Débian reste figé après au démarrage
Je viens d’installer Debian et j’ai un problème au démarrage.
Après avoir inscrit mon nom d’utilisateur et mon mot de passe, il reste figé sur la page de démarrage Debian. Parfois, il démarre aussi normalement.
Voici les erreurs que j’ai pu trouver avec la commande journalct -xb
kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
kernel: TAA CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln//tsx_async_abort.html for more details.
kernel:  #5 #6 #7
kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
kernel: r8169 0000:03:00.1: can't disable ASPM; OS doesn't have ASPM control
kernel: usb: port power management may be unreliable
MXM: GUID detected in BIOS
kernel: ACPI Warning: \_SB.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200925/nsarguments-61)
kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20200925/nsargumentrequires [Package] (20200925/nsarguments-61)
kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 6013d4 [ IBUS ]
systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
kernel: at24 0-0050: supply vcc not found, using dummy regulator
kernel: iwlwifi 0000:04:00.0: firmware: failed to load iwl-debug-yoyo.bin (-2)
kernel: firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
dhclient[1788]: Failed to get interface index: No such device
dhclient[1788]: If you think you have received this message due to a bug rather
dhclient[1788]: than a configuration issue please read the section on submitting
dhclient[1788]: bugs on either our web page at www.isc.org or in the README file
dhclient[1788]: before submitting a bug.  These pages explain the proper
dhclient[1788]: process and the information we find helpful for debugging.
hclient[1788]: exiting.
systemd[1]: Failed to start Raise network interfaces.
kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
bluetoothd[1715]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
bluetoothd[1715]: sap-server: Operation not permitted (1)
kernel: nouveau 0000:01:00.0: bus: MMIO read of 00000000 FAULT at 619444 [ IBUS ]
pipewire[1897]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could not get PID of name 'org.freedesktop.portal.Desktop': no such name
lightdm[1956]: gkr-pam: unable to locate daemon control file
lightdm[1956]: Error getting user list from org.freedesktop.Accounts: GDBus.Error:org.freedesktop.DBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.Accounts was not provided by any .service files
pulseaudio[1898]: Error opening PCM device front:0: Aucun fichier ou dossier de ce type
pipewire[2263]: Failed to receive portal pid: org.freedesktop.DBus.Error.NameHasNoOwner: Could not get PID of name 'org.freedesktop.portal.Desktop': no such name
xdg-desktop-por[2457]: Theme parsing error: gtk.css:5597:11: Not using units is deprecated. Assuming 'px'.
xdg-desktop-por[2457]: Theme parsing error: gtk.css:5597:14: '0' is not a valid color name
xdg-desktop-por[2457]: Theme parsing error: gtk.css:5831:14: '202020' is not a valid color name
xdg-desktop-por[2457]: Theme parsing error: gtk.css:5846:20: Junk at end of value for border-width
xdg-desktop-por[2457]: Theme parsing error: gtk.css:5871:20: Junk at end of value for border-width
xdg-desktop-por[2457]: Theme parsing error: gtk.css:5898:20: Junk at end of value for border-width
xdg-desktop-por[2432]: Failed to get application states: GDBus.Error:org.freedesktop.portal.Error.Failed : Could not get window list
Merci.
Quelle est ta config et ton schéma de partitionnement stp?
Merci pour ta réponse.
lsb_release -a
No LSB modules are available.
Distributor ID:	Debian
Description:	Debian GNU/Linux 11 (bullseye)
Release:	11
Codename:	bullseye
fdisk -l
Disque /dev/sdb : 465,76 GiB, 500107862016 octets, 976773168 secteurs
Modèle de disque : ST500LT012-1DG14
Taille de secteur (logique / physique) : 512 octets / 4096 octets
taille d'E/S (minimale / optimale) : 4096 octets / 4096 octets
Identifiant de disque : DBC46EF2-21AF-416A-BB2F-3166B855CA26
Périphérique Début       Fin  Secteurs Taille Type
/dev/sdb1     2048 976771071 976769024 465,8G Données de base Microsoft
Disque /dev/sda : 238,47 GiB, 256060514304 octets, 500118192 secteurs
Modèle de disque : S11-256G-PHISON-
Type d'étiquette de disque : dos
Identifiant de disque : 0xb74bfc30
Périphérique Amorçage    Début       Fin  Secteurs Taille Id Type
/dev/sda1    *            2048  58593279  58591232  27,9G 83 Linux
/dev/sda2             58595326 500117503 441522178 210,5G  5 Étendue
/dev/sda5             58595328  60594175   1998848   976M 82 partition d'échange
/dev/sda6             60596224 500117503 439521280 209,6G 83 Linux
Au vu de certaines erreurs je pense qu’il faut activer les dépôts non-free et installer au moins les paquets firmware-linux, firmware-realtek
De mon côté, je me demande si c’est une install en uefi ou à l’ancienne. Je ne vois pas la toute petite partoche /efi en 1er. Je conseille l’install en uefi (réglages dans l’uefi justement, plus le bios: secure boot désactivé mais csm aussi)
Et la /swap est ridiculement petite: 8Go a minima, 64Go max c’est une bonne fourchette je pense, pas 976Mo.
