Voici les données obtenues:
00:00.0 Host bridge: Silicon Integrated Systems [SiS] 760/M760 Host (rev 02)
Subsystem: Hewlett-Packard Company Device 2a04
Flags: bus master, medium devsel, latency 32
Memory at e0000000 (32-bit, non-prefetchable) [size=64M]
Capabilities: <access denied>
Kernel driver in use: agpgart-amd64
00:01.0 PCI bridge: Silicon Integrated Systems [SiS] AGP Port (virtual PCI-to-PCI bridge) (prog-if 00 [Normal decode])
Flags: bus master, 66MHz, medium devsel, latency 99
Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
Memory behind bridge: e8000000-e9ffffff
Prefetchable memory behind bridge: e4000000-e7ffffff
00:02.0 ISA bridge: Silicon Integrated Systems [SiS] SiS964 [MuTIOL Media IO] LPC Controller (rev 36)
Flags: bus master, medium devsel, latency 0
00:02.5 IDE interface: Silicon Integrated Systems [SiS] 5513 IDE Controller (rev 01) (prog-if 80 [Master])
Flags: bus master, medium devsel, latency 128
I/O ports at 01f0 [size=8]
I/O ports at 03f4
I/O ports at 0170 [size=8]
I/O ports at 0374
I/O ports at 4000 [size=16]
Kernel driver in use: pata_sis
00:02.7 Multimedia audio controller: Silicon Integrated Systems [SiS] SiS7012 AC'97 Sound Controller (rev a0)
Subsystem: Hewlett-Packard Company Device 2a05
Flags: bus master, medium devsel, latency 32, IRQ 18
I/O ports at c000 [size=256]
I/O ports at c400 [size=128]
Kernel driver in use: snd_intel8x0
00:03.0 USB controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f) (prog-if 10 [OHCI])
Flags: bus master, medium devsel, latency 64, IRQ 20
Memory at eb004000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ohci-pci
00:03.1 USB controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f) (prog-if 10 [OHCI])
Flags: bus master, medium devsel, latency 64, IRQ 21
Memory at eb000000 (32-bit, non-prefetchable) [size=4K]
00:03.2 USB controller: Silicon Integrated Systems [SiS] USB 1.1 Controller (rev 0f) (prog-if 10 [OHCI])
Flags: bus master, medium devsel, latency 64, IRQ 22
Memory at eb001000 (32-bit, non-prefetchable) [size=4K]
00:03.3 USB controller: Silicon Integrated Systems [SiS] USB 2.0 Controller (prog-if 20 [EHCI])
Flags: bus master, medium devsel, latency 32, IRQ 23
Memory at eb002000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: ehci-pci
00:04.0 Ethernet controller: Silicon Integrated Systems [SiS] SiS900 PCI Fast Ethernet (rev 90)
Flags: bus master, medium devsel, latency 32, IRQ 19
I/O ports at c800 [size=256]
Memory at eb003000 (32-bit, non-prefetchable) [size=4K]
[virtual] Expansion ROM at 20000000 [disabled] [size=128K]
Kernel driver in use: sis900
00:05.0 IDE interface: Silicon Integrated Systems [SiS] RAID bus
controller 180 SATA/PATA [SiS] (rev 01) (prog-if 85 [Master SecO PriO])
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 17
I/O ports at cc00 [size=8]
I/O ports at d000 [size=4]
I/O ports at d400 [size=8]
I/O ports at d800 [size=4]
I/O ports at dc00 [size=16]
I/O ports at e000 [size=128]
Kernel driver in use: sata_sis
00:08.0 Multimedia controller: Philips Semiconductors SAA7134/SAA7135HL Video Broadcast Decoder (rev 01)
Subsystem: ASUSTeK Computer Inc. TV-FM 7134
Flags: bus master, medium devsel, latency 32, IRQ 16
Memory at eb005000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: saa7134
00:09.0 Communication controller: LSI Corporation V.92 56K WinModem (rev 03)
Subsystem: LSI Corporation Device 044c
Flags: bus master, medium devsel, latency 32, IRQ 255
Memory at eb006000 (32-bit, non-prefetchable) [size=256]
I/O ports at e400 [size=8]
I/O ports at e800 [size=256]
00:0b.0 FireWire (IEEE 1394): VIA Technologies, Inc. VT6306/7/8 [Fire
II(M)] IEEE 1394 OHCI Controller (rev 80) (prog-if 10 [OHCI])
Memory at eb007000 (32-bit, non-prefetchable) [size=2K]
I/O ports at ec00 [size=128]
Kernel driver in use: firewire_ohci
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] HyperTransport Technology Configuration
Flags: fast devsel
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Address Map
Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] DRAM Controller
Flags: fast devsel
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] K8 [Athlon64/Opteron] Miscellaneous Control
Flags: fast devsel
Kernel driver in use: k8temp
01:00.0 VGA compatible controller: NVIDIA Corporation NV18 [GeForce4 MX 440SE AGP 8x] (rev a2) (prog-if 00 [VGA controller])
Subsystem: LeadTek Research Inc. Device 2922
Flags: bus master, 66MHz, medium devsel, latency 32, IRQ 16
Memory at e8000000 (32-bit, non-prefetchable) [size=16M]
Memory at e4000000 (32-bit, prefetchable) [size=64M]
[virtual] Expansion ROM at e9000000 [disabled] [size=128K]
Kernel driver in use: nouveau
