Curseur introuvable sous Debian 8.4.0 Xfce
Voici le contenu de mon xorg.conf:
Section "ServerLayout"
    Identifier     "X.org Configured"
    Screen      0  "Screen0" 0 0
    InputDevice    "Mouse0" "CorePointer"
    InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
    ModulePath   "/usr/lib/xorg/modules"
    FontPath     "/usr/share/fonts/X11/misc"
    FontPath     "/usr/share/fonts/X11/cyrillic"
    FontPath     "/usr/share/fonts/X11/100dpi/:unscaled"
    FontPath     "/usr/share/fonts/X11/75dpi/:unscaled"
    FontPath     "/usr/share/fonts/X11/Type1"
    FontPath     "/usr/share/fonts/X11/100dpi"
    FontPath     "/usr/share/fonts/X11/75dpi"
    FontPath     "built-ins"
EndSection
Section "Module"
    Load  "glx"
EndSection
Section "InputDevice"
    Identifier  "Keyboard0"
    Driver      "kbd"
EndSection
    Identifier  "Mouse0"
    Driver      "mouse"
    Option        "Protocol" "auto"
    Option        "Device" "/dev/input/mice"
    Option        "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
    Identifier   "Monitor0"
    VendorName   "Monitor Vendor"
    ModelName    "Monitor Model"
EndSection
Section "Device"
        ### Available Driver options are:-
        ### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
        ### <string>: "String", <freq>: "<f> Hz/kHz/MHz",
        ### <percent>: "<f>%"
        ### [arg]: arg optional
        #Option     "SWcursor"               # [<bool>]
        #Option     "HWcursor"               # [<bool>]
        #Option     "NoAccel"                # [<bool>]
        #Option     "ShadowFB"               # [<bool>]
        #Option     "VideoKey"               # <i>
        #Option     "WrappedFB"              # [<bool>]
        #Option     "GLXVBlank"              # [<bool>]
        #Option     "ZaphodHeads"            # <str>
        #Option     "PageFlip"               # [<bool>]
        #Option     "SwapLimit"              # <i>
        #Option     "AsyncUTSDFS"            # [<bool>]
        #Option     "AccelMethod"            # <str>
    Identifier  "Card0"
    Driver      "nouveau"
    BusID       "PCI:1:0:0"
EndSection
Section "Screen"
    Identifier "Screen0"
    Device     "Card0"
    Monitor    "Monitor0"
    SubSection "Display"
        Viewport   0 0
        Depth     1
    EndSubSection
        Viewport   0 0
        Depth     4
    EndSubSection
        Viewport   0 0
        Depth     8
    EndSubSection
        Viewport   0 0
        Depth     15
    EndSubSection
        Viewport   0 0
        Depth     16
    EndSubSection
        Viewport   0 0
        Depth     24
    EndSubSection
EndSection
Cette option est commentée, et l’option HWcursor est activée par defaut.
Ça ne coûterait pas grand chose de dé-commenter l’option SWcursor et relancer le serveur X
histoire de voir si le curseur réapparaît.
J’ai essayé d’éditeur le Xorg.conf mais je n’ai pas les permissions, pourtant je suis en root. :triumph:
faudrait surtout installer le bon driver pour ta carte nvidia…
+1
Sûr que ça ne sert à rien de modifier le fichier de configuration tant que le bon pilote n’est pas installé.
Je pensais que cette histoire ( 96.43.23 does not support your current Xorg version) de pilote était réglée
J’ai réussi à éditer xorg.conf mais le fait de décommenter n’a rien changé, toujours pas de curseur.
Je viens d’essayer d’installer le pilote pour ma CG depuis le package, mais j’obtiens encore un message d’erreur:
ERROR: Unable to find the system utility ld; please make sure you have
the package ‘binutils’ installed. If you do have binutils installed,
then please check that ld is in your PATH.
C’est une caméra cachée ?
non,c’est un message vous disant que vos outils de compilations sont incomplets,il vous faut installer le paquet build-essential.
Chaque solution appelle son problème…
J’ai réussi à installer le paquet en question (après avoir galéré car il me demandait d’insérer un cd donc j’ai dû modifier le fichier sources.list je crois).
J’ai relancé le package .run et là il me dit que je dois arrêter le xserver (je ne sais pas comment faire).
J’ai voulu relancer le package pour revoir le message d’erreur et là j’obtiens “permission denied”…
pourquoi pas essayer nvidia-detect
https://wiki.debian.org/fr/NvidiaGraphicsDrivers#nvidia-detect
Nvidia-detect… il me dit qu’il ne trouve pas le paquet.