Je suis d’accord pour les firmwares,l’iso netinstall avec firmwares est ici avec les shasums: Index of /cdimage/unofficial/non-free/cd-including-firmware/current/amd64/iso-cd
Et pour les pc qu’on voit normaux mais qui peuvent être exotiques (amorçage seulement en 32bits mais os possible en 64bits - c’est du vécu): Index of /cdimage/unofficial/non-free/cd-including-firmware/current/multi-arch/iso-cd
Le mieux est de sauvegarder tes données sur clé usb p.ex. et de repartir sur une install propre avec avant tout un uefi bien configuré et un partitionnement manuel lors de l’install, dans l’ordre de création:
  • table de partition gpt
  • partition de 128Mo en partition système efi (début) (oui c’est énorme mais j’ai eu des soucis avec des plus petites à install identique)
  • partition de 32 voire 64Go en ext4 début pour point de montage /
  • partition de allez 16Go fin pour /swap
  • le reste en ext4 pour /home
Si le disque est un ssd, activer les options discard, noatime, nodiratime pour les partitions ext4.
En fin d’install après reboot et 1re connexion, faire un # dmesg | grep 'firmware' pour lister les éventuels firmwares qui ne seraient pas dispo dans l’iso. On peut les choper dans les paquets de Sid et les installer à la main en décompressant lesdits paquets et en mettant les firmwares dans les bons dossiers de l’os (habituellement /etc/firmware)
Merci pour vos réponses.
J’ai vérifié dans le Boot pour l’UEFI et il est désactivé. Donc, Debian doit s’être installé à l’ancienne.
Et si, au lieu de tout réinstaller, je redimensionne les partitions avec Gparted et que j’active les dépôts non-free (+intallation des paquets firmware-linux et firmware-realtek), cela fonctionnerait-il?
Tu auras des problèmes de boot et un système boiteux mais c’est pas impossible.
En toute logique ça prends pas énormément de temps une install, ça en vaut vraiment la peine. De plus, l’uefi, c’est l’avenir au présent qui date de quelques années déjà :slightly_smiling_face: (roh je l’aime bien celle-là!)
De plus, csm et uefi sont en général incompatibles. En outre, en mode csm il se peut que tu perdes des fonctions système.
OK. Je vais le réinstaller.
Une dernière question:
C’est quoi la partition gpt? Si je choisis la patition gpt, ai-je encore besoin de partition logique ou primaire?
Merci.
Gpt c’est les nouvelles tables de partitions, par rapport à l’ancien mbr. Donc plus besoin de partitions primaires ou logiques. Potentiellement du lvm en cas de fusion de volumes sur des disques différents (en gros, groupir un hdd 500Go avec un hdd 250Go pour avoir un volume de 750Go à découper comme tu veux) mais je pense pas que tu en aies besoin.
Vu sur un site:
OK. Merci pour ton aide. Je vais le réinstaller cette semaine.
Bonne soirée.
Bonjour, j’ai eu un problème similaire. Cela venait de la place insuffisante qu’il me restait sur le disque qui était insuffisante: avant de tout réinstaller commence par faire des backups de tes documents et fait de la place sur les disques. Depuis mon OS redémarre bien.
OK. Merci
Bonsoir à tous,
J’ai réinstallé Debian comme recommandé mais le problème persiste. De temps en temps Débian reste figé au démarrage (après avoir inscrit mon nom d’utilisateur et mon mot de passe) ou il met quelques minutes à afficher le bureau.
Parfois il y a aussi un message d’erreur lorsque je boote (donc avant d’inscrire mon identifiant et mon mot de passe):
A start job is running for hostname Service....
Failed to start Hostname Service
J’ai vérifié le contenu des fichiers /etc/hostname et /etc/hosts et ils ont tous les deux le même hostname.
Je vous donne quelques informations sur ma machine:
lsb_release -a
Release:	11
Codename:	bullseye
fdisk -l
Identifiant de disque : 8348858D-1E3A-41A1-912E-72F268C397EF
/dev/sda1         2048    249855    247808   121M Système EFI
/dev/sda2       249856  78374911  78125056  37,3G Système de fichiers Linux
/dev/sda3    468869120 500117503  31248384  14,9G Partition d'échange Linux
/dev/sda4     78374912 468869119 390494208 186,2G Système de fichiers Linux
Les entrées de la table de partitions ne sont pas dans l'ordre du disque.
Avez-vous une idée du problème?
Merci.
Bonsoir à tous,
J’ai trouvé. Le problème venait du Bluetooth.
Au démarrage, avant ce message d’erreur
J’avais cet autre message d’erreur:
Bluetooth.hclo:unexpected event for opcode oxfc2f
J’ai modifié le fichier /etc/bluetooth/main.conf et j’ai changé AutoEnable=false.
Voilà, plus de problème.
Merci encore à DarkGagan pour le partitionnement manuel et les astuces noatime,…
