Actuellement je retravaille en développement Web ( HTML5, CCS3, PHP7, Ajax), j’utilisais Oracle Netbeans et Eclipse comme éditeurs.
Depuis ma nouvelle mission, j’ai découvert Bluefish , j’ai installé celui-ci via les paquets Debian proposés en version stable : 2.2.6.
En consultant le site de Bluefish j’ai constaté une version plus récente : Bluefish 2.2.10
De ce fait, j’ai récupéré le fichier tar.gz afin de le compiler depuis un Terminal :
Pré-requis : Bluefish nécessite les paquetages : intltool
Voici le déroulement :
./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking whether to enable maintainer-specific portions of Makefiles... no
checking for style of include used by make... GNU
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking for LC_MESSAGES... yes
checking libintl.h usability... yes
checking libintl.h presence... yes
checking for libintl.h... yes
checking for ngettext in libc... yes
checking for dgettext in libc... yes
checking for bind_textdomain_codeset... yes
checking for msgfmt... /usr/bin/msgfmt
checking for dcgettext... yes
checking if msgfmt accepts -c... yes
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking for catalogs to be installed... ar bg ca cs da de el en es eu fa fi fr gl hu it ja ko nb nl nn pl pt pt_BR ro ru sk sr sv ta tr uk zh_CN zh_TW
checking whether NLS is requested... yes
checking for intltool-update... /usr/bin/intltool-update
checking for intltool-merge... /usr/bin/intltool-merge
checking for intltool-extract... /usr/bin/intltool-extract
checking for xgettext... (cached) /usr/bin/xgettext
checking for msgmerge... /usr/bin/msgmerge
checking for msgfmt... (cached) /usr/bin/msgfmt
checking for gmsgfmt... (cached) /usr/bin/msgfmt
checking for perl... /usr/bin/perl
checking for perl >= 5.8.1... 5.20.2
checking for XML::Parser... ok
checking for a sed that does not truncate output... /bin/sed
checking for msgmerge... (cached) /usr/bin/msgmerge
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether gcc understands -c and -o together... (cached) yes
checking dependency style of gcc... (cached) gcc3
checking for ar... ar
checking the archiver (ar) interface... ar
checking how to print strings... printf
checking for a sed that does not truncate output... (cached) /bin/sed
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking how to convert i686-pc-linux-gnu file names to i686-pc-linux-gnu format... func_convert_file_noop
checking how to convert i686-pc-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for a working dd... /bin/dd
checking how to truncate binary pipes... /bin/dd bs=4096 count=1
checking for mt... mt
checking if mt is a manifest tool... no
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking for shl_load... no
checking for shl_load in -ldld... no
checking for dlopen... no
checking for dlopen in -ldl... yes
checking whether a program can dlopen itself... yes
checking whether a statically linked program can dlopen itself... no
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... no
checking for windres... no
checking for library containing strerror... none required
checking for inline... inline
checking for gdk-pixbuf-csource... no
checking for svn tree or exported source tree... ./configure: line 15849: svnversion: command not found
exported
checking for xmlcatalog... no
configure: WARNING: Install the xmlcatalog application, which is delivered with the GNOME xml-library.
checking for update-desktop-database... /usr/bin/update-desktop-database
checking for update-mime-database... /usr/bin/update-mime-database
checking for system XML catalog... not found
configure: The given systems XML catalog ${prefix}/etc/xml/catalog seems to be unavailable.
configure: We will not try to update it after installation.
checking for ANSI C header files... (cached) yes
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for optional libenchant development files... checking enchant.h usability... no
checking enchant.h presence... no
checking for enchant.h... no
checking enchant/enchant.h usability... no
checking enchant/enchant.h presence... no
checking for enchant/enchant.h... no
configure: checking for required development files
checking for BLUEFISH_REQUIRED... no
configure: error: Package requirements (gtk+-3.0 gdk-3.0 glib-2.0 >= 2.24 gmodule-2.0 >= 2.24 gobject-2.0 pango gdk-pixbuf-2.0 gio-unix-2.0 >= 2.24 gthread-2.0 libxml-2.0) were not met:
No package 'gtk+-3.0' found
No package 'gdk-3.0' found
No package 'glib-2.0' found
No package 'gmodule-2.0' found
No package 'gobject-2.0' found
No package 'pango' found
No package 'gdk-pixbuf-2.0' found
No package 'gio-unix-2.0' found
No package 'gthread-2.0' found
No package 'libxml-2.0' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables BLUEFISH_REQUIRED_CFLAGS
and BLUEFISH_REQUIRED_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
Hélas la configuration a échoué, comment resoudre le problème ?
D’avance merci.
