Voila j’ai une carte graphique Nvidia Geforce 9600GTX et j’ai installé debian 6 (sid) très récemment, le soucis c’est qu’avec les paquets nouveau (libnouveau-1a et xserver-xorg-video-nouveau) je n’ai plus d’interface graphique. Notamment lorsque je souhaite lancer gdm3 (/etc/init.d/gdm3 start) j’ai un “failed”.
[quote]VGA compatible controller: nVidia Corporation G94 [GeForce 9600 GT] (rev a1) (prog-if 00 [VGA controller])
Subsystem: XFX Pine Group Inc. Device 2362
Flags: bus master, fast devsel, latency 0, IRQ 11
Memory at fd000000 (32-bit, non-prefetchable) [size=16M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
Memory at fa000000 (64-bit, non-prefetchable) [size=32M]
I/O ports at cc00 [size=28]
Expansion ROM at fe880000 [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100] Virtual Channel[/quote]
Je ne souhaite pas utiliser le driver propriétaire.
Le fichier /var/log/Xorg.0.log :
[quote][ 4269.694] (WW) Warning, couldn’t open module nvidia
[ 4269.694] (II) UnloadModule: “nvidia”
[ 4269.694] (II) Unloading nvidia
[ 4269.694] (EE) Failed to load module “nvidia” (module does not exist, 0)
[ 4269.694] (EE) No drivers available.
[ 4269.694]
Fatal server error:
[ 4269.694] no screens found
[ 4269.694]
Please consult the The X.Org Foundation support
at wiki.x.org
for help.
[ 4269.694] Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 4269.694]
Voici la liste des paquets xserver installé :
[quote]ii x11-xserver-utils 7.6+3 X server utilities
ii xserver-common 2:1.10.2.902-1 common files used by various X servers
ii xserver-xephyr 2:1.10.2.902-1 nested X server
ii xserver-xorg 1:7.6+7 X.Org X server
ii xserver-xorg-core 2:1.10.2.902-1 Xorg X server - core server
ii xserver-xorg-input-all 1:7.6+7 X.Org X server – input driver metapackage
ii xserver-xorg-input-evdev 1:2.6.0-2+b1 X.Org X server – evdev input driver
ii xserver-xorg-input-synaptics 1.4.1-1 Synaptics TouchPad driver for X.Org server
ii xserver-xorg-input-wacom 0.10.10+20110203-1+b1 X.Org X server – Wacom input driver
ii xserver-xorg-video-all 1:7.6+7 X.Org X server – output driver metapackage
ii xserver-xorg-video-apm 1:1.2.3-2+b1 X.Org X server – APM display driver
ii xserver-xorg-video-ark 1:0.7.3-2+b1 X.Org X server – ark display driver
ii xserver-xorg-video-ati 1:6.14.2-1 X.Org X server – AMD/ATI display driver wrapper
ii xserver-xorg-video-chips 1:1.2.4-1+b1 X.Org X server – Chips display driver
ii xserver-xorg-video-cirrus 1:1.3.2-4+b1 X.Org X server – Cirrus display driver
ii xserver-xorg-video-fbdev 1:0.4.2-4+b1 X.Org X server – fbdev display driver
ii xserver-xorg-video-i128 1:1.3.4-2+b1 X.Org X server – i128 display driver
ii xserver-xorg-video-intel 2:2.15.0-3 X.Org X server – Intel i8xx, i9xx display driver
ii xserver-xorg-video-mach64 6.9.0-1 X.Org X server – ATI Mach64 display driver
ii xserver-xorg-video-mga 1:1.4.13.dfsg-3+b1 X.Org X server – MGA display driver
ii xserver-xorg-video-neomagic 1:1.2.5-2+b1 X.Org X server – Neomagic display driver
ii xserver-xorg-video-nouveau 1:0.0.16+git20110411+8378443-1+exp1 X.Org X server – Nouveau display driver (experimental)
ii xserver-xorg-video-openchrome 1:0.2.904+svn920-1 X.Org X server – VIA display driver
ii xserver-xorg-video-r128 6.8.1-5+b1 X.Org X server – ATI r128 display driver
ii xserver-xorg-video-radeon 1:6.14.2-1 X.Org X server – AMD/ATI Radeon display driver
ii xserver-xorg-video-rendition 1:4.2.4-2+b1 X.Org X server – Rendition display driver
ii xserver-xorg-video-s3 1:0.6.3-4+b1 X.Org X server – legacy S3 display driver
ii xserver-xorg-video-s3virge 1:1.10.4-4+b1 X.Org X server – S3 ViRGE display driver
ii xserver-xorg-video-savage 1:2.3.2-3+b1 X.Org X server – Savage display driver
ii xserver-xorg-video-siliconmotion 1:1.7.5-1+b1 X.Org X server – SiliconMotion display driver
ii xserver-xorg-video-sis 1:0.10.3-3+b1 X.Org X server – SiS display driver
ii xserver-xorg-video-sisusb 1:0.9.4-2+b1 X.Org X server – SiS USB display driver
ii xserver-xorg-video-tdfx 1:1.4.3-4+b1 X.Org X server – tdfx display driver
ii xserver-xorg-video-trident 1:1.3.4-2+b1 X.Org X server – Trident display driver
ii xserver-xorg-video-tseng 1:1.2.4-2+b1 X.Org X server – Tseng display driver
ii xserver-xorg-video-vesa 1:2.3.0-7 X.Org X server – VESA display driver
ii xserver-xorg-video-vmware 1:11.0.3-2+b1 X.Org X server – VMware display driver
ii xserver-xorg-video-voodoo 1:1.2.4-2+b1 X.Org X server – Voodoo display driver
Liste des paquets gnome
En sachant qu’au démarrage de l’ordinateur j’ai ce type d’erreur :
J’ai également une fatal error sur le kernel (3.0.0) mais je n’arrive pas à trouver le fichier de log qui contient les lignes qui s’affiche au démarrage du PC.