Je viens d’essayer de relancer depuis le package .run et là j’ai une nouvelle erreur: “The Nouveau kernel driver is currently in use by your system. This driver is incompatible with the NVIDIA driver…”
Mhhh tout ça pour un curseur de souris ? C’est ça Linux ?
non,ce n’est pas ça ,linux; comme tout les débutants vous êtes en train d’apprendre à utiliser une machine,ce que M$ ne vous apprend pas.Mais ne vous inquiétez pas outre mesure,nous sommes tous passés par là avant vous.
Quel est votre sources.list actuel?
Vous dites:
<<J’ai relancé le package .run>>
quel package .run? qui vient de où? A aucun moment il n’a été question d’installer un paquet .run
<<et là il me dit que je dois arrêter le xserver (je ne sais pas comment faire).>>
pour arrêter le serveur X il faut passer en mode console avec la combinaison des touches:
Ctrl+Alt+F1
et faire:
/etc/init.d/lightdm stop
ou:
/etc/init.d/gdm stop
ou
/etc/init.d/kdm stop
en fonction de ce que vous utilisez comme display manager
Donnez les infos demandées pour sources.list et le résultat de la commande en user:
apt-cache policy build-essential
ainsi que:
ls /usr/src/sgfxi-downloads/
lequel, si tu n’es pas précis on ne peut pas t’aider
Copie simplement les retours des commandes dans tes prochains messages
un vieux proverbe qui me revient, " y a pas de mauvais outils, y a que de mauvais ouvriers"
J’ai voulu tout remettre à plat et j’ai fait une réinstallation fraîche cette fois-ci avec LXDE et non XFCE. Je préfère LXDE et j’avais choisi XFCE car LXDE m’avait fait le même problème de curseur auparavant. Comme le problème ne semble pas dépendre du GUI, retour à LXDE donc. Et bien sûr, toujours aucun curseur…
J’ai installé SGFXI suivant les conseils d’Avram, et j’ai lancé l’installation mais j’ai obtenu la même ERROR 226 que précédemment.
Tout à l’heure j’avais téléchargé le pilote Nvidia 96.43.23 depuis le site Nvidia et j’ai tenté de l’installer depuis ce package.
A noter que lorsque je passe en mode console CTRL + ALT + F1 j’ai des messages d’erreurs qui défilent du type:
[ 564.498165] nouveau E [PBUS] [0000:01:00.0] BUS ERROR
Y a-t-il un lien ?
ok pour le .run de nvidia,mais le pilote nouveau est toujours en place.Voilà ce que je tenterais:
-copier le fichier .run dans votre répertoire home
-passer en mode console
-passez root
-installez le paquet nvidia-xconfig avec la commande:
apt-get install nvidia-xconfig
-installez les headers de votre kernel avec la commande:
apt-get install linux-headers-$(uname -r|sed ‘s,[^-]-[^-]-,’)
suivi de:
apt-get install build-essential
-stopez votre display manager avec la commande:
/etc/init.d/“votre-display-manager” stop
-ensuite rendez le fichier .run exécutable avec la commande:
chmod +x nvidia----96.43.23.run
–en root désinstallez le pilote nouveau avec la commande:
apt-get --purge remove xserver-xorg-video-nouveau
-exécutez le fichier .run avec la commande:
./nvidia----96.43.23.run
-exécutez la commande:
nvidia-xconfig
et faites suivre le résultat des courses.
pilote ( driver) “nouveau” non adapté a la carte
faut ajouter contrib
https://packages.debian.org/jessie/amd64/nvidia-xconfig/download
tant qu’a faire ajoutez également non-free au sources.list qui devra ressembler à:
deb http://ftp.fr.debian.org/debian/ jessie main contrib non-free
deb http://security.debian.org/ jessie/updates main contrib non-free
deb http://ftp.fr.debian.org/debian/ jessie-updates main contrib non-free
quel est votre sources.list?
uname -a
dpkg --print-foreign-architectures
quand on touche au sources.list il faut ensuite faire
sudo apt-get update
Mon sources.list
Résultat des commandes uname -a et dpkg
La commande dpkg ne semble pas avoir fonctionné.
En revanche j’ai réussi à installer nvidia-xconfig après avoir amendé le sources.list. A l’issue de l’installation, j’ai eu un message me disant de modifier mon xorg.conf et effectivement j’ai reboot et la résolution en mode console a baissé et lxde ne se lance plus. Peut-être un réglage à faire au niveau du xorg.conf ?
