Débit réseau très faible
j’ai un débit réseau très faible de l’ordre de 1 à 10 Mo/s.
Aussi, j’ai l’impression que ma configuration réseau a été modifiée lors de la mise à jour majeure vers Debian 12.0.
Mon fichier /etc/network/interfaces est vide alors que /etc/network/interfaces.saves est le suivant :
$ cat /etc/network/interfaces.save
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
auto lo
iface lo inet loopback
# This is an autoconfigured IPv6 interface
iface eth0 inet6 auto
# The eth0 network interface
auto eth0
allow-hotplug eth0
iface eth0 inet static
  address 192.168.0.10
  netmask 255.255.255.0
  broadcast 192.168.0.255
  network 192.168.0.0
  gateway 192.168.0.254
  dns-nameservers 192.168.0.254
Ensuite, j’obtiens :
$ sudo ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        ether aa:2c:66:0f:de:e5  txqueuelen 1000  (Ethernet)
        RX packets 3479586  bytes 259714617 (247.6 MiB)
        RX errors 0  dropped 1  overruns 0  frame 0
        TX packets 273  bytes 11466 (11.1 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Boucle locale)
        RX packets 127550  bytes 21493252 (20.4 MiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 127550  bytes 21493252 (20.4 MiB)
pan1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 10.226.102.1  netmask 255.255.255.0  broadcast 0.0.0.0
        inet6 fe80::ac0a:51ff:fe58:f3ca  prefixlen 64  scopeid 0x20<link>
        ether d2:da:3e:7a:92:4c  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 1  bytes 110 (110.0 B)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.0.42  netmask 255.255.255.0  broadcast 192.168.0.255
        inet6 fe80::5635:30ff:fe87:8035  prefixlen 64  scopeid 0x20<link>
        inet6 2a01:e0a:208:ddc0:5635:30ff:fe87:8035  prefixlen 64  scopeid 0x0<global>
        ether 54:35:30:87:80:35  txqueuelen 1000  (Ethernet)
        RX packets 51636080  bytes 6585877446 (6.1 GiB)
        TX packets 105211996  bytes 153980483584 (143.4 GiB)
La partie réseau, c’est pas mon fort. Merci de vos retours. :slight_smile:
le DNS n’a pas besoin d’être dans ce fichier, /etc/resolv.conf est fait pour ça.
plus besoin de mettre l’entrée network et netmask, il suffit de mettre:
address 192.168.0.10/24
Quand tu as mis à jour, il aurait du y avoir un message te disant que le paquet en train d’être mis à jour proposait un fichier de conf différent du tiens. Il faut dire N en réponse pour garder le tien.
Remplace le interfaces par le interfaces.save.
