Bonjour à toute l’équipe.
Ci-joint le dmesg (erreur) et la config sur un xps 9310 avec Bullseye
Je ne suis pas arrivé a corriger ces erreurs …
root@debian:~# dmesg | grep -i error
[ 0.831797] pcieport 10000:e0:06.0: DPC: error containment capabilities: Int Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
[ 1.545369] EXT4-fs (nvme0n1p2): re-mounted. Opts: errors=remount-ro. Quota mode: none.
[ 2.084383] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-67.ucode failed with error -2
[ 2.084422] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-66.ucode failed with error -2
[ 2.084451] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-65.ucode failed with error -2
[ 2.084480] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-64.ucode failed with error -2
[ 2.084508] iwlwifi 0000:00:14.3: Direct firmware load for iwlwifi-QuZ-a0-hr-b0-63.ucode failed with error -2
[ 3.599767] ioremap error for 0x62d03000-0x62d04000, requested 0x2, got 0x0
[ 3.599820] ucsi_acpi: probe of USBC000:00 failed with error -12
[ 9.376583] i915 0000:00:02.0: [drm] *ERROR* mstb 00000000fee64aa3 port 1: DPCD read on addr 0x4b0 for 1 bytes NAKed
[ 10.002320] i915 0000:00:02.0: [drm] *ERROR* mstb 00000000fee64aa3 port 3: DPCD read on addr 0x4b0 for 1 bytes NAKed
Dois-je m’en soucier ?
firmware: failed to load i915/tgl_dmc_ver2_12.bin
résolu récuperer dans le firmware-misc-nonfree (20210818-1) (bookworm)
root@debian:~# uname -a
Linux debian 5.16.0-0.bpo.4-amd64 #1 SMP PREEMPT Debian 5.16.12-1~bpo11+1 (2022-03-08) x86_64 GNU/Linux
root@debian:~# inxi -F
System: Host: debian Kernel: 5.16.0-0.bpo.4-amd64 x86_64 bits: 64 Console: tty 0 Distro: Debian GNU/Linux 11 (bullseye)
Machine: Type: Laptop System: Dell product: XPS 13 9310 v: N/A serial: 1QTP3J3
Mobo: Dell model: 07P9Y7 v: A00 serial: /1QTP3J3/CNCMK001AJ00E9/ UEFI: Dell v: 3.6.0 date: 03/17/2022
Battery: ID-1: BAT0 charge: 51.0 Wh condition: 51.0/51.0 Wh (100%)
CPU: Info: Quad Core model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP L2 cache: 12 MiB
Speed: 533 MHz min/max: 400/4800 MHz Core speeds (MHz): 1: 533 2: 507 3: 548 4: 897 5: 542 6: 517 7: 566 8: 914
Graphics: Device-1: Intel TigerLake GT2 [Iris Xe Graphics] driver: i915 v: kernel
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
Display: server: X.org 1.20.11 driver: loaded: i915 note: n/a (using device driver) tty: 282x76
Message: Advanced graphics data unavailable in console for root.
Audio: Device-1: Intel Tiger Lake-LP Smart Sound Audio driver: sof-audio-pci-intel-tgl
Sound Server: ALSA v: k5.16.0-0.bpo.4-amd64
Network: Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi
IF: wlp0s20f3 state: up mac: ac:74:b1:8b:32:7e
Device-2: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
IF: enxa02919a5a4b0 state: down mac: a0:29:19:a5:a4:b0
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Bluetooth: Device-1: Intel type: USB driver: btusb
Report: ID: hci0 state: down address: AC:74:B1:8B:32:82
RAID: Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
Drives: Local Storage: total: 476.94 GiB used: 228.88 GiB (48.0%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN730 NVMe WDC 512GB size: 476.94 GiB
Partition: ID-1: / size: 466.95 GiB used: 228.79 GiB (49.0%) fs: ext4 dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 90.6 MiB (17.7%) fs: vfat dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 976 MiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p3
Sensors: System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Info: Processes: 255 Uptime: 30m Memory: 15.35 GiB used: 2.53 GiB (16.5%) Init: systemd runlevel: 5 Shell: Bash
inxi: 3.3.01
Edit de modération : mise en forme