Je remercie d’avance tout ceux qui ce pencherons sur mon problème
[quote]# evbug is a debug tool and should be loaded explicitly
blacklist evbug
# these drivers are very simple, the HID drivers are usually preferred
blacklist usbmouse
blacklist usbkbd
# replaced by e100
blacklist eepro100
# replaced by tulip
blacklist de4x5
# replaced by tmscsim
blacklist am53c974
# these watchdog drivers break some systems
blacklist iTCO_wdt
Pas de nouveau ici... :frowning:
j'ai renommé les fichiers.
EDIT1: 2 fichiers nvidia dans modprob.d/ qui contenait "blacklist nouveau", j'ai supprimé les fichiers.
[quote]nvidia-installer-disable-nouveau.conf
nvidia-kernel-common.conf[/quote]
/etc/init.d/gdm3 start fonctionne dorénavant, je suis actuellement en SSH au taff' je ne peux donc pas vérifier avant ce soir si l'interface graphique est bien chargé.
Je ne manquerais pas de vous tenir informé :wink:
Merci etxeberrizahar :wink:
blacklist evbug
blacklist usbmouse
blacklist usbkbd
replaced by e100
blacklist eepro100
replaced by tulip
blacklist de4x5
replaced by tmscsim
blacklist am53c974
blacklist iTCO_wdt
Pas de nouveau ici…
j’ai renommé les fichiers.
EDIT1: 2 fichiers nvidia dans modprob.d/ qui contenait “blacklist nouveau”, j’ai supprimé les fichiers.
/etc/init.d/gdm3 start fonctionne dorénavant, je suis actuellement en SSH au taff’ je ne peux donc pas vérifier avant ce soir si l’interface graphique est bien chargé.
Impec j’ai de nouveau mon interface graphique mais la carte graphique est mal géré car j’ai son ventilateur qui n’est pas régulé et qui tourne à fond ! (alors qu’avec le driver propriétaire, le ventilateur tourne sans faire de bruit…)
de + gnome est tout pété… heuu comment on le répare ? ^^
Moi non plus, mais…[quote=“AnGe7”]Impec j’ai de nouveau mon interface graphique mais la carte graphique est mal géré car j’ai son ventilateur qui n’est pas régulé et qui tourne à fond ! (alors qu’avec le driver propriétaire, le ventilateur tourne sans faire de bruit…)[/quote]
On va dire que ce sujet est résolu (j’ai vu que tu avais ouvert un autre sujet pour ton Gnome3) ?
C’est résolus en partie, le driver nouveau tourne mais mon ventilateur de ma carte graphique n’est pas régulé et tourne en permanence à sa vitesse maximum (ce n’est pas le cas avec le driver proprio).
Je ne sais pas ce que vous voulez comme autre information ?
Paquet “mesa” :
[quote]un glx-alternative-mesa (aucune description n’est disponible)
ii libgl1-mesa-dri 7.10.3-3 free implementation of the OpenGL API – DRI modules
un libgl1-mesa-dri-experimental (aucune description n’est disponible)
ii libgl1-mesa-glx 7.10.3-3 free implementation of the OpenGL API – GLX runtime
un libgl1-mesa-swx11 (aucune description n’est disponible)
ii libglu1-mesa 7.10.3-3 The OpenGL utility library (GLU)
ii mesa-utils 8.0.1-2 Miscellaneous Mesa GL utilities
un mesag3 (aucune description n’est disponible)
un xlibmesa-dri (aucune description n’est disponible)
un xlibmesa3 (aucune description n’est disponible)
Mon PC :
carte mère :
[quote]description: Carte mère
produit: P5E-V HDMI
fabriquant: ASUSTeK Computer INC.
identifiant matériel: 0
version: Rev 1.xx
numéro de série: MS1C7CBA1Q00280
emplacement: To Be Filled By O.E.M.
Processeur :
[quote] description: CPU
produit: Intel® Core™2 Duo CPU E8400 @ 3.00GHz
fabriquant: Intel Corp.
identifiant matériel: 4
information bus: cpu@0
version: Intel® Core™2 Duo CPU E8400 @ 3.00GHz
numéro de série: To Be Filled By O.E.M.
emplacement: LGA775
taille: 1998MHz
capacité: 3800MHz
bits: 64 bits
horloge: 333MHz
fonctionnalités: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx f$
Mémoire :
[quote] *-memory
description: Mémoire Système
identifiant matériel: 3b
emplacement: Carte mère
taille: 4GiB
