Je n’arrive pas à envoyer un programme , par exemple abiword ou gnumeric, à un tag définis
Je voudrais donc envoyer ces programmes dans le tag “bureautique” que j’ai créé , j’y arrive pour “surf” associé au raccourcis alt+s, ça m’envoit surf au tag “web”
Voici la partie du config.h concerné :
[code]/* tagging */
static const char *tags[] = { “term”, “web”, “p2p”, “bureautique”, “5”, “6”, “7”, “8”, “9” };
static const Rule rules[] = {
/* class instance title tags mask isfloating monitor */
{ “Gimp”, NULL, NULL, 0, True, -1 },
{ “surf”, NULL, NULL, 1 << 1, False, -1 },
{ “MPlayer”, NULL, NULL, 0, True, -1 },
{ “gnumeric”, NULL, NULL, 1 << 3, False, -1 },
{ “abiword”, NULL, NULL, 1 << 3, False, -1 },
/* layout(s) /
static const float mfact = 0.62; / factor of master area size [0.05…0.95] /
static const Bool resizehints = False; / True means respect size hints in tiled resizals */
static const Layout layouts[] = {
/* symbol arrange function /
{ “-|=”, tile }, / first entry is default /
{ “-|-”, NULL }, / no layout function means floating behavior */
{ “[M]”, monocle },
/* key definitions */
#define MODKEY Mod1Mask
#define TAGKEYS(KEY,TAG)
{ MODKEY, KEY, view, {.ui = 1 << TAG} },
{ MODKEY|ControlMask, KEY, toggleview, {.ui = 1 << TAG} },
{ MODKEY|ShiftMask, KEY, tag, {.ui = 1 << TAG} },
{ MODKEY|ControlMask|ShiftMask, KEY, toggletag, {.ui = 1 << TAG} },
/* helper for spawning shell commands in the pre dwm-5.0 fashion /
#define SHCMD(cmd) { .v = (const char[]){ “/bin/sh”, “-c”, cmd, NULL } }
/* commands */
static const char *dmenucmd[] = { “dmenu_run”, “-fn”, font, “-nb”, normbgcolor, “-nf”, normfgcolor, “-sb”, selbgcolor, “-sf”, selfgcolor, NULL };
static const char *rxvtcmd[] = { “/bin/zsh”, “-c”, “urxvt -e dvtm”, NULL };
static const char *surfcmd[] = { “surf” , NULL };
static const char *gnumericcmd[] = { “/usr/bin/gnumeric” , NULL };
static const char *abiwordcmd[] = { “/usr/bin/abiword” , NULL };
static Key keys[] = {
/* modifier key function argument */
{ MODKEY, XK_p, spawn, {.v = dmenucmd } },
{ MODKEY|ShiftMask, XK_Return, spawn, {.v = rxvtcmd } },
{ MODKEY, XK_s, spawn, {.v = surfcmd } },
{ MODKEY, XK_g, spawn, {.v = gnumericcmd }},
{ MODKEY, XK_a, spawn, {.v = abiwordcmd }},
{ MODKEY, XK_b, togglebar, {0} },
{ MODKEY, XK_j, focusstack, {.i = +1 } },
{ MODKEY, XK_k, focusstack, {.i = -1 } },
{ MODKEY, XK_h, setmfact, {.f = -0.05} },
{ MODKEY, XK_l, setmfact, {.f = +0.05} },
{ MODKEY, XK_Return, zoom, {0} },
{ MODKEY, XK_Tab, view, {0} },
{ MODKEY|ShiftMask, XK_c, killclient, {0} },
{ MODKEY, XK_t, setlayout, {.v = &layouts[0]} },
{ MODKEY, XK_f, setlayout, {.v = &layouts[1]} },
{ MODKEY, XK_m, setlayout, {.v = &layouts[2]} },
{ MODKEY, XK_space, setlayout, {0} },
{ MODKEY|ShiftMask, XK_space, togglefloating, {0} },
{ MODKEY, XK_0, view, {.ui = ~0 } },
{ MODKEY|ShiftMask, XK_0, tag, {.ui = ~0 } },
{ MODKEY, XK_comma, focusmon, {.i = -1 } },
{ MODKEY, XK_period, focusmon, {.i = +1 } },
{ MODKEY|ShiftMask, XK_comma, tagmon, {.i = -1 } },
{ MODKEY|ShiftMask, XK_period, tagmon, {.i = +1 } },
TAGKEYS( XK_1, 0)
TAGKEYS( XK_2, 1)
TAGKEYS( XK_3, 2)
TAGKEYS( XK_4, 3)
TAGKEYS( XK_5, 4)
TAGKEYS( XK_6, 5)
TAGKEYS( XK_7, 6)
TAGKEYS( XK_8, 7)
TAGKEYS( XK_9, 8)
{ MODKEY|ShiftMask, XK_q, quit, {0} },
};[/code]
J’ai lu les explications concernant les tags sur le site suckless mais je ne comprends pas pourquoi cela ne fonctionne pas pour abiword et gnumeric
Merci!!
