP successful-ok for CUPS-Get-Default (no URI) from localhost
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetVariable: DEFAULT_NAME="Gutenberg"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetVariable: DEFAULT_URI="/printers/Gutenberg"
D [21/Jan/2013:15:05:03 +0100] [CGI] show_printer(http=0x7f9b1426b060, printer="Gutenberg")
D [21/Jan/2013:15:05:03 +0100] cupsdReadClient: 23 1.1 Get-Printer-Attributes 1
D [21/Jan/2013:15:05:03 +0100] Get-Printer-Attributes ipp://localhost/printers/Gutenberg
D [21/Jan/2013:15:05:03 +0100] Returning IPP successful-ok for Get-Printer-Attributes (ipp://localhost/printers/Gutenberg) from localhost
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetVariable: SERVER_NAME="localhost"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetVariable: REMOTE_USER="root"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetVariable: CUPS_VERSION="CUPS v1.5.3"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: printer_is_accepting_jobs[0]="1"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: printer_is_shared[0]="1"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: printer_state[0]="5"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: admin_uri[0]="/admin/"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: printer_uri_supported[0]="/printers/Gutenberg"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: printer_name[0]="Gutenberg"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: printer_location[0]="192.168.0.19"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: printer_info[0]="Canon PIXMA MG5200"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: job_sheets_default[0]="none, none"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: device_uri[0]="lpd://192.168.0.19/lp"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: color_supported[0]="1"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: printer_make_and_model[0]="Canon PIXMA MG5200 - CUPS+Gutenprint v5.2.9"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: media_default[0]="iso_a4_210x297mm"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: sides_supported[0]="one-sided, two-sided-long-edge, two-sided-short-edge"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: sides_default[0]="one-sided"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: printer_commands[0]="none"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: server_is_sharing_printers[0]="0"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetVariable: TITLE="Gutenberg"
D [21/Jan/2013:15:05:03 +0100] Script header: Content-Type: text/html;charset=utf-8
D [21/Jan/2013:15:05:03 +0100] [CGI] Regular expression ".*Clean.*"
D [21/Jan/2013:15:05:03 +0100] [CGI] Regular expression ".*PrintSelfTestPage.*"
D [21/Jan/2013:15:05:03 +0100] cupsdReadClient: 23 1.1 Get-Jobs 1
D [21/Jan/2013:15:05:03 +0100] Get-Jobs ipp://localhost:631/printers/Gutenberg
D [21/Jan/2013:15:05:03 +0100] Returning IPP successful-ok for Get-Jobs (ipp://localhost:631/printers/Gutenberg) from localhost
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiClearVariables called.
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetVariable: ORDER="asc"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetVariable: TOTAL="1"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: job_printer_name[0]="Gutenberg"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: job_printer_uri[0]="/printers/Gutenberg"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: time_at_creation[0]="lun. 21 janv. 2013 15:04:44 CET"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: time_at_processing[0]="lun. 21 janv. 2013 15:04:44 CET"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: time_at_completed[0]="novalue"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: job_id[0]="3"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: job_state[0]="3"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: job_media_sheets_completed[0]="1"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: job_k_octets[0]="1"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetArray: job_printer_state_message[0]="/usr/lib/cups/backend/lpd failed"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetVariable: PRINTER_URI_SUPPORTED="/printers/Gutenberg"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetVariable: THISURL="/printers/Gutenberg"
D [21/Jan/2013:15:05:03 +0100] [CGI] cgiSetVariable: SEARCH_DEST="Gutenberg"
D [21/Jan/2013:15:05:03 +0100] cupsdReadClient: 23 WAITING Closing on EOF
D [21/Jan/2013:15:05:03 +0100] cupsdCloseClient: 23
D [21/Jan/2013:15:05:03 +0100] PID 5672 (/usr/lib/cups/cgi-bin/printers.cgi) exited with no errors.
D [21/Jan/2013:15:05:03 +0100] cupsdSetBusyState: newbusy="Not busy", busy="Active clients"
D [21/Jan/2013:15:05:03 +0100] cupsdReadClient: 16 GET /cups.css HTTP/1.1
D [21/Jan/2013:15:05:03 +0100] cupsdReadClient: 18 GET /images/cups-icon.png HTTP/1.1
D [21/Jan/2013:15:05:03 +0100] cupsdReadClient: 19 GET /images/left.gif HTTP/1.1
D [21/Jan/2013:15:05:03 +0100] cupsdReadClient: 21 GET /images/right.gif HTTP/1.1
D [21/Jan/2013:15:05:03 +0100] cupsdReadClient: 22 GET /images/unsel.gif HTTP/1.1
D [21/Jan/2013:15:05:03 +0100] cupsdReadClient: 16 GET /images/sel.gif HTTP/1.1
Je suis pas doué avec les imprimantes sous Linux… Une idée? Après moultes recherches sur gogole j’ai rien trouvé.
Cordialement, GASPARD Kévin
