tout d’abord voici ma config:
- debian, sarge 3.1
- noyau 2.6.8-2-686x
Je souhaite installer mdbtools sur ma machine.
J’ai récupérer le fichier “mdbtools-0.6pre1.tar.gz” et je l’ai décompressé.
Ensuite je fais “./configure” , cependant j’ai une erreur :
checking for pkg-config... /usr/local/bin/pkg-config
checking for GLIB - version >= 2.0.0...
*** 'pkg-config --modversion glib-2.0' returned 2.12.0, but GLIB (2.6.4)
*** was found! If pkg-config was correct, then it is best
*** to remove the old version of GLib. You may also be able to fix the error
*** by modifying your LD_LIBRARY_PATH enviroment variable, or by editing
*** /etc/ld.so.conf. Make sure you have run ldconfig if that is
*** required on your system.
*** If pkg-config was wrong, set the environment variable PKG_CONFIG_PATH
*** to point to the correct configuration files
no
Comment faire pour désintaller la Glib version 2.6.4 ?
Merci de m’aider
