Hello
il y a un bug des options de dpkg-reconfigure xserver-xorg
son indisponible.
1.la résolution tous ce qui touche a l’écran
2.les caractère son pas reconnu sa deviens illisible.
3.- les modules son indisponible
il me semblait avoir vu un poste à ce sujet mai je ne suis pas parvenu à mettre le mulo sure le topic
comment je fait pour résoudre le problème ??
voici ce que j’obtien:
# xorg.conf (X.Org X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the xorg.conf manual page.
# (Type "man xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
# sudo dpkg-reconfigure -phigh xserver-xorg
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "ch"
Option "XkbVariant" "fr"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
EndSection
Section "Device"
Identifier "Configured Video Device"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
EndSection
Merci d’avance
